10-23-2014, 15:00 | #1 (permalink) |
Freak Poster Join Date: Aug 2012 Location: LC
Member: 1793281 Status: Offline Thanks Meter: 167 | RM-1035, Nokia 130 DS - error during RPL backup Code: Core : v1.98 , MTKx FlashEngine : v6.0 Verify files ... MAUI : RM-1035_ROM_eMP_10.02.11 VIVA : RM-1035_VIVA_eMP_10.02.11 LANG : RM-1035_LANG_PACK_ROM_EA_eMP_10.02.11_001 CUST : RM-1035_CUSTPACK_ROM_EA_EURO_PL_eMP_10.02.11_001 JMPT : RM-1035_JUMP_TABLE_EA_EURO_PL_eMP_10.02.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 11 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 5131244A4C91C574CE661B1E65D8D118 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.02.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_10.02.11 SecureDecrypt : RM-1035_VIVA_eMP_10.02.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_EA_eMP_10.02.11_001 SecureDecrypt : RM-1035_CUSTPACK_ROM_EA_EURO_PL_eMP_10.02.11_001 SecureDecrypt : RM-1035_JUMP_TABLE_EA_EURO_PL_eMP_10.02.11_001 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.02.11.p1 === Backup Enabled Reading RPL backup... Read Error : Not allowed === Backup OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x0001C000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_10.02.11 Write : RM-1035_LANG_PACK_ROM_EA_eMP_10.02.11_001 Write : RM-1035_CUSTPACK_ROM_EA_EURO_PL_eMP_10.02.11_001 Write : RM-1035_JUMP_TABLE_EA_EURO_PL_eMP_10.02.11_001 Write : RM-1035_VIVA_eMP_10.02.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_10.02.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_EA_eMP_10.02.11_001 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_EA_EURO_PL_eMP_10.02.11_001 [VERIFY] DONE : RM-1035_JUMP_TABLE_EA_EURO_PL_eMP_10.02.11_001 [VERIFY] DONE : RM-1035_VIVA_eMP_10.02.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:00:59 Reboot phone Ok - > Hint : If phone shows Battery charge icon - press and hold PowerOn button 10 seconds Wait, when phone will be ready ... Reading Phone Info.... Software Info: 10.02.11 00-00-00 RM-1035 IMEI: 355760068182088 Ape Version: NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM version : EA Product code: 059W083 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 10.02.11 00-00-00 RM-1035 IMEI 1 : 355760068182088 IMEI 2 : 355760068182096 XappVer : 000007BC Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : EA CNT : CRYSTAL.10.02.11.p1 Product SN : 363E194AU Product code : 059W083 Base Prd.code: 059W669 Module code : 0206396 Hardware info======= HWID : 3200 LCDVer: TPO Lock info =========== IMEI : 355760068182088 IMEI spNet : 3A 55 67 00 86 81 02 88 Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; SimLock status : Ok Security status : Ok Done! Execuring SelfTests Failed : Camera_If Test Passed : Display Test Passed : Keyboard_Short_Circuit Test Passed : MicroSD_Short_Circuit Test Passed : Sim_Short_Circuit Test Done Code: Software Info: 10.02.11 00-00-00 RM-1035 IMEI: 355760068182088 PPM version : EA Product code: 059W083 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 11 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 5131244A4C91C574CE661B1E65D8D118 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.02.11.p1 BROM/BL stage done Configure RAMINIT Ok Reading flash now ... Done! Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive :) Mobile Info : IMEI : 355760068182088 BBUID : 5131244A4C91C574CE661B1E65D8D118 SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 355760068182088_MTK.mtsec Read Done! Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 11 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 5131244A4C91C574CE661B1E65D8D118 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.02.11.p1 BROM/BL stage done Configure RAMINIT Ok Reading flash now ... Done! Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive :) Mobile Info : IMEI : 355760068182088 BBUID : 5131244A4C91C574CE661B1E65D8D118 SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 355760068182088_MTK_2nd.mtsec Read Done! Connect phone on selected interface... |
10-23-2014, 15:02 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello, it is Nokia/MS fun. They closed all, what possible, but I make workaround for newer phones. It will work separately only, that is one thing, which not possible fix. |
The Following 2 Users Say Thank You to Dzirt For This Useful Post: |
