07-06-2019, 19:49 | #871 (permalink) |
Freak Poster Join Date: Nov 2017 Location: In Your Mind
Member: 2778467 Status: Offline Sonork: only Telegram Thanks Meter: 265 | Nokia 3310 3G TA-1030 Flash Done With BEST2 Nokia 3310 3G TA-1030 Flash Done Operation : Write FirmWare [ v1.16 ] Setting : UserData erase : False Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM88) MODE : NOKIA USB SERIAL PORT : 88 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : AB83F9E52DBE33FC196FDC0AF8C92B3C BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.11.02.11.p1 BOOT : SWR : 11.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : RETRO.11.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00C2 : 0025 : 0038 : 0000 NOR: [MXIC] MX25U12835FZNI_10G NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 11.02.11 [TA-1030] DEV SoftwareVersion : 11.02.11 SWInfo compare result : SAME Load FlashSet : MROM : TA-1030_ROM_eMP_11.02.11 LANG : TA-1030_LANG_PACK_ROM_IJ_eMP_11.02.11_001 CUST : TA-1030_CUSTPACK_ROM_IJ_MEA_IR_eMP_11.02.11_001 JUMP : TA-1030_JUMP_TABLE_IJ_MEA_IR_eMP_11.02.11_001 VIVA : TA-1030_VIVA_eMP_11.02.11 Prepare FlashSet : DCR : TA-1030_ROM_eMP_11.02.11 DCR : TA-1030_LANG_PACK_ROM_IJ_eMP_11.02.11_001 DCR : TA-1030_CUSTPACK_ROM_IJ_MEA_IR_eMP_11.02.11_001 DCR : TA-1030_JUMP_TABLE_IJ_MEA_IR_eMP_11.02.11_001 DCR : TA-1030_VIVA_eMP_11.02.11 Prepare Target SDS : OK : 0x00FF4000 : 0x0000C000 Erase Target Flash Erase done! Write Target Flash Write : TA-1030_ROM_eMP_11.02.11 Write : TA-1030_LANG_PACK_ROM_IJ_eMP_11.02.11_001 Write : TA-1030_CUSTPACK_ROM_IJ_MEA_IR_eMP_11.02.11_001 Write : TA-1030_JUMP_TABLE_IJ_MEA_IR_eMP_11.02.11_001 Write : TA-1030_VIVA_eMP_11.02.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1030_ROM_eMP_11.02.11 Verify : TA-1030_LANG_PACK_ROM_IJ_eMP_11.02.11_001 Verify : TA-1030_CUSTPACK_ROM_IJ_MEA_IR_eMP_11.02.11_001 Verify : TA-1030_JUMP_TABLE_IJ_MEA_IR_eMP_11.02.11_001 Verify : TA-1030_VIVA_eMP_11.02.11 Done! Elapsed: 00:02:54 Reconnect Power/Cable! Card found : 6A0C738C , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.16 Thanks Infinity |
The Following 2 Users Say Thank You to sajidi1984 For This Useful Post: |
07-07-2019, 21:34 | #872 (permalink) |
No Life Poster Join Date: Feb 2018 Location: Nigeria
Member: 2812901 Status: Offline Thanks Meter: 493 | NOKIA 1 TA-1047 RESET PROTECTION DONE BY CM2 Card found : F61C9Axx , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.16 Operation : Reset Settings [ v1.16 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM29) MODE : PRELOADER PORT PORT : 29 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 90014A483847346132A5C2E34D816025 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483847346132A5C2E34D816525 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 6CDA999EFDAAC685D86CB75649B9B529 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Done! Elapsed: 00:00:27 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Oyetunde Semiu For This Useful Post: |
07-07-2019, 21:36 | #873 (permalink) |
Member: 2812901 Status: Offline Thanks Meter: 493 | Nokia 230 rm 1172 Reset code done by infinity-best Card found: S/N : F61C9Axx , v0136 Registered to: TUNDE Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Phone disconected! Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 30 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 2DAFB46F12160C48B4EFB17C2B6C36B6 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 30 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 2DAFB46F12160C48B4EFB17C2B6C36B6 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
