06-15-2012, 20:44 | #1 (permalink) |
Junior Member Join Date: Nov 2008
Member: 908789 Status: Offline Thanks Meter: 0 | Restoring NEW rpl from not solving SIMLOCK/SECURITY damage i bought a new RPL from imei-server, my IMEI, SDD KEY and SECURITY status were FINE only SIMLOCK was damaged so... i apply the new RPL ticking only SIMLOCK but no success Code: Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SimLock Data found! SimLock key found! SuperDongle Key found! CMLA key found! WMDRM key found! -> Skip Flash keys Part, for Flash Part use Dead Mode or Fbus Writing SimLock Key... Error! Writing SimLock Data... Error! Product Code Update : 059C426 SDD Key status : SD Data is Ok SimLock status : SimLock Damaged!!!!! :( Security status : Security is Ok Done! so i did a FULL FLASH ERASE, flash to LAST firmware (111.030.0906), mi log was like this Code: Reading Phone Info.... Connected phone - Nokia N8-00 Software ver : V 79_sr1_11w42.5 25-11-11 RM-596 (c) Nokia IMEI : 12345610654321? Ape Ver : 111.030.0609 APE Var : 111.030.0609111.030.0609.32.01111.030.0609.427.02 APE ADSP: 256 DSP Ver : 79_SR1_11w42.5 APE Test: 0.162 PPM : CNT : Product SN : 0 Product code : Long Prod.SN : 0 Hardware info======= HWID : Retu : 35 Tahvo : 00 Batery: 3903 mV APE BT: HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. APE HW: 256 Lock info =========== IMEI : 12345610654321? IMEI spNet : 1A 32 54 16 60 45 23 01 IMEI svNet : 13 32 54 16 60 45 23 31 F3 Unable to read Lock table... :( IMEI DAMAGED!!! CRT308 save skipped... :( SDD key status : Damaged!!!!! SimLock status : Ok Security status : Ok PA_SL phone User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! what can i do is the NEW RPL bad???? |
06-16-2012, 05:57 | #3 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Just write it from DEAD mode, all will be ok. BEST say it in log Press write RPL, select your file, connect powered off phone. |
The Following User Says Thank You to Dzirt For This Useful Post: |
06-17-2012, 10:05 | #8 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Aha, as I think - phone is was locked. Still can't get such phone for tests http://upwap.ru/d/2555135/d05966343a...169779.rpl.rar Try this one as PM write. But BEST do some additional steps automatically, something more needed. Also phone is Telcel locked. As mention. |
06-17-2012, 10:18 | #9 (permalink) | |
Member: 908789 Status: Offline Thanks Meter: 0 | My PM120 is corrupted 0000 i have no back up thas why i bought a NEW RPL Quote:
is this PM120 for telcel??? | |
06-17-2012, 10:55 | #12 (permalink) | |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Then press Read Info. Quote:
2 additional ways it use, if normal failed. But if 2 others failed - it clear all inside, what was changed during it | |
06-17-2012, 11:01 | #14 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Fix security - not a problem. But it useless untill we not fix PM. Before play with it (erase and e.t.c) did you make any backups? PM, flash, rpl? |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
