Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 04-28-2013, 07:17   #1 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
strange problem with nokia 110 rm-827
i have nokia 110 rm-827 ...
i have flash the phone with ver 3.04 rm827
now phone show me the rm 704 in its menu and phone also detected as nokia c2-00 and rm704..
the problem is that internet is not working in phone after that but phone works normally ..
i flashed with many product code but same ...any way to revive that ...
Reading Phone Info....
Connected phone - C2-00
Software Info: V 03.04 20-04-12 RM-704 (c) Nokia
IMEI: 35461$$$$$$$$$$
PPM version : V 03.04 20-04-12 RM-827 (c) Nokia MH1
Product code: 059Q9H9
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Processing After Flash Defaults...
FullFactorySet... Ok!
UserDataDefaultsSet...OK!
ServiceDefaultsSet... Ok!
LeaveDefaultsSet... Ok!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Set phone to Normal mode...
AfterFlash operations done ;D
Done!
hare is flashing log
Connect phone on selected interface...
Core : v1.61 , BB5XG FlashEngine : v4.0
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm827__03.04.mcusw
PPM : rm827__03.04.ppm_mh1
CNT : rm827__03.04.image_mh1_059N3C9
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
-> If Windows say "Unrecognized device" - just reinsert battery
-> If flashing freeze - reinsert cable and try again
--- Press phone's power button or insert charger! ---
Connection opened successfully
DBG : F00A1FB300020303010100FF
CPUID : XGOLD 213
2nd boot Ok, 01
2nd ready, AA
Sending Algo
Algo sent Ok
BL : Quantum_Bootloader_10.49_M1S1
Speed accepted, use 6.500.000
FLASHID : 89008289
FLIC conf set, RST set
Boot done!
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 35461$$$$$$$$$0
IMEI 2 : 3546160$$$$$$$$
PCcode : #y_žL—2
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : c:\InfinityBox\BEST\Backup\Cert\354616055365600_XG 213_CRT.rpl
===Flashing [MCU]===
File : rm827__03.04.mcusw
Image : rm827__03.04.mcusw_ebl_psi.fls
Cert block found, sending....
Cert sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:05
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x01940000
Erasing, wait ...
Erase done, time : 00:02:27
Write , Start : 0x40280000 , Len : 0x018C0000
Flashing , wait ...
Region flash done, time : 00:00:39
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
===Flashing [PPM]===
File : rm827__03.04.ppm_mh1
Image : package_mh1.ppm_ebl_psi.fls
Cert sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41BC0000 , Len : 0x00600000
Erasing, wait ...
Erase done, time : 00:00:19
Write , Start : 0x41BC0000 , Len : 0x0031E1A4
Flashing , wait ...
Region flash done, time : 00:00:04
===Flashing [CNT]===
File : rm827__03.04.image_mh1_059N3C9
Image : package_mh1_059N3C9.image.fls
Cert sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x421C0000 , Len : 0x01C60000
Erasing, wait ...
Erase done, time : 00:03:47
Write , Start : 0x421C0000 , Len : 0x00F00000
Flashing , wait ...
Region flash done, time : 00:00:24
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
Erase done, time : 00:00:07
No write data, skip
Flashing done!
Total flash time : 00:07:59
Reboot phone now...
IMEI: 3546##########
Checking...
Read Info Done!
SwUpgradeSet...OK!
Done!
5600
Old 04-28-2013, 08:08   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Hello.
Read PP (Product Profile)
open it.
Check field 9
Change it value to 1 or 2 or 3
Write PP , reconct phone.
It will have now other rm.
Inet - check settings on your operator.
The Following 2 Users Say Thank You to Dzirt For This Useful Post:
Old 04-28-2013, 08:25   #3 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
Originally Posted by Dzirt View Post
Hello.
open it.
Check field 9
thanks its change to rm-827
Page generated in 0.20542 seconds with 9 queries
