06-10-2019, 16:17 | #856 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Nokia 2 reset frp done by nokia best2 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.09 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.09 Operation : Identify [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] BB_IDC_SWB : 00000000 ID_BLOCK_S : 12F9205A ID_BLOCK_I : 009600E1 ID_BLOCK_L : 565CB9899B112DBAF328A9A33534E92B ID_BLOCK_L : 8BB9AE5256BB65307A11A55CE97F96D1 Use BEST Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Brand : Nokia ProdName : Dynamo_00WW ProdModel : Nokia 2 Device : E1M Manufact. : HMD Global NickName : Nokia 2 Dev Build : Dynamo_00WW-user 7.1.1 NMF26F 00WW_0_64C release-keys Dev CPU : MSM8909 Dev SKU : 600WW SKU Vendor: NOKIA SKU Locale: Worldwide SKU Carier: FIH Generic FXCN_SW : E1M-064C-0-00WW-B0 USERData : PLAIN ( NON-ENCRYPTED ) FRP State : ON ( ACTIVE ) Done! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Reset Settings [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] BB_IDC_SWB : 00000000 ID_BLOCK_S : 12F9205A ID_BLOCK_I : 009600E1 ID_BLOCK_L : 565CB9899B112DBAF328A9A33534E92B ID_BLOCK_L : 8BB9AE5256BB65307A11A55CE97F96D1 Use BEST Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
The Following User Says Thank You to A.G.Shahid For This Useful Post: |
06-11-2019, 07:42 | #857 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 216 Flash Done Operation : Write FirmWare [ v1.16 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM20) MODE : NOKIA USB SERIAL PORT : 20 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : F6F3282FDA794AC3FD65077E20686ADE BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : SUEZ.12.00.11.p1 BOOT : SWR : 12.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : SUEZ.12.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 12.00.11 [RM-1187] DEV SoftwareVersion : 12.00.11 SWInfo compare result : SAME Load FlashSet : MROM : RM-1187_SUEZ_ROM_eMP_12.00.11 LANG : RM-1187_SUEZ_LANG_PACK_ROM_IJ_eMP_12.00.11 CUST : RM-1187_SUEZ_CUSTPACK_ROM_IJ_eMP_12.00.11 JUMP : RM-1187_SUEZ_JUMP_TABLE_IJ_eMP_12.00.11 VIVA : RM-1187_SUEZ_VIVA_eMP_12.00.11 Prepare FlashSet : DCR : RM-1187_SUEZ_ROM_eMP_12.00.11 DCR : RM-1187_SUEZ_LANG_PACK_ROM_IJ_eMP_12.00.11 DCR : RM-1187_SUEZ_CUSTPACK_ROM_IJ_eMP_12.00.11 DCR : RM-1187_SUEZ_JUMP_TABLE_IJ_eMP_12.00.11 DCR : RM-1187_SUEZ_VIVA_eMP_12.00.11 Prepare Target SDS : OK : 0x00FF4000 : 0x0000C000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : RM-1187_SUEZ_ROM_eMP_12.00.11 Write : RM-1187_SUEZ_LANG_PACK_ROM_IJ_eMP_12.00.11 Write : RM-1187_SUEZ_CUSTPACK_ROM_IJ_eMP_12.00.11 Write : RM-1187_SUEZ_JUMP_TABLE_IJ_eMP_12.00.11 Write : RM-1187_SUEZ_VIVA_eMP_12.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : RM-1187_SUEZ_ROM_eMP_12.00.11 Verify : RM-1187_SUEZ_LANG_PACK_ROM_IJ_eMP_12.00.11 Verify : RM-1187_SUEZ_CUSTPACK_ROM_IJ_eMP_12.00.11 Verify : RM-1187_SUEZ_JUMP_TABLE_IJ_eMP_12.00.11 Verify : RM-1187_SUEZ_VIVA_eMP_12.00.11 Done! Elapsed: 00:03:06 Reconnect Power/Cable! |
The Following User Says Thank You to Luckey1 For This Useful Post: |
06-11-2019, 16:16 | #858 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Abidjan,ivory coast
Member: 1272267 Status: Offline Sonork: 100.1667652 Thanks Meter: 407 | nokia ta-1034 reset settings done by infinty best Operation : Reset Settings [ v1.16 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM92) MODE : NOKIA USB SERIAL PORT : 92 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : C1D6F6924CF7D8CE736902006F26735C BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.30.04.11.p1 BOOT : SWR : 30.04.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.30.04.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4,00 MB ] PSIZE : 0x00400000 [ 4,00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00370000 : 0x00088000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:27 Reconnect Power/Cable! |
