02-12-2016, 12:24 | #1 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Ново&#
Member: 599694 Status: Offline Thanks Meter: 76 | rm-984 (lumia 830) flight mode, need solution! first start (without SIM) flight mode working fine (imei correct, emergency call working) after insert SIM and reboot, flight mode goes on again... need solution!1 |
07-23-2019, 22:30 | #5 (permalink) |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 415 | just repaired one (lumia 830 stuck on Plane Mode, reset didn't help but flashing with BEST helped (ERASE USER DATA and UPDATE NVI must be tiked): Waiting for phone... Dead mode is selected , no phone in normal mode found 1. Press and hold "Volume Down" 2. Insert USB cable 3. Hold button until phone will be detected Device catched in BOOT mode! Boot Mode confirmed! Setting Preloder Collect Info... Setting Application Setting Secure Collect Info... === Nokia Flash App info : Protocol Version : 2.37 Protocol Implementation : 2.60 === Phone Initial info : Phone RMxxx ID : RM-984 Phone Model ID : Nokia.MSM8926.P6122.1.1 Phone Model PC : 059W5N8 Phone IMEI : 355159062772434 === eMMC info : eMMC Vendor : Samsung eMMC CID : 0015 eMMC Size : 14910 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : 7E07F43C43AA9A241426EA94D70F9BD82C67DEBF === Other info : SD present : False FFU : RM984_02040.00005.14372.54001_RETAIL_prod_signed_1 070_00E771_000-33.ffu Checking... Override Software RRKH check , will check via Signature Device ProductID Match with FFU ProductID! ProductID : Nokia.MSM8926.P6122 DevRKH : 7E07F43C43AA9A241426EA94D70F9BD82C67DEBF All Ok, Continue flashing... Battery Level : 47% RPMB Provision Status Code : 0x0101 Device RAM size : 1024 MiB Device have ATRP (AntiTheft) system! Backup to RAM Ok! FFU : RM984_02040.00005.14372.54001_RETAIL_prod_signed_1 070_00E771_000-33.ffu Flashing FFU Sending FFU Header CertData Header sent , accepted Perform Data Partition Erase Erase done Sending FFU Payload Data... Finishing flashing Flashing done! Green Light Image Sent, processing PostFlash FinalConfig : abnormal status, error code : 0xFF7B0000 Make Factory Set : Ok Restore RAMBkp : Ok Update NVI from Image Ok , NVI will be updated on first boot! PostFlash Finished Total flash time : 00:06:06 Rebooting Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Phone disconected! Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok |
The Following User Says Thank You to dragosgsm For This Useful Post: |
