04-28-2018, 09:46 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Srilanka
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | RM-945 108 can not flash via UFS I have RM-945 108 set...I don't have the USB flash cable but I have the RJ45 UFS flash cable So I connect via COM/UFS/JAF and use HWK Micro Box But when i format or any operation it ask to "insert USB cable now" Pls fix this bro.it did not take the phone from hwk box Tx |
04-30-2018, 14:10 | #4 (permalink) |
No Life Poster Join Date: May 2005 Location: Romania Focsani
Member: 149135 Status: Offline Thanks Meter: 234 | When you connect as UFS..BEST software must see UFS interface..serial number and so on. In your screenshot BEST software don not see UFS interface..no serial number from UFS..nothing. So..maybe HWK micro box as interface not work and you need JAF or original USF/Tornado/Twister! Drivers from UFS are instaled? In device manager UFS interface appear? |
04-30-2018, 16:02 | #5 (permalink) | |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Quote:
Also my HWK work perfect...no problem in the Box side. problem only In best software.... if u have the best software then pls check and report here Tx | |
05-01-2018, 16:24 | #8 (permalink) | |
I don't want to solder ....with out solder only I like to use For that I have the cable but it is only ufs not usb Tx | |
05-01-2018, 16:55 | #9 (permalink) |
Product Supporter Join Date: Jun 2010 Location: Infinity Team support
Member: 1330296 Status: Offline Thanks Meter: 1,137 | Nokia 108 can't be flashed over UFS. Use USB cable with solder, or buy special cable for Nokia 108. Or use FBUS uni cable and make jumper to usb from rj45. |
05-02-2018, 05:57 | #10 (permalink) | ||
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Dear Bro Quote:
Tx | ||
05-02-2018, 08:17 | #11 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | There was atleast 4 vendor who made it to market. USB pinout has been posted by me at 2013, december. You can find it on forum or over google well. |