The Following User Says Thank You to Freeboy08 For This Useful Post: |
06-11-2019, 16:19 | #859 (permalink) |
Member: 1272267 Status: Offline Sonork: 100.1667652 Thanks Meter: 407 | nokia ta-1114 reset settings done by infinty best 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM92) MODE : NOKIA USB SERIAL PORT : 92 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 6D3FA0D482915D92458F7E124EF80C8D BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NEMO61D.10.00.11.p2 BOOT : SWR : 10.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : NEMO61D.10.00.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4,00 MB ] PSIZE : 0x00400000 [ 4,00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00370000 : 0x00088000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:27 |
The Following 2 Users Say Thank You to Freeboy08 For This Useful Post: |
06-11-2019, 18:48 | #860 (permalink) |
No Life Poster Join Date: Aug 2011 Location: United Kingdom
Member: 1638915 Status: Offline Thanks Meter: 432 | nokia 3 ta 1020 frp lock Done Operation : Identify [ v1.09 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM9) MODE : PRELOADER PORT PORT : 9 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v02.2018.1809 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 13014E51324A393652100517A480200B DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 13014E51324A393652100517A480340B EMMC: VEN : MICRON | OEM : 4E01 | DEV : Q2J96R EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 9349C4CD2195D2ED86FF4FFAA8DDCEBE STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! --- SysInfoSub : Patch Level : NMF26O Display ID : 00WW_2_15F Ver. CodeName : REL Ver. Release : 7.1.1 Sec. Patch : 2017-11-06 Build Time : 1508913978 Product Model : NE1 Product Brand : alps Product Name : NE1_00WW_FIH Product Device : NE1 Product Manfct : alps Board Platform : mt6737m Product Info : NE1 --- SecuritySub : IMEI[0] : 356802081655*** NVRAM check : Passed! Done! Elapsed: 00:01:19 Reconnect Power/Cable! Operation : Reset Settings [ v1.09 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM9) MODE : PRELOADER PORT PORT : 9 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v02.2018.1809 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 13014E51324A393652100517A480200B DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 13014E51324A393652100517A480340B EMMC: VEN : MICRON | OEM : 4E01 | DEV : Q2J96R EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 9349C4CD2195D2ED86FF4FFAA8DDCEBE STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Done! Elapsed: 00:00:42 Reconnect Power/Cable! |
The Following User Says Thank You to bux_harun For This Useful Post: |
06-15-2019, 08:56 | #861 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 5130 flashing done Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm495__07.97.mcusw PPM : rm495__07.97.ppm_mena_a1 CNT : rm495__07.97.image_mena_a1_red Flashing phone now... [Gen] Rules accepted for : RAP3x Generation Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 22700111F3967D560651F9EFA80F71E6C502AC18 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ===Flashing [MCU]=== Erase : Processing rm495__07.97.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:56 Write : Processing rm495__07.97.mcusw Total 1178 [1178/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:57 MCU Write done ===Flashing [PPM]=== Erase : Processing rm495__07.97.ppm_mena_a1 Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:47 Write : Processing rm495__07.97.ppm_mena_a1 Total 388 [388/0/0] blocks to write, writing... TIME : Write time : 00:00:18 PPM Write done ===Flashing [CNT]=== Erase : Processing rm495__07.97.image_mena_a1_red Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:04:17 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm495__07.97.image_mena_a1_red Total 656 [656/0/0] blocks to write, writing... TIME : Write time : 00:00:32 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:08:49 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5130 Software Info: V 07.97 13-09-10 RM-495 (c) Nokia IMEI: 353223039566535 PPM version : V 07.97 13-09-10 RM-495 (c) Nokia MEN Product code: 0579262 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 0 certs Uploading User Certificates... Uploaded 26 certs! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:10:04 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
