Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 02-01-2016, 14:02   #1 (permalink)
Member: 80858
Sonork: 100.1601506
Thanks Meter: 8
SSChannel : Create SC SSChannel : Failed to get info! ErroInfo : Unable connect to SR
ErroInfo : Unable connect to SRV
The Following 2 Users Say Thank You to elfadelmed For This Useful Post:
Old 02-01-2016, 14:11   #2 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 940
i have same problem..
Card found: S/N : 017xxxx , v0122
Registered to: alex
Connect phone on selected interface...
The Following User Says Thank You to Deni's For This Useful Post:
Old 02-01-2016, 15:10   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Yes, better make over9000 posts, instead read update topic once.
http://forum.gsmhosting.com/vbb/11592117-post17.html
Old 02-07-2016, 08:58   #4 (permalink)
Member: 2417288
Thanks Meter: 4
this is not work please help
Old 02-07-2016, 10:19   #5 (permalink)
JayDi's Avatar
Member: 462970
Sad then, peoples told about it work.
If not work for you - then you can't use it. Bad luck.
Old 04-19-2016, 06:32   #6 (permalink)
Member: 2261385
Bro win 7 me try kro..
Old 05-26-2016, 10:09   #7 (permalink)
Member: 317871
Thanks Meter: 27
Registered to: alex
disabled anti virus 10000% tested
Old 12-04-2016, 06:51   #8 (permalink)
Member: 2417288
Thanks Meter: 4
The Following User Says Thank You to arslan iqbal For This Useful Post:
Old 02-05-2017, 12:41   #9 (permalink)
Member: 1353783
i have not installed any antivirus then y its not work for me
Old 02-15-2017, 15:21   #10 (permalink)
Member: 2477331
Sonork: 100.1676088
Thanks Meter: 29
i am waiting your response infinity team please give me solution!!!!!
Old 02-15-2017, 22:08   #11 (permalink)
JayDi's Avatar
Member: 462970
Use latest BEST SW.
Select correct model and use.
Old 05-11-2017, 06:19   #12 (permalink)
Member: 1765167
Thanks Meter: 71
JayDi, this solution worked for me when I was using version 2.28. Now I upgraded to version 2.29 and the problem is here again. "Schan" is no longer in my Best.ini file. Please what is the solution?
Old 05-11-2017, 06:57   #13 (permalink)
JayDi's Avatar
Member: 462970
In 2.28 was no schan option. Even in 2.27 there was no it.
Use "copy links" option.
The Following User Says Thank You to JayDi For This Useful Post:
Old 05-11-2017, 07:05   #14 (permalink)
nadeem6677's Avatar
Member: 1252644
Sonork: 100.1602567
Thanks Meter: 47
hahahahaha good
Old 05-12-2017, 04:26   #15 (permalink)
Member: 1765167
Thanks Meter: 71
Yeah, you are right. Because I had to downgrade to find the Schan parameter but it is not there. I know I have used it at some point to fix this issue but I think I made a mistake about the version.
I can't find the "copy links" option either. Where do I find this Option?
Page generated in 0.27901 seconds with 9 queries
