05-28-2016, 04:46 | #1 (permalink) |
Freak Poster Join Date: Jul 2013 Location: In your heart.
Member: 1973579 Status: Offline Thanks Meter: 30 | RM-969 flash failed Verify files ... MAUI : RM-969_ROM_eMP_13.00.11 VIVA : RM-969_VIVA_eMP_13.00.11 LANG : RM-969_LANG_PACK_ROM_AH_eMP_13.00.11 CUST : RM-969_CUSTPACK_ROM_AH_EURO_GR_eMP_13.00.11 JMPT : RM-969_JUMP_TABLE_AH_EURO_GR_eMP_13.00.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Device boot not done Check Drivers Try again Boot Error Flashing failed! Connect phone on selected interface... Core : v2.21 , MTKx FlashEngine : v9.8 Verify files ... MAUI : RM-969_ROM_eMP_13.00.11 VIVA : RM-969_VIVA_eMP_13.00.11 LANG : RM-969_LANG_PACK_ROM_AH_eMP_13.00.11 CUST : RM-969_CUSTPACK_ROM_AH_EURO_GR_eMP_13.00.11 JMPT : RM-969_JUMP_TABLE_AH_EURO_GR_eMP_13.00.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 37 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 56603E7E52ABA3021DA1982DADFDF4AF BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Rivendell.10.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 SecureDecrypt : RM-969_ROM_eMP_13.00.11 SecureDecrypt : RM-969_VIVA_eMP_13.00.11 SecureDecrypt : RM-969_LANG_PACK_ROM_AH_eMP_13.00.11 SecureDecrypt : RM-969_CUSTPACK_ROM_AH_EURO_GR_eMP_13.00.11 SecureDecrypt : RM-969_JUMP_TABLE_AH_EURO_GR_eMP_13.00.11 OVRLP : 000069B900000001 PHPID : Rivendell.10.03.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) [ERROR] : DA_NOR_BLOCK_DATA_UNSTABLE Write : RM-969_ROM_eMP_13.00.11 Connect phone on selected interface... [ERROR] : Error While flash area!!! Flashing failed! Connect phone on selected interface... Core : v2.21 , MTKx FlashEngine : v9.8 Verify files ... MAUI : RM-969_ROM_eMP_13.00.11 VIVA : RM-969_VIVA_eMP_13.00.11 LANG : RM-969_LANG_PACK_ROM_AH_eMP_13.00.11 CUST : RM-969_CUSTPACK_ROM_AH_EURO_GR_eMP_13.00.11 JMPT : RM-969_JUMP_TABLE_AH_EURO_GR_eMP_13.00.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 37 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 56603E7E52ABA3021DA1982DADFDF4AF BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 [BL_ERROR] : Error while receiving Project ID info! BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 [ERROR] : DA_FAT_NOT_EXIST FAT_RANGE : 0x00000000-0xFFFFFFFF , LEN : 0x00000000 SecureDecrypt : RM-969_ROM_eMP_13.00.11 SecureDecrypt : RM-969_VIVA_eMP_13.00.11 SecureDecrypt : RM-969_LANG_PACK_ROM_AH_eMP_13.00.11 SecureDecrypt : RM-969_CUSTPACK_ROM_AH_EURO_GR_eMP_13.00.11 SecureDecrypt : RM-969_JUMP_TABLE_AH_EURO_GR_eMP_13.00.11 [ERROR] : [ERROR] : FT_FILE_NOT_EXIST OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 [ERROR] : Error While erase area!!! Flashing failed! Connect phone on selected interface... Core : v2.21 , MTKx FlashEngine : v9.8 Verify files ... MAUI : RM-969_ROM_eMP_13.00.11 VIVA : RM-969_VIVA_eMP_13.00.11 LANG : RM-969_LANG_PACK_ROM_AH_eMP_13.00.11 CUST : RM-969_CUSTPACK_ROM_AH_EURO_GR_eMP_13.00.11 JMPT : RM-969_JUMP_TABLE_AH_EURO_GR_eMP_13.00.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 38 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 56603E7E52ABA3021DA1982DADFDF4AF BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 [BL_ERROR] : Error while receiving Project ID info! BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 [ERROR] : DA_FAT_NOT_EXIST FAT_RANGE : 0x00000000-0xFFFFFFFF , LEN : 0x00000000 SecureDecrypt : RM-969_ROM_eMP_13.00.11 SecureDecrypt : RM-969_VIVA_eMP_13.00.11 SecureDecrypt : RM-969_LANG_PACK_ROM_AH_eMP_13.00.11 SecureDecrypt : RM-969_CUSTPACK_ROM_AH_EURO_GR_eMP_13.00.11 SecureDecrypt : RM-969_JUMP_TABLE_AH_EURO_GR_eMP_13.00.11 [ERROR] : [ERROR] : FT_FILE_NOT_EXIST OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 Connect phone on selected interface... [ERROR] : Error While erase area!!! Flashing failed! Connect phone on selected interface... Core : v2.21 , MTKx FlashEngine : v9.8 Verify files ... MAUI : RM-969_ROM_eMP_13.00.11 VIVA : RM-969_VIVA_eMP_13.00.11 LANG : RM-969_LANG_PACK_ROM_AH_eMP_13.00.11 CUST : RM-969_CUSTPACK_ROM_AH_EURO_GR_eMP_13.00.11 JMPT : RM-969_JUMP_TABLE_AH_EURO_GR_eMP_13.00.11 - > MODE : FullFlash Repair Mode is On Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 38 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 56603E7E52ABA3021DA1982DADFDF4AF BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 [BL_ERROR] : Error while receiving Project ID info! BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 [ERROR] : DA_FAT_NOT_EXIST FAT_RANGE : 0x00000000-0xFFFFFFFF , LEN : 0x00000000 SecureDecrypt : RM-969_ROM_eMP_13.00.11 SecureDecrypt : RM-969_VIVA_eMP_13.00.11 SecureDecrypt : RM-969_LANG_PACK_ROM_AH_eMP_13.00.11 SecureDecrypt : RM-969_CUSTPACK_ROM_AH_EURO_GR_eMP_13.00.11 SecureDecrypt : RM-969_JUMP_TABLE_AH_EURO_GR_eMP_13.00.11 [ERROR] : [ERROR] : FT_FILE_NOT_EXIST OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) [ERROR] : DA_NOR_BLOCK_DATA_UNSTABLE Write : RM-969_ROM_eMP_13.00.11 I have tried repair mode but still same... phone was on Nokia logo. its now completely dead |
05-28-2016, 15:48 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | In 99% cases that is HW problem. Some peoples told about them helped old "Repair MAUI" option. It exists in older BEST versions ( like 2.09 or few up ). Files should be on support area. |