07-14-2019, 09:24 | #874 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,802 | Nokia 3310 TA-1030 security code reset done Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 9 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 9405867D280DDFAEE24F748D08442932 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
The Following 3 Users Say Thank You to profkefah For This Useful Post: |
07-14-2019, 09:52 | #875 (permalink) | |
Member: 2371500 Status: Offline Thanks Meter: 5,802 | video tutorial Nokia 3310 TA-1030 security code reset done video tutorial Nokia 3310 TA-1030 security code reset done Quote:
The Following 2 Users Say Thank You to profkefah For This Useful Post: |
07-20-2019, 10:10 | #876 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Ethiopia
Member: 449991 Status: Offline Thanks Meter: 933 | world first nokia 1plus TA-1130 dm veryfication failed done world first nokia 1plus TA-1130 dm veryfication failed done Card found : Infinity-Box BEST Nokia [HMD] Module [NK2] v1.16 Load : C:\Users\d-max\Desktop\ANT-0360-0-00WW-B02.nb0 Load Ok! Operation : Write FW [ v1.16 ] Setting : UserData preserve : False Setting : Flash Pre-Erase : True Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MTK USB Port (COM530) MODE : BOOTROM PORT : 530 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_ARB BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6739 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 150100464E36324D42032F59C6CFC56B EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A3121C655C5FC64C4E525DCC144A93FE DA : USB : HIGH-SPEED Boot done! DL_INFO : PMT present SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : HW verification passed! Erase : 0x0000000000000000 : 0x0000000002000000 Erase : 0x0000000002800000 : 0x0000000004000000 Erase : 0x0000000007800000 : 0x0000000000800000 Erase : 0x000000000B300000 : 0x0000000000800000 Erase : 0x000000000C440000 : 0x00000000003C0000 Erase : 0x000000000CA80000 : 0x0000000005200000 Erase : 0x0000000012180000 : 0x0000000000200000 Erase : 0x00000000123A0000 : 0x00000000B5C60000 PMT Update : OK Flashing now ... PROCESS : PRELOADER Unpack : ANT-0-0360-00WW-1-1-preloader_ANT.bin Flash : ANT-0-0360-00WW-1-1-preloader_ANT.bin Update bootloader backup copy ... Update bootloader backup copy Ok! PROCESS : RECOVERY Unpack : ANT-0-0360-00WW-1-1-recovery.img Flash : ANT-0-0360-00WW-1-1-recovery.img PROCESS : MD1IMG Unpack : ANT-0-0360-00WW-1-1-md1img.img Flash : ANT-0-0360-00WW-1-1-md1img.img PROCESS : MD1DSP Unpack : ANT-0-0360-00WW-1-1-md1dsp.img Flash : ANT-0-0360-00WW-1-1-md1dsp.img PROCESS : SPMFW Unpack : ANT-0-0360-00WW-1-1-spmfw.img Flash : ANT-0-0360-00WW-1-1-spmfw.img PROCESS : MCUPMFW Unpack : ANT-0-0360-00WW-1-1-mcupmfw.img Flash : ANT-0-0360-00WW-1-1-mcupmfw.img PROCESS : LK Unpack : ANT-0-0360-00WW-1-1-lk.img Flash : ANT-0-0360-00WW-1-1-lk.img PROCESS : LK2 Unpack : ANT-0-0360-00WW-1-1-lk.img Flash : ANT-0-0360-00WW-1-1-lk.img PROCESS : LOADER_EXT1 Unpack : ANT-0-0360-00WW-1-1-loader_ext.img Flash : ANT-0-0360-00WW-1-1-loader_ext.img PROCESS : LOADER_EXT2 Unpack : ANT-0-0360-00WW-1-1-loader_ext.img Flash : ANT-0-0360-00WW-1-1-loader_ext.img PROCESS : BOOT Unpack : ANT-0-0360-00WW-1-1-boot.img Flash : ANT-0-0360-00WW-1-1-boot.img PROCESS : LOGO Unpack : ANT-0-0360-00WW-1-1-logo.bin Flash : ANT-0-0360-00WW-1-1-logo.bin PROCESS : DTBO Unpack : ANT-0-0360-00WW-1-1-dtbo.img Flash : ANT-0-0360-00WW-1-1-dtbo.img PROCESS : TEE1 Unpack : ANT-0-0360-00WW-1-1-tee.img Flash : ANT-0-0360-00WW-1-1-tee.img PROCESS : TEE2 Unpack : ANT-0-0360-00WW-1-1-tee.img Flash : ANT-0-0360-00WW-1-1-tee.img PROCESS : VENDOR Unpack : ANT-0-0360-00WW-1-1-vendor.img Flash : ANT-0-0360-00WW-1-1-vendor.img PROCESS : SYSTEM Unpack : ANT-0-0360-00WW-1-1-system.img Flash : ANT-0-0360-00WW-1-1-system.img PROCESS : CACHE Unpack : ANT-0-0360-00WW-1-1-cache.img Flash : ANT-0-0360-00WW-1-1-cache.img PROCESS : USERDATA Unpack : ANT-0-0360-00WW-1-1-userdata.img Flash : ANT-0-0360-00WW-1-1-userdata.img PMT Update : OK SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 Flashing finished! Done! Elapsed: 00:02:53 Reconnect Power/Cable! |
