09-25-2013, 10:18 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: djerba
Member: 1269161 Status: Offline Thanks Meter: 119 | strange problem in lumia520 i use server to get unlock code for lumia520 locked org fr phone ask pin network with 10 try, i put code but show bad code and ask puk code after 1 try, reboot phone, and is ask pin code with 10 try. after use "clear simlock code" in best (wp8) phone accept code and unlocked and work 100%. with read info show simlock statu: locked and if reboot phone is ask again pin network code with 10 try and cant accept the same code only after use "clear simlock statut" in best flashed phone with same version but same problem any help!! |
09-25-2013, 10:22 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. If phone after unlock code say in log - locked - it is Ok, because phone give only lock table, where is not affected unlocked/locked state. But it is very interest, why it clear code after. Do next - flash Latest Amber (3xxxx) and make "clear simlock code" Make HardReset. Enter code. After leave phone to some time. Reboot it and check. |
The Following User Says Thank You to Dzirt For This Useful Post: |
09-25-2013, 11:46 | #5 (permalink) |
Member: 1269161 Status: Offline Thanks Meter: 119 | flashed with last version downloaded with best navi and clear simlock code+ hard reset+enter code ( code accepted) but after reboot ask pin network code and dont accept the same code. |
09-25-2013, 11:57 | #6 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Try fill counter, it will ask anything after? Counter will be reseted after Clear SimUnlock code +Reboot. |
09-26-2013, 08:53 | #7 (permalink) |
Member: 1269161 Status: Offline Thanks Meter: 119 | i can't fill counter : after (1 try with good code show puk code, and sim error after 1 try with any n° in puk code ) & ( 1 try with any code show pin incorrect and ask again with 9 try and show sim erro if try again ) |
09-26-2013, 09:29 | #9 (permalink) |
Member: 1269161 Status: Offline Thanks Meter: 119 | log in test and normal mode: Code: Connect phone on selected interface... Phone found! WP8x Nokia Phone detected Read info... Ok === Main info === NCSD Version : 1.25 Sw Version : 1030.6409.1314.1004 IMEI : xxx ProductCode : 059S102 ProductSN : CPN833401 Module Code : 0205435 === HW info === Public ID : 04C8361F2D073DD95B3C8A376A1F7ED0D6FB525C HW Version : 1501 BT Addr. : F4F5A522A87B Wlan Mac : F4F5A5235BA2 Battery Level : 55 % === Branding and security info === Operator : 000-FR SimLock : Locked! SimLock : 2080100000000 Country : France Operator : Orange F Branding : RM-914_eu_france_378 Sec. Mode : Restricted Done! Set Phone to Test mode Done Connect phone on selected interface... Phone found! WP8x Nokia Phone detected Read info... Ok Phone disconected! Connect phone on selected interface... Phone found! WP8x Nokia Phone detected Read info... Ok === Main info === SecLabel Version : Security LabelSW 5.9.0.46153 Sw Version : RM914 1030.6409.9200.10211 199970 2013/04/05 //collins_engine_8227/PRx_L1 \r\n IMEI : xxxx ProductCode : 059S102 ProductSN : CPN833401 Module Code : 0205435 === HW info === Public ID : 04C8361F2D073DD95B3C8A376A1F7ED0D6FB525C BT Addr. : F4F5A522A87B Wlan Mac : F4F5A5235BA2 === Branding and security info === Sec. Mode : Restricted Conf key : 8000000000000000 Provider key : 2080100000000000 Country : France Operator : Orange F Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= Making RPL backup... NPC : Read Ok , [520] IMEI : xxxxxx CCC : Read Ok , [352] HWC : Read Ok , [212] RDC : Certificate not available NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\xxxxx_CRT_2nd.rpl Done! |
09-26-2013, 09:54 | #12 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | For why downgrade? Flash Amber (3xxx. version) some of Generic swap. They must work |
09-26-2013, 12:27 | #14 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Strange. I not have any locked phone to check where can be problem, but I will try check for something. In near few days will be some more info. |
