09-27-2019, 13:07 | #916 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 2 reset frp done by nokia best2 Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.09 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.09 Operation : Identify [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] BB_IDC_SWB : 00000000 ID_BLOCK_S : 12F9205A ID_BLOCK_I : 009600E1 ID_BLOCK_L : 565CB9899B112DBAF328A9A33534E92B ID_BLOCK_L : 8BB9AE5256BB65307A11A55CE97F96D1 Use BEST Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Brand : Nokia ProdName : Dynamo_00WW ProdModel : Nokia 2 Device : E1M Manufact. : HMD Global NickName : Nokia 2 Dev Build : Dynamo_00WW-user 7.1.1 NMF26F 00WW_0_64C release-keys Dev CPU : MSM8909 Dev SKU : 600WW SKU Vendor: NOKIA SKU Locale: Worldwide SKU Carier: FIH Generic FXCN_SW : E1M-064C-0-00WW-B0 USERData : PLAIN ( NON-ENCRYPTED ) FRP State : ON ( ACTIVE ) Done! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Reset Settings [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] BB_IDC_SWB : 00000000 ID_BLOCK_S : 12F9205A ID_BLOCK_I : 009600E1 ID_BLOCK_L : 565CB9899B112DBAF328A9A33534E92B ID_BLOCK_L : 8BB9AE5256BB65307A11A55CE97F96D1 Use BEST Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
The Following User Says Thank You to A.G.Shahid For This Useful Post: |
09-29-2019, 15:29 | #917 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 3310 Operation : Reset Settings [ v1.18 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM256) MODE : NOKIA USB SERIAL PORT : 256 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : A656DE4F9213417CBF14F55BBA633DCD BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.11.02.11.p1 BOOT : SWR : 11.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : RETRO.11.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00CD0000 : 0x00324000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:01:04 Reconnect Power/Cable! |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
09-30-2019, 07:01 | #918 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 108 blinking problem done by best Card found: S/N : 30C22462 , v0122 Registered to: A.G.Shahid Connect phone on selected interface... Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-944_ROM_eMP_20.06.11 VIVA : RM-944_VIVA_eMP_20.06.11 LANG : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 CUST : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 JMPT : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 12 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 8E7095DC0EE52208D8E9611F63E4F54F BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Bree.20.06.11.p4 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 SecureDecrypt : RM-944_ROM_eMP_20.06.11 SecureDecrypt : RM-944_VIVA_eMP_20.06.11 SecureDecrypt : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 SecureDecrypt : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 SecureDecrypt : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 OVRLP : 000069B900000001 PHPID : Bree.20.06.11.p4 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-944_ROM_eMP_20.06.11 Write : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 Write : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 Write : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 Write : RM-944_VIVA_eMP_20.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-944_ROM_eMP_20.06.11 [VERIFY] DONE : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 [VERIFY] DONE : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 [VERIFY] DONE : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 [VERIFY] DONE : RM-944_VIVA_eMP_20.06.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:09 Reboot phone Ok |
09-30-2019, 14:47 | #919 (permalink) |
Freak Poster Join Date: Dec 2010 Location: Bulgaria Age: 44
Member: 1475192 Status: Offline Thanks Meter: 121 | Code: Card found : A , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.16 Operation : Reset Settings [ v1.16 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6739 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x40000000 [ 1,00 GB ] EMMC: 150100464E36324D42035525CE6B3669 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00080000 [ 512,00 KB ] USER : 0x1D2000000 [ 7,28 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : FF13EAFC3414FB14912D41B233DEBFFB DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
The Following User Says Thank You to pitbulli For This Useful Post: |
10-04-2019, 15:04 | #920 (permalink) |
Freak Poster Join Date: Nov 2012 Location: pune india Age: 45