The Following 7 Users Say Thank You to dereje For This Useful Post: |
07-20-2019, 10:57 | #877 (permalink) |
No Life Poster Join Date: Dec 2005 Location: KARACHI PAKISTAN Age: 45
Member: 207561 Status: Offline Thanks Meter: 820 | Nokia ONEPLUS TA-1033 FRP RESET SUCCSUS FULLY RESET.. Code: Card found : 4B42917A , v0118 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.16 Operation : Identify [ v1.16 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM39) MODE : PRELOADER PORT PORT : 39 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6739 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 150100464E36324D4203E59DC6FD2655 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E7456800D343DBECBD38A467DA7DA35A DA : USB : HIGH-SPEED Boot done! --- SysInfoSub [PART A]: Patch Level : PPR1.180610.011 Display ID : 00WW_0_630 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-03-01 Build Time : 1551425299 Product Model : ANT Product Brand : alps Product Name : ANT_00WW_FIH Product Device : ANT Product Manfct : alps Product Info : ANT Product Board : ANT Board Platform : mt6739 --- SecuritySub : NVRAM check : Passed! Done! Elapsed: 00:00:21 Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM39) MODE : PRELOADER PORT PORT : 39 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6739 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 150100464E36324D4203E59DC6FD2655 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E7456800D343DBECBD38A467DA7DA35A DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to love_4all For This Useful Post: |
07-22-2019, 22:27 | #878 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Code: Operation : Flash Firmware [FTM] [ v1.17 ] Setting : UserData preserve : False Setting : FRP Reset : True Setting : Keep SVC : False -> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Initialize Ok! Dev Model : P2A HW version : 5.0 HW variant : SDM EMMC HW RF_BAND : G_850_900_1800_1900^W_1_2_5_8^L_1_3_5_7_8_20_28_ SW version : PL2-3260-0-00WW-B06 SW CurrSlot : A SW serialnm : PL2GAR2819602391 SW secured : YES Bootloader type : SERVICE Security Version : 0004 OP : Flash OEM : oem dm-veracity Device : P2A ( PL21 ) BLType : SERVICE SecVer : 04 Device authentification ... Processing server operation ... Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Process... Finished Disconnected Finished Flash : partition : B2N-0-3260-gpt_both0.bin Flash : xbl_a : B2N-0-3260-xbl_service.elf Flash : xbl_b : B2N-0-3260-xbl_service.elf Flash : xbl_a : B2N-0-3260-xbl_service.zip Flash : abl_a : B2N-0-3260-abl_service.elf Flash : abl_b : B2N-0-3260-abl_service.elf Flash : abl_a : B2N-0-3260-abl_service.zip Flash : tz_a : B2N-0-3260-tz.mbn Flash : rpm_a : B2N-0-3260-rpm.mbn Flash : hwcfg : B2N-0-3260-hwcfg.img Flash : hyp_a : B2N-0-3260-hyp.mbn Flash : pmic_a : B2N-0-3260-pmic.elf Flash : keymaster_a : B2N-0-3260-keymaster64.mbn Flash : cmnlib_a : B2N-0-3260-cmnlib.mbn Flash : cmnlib64_a : B2N-0-3260-cmnlib64.mbn Flash : dsp_a : B2N-0-3260-dspso.bin Flash : devcfg_a : B2N-0-3260-devcfg.mbn Flash : sec : B2N-0-3260-sec.dat Flash : mdtpsecapp_a : B2N-0-3260-mdtpsecapp.mbn Flash : storsec : B2N-0-3260-storsec.mbn Flash : systeminfo_a : systeminfo.img INFO : Skip