03-21-2019, 15:22 | #781 (permalink) |
No Life Poster Join Date: Oct 2006 Location: pakistan
Member: 361094 Status: Offline Sonork: 100.1597521 Thanks Meter: 172 | nokia 3310 format done 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : SPRD SECURE BOOT Block version BootVersion : BEST RETRO3G Port speed : 921600 FDL Flash : Control transfered! Boot Done! Erase BLK #0 Erase BLK #1 Erase BLK #2 Erase BLK #3 Format Ok! Done! Elapsed: 00:02:57 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to nadim electro For This Useful Post: |
03-22-2019, 06:40 | #782 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 130 RM-1035 Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1035_ROM_eMP_11.00.11 VIVA : RM-1035_VIVA_eMP_11.00.11 LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 JMPT : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 27 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 39826C3723D76E2279F09CC89E1A359B BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.11.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_11.00.11 SecureDecrypt : RM-1035_VIVA_eMP_11.00.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 OVRLP : 000069B900000001 PHPID : CRYSTAL.11.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_11.00.11 Write : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 Write : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_VIVA_eMP_11.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_11.00.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_VIVA_eMP_11.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:05 Reboot phone Ok Connect phone on selected interface... |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
03-22-2019, 10:32 | #783 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 3310 3G TA-1006 Format FS Done Operation : Reset Settings ( Format FS ) [ v1.10 ] 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : SPRD SECURE BOOT Block version BootVersion : BEST RETRO3G Port speed : 921600 FDL Flash : Control transfered! Boot Done! Erase BLK #0 Erase BLK #1 Erase BLK #2 Erase BLK #3 Format Ok! Done! Elapsed: 00:01:08 |
The Following 4 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
03-23-2019, 06:01 | #784 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 130 TA-1017 Format Done Operation : Reset Settings [ v1.09 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM27) MODE : NOKIA USB SERIAL PORT : 27 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : AC9E9CA050C000E35EF7E5E486230FAC BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : KESA61A.10.00.11.p2 BOOT : SWR : 10.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : KESA61A.10.00.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0060 : 0017 : 0000 NOR: [WINBOND] W25Q64DW NOR: TSIZE : 0x00800000 [ 8.00 MB ] PSIZE : 0x00800000 [ 8.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00580000 : 0x00278000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:52 Reconnect Power/Cable! |
03-25-2019, 12:53 | #785 (permalink) |
Insane Poster Join Date: Jul 2014 Location: Perambalur TamilNadu Age: 31
Member: 2226775 Status: Offline Thanks Meter: 138 | Nokia 5.1 plus {ta-1102} phone lock frp done NOKIA 5.1 PLUS {TA-1102} PHONE LOCK FRP DONE READ INFO Card found : 87CBAAFA , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.11 Operation : Identify [ v1.11 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM53) MODE : BOOTROM PORT : 53 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_ARB BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6771 AGENT : Nokia_All_InOne_DA_v03.2019.1303 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A68423861503E010F7440117591 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP> EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3206BB6FC5A908CE3F6BD6F02755AA09 DA : USB : HIGH-SPEED Boot done! --- SysInfoSub [PART A]: Patch Level : PPR1.180610.011 Display ID : 0001_2_14B Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-03-05 Build Time : 1551892830 Product Model : FIH-PDA Product Brand : alps Product Name : fih_mt6771_64_0001 Product Device : PDA_sprout Product Manfct : alps Product Info : fih_mt6771_64 Product Board : fih_mt6771_64 Board Platform : mt6771 --- SysInfoSub [PART B]: Patch Level : PPR1.180610.011 Display ID : 0001_2_14A Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-02-05 Build Time : 1548836152 Product Model : FIH-PDA Product Brand : alps Product Name : fih_mt6771_64_0001 Product Device : PDA_sprout Product Manfct : alps Product Info : fih_mt6771_64 Product Board : fih_mt6771_64 Board Platform : mt6771 --- SecuritySub : NVRAM check : Passed! Done! Elapsed: 00:01:08 Reconnect Power/Cable! RESET FRP Card found : 87CBAAFA , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.11 Operation : Identify [ v1.11 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM53) MODE : BOOTROM PORT : 53 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_ARB BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6771 AGENT : Nokia_All_InOne_DA_v03.2019.1303 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A68423861503E010F7440117591 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP> EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3206BB6FC5A908CE3F6BD6F02755AA09 DA : USB : HIGH-SPEED Boot done! --- SysInfoSub [PART A]: Patch Level : PPR1.180610.011 Display ID : 0001_2_14B Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-03-05 Build Time : 1551892830 Product Model : FIH-PDA Product Brand : alps Product Name : fih_mt6771_64_0001 Product Device : PDA_sprout Product Manfct : alps Product Info : fih_mt6771_64 Product Board : fih_mt6771_64 Board Platform : mt6771 --- SysInfoSub [PART B]: Patch Level : PPR1.180610.011 Display ID : 0001_2_14A Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-02-05 Build Time : 1548836152 Product Model : FIH-PDA Product Brand : alps Product Name : fih_mt6771_64_0001 Product Device : PDA_sprout Product Manfct : alps Product Info : fih_mt6771_64 Product Board : fih_mt6771_64 Board Platform : mt6771 --- SecuritySub : NVRAM check : Passed! Done! Elapsed: 00:01:08 Reconnect Power/Cable! Operation : Reset Settings [ v1.11 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM53) MODE : BOOTROM PORT : 53 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_ARB BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6771 AGENT : Nokia_All_InOne_DA_v03.2019.1303 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A68423861503E010F7440117591 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP> EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3206BB6FC5A908CE3F6BD6F02755AA09 DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : RESET PROTECTION Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
The Following 7 Users Say Thank You to prabakaran143 For This Useful Post: |
03-26-2019, 12:00 | #786 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | TA-1034 Format / Reset Done :) Code: Operation : Reset Settings [ v1.11 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM246) MODE : NOKIA USB SERIAL PORT : 246 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 400AAC7E14421E3F84B9270AB493BDC9 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.10.02.11.p1 BOOT : SWR : 10.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.10.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00370000 : 0x00088000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to syed tuqeer For This Useful Post: |
03-31-2019, 12:58 | #787 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 150 reset password done by best2 Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.11 Operation : Identify [ v1.11 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM6) MODE : NOKIA USB SERIAL PORT : 6 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : E8BF060F73FE2D6D916065AC2F1CB20C BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DUBAI61D.10.02.11.p1 BOOT : SWR : 10.02.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : DUBAI61D.10.02.11.p1 FLASH : 00C2 : 0025 : 0036 : 0000 BBSN : E8BF060F73FE2D6D916065AC2F1CB20C PRDC : 059X8W6 IMEI[1] : IMEI[2] : NCK : 20 digits PROV : 24407000 Saved as : 35xxxxxxxxxxxxx.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:00:59 Reconnect Power/Cable! Operation : Reset Settings [ v1.11 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM6) MODE : NOKIA USB SERIAL PORT : 6 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : E8BF060F73FE2D6D916065AC2F1CB20C BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DUBAI61D.10.02.11.p1 BOOT : SWR : 10.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : DUBAI61D.10.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x003A0000 : 0x00058000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
The Following User Says Thank You to A.G.Shahid For This Useful Post: |