Member: 1838311 Status: Offline Sonork: 100.1638474 Thanks Meter: 103 | Nokia 3.1 Plus Flashing Done Operation : Write FW [ v1.18 ] Setting : UserData preserve : False Setting : Flash Pre-Erase : True Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM25) MODE : BOOTROM PORT : 25 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_ARB BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : C56023D50603F1AA0C4E2486FAB0D6C0FEB0C9F5FD40E954FA 9566D1FC136BE7 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6765 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100474436424D42010B529AD075F5 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GD6BMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : FE8C68A4F66B8558B92DE553FE748ACA DA : USB : HIGH-SPEED Boot done! DL_INFO : PMT present SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : HW verification passed! Erase : 0x0000000000000000 : 0x0000000001688000 Erase : 0x0000000003688000 : 0x0000000006000000 Erase : 0x000000000E800000 : 0x0000000000800000 Erase : 0x0000000012584000 : 0x0000000000800000 Erase : 0x0000000013DA4000 : 0x0000000001800000 Erase : 0x00000000156A4000 : 0x0000000002000000 Erase : 0x0000000018000000 : 0x00000000DE000000 Erase : 0x00000000F6100000 : 0x0000000002000000 Erase : 0x00000000F9000000 : 0x000000019D800000 PMT Update : OK Flashing now ... PROCESS : PRELOADER Unpack : ROO-0-124H-preloader_ROO.bin Flash : ROO-0-124H-preloader_ROO.bin Update bootloader backup copy ... Update bootloader backup copy Ok! PROCESS : LOGO_A Unpack : ROO-0-124H-00WW-logo.bin Flash : ROO-0-124H-00WW-logo.bin PROCESS : MD1IMG_A Unpack : ROO-0-124H-md1img.img Flash : ROO-0-124H-md1img.img PROCESS : SPMFW_A Unpack : ROO-0-124H-spmfw.img Flash : ROO-0-124H-spmfw.img PROCESS : SCP_A Unpack : ROO-0-124H-scp.img Flash : ROO-0-124H-scp.img PROCESS : SSPM_A Unpack : ROO-0-124H-sspm.img Flash : ROO-0-124H-sspm.img PROCESS : LK_A Unpack : ROO-0-124H-00WW-lk.img Flash : ROO-0-124H-00WW-lk.img PROCESS : BOOT_A Unpack : ROO-0-124H-00WW-boot.img Flash : ROO-0-124H-00WW-boot.img PROCESS : ODMDTBO_A Unpack : ROO-0-124H-odmdtbo.img Flash : ROO-0-124H-odmdtbo.img PROCESS : TEE_A Unpack : ROO-0-124H-tee.img Flash : ROO-0-124H-tee.img PROCESS : VENDOR_A Unpack : ROO-0-124H-00WW-vendor.img Flash : ROO-0-124H-00WW-vendor.img PROCESS : SYSTEM_A Unpack : ROO-0-124H-00WW-system.img Flash : ROO-0-124H-00WW-system.img PROCESS : VBMETA_A Unpack : ROO-0-124H-00WW-vbmeta.img Flash : ROO-0-124H-00WW-vbmeta.img PROCESS : USERDATA Unpack : ROO-0-124H-00WW-userdata.img Flash : ROO-0-124H-00WW-userdata.img PMT Update : OK SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 Flashing finished! Done! Elapsed: 00:04:39 Reconnect Power/Cable! |
The Following User Says Thank You to gsmpimpri For This Useful Post: |
10-05-2019, 13:59 | #921 (permalink) |
Product Manager Join Date: Mar 2014 Location: Bangladesh Age: 30
Member: 2142580 Status: Offline Thanks Meter: 1,214 | Nokia 1 Flash Done Auto Restart Problem Solve Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 150100464E36324D42036C799AD6B515 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464E36324D42036C799AD64515 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 159ECD8B9D5D25E91F7D158E471513BE STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! DL_INFO : PMT present SEC_DL : False (CUST) SEC_ID : 0x03041013EE0E00F800F21212EF110DFC [FL] : HW verification passed! Erase : 0x0000000000000000 : 0x0000000000080000 Erase : 0x0000000001C80000 : 0x0000000008900000 Erase : 0x000000000ADC0000 : 0x0000000000100000 Erase : 0x000000000B000000 : 0x00000000D4800000 PMT Update : OK Flashing now ... PROCESS : PRELOADER Unpack : FRT-0-1550-00WW-1-2-preloader_FRT.bin Flash : FRT-0-1550-00WW-1-2-preloader_FRT.bin Update bootloader code ... Update bootloader Ok! PROCESS : LK Unpack : FRT-0-1550-00WW-1-2-lk.img Flash : FRT-0-1550-00WW-1-2-lk.img PROCESS : BOOT Unpack : FRT-0-1550-00WW-1-2-boot.img Flash : FRT-0-1550-00WW-1-2-boot.img PROCESS : RECOVERY Unpack : FRT-0-1550-00WW-1-2-recovery.img Flash : FRT-0-1550-00WW-1-2-recovery.img PROCESS : LOGO Unpack : FRT-0-1550-00WW-1-2-logo.bin Flash : FRT-0-1550-00WW-1-2-logo.bin PROCESS : SECRO Unpack : FRT-0-1550-00WW-1-2-secro.img Flash : FRT-0-1550-00WW-1-2-secro.img PROCESS : TEE1 Unpack : FRT-0-1550-00WW-1-2-tee.img Flash : FRT-0-1550-00WW-1-2-tee.img PROCESS : TEE2 Unpack : FRT-0-1550-00WW-1-2-tee.img Flash : FRT-0-1550-00WW-1-2-tee.img PROCESS : ODMDTBO Unpack : FRT-0-1550-00WW-1-2-odmdtbo.img Flash : FRT-0-1550-00WW-1-2-odmdtbo.img PROCESS : SYSTEMINFO Unpack : fver Flash : fver PROCESS : SUTINFO Unpack : FRT-00WW-001-sutinfo.img Flash : FRT-00WW-001-sutinfo.img PROCESS : CDA Unpack : FRT-00WW-013-cda.img Flash : FRT-00WW-013-cda.img PROCESS : VENDOR Unpack : FRT-0-1550-00WW-1-2-vendor.img Flash : FRT-0-1550-00WW-1-2-vendor.img PROCESS : SYSTEM Unpack : FRT-0-1550-00WW-1-2-system.img Flash : FRT-0-1550-00WW-1-2-system.img PROCESS : CACHE Unpack : FRT-0-1550-00WW-1-2-cache.img Flash : FRT-0-1550-00WW-1-2-cache.img PROCESS : USERDATA Unpack : FRT-0-1550-00WW-1-2-userdata.img Flash : FRT-0-1550-00WW-1-2-userdata.img PMT Update : OK SEC_DL : False (CUST) SEC_ID : 0x67887C7972766E6888787678777B796E Flashing finished! Done! Elapsed: 00:02:33 Reconnect Power/Cable! |