The Following 4 Users Say Thank You to Luckey1 For This Useful Post: |
06-18-2019, 13:35 | #862 (permalink) |
No Life Poster Join Date: Jun 2004 Location: MACEDONIA
Member: 67805 Status: Offline Thanks Meter: 364 | SP Unlock Nokia 3.1 TA-1057 Code: Card found : 18534988 , v0118 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.15 Operation : SP Unlock [ v1.15 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM21) MODE : BOOTROM PORT : 21 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6755 AGENT : Nokia_All_InOne_DA_v04.2019.0804 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: 90014A484147346132A505B3D04B35CB EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3AB400000 [ 14,68 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : C0DF9A470FFF3C8A61BE58111630E9D DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : DA USB VCOM Port (COM94) MODE : PRELOADER PORT PORT : 94 Boot done! ID0 : Lock : Locked! | MNC : 256 | CNT : 5 | CODE : 1741112835095463 ID1 : Lock : Not Locked! ID2 : Lock : Not Locked! ID3 : Lock : Not Locked! ID4 : Lock : Not Locked! ID5 : Lock : Not Locked! ID6 : Lock : Not Locked! Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to MOBICOM For This Useful Post: |
06-21-2019, 08:13 | #863 (permalink) |
No Life Poster Join Date: Mar 2016 Location: Ukraine
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Nokia 3310 TA-1030 Write Flash Done Nokia 3310 TA-1030 Write Flash Done Identify Code: Operation : Identify [ v1.16 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM69) MODE : NOKIA USB SERIAL PORT : 69 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : DC286C47436B1E492ABD36F38EBA44C9 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.11.02.11.p1 BOOT : SWR : 11.02.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : RETRO.11.02.11.p1 FLASH : 00EF : 0060 : 0018 : 0000 BBSN : DC286C47436B1E492ABD36F38EBA44C9 PRDC : 059Z024 IMEI[1] : 357330086440245 IMEI[2] : 357330086440252 NCK : 20 digits PROV : 24407000 Saved as : 357330086440245.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:01:05 Code: Operation : Write FirmWare [ v1.16 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM69) MODE : NOKIA USB SERIAL PORT : 69 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : DC286C47436B1E492ABD36F38EBA44C9 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.11.02.11.p1 BOOT : SWR : 11.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : RETRO.11.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16,00 MB ] PSIZE : 0x01000000 [ 16,00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 11.02.11 [TA-1030] DEV SoftwareVersion : 11.02.11 SWInfo compare result : SAME Load FlashSet : MROM : TA-1030_ROM_eMP_11.02.11 LANG : TA-1030_LANG_PACK_ROM_EI_eMP_11.02.11_001 CUST : TA-1030_CUSTPACK_ROM_EI_EURO_RU_eMP_11.02.11_001 JUMP : TA-1030_JUMP_TABLE_EI_EURO_RU_eMP_11.02.11_001 VIVA : TA-1030_VIVA_eMP_11.02.11 Prepare FlashSet : DCR : TA-1030_ROM_eMP_11.02.11 DCR : TA-1030_LANG_PACK_ROM_EI_eMP_11.02.11_001 DCR : TA-1030_CUSTPACK_ROM_EI_EURO_RU_eMP_11.02.11_001 DCR : TA-1030_JUMP_TABLE_EI_EURO_RU_eMP_11.02.11_001 DCR : TA-1030_VIVA_eMP_11.02.11 Prepare Target SDS : OK : 0x00FF4000 : 0x0000C000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : TA-1030_ROM_eMP_11.02.11 Write : TA-1030_LANG_PACK_ROM_EI_eMP_11.02.11_001 Write : TA-1030_CUSTPACK_ROM_EI_EURO_RU_eMP_11.02.11_001 Write : TA-1030_JUMP_TABLE_EI_EURO_RU_eMP_11.02.11_001 Write : TA-1030_VIVA_eMP_11.02.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1030_ROM_eMP_11.02.11 Verify : TA-1030_LANG_PACK_ROM_EI_eMP_11.02.11_001 Verify : TA-1030_CUSTPACK_ROM_EI_EURO_RU_eMP_11.02.11_001 Verify : TA-1030_JUMP_TABLE_EI_EURO_RU_eMP_11.02.11_001 Verify : TA-1030_VIVA_eMP_11.02.11 Done! Elapsed: 00:03:37 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to localizator For This Useful Post: |
