01-19-2018, 12:06 | #1 (permalink) |
Freak Poster Join Date: Oct 2016 Location: india
Member: 2636476 Status: Offline Thanks Meter: 61 | Nokia 5 TA-1053 flashing failed some one play with this set now set in restart problem then i flash with best now flashing failed and set not pwr on i use support area firmware TA-1053_00WW_ND1_600WW Code: Device Brand : Nokia Device IntName : TA-1053_00WW Device TA-IDxx : TA-1053 Device Manufact.: HMD Global Device Model : ND1 Device CPU : MSM8937 Nokia Model : Nokia 5 CU_SWVer : HMD Global Device Project : 600WW Dev Build Info : TA-1053_00WW-user 7.1.1 NMF26F 00WW_3_32B release-keys Dev CPU : MSM8937 Dev SKU : 600WW SKU Vendor : NOKIA SKU Locale : Worldwide SKU Carier : FIH Generic Load Ok! Code: Operation : Flash [ v1.02 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 430 [MSM8937] ID_BLOCK_S : 88CD357C ID_BLOCK_I : 0004F0E1 ID_BLOCK_L : 303EDBEFF97753DCDD0ACBC54B6ACF45 ID_BLOCK_L : DFE582060AEF0944A625F1288553A28D Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RE1BMB Boot Ok! Flash Chain : 65 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : devcfg.mbn Flashing : devcfg.mbn Flashing : adspso.bin Flashing : sec.dat Flashing : splash.img Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : boot.img Flashing : recovery.img Flashing : ftm_boot.img Flashing : hwconf.cfg Flashing : sysinfo.cfg Flashing : splashm.img Flashing : hidden.img Flashing : cda.img Flashing : persist.img Flashing : misc.img Flashing : mdtp.img Flashing : cmnlib.mbn Flashing : cmnlib.mbn Flashing : cmnlib64.mbn Flashing : cmnlib64.mbn Flashing : keymaster.mbn Flashing : keymaster.mbn Flashing : system.img Flashing : cache.img Flashing : userdata.img Flashing : gpt_backup0.bin ProgStart : Parsed value exceeds size of partition in sectors Flash Error , Prepare data error #0 , Check battery charge! Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! |
01-19-2018, 13:21 | #2 (permalink) |
Member: 2636476 Status: Offline Thanks Meter: 61 | now flash done with cm2 not best but still same restart on android logo and some time show erasing logo and nokia logo then restart Code: Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 430 [MSM8937] ID_BLOCK_S : 88CD357C ID_BLOCK_L : 303EDBEFF97753DCDD0ACBC54B6ACF45 ID_BLOCK_L : DFE582060AEF0944A625F1288553A28D Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RE1BMB Boot Ok! Flash Chain : 65 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : devcfg.mbn Flashing : devcfg.mbn Flashing : adspso.bin Flashing : sec.dat Flashing : splash.img Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : boot.img Flashing : recovery.img Flashing : hwconf.cfg Flashing : sysinfo.cfg Flashing : splashm.img Flashing : hidden.img Flashing : cda.img Flashing : persist.img Flashing : misc.img Flashing : mdtp.img Flashing : cmnlib.mbn Flashing : cmnlib.mbn Flashing : cmnlib64.mbn Flashing : cmnlib64.mbn Flashing : keymaster.mbn Flashing : keymaster.mbn Flashing : system.img Flashing : cache.img Flashing : userdata.img Flashing : gpt_backup0.bin Wipe data ... BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:07:30 Reconnect Power/Cable! |
04-22-2018, 15:59 | #4 (permalink) |
Insane Poster Join Date: Sep 2015 Location: Kuwait
Member: 2453348 Status: Offline Thanks Meter: 14 | i have same problem please help.... Flashing : userdata.img Flashing : gpt_backup0.bin ProgStart : Parsed value exceeds size of partition in sectors Flash Error , Prepare data error #0 , Check battery charge! Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! |
04-23-2018, 08:07 | #6 (permalink) |
Member: 2453348 Status: Offline Thanks Meter: 14 | this is infinity best brother.. Flashing : userdata.img Flashing : gpt_backup0.bin ProgStart : Parsed value exceeds size of partition in sectors Flash Error , Prepare data error #0 , Check battery charge! Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! |
06-29-2018, 11:51 | #7 (permalink) | |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | Quote:
for information for others if them cause the problem use bestnk2 1.3 version for ignore this error | |
05-07-2019, 12:30 | #8 (permalink) | |
Freak Poster Join Date: Dec 2004 Location: Z3x
Member: 98342 Status: Offline Sonork: 1641338 Thanks Meter: 19 | what driver u use ?? Quote:
