Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 05-07-2019, 06:13   #826 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Nokia 105 full flash by best
Card found: S/N : 30C22462 , v0122
Registered to: A.G.Shahid
Connect phone on selected interface...
UFS S/N 14332 boot - Ok
Core : v2.29 , BB5XG FlashEngine : v10.5
Selected FlashSettings : Manual
Files Set for Flashing :
MCU : rm908_02.700
PPM : rm908_02.70ij
CNT : rm908_nai02.70ij
Infineon flashing...
-> Infineon XG110 : IMEI Backup Created
Booting phone now....
Sync Ok , A2
CPU ID : XGOLD , A200341100
PBL : Dynamic
Boot Ok , 01AB
SBL : Dynamic
Algo Ok , 01
SBL mode Ok
SBL : Default_RAM_Bootloader
EPP CFG [Bering]...
FLASH VEN : 0000002C
FLASH DIE : 0000CB17
FLASH ID : SPI , 25W064A
Boot Done!
===Flashing [MCU]===
File : rm908_02.700
Image : hw_b1_rm908_02.700.fls
Cert block found, sending....
Cert sent
Found 3 region(s)
Processing Region 1/3
Erase , Start : 0x00800000 , Len : 0x00210000
Erasing, wait ...
Erase done
Write , Start : 0x00800000 , Len : 0x00210000
Flashing , wait ...
Region flash done
Processing Region 2/3
Erase , Start : 0x00C60000 , Len : 0x00250000
Erasing, wait ...
Erase done
Write , Start : 0x00C60000 , Len : 0x00221240
Flashing , wait ...
Region flash done
Processing Region 3/3
Erase , Start : 0x00FFC000 , Len : 0x00004000
Erasing, wait ...
Erase done
Write , Start : 0x00FFC000 , Len : 0x00000040
Flashing , wait ...
Region flash done
Check : A59F
===Flashing [PPM]===
File : rm908_02.70ij
Image : hw_b1_rm908_02.70ij.fls
Cert sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x00210000 , Len : 0x00250000
Erasing, wait ...
Erase done
Write , Start : 0x00210000 , Len : 0x0018A340
Flashing , wait ...
Region flash done
Check : 96E9
===Flashing [CNT]===
File : rm908_nai02.70ij
Image : hw_b1_rm908_nai02.70ij.fls
Cert sent
Found 1 region(s)
Erase , Start : 0x00EB0000 , Len : 0x000D0000
Erasing, wait ...
Erase done
Write , Start : 0x00EB0000 , Len : 0x000661C0
Flashing , wait ...
Region flash done
Check : A3FD
Flashing done, rebooting...
-> Infineon info : Do FullFactory Sets after flashing
Flashing Done!
Init Service mode... Wait...
Afterflash settings...
SW ver :
IMEI :
PCode :
Settings After Flash Defaults...
Error When resetting FullFactory ...
Error When resetting Product Tune ...
Error When resetting SW upgrade Default ...
All done!
Phone found!
Series 40 Device detected!
read info... - Ok
Resetting selected items...
Check phone mode...
Phone in Local mode
Seting Test mode... wait...
Test mode set
Settings Full Factory Defaults...
Set OK!
Settings Software Upgrade Defaults...
Set OK!
Settings Service Centre Defaults...
Set OK!
Settings Production Tune Defaults...
Set OK!
Settings User Data Defaults...
Set OK!
Settings Leave Factory defaults...
Set OK!
Elapsed: 00:00:14
Phone disconected!
The Following User Says Thank You to A.G.Shahid For This Useful Post:
Old 05-07-2019, 13:53   #827 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Nokia 130 hang on logo done by best2
Card found : 30C22462 , v0122
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.16
Operation : Identify [ v1.16 ]
1. Make sure device is powered off. Power off, if need. Wait 10 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : Nokia USB Serial Port (COM29)
MODE : NOKIA USB SERIAL
PORT : 29
BROM : Init BROM
BROM init passed!
CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000
BROM : SECCFG : 0x00000007
BROM : NOKIA USB SERIAL
BROM : 0x05 BL : 0x00
BROM : MEID : 01989AB4315977B36A0CF0B3EE847D20
BROM : Run BootLoader ...
BOOT : Run BL ver. 01
BOOT : 0x05 BL : 0x01
BOOT : WD : 0005
BOOT : RTC : Setup ...
BOOT : RTC : 000E
BOOT : PRJ : CRYSTAL.14.00.11.p1
BOOT : SWR : 14.00.11
BOOT : BDDS : 30
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
SWVer : CRYSTAL.14.00.11.p1
FLASH : 00C2 : 0025 : 0036 : 0000
BBSN : 01989AB4315977B36A0CF0B3EE847D20
PRDC : 059W037
IMEI[1] :
IMEI[2] :
NCK : 20 digits
PROV : 24407000
Saved as : 35729xxxxxxxxxx.mtsec
Saved to : C:\InfinityBox\BEST2\Backup\
Done!
Elapsed: 00:01:03
Reconnect Power/Cable!
Open VPLfile : RM-1035_059W2D7_14.00.11.vpl
Description : RM-1035 059W2D7 IJ 14.00.11
DeviceType : RM-1035
ProductCode : 059W2D7
SoftwareVer : 14.00.11
PPM LangPack :
[1] : Urdu (Islamic Republic of Pakistan)
[2] : English (United Kingdom)
Load Ok!
Operation : Write FirmWare [ v1.16 ]
Setting : UserData erase : True
Setting : LangPack Only : False
PORT : 29
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
AGENT : Look for suitable BootChain in DA ...
AGENT : DEFAULT AUTO
AGENT : Found MT6260
AGENT : CRYSTAL.14.00.11.p1
BOOT : Sending 1st DA ...
BOOT : DA sent
BOOT : Transfer control to DA ...
DA : Sync Passed!
DA : Authentification pass!
DA : Agent : v03.02 on BBID : 0x8B
NOR: 00EF : 0040 : 0016 : 0000
NOR: [WINBOND] W25Q32BV
NOR:
TSIZE : 0x00400000 [ 4.00 MB ]
PSIZE : 0x00400000 [ 4.00 MB ]
STYPE : 0x00000000
FLOTP : DA_NOR_OTP_EXIST
STATUS : OK
BSTYLE : SF_FLASH_BOOT
Boot done!
VPL SoftwareVersion : 14.00.11 [RM-1035]
DEV SoftwareVersion : 14.00.11
SWInfo compare result : SAME
Load FlashSet :
MROM : RM-1035_CRYSTAL_ROM_eMP_14.00.11
LANG : RM-1035_CRYSTAL_LANG_PACK_ROM_IJ_eMP_14.00.11
CUST : RM-1035_CRYSTAL_CUSTPACK_ROM_IJ_eMP_14.00.11
JUMP : RM-1035_CRYSTAL_JUMP_TABLE_IJ_eMP_14.00.11
VIVA : RM-1035_CRYSTAL_VIVA_eMP_14.00.11
Prepare FlashSet :
DCR : RM-1035_CRYSTAL_ROM_eMP_14.00.11
DCR : RM-1035_CRYSTAL_LANG_PACK_ROM_IJ_eMP_14.00.11
DCR : RM-1035_CRYSTAL_CUSTPACK_ROM_IJ_eMP_14.00.11
DCR : RM-1035_CRYSTAL_JUMP_TABLE_IJ_eMP_14.00.11
DCR : RM-1035_CRYSTAL_VIVA_eMP_14.00.11
Prepare Target
SDS : OK : 0x003F4000 : 0x0000C000
FFS Format Ok!
CBR : 0x0000001A:0x00000001:0x00000000:0x00000000:0x0000 0010:0x00000002:0x00000000
Erase Target Flash
Erase done!
Write Target Flash
Write : RM-1035_CRYSTAL_ROM_eMP_14.00.11
Write : RM-1035_CRYSTAL_LANG_PACK_ROM_IJ_eMP_14.00.11
Write : RM-1035_CRYSTAL_CUSTPACK_ROM_IJ_eMP_14.00.11
Write : RM-1035_CRYSTAL_JUMP_TABLE_IJ_eMP_14.00.11
Write : RM-1035_CRYSTAL_VIVA_eMP_14.00.11
Write done, waiting target response ...
Write flash done!
Verify Target FlashContent
Verify : RM-1035_CRYSTAL_ROM_eMP_14.00.11
Verify : RM-1035_CRYSTAL_LANG_PACK_ROM_IJ_eMP_14.00.11
Verify : RM-1035_CRYSTAL_CUSTPACK_ROM_IJ_eMP_14.00.11
Verify : RM-1035_CRYSTAL_JUMP_TABLE_IJ_eMP_14.00.11
Verify : RM-1035_CRYSTAL_VIVA_eMP_14.00.11
Done!
Elapsed: 00:01:22
Old 05-09-2019, 12:11   #828 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,424
Smile Nokia 216 Format Done
Dead Mode is Selected
Waiting for USB device...
1. Phone should be Off!
2. Battery must be charged and inserted! ( if not used external power )
- > If phone can't switch to BL - use battery or flash from Local mode!
--- Insert USB cable now! ---
Wait for phone...
Phone found! [ 44 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0001
BB_CPU_SN : B71833E3B4C17E2007144D3C7A8B1065
BROM Protocol Version : 05
BROM Status : 0000
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
Setting done , result code 0x8000
Project ID : SUEZ.40.00.11.p1
BROM/BL stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_eMP_Suez.fg
DA_VERIFY : 00
DA_JUMP : 00040000
DA_AUTH : Passed!
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW
[0] : FLASH_DIE : 00EF 0060 0018 0000
[0] : FLASH_LEN : 0x01000000
FAT_RANGE : 0x00CE0000-0x00FF3FFF , LEN : 0x00314000
Executing FFS FORMAT now...
DA_RET : DA_IN_PROGRESS
DA_RET : FORMAT_DONE
Elapsed: 00:00:36
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post:
Old 05-09-2019, 20:38   #829 (permalink)
Member: 579725
Sonork: 100.1675677
Thanks Meter: 96
Verify FW package ...
Verification passed!
2. Use BOOT JIG or EDL cable!
3. Insert USB cable, press "POWER_ON" button few times, if need
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 210 [MSM8x09]
ID_BLOCK_S : 141EE8EC
ID_BLOCK_I : 009600E1
ID_BLOCK_L : C0CE2B1F0987C34C6D9A3B55DB9A5FB5
ID_BLOCK_L : AE92F5777D9E5A15174A807BD622F3FC
Pickup loader from firmware package
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Boot Ok!
Flash Chain : 49
Flashing now
Flashing : gpt_main0.bin
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : emmc_appsboot.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : sysinfo.cfg
Flashing : splash.img
Flashing : hidden.img
Flashing : cda.img
Flashing : recovery.img
Flashing : sec.dat
Flashing : boot.img
Flashing : NON-HLOS.bin
Flashing : system.img
Flashing : misc.img
Flashing : cache.img
Flashing : persist.img
Flashing : cmnlib.mbn
Flashing : keymaster.mbn
Flashing : userdata.img
Flashing : gpt_backup0.bin
Wipe data ...
BootConfig set to 0x00
Flashing done!
When you will see ANDROID on screen make next steps :
1. Press and Hold both 'Vol_UP' and 'Power_On' keys
2. Hold them until device will reboot and show again ANDROID logo
3. Release 'Power_On' button, wait when color circle appear on screen!
Done!
Elapsed: 00:03:46
The Following User Says Thank You to MIRZAvicko For This Useful Post:
Old 05-10-2019, 05:31   #830 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Nokia 105 rm-1133 reset password done by best2
PORT : 29
BROM : Init BROM
BROM init passed!
CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001
BROM : MEID : 174FCD67395B8EEF5A627CA16219F59F
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : LAGOS61D.13.00.11.p1
BOOT : SWR : 13.00.11
BOOT : BDDS : 30
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
SWVer : LAGOS61D.13.00.11.p1
BBSN : 174FCD67395B8EEF5A627CA16219F59F
PRDC : 059W9Z8
IMEI[1] :
IMEI[2] :
NCK : 20 digits
PROV : 24407000
Saved as : 354877xxxxxxxxxx.mtsec
Done!
Elapsed: 00:01:01
Operation : Reset Settings [ v1.16 ]
PORT : 29
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
AGENT : Found MT6261
AGENT : LAGOS61D.13.00.11.p1
BOOT : DA sent
DA : Sync Passed!
DA : Agent : v03.02 on BBID : 0x8E
NOR: 00C8 : 0060 : 0016 : 0000
NOR: [GigaDevice] GD25LQ32
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
FFS Info exists in MAUI : 0x00368000 : 0x00090000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:28
Old 05-13-2019, 10:35   #831 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Nokia 130 Format Done
PTFN : Nokia USB Serial Port (COM20)
PORT : 20
BROM : Init BROM
BROM init passed!
BROM : MEID : FDE9342C98CC3EFF6DAF529717348379
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : CRYSTAL.10.01.11.p2
BOOT : SWR : 10.01.11
AGENT : CRYSTAL.10.01.11.p2
BOOT : DA sent
DA : Sync Passed!
NOR: 00C2 : 0025 : 0036 : 0000
NOR: [MX] MX25U3235E
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
FFS Info exists in MAUI : 0x003A4000 : 0x00050000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:01:23
Old 05-13-2019, 16:01   #832 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Nokia 3310 3g reset password done by best2
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.12
Operation : Reset Settings ( Format FS ) [ v1.12 ]
1. Power off device, remove battery
2. Insert cable, press and hold BootKey ( # )
3. Insert battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD SECURE BOOT Block version
BootVersion : BEST RETRO3G
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
Erase BLK #0
Erase BLK #1
Erase BLK #2
Erase BLK #3
Format Ok!
Done!
Elapsed: 00:00:32
Old 05-17-2019, 13:29   #833 (permalink)
Member: 1051138
Sonork: 123456
Thanks Meter: 382
nokia 5.1 plus frp+formate done
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
- > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage!
PTFN : MediaTek USB Port (COM15)
MODE : BOOTROM
PORT : 15
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : MODERN RAPHAEL
BROM : DSLevel : DEV_KEY+DEV_ARB
BROM : BOOTROM
AGENT : Found MT6771
AGENT : Nokia DownloadAgent ver.07220419 BEST2
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00040000 [ 256.00 KB ]
DRAM: 0xC0000000 [ 3.00 GB ]
EMMC: 150100474436424D420128226B665CF
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GD6BMB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x747C00000 [ 29.12 GB ]
CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : A9C28950AFA24F7BA77149CE3D9E10F7
DA : USB : HIGH-SPEED
Boot done!
Format Ok : USERDATA
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:14
The Following User Says Thank You to akeel2000 For This Useful Post:
Old 05-17-2019, 15:52   #834 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Nokia 215 reset password done by cm2
PORT : 29
BROM : Init BROM
BROM init passed!
BROM : MEID : 5DA39B80632FD72C3DFD9511C5C22E78
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : JET.10.01.11.p1
AGENT : JET.10.01.11.p1
BOOT : DA sent
DA : Sync Passed!
NOR: 00C2 : 0025 : 0038 : 0000
NOR: [MXIC] MX25U12835FZNI_10G
NOR:
TSIZE : 0x01000000 [ 16.00 MB ]
PSIZE : 0x01000000 [ 16.00 MB ]
STYPE : 0x00000000
STATUS : OK
Boot done!
FFS Info exists in MAUI : 0x00E80000 : 0x00174000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:30
Old 05-19-2019, 10:43   #835 (permalink)
niaz muhammad's Avatar
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,951
NOKIA 1LITER TA-1047 FRP RESET DON
Card found : 8C73AEBC , v0122
PTFN : MediaTek PreLoader USB VCOM (Android) (COM19)
MODE : PRELOADER PORT
PORT : 19
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     TYPE : LEGACY MTK
BROM : PRELOADER PORT
AGENT : Found MT6735
BROM : DA sent
     DA : AGENT started!
NAND : DEVICE NOT FOUND
eMMC : OK
eMMC : 150100464E36324D42034DF1D09725A7
DAInf: 4 : 2 : 155
     DA : DRAM ready!
        EMMC: 150100464E36324D42034DF1D09715A7
        EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB
        EMMC:
              RPMB   : 0x00080000 [ 512.00 KB ]
              USER   : 0x1D2000000 [ 7.28 GB ]
        SRAM: 0x00020000 [ 128.00 KB ]
        DRAM: 0x40000000 [ 1.00 GB ]
        CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 24AEAEB6C5CC487C755D6112F60C7A97
 STATUS : BLANK FLASH
 BSTYLE : EMMC FLASH BOOT
Boot done!
Format Ok : CACHE
Done!
Elapsed: 00:00:27
The Following User Says Thank You to niaz muhammad For This Useful Post:
Old 05-20-2019, 08:03   #836 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Nokia 105 reset password done by best
Phone found!
read info... - Ok
Reading Phone Info....
SW ver : V 03.40 08-08-13 RM-908 (c) Nokia
IMEI : 359193052364494
PPM : V 02.70
22-02-13
RM-908
(c) Nokia
IA
PCode : 059R452
BPCode : 059T865
HWID : 2000
LCDVer : CMI:BEIHAIv01
ILI9163C
Sl Conf : 001-01-00000000000
Sl Prof : 000000000004000-2
Sl Aux : 000B0000
Hw Sig : A3E2A5F0DFC9458E
Country : Test SIM (Open)
Operator : NOKIA (Open)
Lock info:
Done!
Check phone mode...
Phone in Local mode
Test mode set
Set OK!
Set OK!
Set OK!
Set OK!
Set OK!
Set OK!
Elapsed: 00:00:14
Old 05-22-2019, 14:00   #837 (permalink)
.::EXTREME::.'s Avatar
Member: 1619462
Sonork: 100.1606509
Thanks Meter: 1,517
Nokia 5.1. TA1105 V 9.0 FRP reset done
Nokia 5.1. TA1105 V 9.0 FRP Reset Done
PTFN : MTK USB Port (COM7)
MODE : BOOTROM
PORT : 7
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMMC: 90014A68423861503E016738EEFB657B
EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP>
EMMC:
RPMB : 0x01000000 [ 16.00 MB ]
RNID : A4BC9FBB98A69460C4DBEC328F21A4
Boot done!
--- SysInfoSub [PART A]:
Patch Level : O11019
Display ID : 00WW_1_080
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2018-09-05
Build Time : 1535654259
Product Model : PDA
Product Brand : alps
Product Name : PDA_00WW_FIH
Product Device : PDA
Product Manfct : alps
Product Info : PDA
Product Board : PDA
Board Platform : mt6771
--- SysInfoSub [PART B]:
Patch Level : PPR1.180610.011
Display ID : 0001_2_16A
Ver. CodeName : REL
Ver. Release : 9
Sec. Patch : 2019-04-05
Build Time : 1555600727
Product Model : FIH-PDA
Product Name : fih_mt6771_64_0001
Product Device : PDA_sprout
Product Info : fih_mt6771_64
Product Board : fih_mt6771_64
--- SecuritySub :
NVRAM check : Passed!
Done!
Elapsed: 00:01:12
MODE : BOOTROM
PORT : 7
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMMC:
Boot done!
Done!
Elapsed: 00:00:17
The Following User Says Thank You to .::EXTREME::. For This Useful Post:
Old 05-23-2019, 06:42   #838 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Nokia 206 reset password done by best
Phone found!
read info... - Ok
Connected phone - 206
Software ver : V 03.58 05-12-12 RM-872 (c) Nokia
IMEI 1 :
IMEI 2 :
XappVer : 000008F2
PPM : V 03.58 05-12-12 RM-872 (c) Nokia M2
CNT : Content: m2_059R6D9 V 03.58 05-12-12 RM-872 (c) Nokia
Product SN : 218A2EEBH
Product code : 059S8K7
Base Prd.code: 059P6H3
Module code : 0205283
Long Prod.SN : 0
Hardware info=======
HWID : 1601
Battery: 5110 mV
CMT BT: 19b5-22012
LCDVer: AUO
Lock info ===========
IMEI :
IMEI spNet : 3A 85 73 01 65 55 25 06
IMEI svNet : 33 85 73 01 65 55 25 06 F5
Sl Prof : 800000000004000-B
Sl Aux : 000B0000
Hw Sig : 5D35574E4BF75307
Lock info:
Block 1
L1:Open; L2:Open; L3:Open; L4:Open; L5:Open;
Block 2
Block 3
Block 4
Block 5
Block 6
Block 7
Error collect lock info, try again
CRT308 Backup Created
CMLA Key status : Ok
SimLock status : Ok
Security status : Ok
PA_SimLock Version :
PA_SL30 (20 digit) phone detected...
User Code : 25524
MMC pwd : no any record found
UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery]
Done!
Check phone mode...
Phone in Local mode
Test mode set
Set OK!
Set OK!
Set OK!
Set OK!
Set OK!
Set OK!
Elapsed: 00:00:12
Phone disconected!
Old 05-25-2019, 09:44   #839 (permalink)
JONONItelecom™'s Avatar
Member: 1076772
Sonork: 100.1601881
Thanks Meter: 2,847
TA-1102} PHONE LOCK FRP DONE
Operation : Reset Settings [ v1.15 ]
PTFN : MTK USB Port (COM20)
MODE : BOOTROM
PORT : 20
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
AGENT : Nokia_All_InOne_DA_v04.2019.0804
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMMC: 90014A68423861503E016647EEC6755D
EMMC:
RNID : 546D3848553355001BBFF48C3BB0C00D
Boot done!
Done!
Elapsed: 00:00:19
The Following 2 Users Say Thank You to JONONItelecom™ For This Useful Post:
Old 05-27-2019, 07:41   #840 (permalink)
Member: 953334
Sonork: 100.1614005
Nokia 230 Format /Reset Settings Done
PTFN : MediaTek PreLoader USB VCOM Port (COM23)
PORT : 23
BROM : Init BROM
BROM init passed!
BROM : MEID : ACFA02DE26017715DFEAA58130C789AC
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : DOHA.13.00.11.p1
AGENT : DOHA.13.00.11.p1
BOOT : DA sent
DA : Sync Passed!
NOR: 00EF : 0060 : 0018 : 0000
NOR: [WINBOND] W25Q128FW
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
FFS Info exists in MAUI : 0x00DC0000 : 0x00234000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:45
Page generated in 0.36978 seconds with 9 queries