06-25-2019, 12:15 | #864 (permalink) |
Major Poster Join Date: Oct 2015 Location: Vietnams
Member: 2478964 Status: Offline Sonork: Zalo:0932606079 Thanks Meter: 24 | Nokia 3.1 Plus Fomat + FRP done thanks Infinity-Box 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.16 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM33) MODE : BOOTROM PORT : 33 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_ARB BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6765 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100474436424D42019FCA764A567 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GD6BMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 692C87E525950ADDA28F6FC62A9E465E DA : USB : HIGH-SPEED Boot done! --- SysInfoSub [PART A]: Sec. Patch : 2019-05-05 Patch Level : PPR1.180610.011 Display ID : 0001_2_25G Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-05-05 Build Time : 1557036034 Product Model : FIH-ROO Product Brand : alps Product Name : fih_mt6762_64_0001 Product Device : ROO_sprout Product Manfct : alps Product Info : fih_mt6762_64 Product Board : fih_mt6762_64 Board Platform : mt6765 --- SysInfoSub [PART B]: Sec. Patch : 2019-02-05 Patch Level : PPR1.180610.011 Display ID : 0001_2_230 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-02-05 Build Time : 1548958676 Product Model : FIH-ROO Product Brand : alps Product Name : fih_mt6762_64_0001 Product Device : ROO_sprout Product Manfct : alps Product Info : fih_mt6762_64 Product Board : fih_mt6762_64 Board Platform : mt6765 --- SecuritySub : NVRAM check : Passed! Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM33) MODE : BOOTROM PORT : 33 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_ARB BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6765 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100474436424D42019FCA764A567 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GD6BMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 692C87E525950ADDA28F6FC62A9E465E DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : RESET PROTECTION Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to SmartGsmViet For This Useful Post: |
06-27-2019, 07:27 | #865 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Nokia 230 reset password done by best Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.16 Operation : Identify [ v1.16 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM3) MODE : NOKIA USB SERIAL PORT : 3 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 9F45181A1F562571C4DD8DF2D4D58773 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DOHA.13.00.11.p1 BOOT : SWR : 13.00.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : DOHA.13.00.11.p1 FLASH : 00EF : 0060 : 0018 : 0000 BBSN : 9F45181A1F562571C4DD8DF2D4D58773 PRDC : 059X4P8 IMEI[1] : 3548930xxxxxxxx IMEI[2] : 3548930xxxxxxxx NCK : 20 digits PROV : 24407000 Saved as : 3548930xxxxxxxx.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:01:00 Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM3) MODE : NOKIA USB SERIAL PORT : 3 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 9F45181A1F562571C4DD8DF2D4D58773 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DOHA.13.00.11.p1 BOOT : SWR : 13.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : DOHA.13.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00DC0000 : 0x00234000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
