02-13-2020, 06:46 | #1 (permalink) |
No Life Poster Join Date: Apr 2010 Location: lagos nigeria
Member: 1278793 Status: Offline Thanks Meter: 68 | problem flashing nokia150 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.19 Operation : Identify [ v1.19 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM330) MODE : NOKIA USB SERIAL PORT : 330 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : FFDDC69C3D61261FB5503999B65FB110 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NEMO61D.12.03.11.p1 BOOT : SWR : 12.03.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : NEMO61D.12.03.11.p1 FLASH : 00C2 : 0025 : 0036 : 0000 PRDC : 059Z0X8 IMEI[1] : 354200104429509 NCK : 20 digits PROV : 24407000 Saved as : 354200104429509.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:08:41 Reconnect Power/Cable! Open VPLfile : RM-1190_059Z0X8_50.00.11.vpl Description : RM-1190 IC DeviceType : RM-1190 ProductCode : 059Z0X8 SoftwareVer : 50.00.11 PPM LangPack : [1] : Arabic (Saudi Arabia) [2] : French (France) [3] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.19 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM330) MODE : NOKIA USB SERIAL PORT : 330 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : FFDDC69C3D61261FB5503999B65FB110 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NEMO61D.12.03.11.p1 BOOT : SWR : 12.03.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : NEMO61D.12.03.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 50.00.11 [RM-1190] DEV SoftwareVersion : 12.03.11 SWInfo compare result : DEVICE SW ( Major version ) is LOWER, than in VPL! Load FlashSet : MROM : RM-1190_ROM_eMP_50.00.11 LANG : RM-1190_LANG_PACK_ROM_IC_eMP_50.00.11_001 CUST : RM-1190_CUSTPACK_ROM_IC_eMP_50.00.11_001 JUMP : RM-1190_JUMP_TABLE_IC_eMP_50.00.11_001 VIVA : RM-1190_VIVA_eMP_50.00.11 Prepare FlashSet : DCR : RM-1190_ROM_eMP_50.00.11 DataDecryptError ERROR : Wrong Firmware selected! Info : Data processing failed! Select firmware in flashing tab! Reconnect Power/Cable! |
02-13-2020, 09:37 | #2 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Somewhere
Member: 22466 Status: Offline Thanks Meter: 282 | Just flesh 30.00.11 any desired firmware form BEST support (files/ flashfiles / N-150 / RM-1190_HMD /) for ex. RM-1190__059X8W4__30.00.11__NDT_MEA_IK_BLACK_LATIN_NG dont try ver 50 on this phone |
02-13-2020, 12:59 | #3 (permalink) | |
Member: 1278793 Status: Offline Thanks Meter: 68 | Quote:
my mistake phone is nokia 106 ta-1190 i cant find firmware in support | |