RST command! Reason : already under root OEM : oem dm-veracity Flash : modem_a : B2N-3-3260-NON-HLOS.bin Flash : mdtp_a : B2N-0-3260-mdtp.img Flash : boot_a : PL2-0-3260-00WW-boot.img Erase : boot_b Flash : system_a : PL2-0-3260-00WW-system.img SPImage : Process system_a_0 SPImage : Process system_a_1 SPImage : Process system_a_2 SPImage : Process system_a_3 SPImage : Process system_a_4 SPImage : Process system_a_5 SPImage : Process system_a_6 Flash : system_b : PL2-0-3260-00WW-system_other.img SPImage : Process system_b_0 SPImage : Process system_b_1 Flash : bluetooth_a : B2N-0-3260-BTFM.bin Flash : persist : B2N-0-3260-persist.img Erase : userdata Flash : sutinfo : PL2-00WW-001-sutinfo.img Flash : nvdef_a : B2N-0-3260-NV-default.mbn Flash : hidden_a : C1N-0-0020-0001-hidden.img.ext4 Flash : cda_a : PL2-00WW-021-cda.img Erase : ssd Erase : misc Erase : sti Flash : splash_a : PL2-00WW-021-splash.img Flash : splash2 : PL2-00WW-021-multi-splash.img Erase : ddr Flash : vendor_a : PL2-0-3260-00WW-vendor.img SPImage : Process vendor_a_0 SPImage : Process vendor_a_1 Flash : xbl_a : B2N-0-3260-xbl.elf Flash : xbl_b : B2N-0-3260-xbl.elf Flash : abl_a : B2N-0-3260-abl.elf Flash : abl_b : B2N-0-3260-abl.elf Flash : logfs : B2N-0-0000-0001-logfs_ufs_8mb.bin Flash : md4 : md4.dat OP : Reset FRP Reset FRP Ok! Done! Elapsed: 00:04:45 Reconnect Power/Cable! |
The Following 8 Users Say Thank You to JayDi For This Useful Post: |
07-22-2019, 22:28 | #879 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Code: Operation : Reset Settings [FTM] [ v1.17 ] -> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Initialize Ok! Package : NB1-5150 Device : NB1 ( NB11 ) BLType : RETAIL SecVer : 04 Device authentification ... Processing server operation ... Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Process... Finished Disconnected Finished Flash : abl_a : NB1-0-5150-00WW-abl_service.elf Flash : abl_b : NB1-0-5150-00WW-abl_service.elf Flash : xbl_a : NB1-0-5150-xbl_service.elf Flash : xbl_b : NB1-0-5150-xbl_service.elf Device reboot required! Device : NB1 ( NB11 ) BLType : SERVICE SecVer : 04 Device authentification ... Processing server operation ... Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Process... Finished Disconnected Finished FRP reset Ok! UserData reset Ok! SPImage : Process userdata_0 UserData reset Ok! Done! Elapsed: 00:01:21 |
The Following 9 Users Say Thank You to JayDi For This Useful Post: |
07-22-2019, 22:29 | #880 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Code: Operation : Flash Firmware [FTM] [ v1.17 ] Setting : UserData preserve : False Setting : FRP Reset : True Setting : Keep SVC : False -> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Initialize Ok! Dev Model : NB1 HW version : 3.1 HW variant : MSM UFS HW RF_BAND : G_850_900_1800_1900^W_1_2_4_5_8^L_1_2_3_4_5_7_8_ SW version : NB1-5150-0-00WW-B03 SW CurrSlot : A SW serialnm : NB1GAD8771711296 SW secured : YES Bootloader type : RETAIL Security Version : 0004 OP : Activate SVC Device : NB1 ( NB11 ) BLType : RETAIL SecVer : 04 Device authentification ... Processing server operation ... Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Process... Finished Disconnected Finished Flash : abl_a : NB1-0-5150-00WW-abl_service.elf Flash : abl_a : NB1-0-5150-00WW-abl_service.zip Flash : abl_b : NB1-0-5150-00WW-abl_service.zip Flash : xbl_a : NB1-0-5150-xbl_service.zip Flash : xbl_b : NB1-0-5150-xbl_service.zip Device reboot required! OP : Flash OEM : oem dm-verity Device : NB1 ( NB11 ) BLType : SERVICE SecVer : 04 Device authentification ... Processing server operation ... Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Process... Finished Disconnected Finished Flash : partition:0 : NB1-0-5150-gpt_both0.bin Flash : partition:1 : NB1-0-5150-gpt_both1.bin Flash : partition:2 : NB1-0-5150-gpt_both2.bin Flash : partition:3 : NB1-0-5150-gpt_bo***.bin Flash : partition:4 : NB1-0-5150-gpt_both4.bin Flash : partition:5 : NB1-0-5150-gpt_both5.bin Flash : tz_a : NB1-0-5150-tz.mbn Flash : rpm_a : NB1-0-5150-rpm.mbn Flash : hyp_a : NB1-0-5150-hyp.mbn Flash : pmic_a : NB1-0-5150-pmic.elf Flash : keymaster_a : NB1-0-5150-keymaster.mbn Flash : cmnlib_a : NB1-0-5150-cmnlib.mbn Flash : cmnlib64_a : NB1-0-5150-cmnlib64.mbn Flash : devcfg_a : NB1-0-5150-devcfg.mbn Flash : abl_a : NB1-0-5150-00WW-abl_service.elf Flash : abl_a : NB1-0-5150-00WW-abl_service.zip Flash : abl_b : NB1-0-5150-00WW-abl_service.zip Flash : xbl_a : NB1-0-5150-xbl_service.zip Flash : xbl_b : NB1-0-5150-xbl_service.zip INFO : Skip RST command! Reason : already under root OEM : oem dm-verity Flash : system_a : NB1-0-5150-00WW-system.img SPImage : Process system_a_0 SPImage : Process system_a_1 SPImage : Process system_a_2 SPImage : Process system_a_3 SPImage : Process system_a_4 SPImage : Process system_a_5 SPImage : Process system_a_6 Flash : system_b : NB1-0-5150-00WW-system_other.img SPImage : Process system_b_0 Flash : persist : NB1-0-5150-00WW-persist.img Flash : modem_a : NB1-0-5150-NON-HLOS.bin Flash : dsp_a : NB1-0-5150-adspso.bin Flash : boot_a : NB1-0-5150-00WW-boot.img Flash : bluetooth_a : NB1-0-5150-BTFM.bin Flash : mdtp_a : NB1-0-5150-00WW-mdtp.img Flash : logfs : NB1-0-5150-00WW-logfs_ufs_8mb.bin Flash : nvdef_a : NB1-0-5150-NV-default.mbn Erase : userdata Flash : cda_a : NB1-00WW-033-cda.img Flash : hidden_a : NB1-0-0030-0001-hidden.img.ext4 Flash : sutinfo : NB1-00WW-001-sutinfo.img Flash : splash_a : NB1-00WW-033-splash.img Flash : splash2 : NB1-0-0002-splash2.img Flash : mdtpsecapp_a : NB1-0-5150-mdtpsecapp.mbn Flash : storsec : NB1-0-5150-storsec.mbn Flash : abl_a : NB1-0-5150-00WW-abl.elf Flash : abl_b : NB1-0-5150-00WW-abl.elf Flash : xbl_a : NB1-0-5150-xbl.elf Flash : xbl_b : NB1-0-5150-xbl.elf Erase : boot_b Flash : md4 : md4.dat OP : Reset FRP Reset FRP Ok! Done! Elapsed: 00:05:02 Reconnect Power/Cable! |
The Following 10 Users Say Thank You to JayDi For This Useful Post: |
07-22-2019, 23:23 | #881 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Code: Operation : Flash Firmware [FTM] [ v1.17 ] Setting : UserData preserve : False Setting : FRP Reset : True Setting : Keep SVC : True -> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Initialize Ok! Dev Model : Deadpool HW version : 1 HW variant : QRD eMMC HW RF_BAND : GSM_850_900_1800_1900^W1_5_8^L_1_3_5_7_8_20_28_38_40 SW version : V1.03D_B01 SW CurrSlot : A SW serialnm : 4T89626AA6951002566 SW secured : YES Bootloader type : WT2 Security Version : 0002 Prepare base package, please, wait ... Prepare data package, please, wait ... Prepare update package, please, wait ... Device : Deadpool ( Deadpool ) BLType : WT2 SecVer : 02 Device authentification ... Processing server operation ... Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Process... Finished Disconnected Finished OP : Initial Process : sbl1 : sbl1.mbn Process : rpm : rpm.mbn Process : dsp : adspso.bin Process : tz : tz.mbn Process : cmnlib : cmnlib_30.mbn Process : cmnlib64 : cmnlib64_30.mbn Process : keymaster : km4.mbn Process : devcfg : devcfg.mbn Process : modem : NON-HLOS.bin Process : aboot : emmc_appsboot.mbn Process : custom : custom.img SPImage : Process custom_a_0 SPImage : Process custom_b_0 Process : splash : splash.img OP : Update Process : boot : boot.img Process : dtbo : dtbo.img Process : system : system.img SPImage : Process system_a_0 SPImage : Process system_a_1 SPImage : Process system_a_2 SPImage : Process system_a_3 SPImage : Process system_a_4 SPImage : Process system_b_0 SPImage : Process system_b_1 SPImage : Process system_b_2 SPImage : Process system_b_3 SPImage : Process system_b_4 Process : vbmeta : vbmeta.img Process : vendor : vendor.img SPImage : Process vendor_a_0 SPImage : Process vendor_b_0 OP : Post OP : UserData preserve : disabled Process : userdata : userdata.img SPImage : Process userdata_0 OP : Reset FRP Reset FRP Ok! Done! Elapsed: 00:07:09 Reconnect Power/Cable! |
07-24-2019, 05:08 | #882 (permalink) |
Product Supporter Join Date: Mar 2016 Location: Bangladesh
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Nokia 1 TA-1060 FRP Remove By Infinity-Box BEST2 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia DownloadAgent ver.07220419 BEST2 Fail to disable Dog! BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 150100464E36324D420309EA684A12D3 DAInf: 4 : 2 : 155 eMMC : OK eMMC : 460001154D32364EEA090342D3124A68 DRAM : DRAM: 0x40000000 [ 1.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464E36324D420309EA684AC4D3 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : EA2C00291A52B536CB0ECF98A0827F6F STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM13) MODE : PRELOADER PORT PORT : 13 Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to nobichanmaruf For This Useful Post: |
07-25-2019, 09:46 | #884 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | Code: Operation : Identify [ v1.17 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM7) MODE : BOOTROM PORT : 7 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6755 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 90014A484147346132A5186A14474557 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 7DD52947D12770BFE83D04A488E2CC07 DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM8) MODE : PRELOADER PORT PORT : 8 Boot done! --- SysInfoSub [PART A]: Patch Level : O11019 Display ID : 00WW_2_68B Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-01-01 Build Time : 1545117623 Product Model : ES2 Product Brand : alps Product Name : ES2_00WW_FIH Product Device : ES2_sprout Product Manfct : alps Product Info : ES2 Product Board : ES2 Board Platform : mt6750 --- SysInfoSub [PART B]: Patch Level : O11019 Display ID : 00WW_2_68D Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-02-01 Build Time : 1548161509 Product Model : ES2 Product Brand : alps Product Name : ES2_00WW_FIH Product Device : ES2_sprout Product Manfct : alps Product Info : ES2 Product Board : ES2 Board Platform : mt6750 --- SecuritySub : IMEI[0] : 353xxxxxxxxxxxx IMEI[1] : 353xxxxxxxxxxxx NVRAM check : Passed! Backup sensetive data [ 11 ] Backup path : Backup\MT6755__7DD52947D12770BFE83D04A488E2CC07\ [20] Read : SUTINFO [22] Read : ELABEL [13] Read : PROINFO [6] Read : PERSIST [15] Read : NVRAM [21] Read : DEVICEINFO Backup done! Done! Elapsed: 00:00:43 Reconnect Power/Cable! Code: Operation : Reset Settings [ v1.17 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM7) MODE : BOOTROM PORT : 7 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6755 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 90014A484147346132A5186A14474557 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 7DD52947D12770BFE83D04A488E2CC07 DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM8) MODE : PRELOADER PORT PORT : 8 Boot done! Format Ok : USERDATA Format Ok : RESET PROTECTION Format Ok : PRIVACY Done! Elapsed: 00:01:43 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to malka4u For This Useful Post: |