06-27-2019, 12:05 | #866 (permalink) |
No Life Poster Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 | Nokia Ta-1066 Flashing done...... Code: Operation : Write FW [ v1.16 ] Setting : UserData preserve : False Setting : Flash Pre-Erase : True Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM14) MODE : PRELOADER PORT PORT : 14 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 150100464E36324D420311389AF6BD1F DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464E36324D420311389AF6C41F EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 78CAE96A18FC41692D7D2BD4A4CB813C STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! DL_INFO : PMT present SEC_DL : False (CUST) SEC_ID : 0x67887C7972766E6888787678777B796E [FL] : HW verification passed! Erase : 0x0000000000000000 : 0x0000000000080000 Erase : 0x0000000001C80000 : 0x0000000008900000 Erase : 0x000000000ADC0000 : 0x0000000000100000 Erase : 0x000000000B000000 : 0x00000000D4800000 PMT Update : OK Flashing now ... PROCESS : PRELOADER Unpack : FRT-0-028D-00WW-1-2-preloader_FRT.bin Flash : FRT-0-028D-00WW-1-2-preloader_FRT.bin Update bootloader code ... Update bootloader Ok! PROCESS : LK Unpack : FRT-0-028D-00WW-1-2-lk.img Flash : FRT-0-028D-00WW-1-2-lk.img PROCESS : BOOT Unpack : FRT-0-028D-00WW-1-2-boot.img Flash : FRT-0-028D-00WW-1-2-boot.img PROCESS : RECOVERY Unpack : FRT-0-028D-00WW-1-2-recovery.img Flash : FRT-0-028D-00WW-1-2-recovery.img PROCESS : LOGO Unpack : FRT-0-028D-00WW-1-2-logo.bin Flash : FRT-0-028D-00WW-1-2-logo.bin PROCESS : SECRO Unpack : FRT-0-028D-00WW-1-2-secro.img Flash : FRT-0-028D-00WW-1-2-secro.img PROCESS : TEE1 Unpack : FRT-0-028D-00WW-1-2-tee.img Flash : FRT-0-028D-00WW-1-2-tee.img PROCESS : TEE2 Unpack : FRT-0-028D-00WW-1-2-tee.img Flash : FRT-0-028D-00WW-1-2-tee.img PROCESS : ODMDTBO Unpack : FRT-0-028D-00WW-1-2-odmdtbo.img Flash : FRT-0-028D-00WW-1-2-odmdtbo.img PROCESS : SYSTEMINFO Unpack : fver Flash : fver PROCESS : SUTINFO Unpack : FRT-00WW-001-sutinfo.img Flash : FRT-00WW-001-sutinfo.img PROCESS : CDA Unpack : FRT-00WW-011-cda.img Flash : FRT-00WW-011-cda.img PROCESS : VENDOR Unpack : FRT-0-028D-00WW-1-2-vendor.img Flash : FRT-0-028D-00WW-1-2-vendor.img PROCESS : SYSTEM Unpack : FRT-0-028D-00WW-1-2-system.img Flash : FRT-0-028D-00WW-1-2-system.img PROCESS : CACHE Unpack : FRT-0-028D-00WW-1-2-cache.img Flash : FRT-0-028D-00WW-1-2-cache.img PROCESS : USERDATA Unpack : FRT-0-028D-00WW-1-2-userdata.img Flash : FRT-0-028D-00WW-1-2-userdata.img PMT Update : OK SEC_DL : False (CUST) SEC_ID : 0x67887C7972766E6888787678777B796E Flashing finished! Done! Elapsed: 00:02:42 Reconnect Power/Cable! |
The Following User Says Thank You to 4G Telecom For This Useful Post: |
06-28-2019, 07:18 | #867 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,419 | Nokia 108 Flashing Done Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-944_ROM_eMP_20.06.11 VIVA : RM-944_VIVA_eMP_20.06.11 LANG : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 CUST : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 JMPT : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 20 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 7DDAF539B30448C1391537275947CAF5 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Bree.20.06.11.p4 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 SecureDecrypt : RM-944_ROM_eMP_20.06.11 SecureDecrypt : RM-944_VIVA_eMP_20.06.11 SecureDecrypt : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 SecureDecrypt : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 SecureDecrypt : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 OVRLP : 000069B900000001 PHPID : Bree.20.06.11.p4 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-944_ROM_eMP_20.06.11 Write : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 Write : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 Write : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 Write : RM-944_VIVA_eMP_20.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-944_ROM_eMP_20.06.11 [VERIFY] DONE : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 [VERIFY] DONE : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 [VERIFY] DONE : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 [VERIFY] DONE : RM-944_VIVA_eMP_20.06.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:06 Reboot phone Ok Connect phone on selected interface... |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
