07-30-2016, 23:32 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: philippines
Member: 45571 Status: Offline Thanks Meter: 45 | SL2 unlock done but still locked Connected phone - Nokia E71 Software ver : V ICPR71_09w22.9 16-10-09 RM-346 (c) Nokia IMEI : 358xxxxxxxxxxxx XappVer : 000008B6 Ape Ver : 400.21.013 APE Var : 400.21.013400.21.013_v19 APE ADSP: 256 DSP Ver : ICPR71_09w36 APE Test: RM346ENO74110842.a36 PPM : CNT : Product SN : SCP766142 Product code : 0569999 Base Prd.code: 0552256 Long Prod.SN : 0 Hardware info======= HWID : 0912 Retu : 16 Tahvo : 22 Battery: 3896 mV APE BT: HCI Version 8 (rev. 0). LMP Version 32 (rev. 4127). Manufacturer 13064. APE HW: 256 Lock info =========== IMEI : 358xxxxxxxxxxxx IMEI spNet : 3A 85 42 00 93 86 95 07 IMEI svNet : 33 85 42 00 93 86 95 57 F2 Conf key : 0000000000000000 Provider key : 2342000000000000 Country : United Kingdom Operator : 3 UK Counters : Key 0 [3] , Fbus 0 [10] Blocks : 4 LOCK STATUS : ============================= BLK : 1 Lock1:Close BLK : 2 Lock1:Close BLK : 3 Lock1:Close BLK : 4 Lock1:Close ============================= LOCKS : Closed ============================= Error collect lock info, try again CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL2 phone detected User Code : Crypted and protected UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Unlock procedure started... Phone Imei: 358xxxxxxxxxxxx Checking locks... Conf key : 0000000000000000 Provider key : 2342000000000000 Country : United Kingdom Operator : 3 UK Counters : Key 0 [3] , Fbus 0 [10] Blocks : 4 LOCK STATUS : ============================= BLK : 1 Lock1:Close BLK : 2 Lock1:Close BLK : 3 Lock1:Close BLK : 4 Lock1:Close ============================= LOCKS : Closed ============================= PA_SL2 phone detected... Key file exists, no need to read... NCK unlock failed, will try direct RPL Phone Imei: 358xxxxxxxxxxxx Key file exists, no need to read... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Writing SimLock Data... Ok! Writing SimLock Key... Ok! Unlock Done! |
