08-19-2016, 14:29 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: BIH,Bratunac
Member: 888715 Status: Offline Thanks Meter: 109 | problem unlock 535 === Main info === NCSD Version : 5.0 Sw Version : 02074.00000.15234.28004 IMEI : 353707072069902 ProductCode : 059W877 ProductCodeB : 059W248 ProductSN : 6776873AB Module Code : 0206285 === HW info === Public ID : 9E302FB4F1EFAF6A9015102C97426A131D42CA6B HW Version : 3000 BT Addr. : A4516FF5732E Wlan Mac : A4516FF5CFDC Battery Level : 68 % === Branding and security info === Operator : SWI-CH SimLock : Locked! SimLock : 2280100000000 Country : Switzerland Operator : Swisscom Branding : RM-1089_1006 Sec. Mode : Restricted Done! [WP8x] : Init TesMode [TSTM] : Use File : RM1089_2074.0000.9651.14234.207.694_enosw-wim-signed_803881.secwim === Base Phone Info Sw Version : 02074.00000.15234.28004 IMEI : 353707072069902 ProductCode : 059W877 Device catched in BOOT mode! Collect Info... === Nokia Flash App info : Protocol Version : 2.34 Protocol Implementation : 2.59 === Phone Initial info : Phone Model ID : Nokia.MSM8212.P6214.1.1 === eMMC info : eMMC Vendor : Samsung eMMC CID : 0015 eMMC Size : 7456 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : BC2353ACA62C327ECCD582A281CA4A5672F35001 === Other info : SD present : False SECWIM : RM1089_2074.0000.9651.14234.207.694_enosw-wim-signed_803881.secwim Sending WIM ... WIM Image sent! Trying init TestMode now... Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Need SDAuth to finish ... Started Connecting to SX4 server... Connection faled: Socket Error # 10060 Connection timed out. SX4 Disconnected SX4 Failed, will retry Auth again ... Started Connecting to SX4 server... Connection faled: Socket Error # 10060 Connection timed out. SX4 Disconnected SDAuth not done! Try make SX4 after 1-2 minute and make "Unlock" again! Error! Check previous error message for more info! WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Need SDAuth to finish ... Started Connecting to SX4 server... Connection faled: Socket Error # 10060 Connection timed out. SX4 Disconnected SX4 Failed, will retry Auth again ... Started Connecting to SX4 server... Connection faled: Socket Error # 10060 Connection timed out. SX4 Disconnected SDAuth not done! Try make SX4 after 1-2 minute and make "Unlock" again! Error! Check previous error message for more info! Set Phone to Normal mode Done Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Phone disconected! Connect phone on selected interface... |
08-19-2016, 18:01 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Hello, - Close [BEST] software - Download latest Configurator software - http://www.infinity-box.com/support/...onfigurator.7z - Start Configurator to update config - Start BEST again Result ? |
08-20-2016, 10:15 | #3 (permalink) |
Member: 888715 Status: Offline Thanks Meter: 109 | Phone found! WP10/WP8x Lumia Phone detected Read info... Ok WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Need SDAuth to finish ... Started Connecting to SX4 server... Connected SX4 enter .. SDAuth Ok! SX4 Disconnected Unlock Done! Wait for phone reboot ... Reboot Ok! txnn broo |
