08-20-2014, 22:11 | #1 (permalink) |
Junior Member Join Date: Jul 2006
Member: 304499 Status: Offline Thanks Meter: 0 | RM-807 Pureview 808 BEST - Phone Startup Failed I have an 808 pureview that is bricked and I am trying to recover, its in the state where it just shows the Nokia logo and then turns back off. It cannot get into test or local mode, and if I try and use the BEST tool to do anything it just shows on the phone, phone start-up failed, contact the retailer I've tried erasing, re-flashing and then I get to restore rpl, and it fails at that point, when the phone reboots, it wont boot into test or local mode, and I get the phone failed to start message on the phone screen again. Any ideas? I think I need the ENO file, but cannot find it on the server. |
08-21-2014, 19:18 | #3 (permalink) |
Member: 304499 Status: Offline Thanks Meter: 0 | Brilliant, Flashed up and got it so it boots to local and test mode, did SSD repair and SX4 Auth. The only thing I have a problem with is it says: CMLA Key status : CMLA key Not exist How do I fix this? |
09-03-2014, 19:08 | #5 (permalink) |
Member: 304499 Status: Offline Thanks Meter: 0 | I still cant get the phone to work, just does a boot loop. ive tried erasing, flash flash eno write pm write rpl repair ssd sx4 auth This is what I get? Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok CMLA Key status : CMLA key Not exist SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! |
09-04-2014, 23:18 | #7 (permalink) |
Member: 304499 Status: Offline Thanks Meter: 0 | Yeah. Without phone connected to BEST, if I press power it shows the Nokia logo, goes off then does the same again. On BEST I can get it to go into local or test mode. But if I try to set to normal it loops again. |