03-31-2019, 14:23 | #788 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia C2-03 Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm702__07.65.mcusw PPM : rm702__07.65.ppm_m_a CNT : rm702__07.65.image_m_a_059D434 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 359328046833762 IMEI 2 : 359328046833770 PCcode : 059D434 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\359328046833762_XG 213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm702__07.65.mcusw Image : rm702__07.65.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:04 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01B40000 Erasing, wait ... Erase done, time : 00:01:56 Write , Start : 0x40280000 , Len : 0x01AC0000 Flashing , wait ... Region flash done, time : 00:00:31 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x26E7 ===Flashing [PPM]=== File : rm702__07.65.ppm_m_a Image : package_m_a.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41DC0000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:17 Write , Start : 0x41DC0000 , Len : 0x004048E0 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xB129 ===Flashing [CNT]=== File : rm702__07.65.image_m_a_059D434 Image : package_m_a_059D434.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x424C0000 , Len : 0x01960000 Erasing, wait ... Erase done, time : 00:03:19 Write , Start : 0x424C0000 , Len : 0x00D00000 Flashing , wait ... Region flash done, time : 00:00:19 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:07 No write data, skip CRC check passed , 0xF4B0 Flashing done! Total flash time : 00:06:42 Reboot phone now... Reading Phone Info.... Connected phone - C2-03 Software Info: V 07.65 19-09-12 RM-702 (c) Nokia IMEI: 359328046833762 PPM version : V 07.65 19-09-12 RM-702 (c) Nokia M_A Product code: 059D434 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 42 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:07:57 Connect phone on selected interface... |
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
03-31-2019, 15:21 | #789 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Unknown
Member: 2469611 Status: Offline Thanks Meter: 389 | Nokia 3310 TA-1030 Contact Service Done Code: 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM382) MODE : NOKIA USB SERIAL PORT : 382 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 7AEE428C59A9FF0FA814B7681327AD3B BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.11.02.11.p1 BOOT : SWR : 11.02.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : RETRO.11.02.11.p1 FLASH : 00EF : 0060 : 0018 : 0000 BBSN : 7AEE428C59A9FF0FA814B7681327AD3B PRDC : 059Z014 IMEI[1] : 3XXXXXXXXXXXX8 IMEI[2] : 3XXXXXXXXXXXX5 Done! Elapsed: 00:00:30 Reconnect Power/Cable! Open VPLfile : TA1030_059X9S3_11.02.11.vpl Description : TA-1030 NDT MEA IJ GREY URDU PK DeviceType : TA-1030 ProductCode : 059X9S3 SoftwareVer : 11.02.11 PPM LangPack : [1] : Urdu (Islamic Republic of Pakistan) [2] : English (United Kingdom) Load Ok! Operation : Write FirmWare Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM382) MODE : NOKIA USB SERIAL PORT : 382 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 7AEE428C59A9FF0FA814B7681327AD3B BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.11.02.11.p1 BOOT : SWR : 11.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : RETRO.11.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8B NOR: 00C2 : 0025 : 0038 : 0000 NOR: [MXIC] MX25U12835FZNI_10G NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 11.02.11 [TA-1030] DEV SoftwareVersion : 11.02.11 SWInfo compare result : SAME Load FlashSet : MROM : TA-1030_ROM_eMP_11.02.11 LANG : TA-1030_LANG_PACK_ROM_IJ_eMP_11.02.11_001 CUST : TA-1030_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.02.11_001 JUMP : TA-1030_JUMP_TABLE_IJ_MEA_PK_eMP_11.02.11_001 VIVA : TA-1030_VIVA_eMP_11.02.11 Prepare FlashSet : DCR : TA-1030_ROM_eMP_11.02.11 DCR : TA-1030_LANG_PACK_ROM_IJ_eMP_11.02.11_001 DCR : TA-1030_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.02.11_001 DCR : TA-1030_JUMP_TABLE_IJ_MEA_PK_eMP_11.02.11_001 DCR : TA-1030_VIVA_eMP_11.02.11 Prepare Target SDS : OK : 0x00FF4000 : 0x0000C000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : TA-1030_ROM_eMP_11.02.11 Write : TA-1030_LANG_PACK_ROM_IJ_eMP_11.02.11_001 Write : TA-1030_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.02.11_001 Write : TA-1030_JUMP_TABLE_IJ_MEA_PK_eMP_11.02.11_001 Write : TA-1030_VIVA_eMP_11.02.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1030_ROM_eMP_11.02.11 Verify : TA-1030_LANG_PACK_ROM_IJ_eMP_11.02.11_001 Verify : TA-1030_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.02.11_001 Verify : TA-1030_JUMP_TABLE_IJ_MEA_PK_eMP_11.02.11_001 Verify : TA-1030_VIVA_eMP_11.02.11 Done! Elapsed: 00:03:14 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to CYB3R GSM For This Useful Post: |
03-31-2019, 16:25 | #790 (permalink) |
Freak Poster Join Date: Dec 2008 Location: jalandhar cantt,india
Member: 914059 Status: Offline Sonork: 121212 Thanks Meter: 34 | ta-1118 frp done Card found : 618EA76A , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.11 Operation : Reset Settings [ v1.11 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM7) MODE : BOOTROM PORT : 7 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_ARB BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6765 AGENT : Nokia_All_InOne_DA_v03.2019.1303 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A68423861503E0163E92EAF759F EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP> EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : FD156F39C7F926102FCEE65D274FFFCF DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : RESET PROTECTION Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to aonemobile For This Useful Post: |
03-31-2019, 19:23 | #791 (permalink) |
Member: 2469611 Status: Offline Thanks Meter: 389 | Nokia RM-1090 Contact Service Done Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1190_ROM_eMP_10.02.11 VIVA : RM-1190_VIVA_eMP_10.02.11 LANG : RM-1190_LANG_PACK_ROM_IC_eMP_10.02.11_001 CUST : RM-1190_CUSTPACK_ROM_IC_MEA_IQ_eMP_10.02.11_001 JMPT : RM-1190_JUMP_TABLE_IC_MEA_IQ_eMP_10.02.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 382 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 98E153F9069B541F56EE8FCA2F2EB546 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DUBAI61D.11.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Dubai.fg DA_VERIFY : 00 DA_JUMP : 00100000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A0000-0x003F7FFF , LEN : 0x00058000 SecureDecrypt : RM-1190_ROM_eMP_10.02.11 SecureDecrypt : RM-1190_VIVA_eMP_10.02.11 SecureDecrypt : RM-1190_LANG_PACK_ROM_IC_eMP_10.02.11_001 SecureDecrypt : RM-1190_CUSTPACK_ROM_IC_MEA_IQ_eMP_10.02.11_001 SecureDecrypt : RM-1190_JUMP_TABLE_IC_MEA_IQ_eMP_10.02.11_001 OVRLP : 000069B900000001 PHPID : DUBAI61D.11.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1190_ROM_eMP_10.02.11 Write : RM-1190_LANG_PACK_ROM_IC_eMP_10.02.11_001 Write : RM-1190_CUSTPACK_ROM_IC_MEA_IQ_eMP_10.02.11_001 Write : RM-1190_JUMP_TABLE_IC_MEA_IQ_eMP_10.02.11_001 Write : RM-1190_VIVA_eMP_10.02.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1190_ROM_eMP_10.02.11 [VERIFY] DONE : RM-1190_LANG_PACK_ROM_IC_eMP_10.02.11_001 [VERIFY] DONE : RM-1190_CUSTPACK_ROM_IC_MEA_IQ_eMP_10.02.11_001 [VERIFY] DONE : RM-1190_JUMP_TABLE_IC_MEA_IQ_eMP_10.02.11_001 [VERIFY] DONE : RM-1190_VIVA_eMP_10.02.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A0000-0x003F7FFF , LEN : 0x00058000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:07 Reboot phone Ok |
The Following 2 Users Say Thank You to CYB3R GSM For This Useful Post: |
04-06-2019, 09:36 | #792 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 150 hang on logo done by best2 Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.12 Open VPLfile : RM-1190_059X975_11.00.11.vpl Description : RM-1190 059X975 IJ 11.00.11 DeviceType : RM-1190 ProductCode : 059X975 SoftwareVer : 11.00.11 PPM LangPack : [1] : Urdu (Islamic Republic of Pakistan) [2] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.12 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM8) MODE : NOKIA USB SERIAL PORT : 8 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 9D2781546402CE3464A7F68EEA23EE45 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DUBAI61D.10.02.11.p1 BOOT : SWR : 10.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : DUBAI61D.10.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 11.00.11 [RM-1190] DEV SoftwareVersion : 10.02.11 SWInfo compare result : DEVICE SW ( Minor version ) is LOWER, than in VPL! Load FlashSet : MROM : RM-1190_DUBAI_ROM_eMP_11.00.11 LANG : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11 CUST : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11 JUMP : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11 VIVA : RM-1190_DUBAI_VIVA_eMP_11.00.11 Prepare FlashSet : DCR : RM-1190_DUBAI_ROM_eMP_11.00.11 DCR : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11 DCR : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11 DCR : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11 DCR : RM-1190_DUBAI_VIVA_eMP_11.00.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : RM-1190_DUBAI_ROM_eMP_11.00.11 Write : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11 Write : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11 Write : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11 Write : RM-1190_DUBAI_VIVA_eMP_11.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : RM-1190_DUBAI_ROM_eMP_11.00.11 Verify : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11 Verify : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11 Verify : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11 Verify : RM-1190_DUBAI_VIVA_eMP_11.00.11 Done! Elapsed: 00:01:23 Reconnect Power/Cable! |
