07-27-2016, 16:34 | #1 (permalink) |
No Life Poster Join Date: May 2015 Age: 40
Member: 2394595 Status: Offline Thanks Meter: 24 | Rm 902 flashing error Selected FlashSettings : Manual File [Ok] : rm902_14.0.6.mcusw.fpsx File [Ok] : rm902_14.0.3_059R6T8_m1_276_03_452451.rofs.fpsx File [Ok] : rm902_14.0.3_059R6T8_m1_276_03_452451.image.fpsx Dead Mode is Selected Waiting for USB device... If PC not detect phone - Insert Cable first, then Insert battery If stuck on boot - remove MicroSD card from phone! --- Press phone's power button or insert cable & charger! --- 1st Boot Done, processing booting now ASIC ID_F : 00000C201610004049B22E09BA32B4E813B6CF00 ASIC ID_E : 00000C2016100040 PUBLIC ID : 45BDB5C0E3405BE449B22E09BA32B4E813B6CF00 XGCHIP ID : 45BDB5C0E3405BE4 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 358139055733681 IMEI [2] : 358139055733699 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\358139055733681_2n d_XG223_CRT.rpl PAPUBkeys : 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E === PPM_ID Check === - > PPM_ID LOWER, THAN IN PHONE!!! - > Find other ID version and try again! - > Stop killing phone, break flashing! === PPM_ID Check === Error During flashing Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - 501 Software ver : V 14.0.6 10-07-14 RM-902 (c) Nokia IMEI : 358139055733681 XappVer : 000008B6 APE Var : 0000000000000000000000000000000000000000 PPM : cb8b851f805fb1b178923536532e44658e1163d8 CNT : Product SN : 19C6A80BH Product code : 059T1W3 Base Prd.code: 059P9V6 Module code : 0205341 Long Prod.SN : 0 Hardware info======= HWID : 1000 Tahvo : RM-902-14.0.6-059T1W3-14.0.2-14.0.2 Battery: 3734 mV CMT BT: 0101-0.1.C LCDVer: TPO Lock info =========== IMEI : 358139055733681 IMEI spNet : 3A 85 31 09 55 37 63 08 IMEI svNet : 33 85 31 09 55 37 63 38 F4 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= Error collect lock info, try again CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL30 (20 digit) phone detected... User code : Crypted MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
07-06-2017, 13:25 | #3 (permalink) |
No Life Poster Join Date: Dec 2005 Location: KARACHI PAKISTAN Age: 45
Member: 207561 Status: Offline Thanks Meter: 820 | Card found: S/N : 4B42917A , v0118 Registered to: bilal483 Connect phone on selected interface... Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual File [Ok] : rm902_14.0.6.mcusw.fpsx File [Ok] : rm902_14.0.3_059R2T6_m1_245_03_452443.rofs.fpsx File [Ok] : rm902_14.0.3_059R2T6_m1_245_03_452443.image.fpsx Dead Mode is Selected Waiting for USB device... If PC not detect phone - Insert Cable first, then Insert battery If stuck on boot - remove MicroSD card from phone! --- Press phone's power button or insert cable & charger! --- 1st Boot Done, processing booting now ASIC ID_F : 00000C201610004049B2210992DC30289ADE5300 ASIC ID_E : 00000C2016100040 PUBLIC ID : 097AAFD487B71EB049B2210992DC30289ADE5300 XGCHIP ID : 097AAFD487B71EB0 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 358139052452848 IMEI [2] : 358139052452855 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\358139052452848_XG 223_CRT.rpl PAPUBkeys : 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E === PPM_ID Check === - > PPM_ID LOWER, THAN IN PHONE!!! - > Find other ID version and try again! - > Stop killing phone, break flashing! === PPM_ID Check === Error During flashing |
07-07-2017, 05:00 | #4 (permalink) | |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Again., It is the same advice(Post no :2) for you also @love_4all, Answer is in logs... Try search the following things in infinity BEST section with the following keywords? And you will get the answer... Quote:
The Following User Says Thank You to chandanps18 For This Useful Post: |
