09-17-2012, 22:27 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | Solution for dead C6-00 after flashing? checked countless of threads on this one. Flashed successfully with latest version 42.0.4. having the same product code and correct model, but still the same problem. Is there a definite working solution to this problem pls? Phone was hanging on camera before flashing. Tried even latest Phoenix. Process finishes successfully but set wont power, just vibrates and that is all. any help appreciated thanks |
09-18-2012, 01:55 | #2 (permalink) | |
Freak Poster Join Date: May 2008 Location: LAGOS NIGERIA
Member: 773516 Status: Offline Sonork: 100.1583311 Thanks Meter: 69 | Quote:
09-18-2012, 09:24 | #5 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | here it is. Cannot see any sort of problem in the process. Connect phone on selected interface... Core : v1.47 , FlashEngine : v1.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-612_42.0.004_prd.core.C00 PPM : RM-612_42.0.004_prd.rofs2.V01 PPM2 : RM-612_42.0.004_C01_prd.rofs3.fpsx CNT : RM-612_42.0.004_uda_1_001.uda.fpsx APE : RM612_APE_ONLY_ENO_11w42_v0.020.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0D000108A122015251617AAB43D0E581781369EF ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-612_42.0.004_prd.core.C00 Found 4 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x0D39FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:01 Write : Processing RM-612_42.0.004_prd.core.C00 Total 489 [489/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:36 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-612_42.0.004_prd.rofs2.V01 Found 1 areas to erase Erasing area 0x094A0000 - 0x0C49FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-612_42.0.004_prd.rofs2.V01 Total 131 [131/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:10 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-612_42.0.004_C01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x0C4A0000 - 0x0D39FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-612_42.0.004_C01_prd.rofs3.fpsx Total 5 [5/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:00 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-612_42.0.004_uda_1_001.uda.fpsx Found 1 areas to erase Erasing area 0x0D3C0000 - 0x1EF7FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-612_42.0.004_uda_1_001.uda.fpsx Total 228 [228/0/0] blocks to write, writing... TIME : Write time : 00:00:32 CNT Write done ===Flashing [APE]=== Erase : Processing RM612_APE_ONLY_ENO_11w42_v0.020.fpsx Found 1 areas to erase Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM612_APE_ONLY_ENO_11w42_v0.020.fpsx Total 15 [15/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS*ENO] TIME : Write time : 00:00:00 APE Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:01:22 Reboot phone now... Reading Phone Info.... Connected phone - Nokia C6-00 Software Info: V ICPR72_11w16.3 05-12-11 RM-612 (c) Nokia IMEI: 354839043222366 Ape Version: v 42.0.004 Product code: 0598006 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:53 Connect phone on selected interface... |