06-30-2019, 09:18 | #868 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,419 | Nokia 105 TA-1034 Format Done Operation : Reset Settings [ v1.16 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM20) MODE : NOKIA USB SERIAL PORT : 20 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : F6F00715D3DADC50BCF8656A82203303 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.30.04.11.p1 BOOT : SWR : 30.04.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.30.04.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00370000 : 0x00088000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
07-01-2019, 10:25 | #869 (permalink) |
Freak Poster Join Date: Jun 2009
Member: 1051138 Status: Offline Sonork: 123456 Thanks Meter: 382 | nokia 5.1 plus frp+formate done Operation : Reset Settings [ v1.16 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM15) MODE : BOOTROM PORT : 15 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_ARB BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6771 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100474436424D420128226B665CF EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GD6BMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A9C28950AFA24F7BA77149CE3D9E10F7 DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : RESET PROTECTION Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to akeel2000 For This Useful Post: |
07-05-2019, 07:30 | #870 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,213 | Rm-969 20.14.11.p1 upgrade to ver 30x Code: Operation : Write FirmWare [ v1.16 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM54) MODE : NOKIA USB SERIAL PORT : 54 BROM : Init BROM BROM init passed! CHIP : MT625A , SBID : 0xCA01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : B57707CCCC474B5F6AA8D7CF82482E01 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : Rivendell.20.14.11.p1 BOOT : SWR : 20.14.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT625A AGENT : Rivendell.20.14.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x88 NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 31.01.11 [RM-969] DEV SoftwareVersion : 20.14.11 SWInfo compare result : DEVICE SW ( Major version ) is LOWER, than in VPL! Load FlashSet : MROM : RM-969_ROM_eMP_31.01.11 LANG : RM-969_LANG_PACK_ROM_IC_eMP_31.01.11_001 CUST : RM-969_CUSTPACK_ROM_IC_MEA_JO_eMP_31.01.11_001 JUMP : RM-969_JUMP_TABLE_IC_MEA_JO_eMP_31.01.11_001 VIVA : RM-969_VIVA_eMP_31.01.11 Prepare FlashSet : DCR : RM-969_ROM_eMP_31.01.11 DCR : RM-969_LANG_PACK_ROM_IC_eMP_31.01.11_001 DCR : RM-969_CUSTPACK_ROM_IC_MEA_JO_eMP_31.01.11_001 DCR : RM-969_JUMP_TABLE_IC_MEA_JO_eMP_31.01.11_001 DCR : RM-969_VIVA_eMP_31.01.11 Prepare Target SDS : OK : 0x00FF4000 : 0x0000C000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : RM-969_ROM_eMP_31.01.11 Write : RM-969_LANG_PACK_ROM_IC_eMP_31.01.11_001 Write : RM-969_CUSTPACK_ROM_IC_MEA_JO_eMP_31.01.11_001 Write : RM-969_JUMP_TABLE_IC_MEA_JO_eMP_31.01.11_001 Write : RM-969_VIVA_eMP_31.01.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : RM-969_ROM_eMP_31.01.11 Verify : RM-969_LANG_PACK_ROM_IC_eMP_31.01.11_001 Verify : RM-969_CUSTPACK_ROM_IC_MEA_JO_eMP_31.01.11_001 Verify : RM-969_JUMP_TABLE_IC_MEA_JO_eMP_31.01.11_001 Verify : RM-969_VIVA_eMP_31.01.11 Done! Elapsed: 00:02:51 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to mbiborna For This Useful Post: |