04-06-2019, 09:58 | #793 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 3310 3g reset password done by best2 Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.12 Operation : Reset Settings ( Format FS ) [ v1.12 ] 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : SPRD SECURE BOOT Block version BootVersion : BEST RETRO3G Port speed : 921600 FDL Flash : Control transfered! Boot Done! Erase BLK #0 Erase BLK #1 Erase BLK #2 Erase BLK #3 Format Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
04-06-2019, 10:19 | #794 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | TA-1017 Change Language Done :) Code: Infinity-Box BEST Nokia [HMD] Module [NK2] v1.12 Open VPLfile : TA1017_059Z1Z6_11.02.11.vpl Description : TA-1017 NDT MEA IJ BLACK FARSI IR DeviceType : TA-1017 ProductCode : 059Z1Z6 SoftwareVer : 11.02.11 PPM LangPack : [1] : Urdu (Islamic Republic of Pakistan) [2] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.12 ] Setting : UserData erase : False Setting : LangPack Only : True 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM246) MODE : NOKIA USB SERIAL PORT : 246 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : A65FC243B29638BE6BAFDAE0F86A24C3 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : KESA61A.11.02.11.p1 BOOT : SWR : 11.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : KESA61A.11.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0060 : 0017 : 0000 NOR: [WINBOND] W25Q64DW NOR: TSIZE : 0x00800000 [ 8.00 MB ] PSIZE : 0x00800000 [ 8.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 11.02.11 [TA-1017] DEV SoftwareVersion : 11.02.11 SWInfo compare result : SAME Load FlashSet : LANG : TA-1017_LANG_PACK_ROM_IJ_eMP_11.02.11_001 CUST : TA-1017_CUSTPACK_ROM_IJ_MEA_IR_eMP_11.02.11_001 JUMP : TA-1017_JUMP_TABLE_IJ_MEA_IR_eMP_11.02.11_001 Prepare FlashSet : DCR : TA-1017_LANG_PACK_ROM_IJ_eMP_11.02.11_001 DCR : TA-1017_CUSTPACK_ROM_IJ_MEA_IR_eMP_11.02.11_001 DCR : TA-1017_JUMP_TABLE_IJ_MEA_IR_eMP_11.02.11_001 Prepare Target SDS : OK : 0x007F8000 : 0x00008000 Erase Target Flash Erase done! Write Target Flash Write : TA-1017_LANG_PACK_ROM_IJ_eMP_11.02.11_001 Write : TA-1017_CUSTPACK_ROM_IJ_MEA_IR_eMP_11.02.11_001 Write : TA-1017_JUMP_TABLE_IJ_MEA_IR_eMP_11.02.11_001 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1017_LANG_PACK_ROM_IJ_eMP_11.02.11_001 Verify : TA-1017_CUSTPACK_ROM_IJ_MEA_IR_eMP_11.02.11_001 Verify : TA-1017_JUMP_TABLE_IJ_MEA_IR_eMP_11.02.11_001 Done! Elapsed: 00:00:43 Reconnect Power/Cable! |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
04-07-2019, 14:04 | #795 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 206 FullFlash Done Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm872__04.52.mcusw PPM : rm872__04.52.ppm_m2 CNT : rm872__04.52.image_m2_059Q4J7 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 351716063243600 IMEI 2 : 351716063243618 PCcode : 059Q4L3 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\351716063243600_XG 213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm872__04.52.mcusw Image : rm872__04.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:00:49 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:29 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xFA4D ===Flashing [PPM]=== File : rm872__04.52.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00680000 Erasing, wait ... Erase done, time : 00:00:11 Write , Start : 0x41A80000 , Len : 0x003C68F0 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xC9E6 ===Flashing [CNT]=== File : rm872__04.52.image_m2_059Q4J7 Image : package_m2_059Q4J7.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:01:03 Write , Start : 0x42100000 , Len : 0x01040000 Flashing , wait ... Region flash done, time : 00:00:19 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0x5521 Flashing done! Total flash time : 00:03:05 Reboot phone now... Reading Phone Info.... Connected phone - 206 Software Info: V 04.52 30-06-13 RM-872 (c) Nokia IMEI: 351716063243600 PPM version : V 04.52 30-06-13 RM-872 (c) Nokia M2 Product code: 059Q4L3 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:01 |