The Following User Says Thank You to >>Gsmmilon>> For This Useful Post: |
10-08-2019, 09:30 | #922 (permalink) |
No Life Poster Join Date: Jan 2010 Location: india Age: 43
Member: 1222236 Status: Offline Sonork: 100.1619169 Thanks Meter: 288 | nokia 1086 Reset Settings Operation : Identify [FTM] [ v1.18 ] -> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Initialize Ok! Dev Model : E2I HW version : PVT HW variant : FIH eMMC HW RF_BAND : G_900_1800^W_1_5_8^L_1_3_5_40_41 SW version : E2M-113F-0-00WW-B02 SW serialnm : E2MID18108601285 SW secured : YES Project DevCode : E2M Bootloader type : RETAIL Security Version : 0004 Done! Elapsed: 00:00:07 Reconnect Power/Cable! Operation : Reset Settings [FTM] [ v1.18 ] -> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Initialize Ok! Looking for SVC package in local database ... SW : E2M-113F-0-00WW-B02 Package : E2M-108C Device : E2I ( E2M ) BLType : RETAIL SecVer : 04 Device authentification ... Processing server operation ... Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version check error:Error: Client version is too old Disconnected Disconnected Finished Error : Device auth failed! Server reported error! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
The Following 2 Users Say Thank You to gkmobiles For This Useful Post: |
10-15-2019, 09:42 | #923 (permalink) |
Member: 2142580 Status: Offline Thanks Meter: 1,214 | Nokia TA-1010_059Z143_Dead Recovery Done Nokia TA-1010_059Z143_Dead Recovery Done After Wrong Flash Phone Dead. Now Recovery Done by - TA-1010_059Z143_30.04.11 |
10-16-2019, 09:25 | #924 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 105 Format DOne Nokia 105 Format DOne Operation : Reset Settings [ v1.18 ]
PTFN : Nokia USB Serial Port (COM254) MODE : NOKIA USB SERIAL PORT : 254 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 66B87B8E39CCEF27D686A5AADC6B712E BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : KESA61A.10.00.11.p2 BOOT : SWR : 10.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : KESA61A.10.00.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0060 : 0017 : 0000 NOR: [WINBOND] W25Q64DW NOR: TSIZE : 0x00800000 [ 8.00 MB ] PSIZE : 0x00800000 [ 8.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00580000 : 0x00278000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
10-20-2019, 06:16 | #925 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Insert USB cable now! --- Wait for phone... Phone found! [ 12 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 1357D4D3121BFDE5E2AC3130E18052BD BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.21.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 Executing FFS FORMAT now... FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:01:14 |
The Following User Says Thank You to Nadeem Waris For This Useful Post: |
10-20-2019, 06:17 | #926 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | --- Insert USB cable now! --- Wait for phone... Phone found! [ 12 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 47FACA02713E83584E66D7D7A2A42BD4 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Bree.10.04.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:34 |
10-20-2019, 06:18 | #927 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1190_DUBAI_ROM_eMP_30.00.11 VIVA : RM-1190_DUBAI_VIVA_eMP_30.00.11 LANG : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_30.00.11 CUST : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_30.00.11 JMPT : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_30.00.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 31 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : FF6AE11274AF2051790CD2411584132D BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DUBAI61D.30.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Dubai.fg DA_VERIFY : 00 DA_JUMP : 00100000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A0000-0x003F7FFF , LEN : 0x00058000 SecureDecrypt : RM-1190_DUBAI_ROM_eMP_30.00.11 SecureDecrypt : RM-1190_DUBAI_VIVA_eMP_30.00.11 SecureDecrypt : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_30.00.11 SecureDecrypt : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_30.00.11 SecureDecrypt : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_30.00.11 Executing FFS FORMAT now... FAT_RANGE : 0x003A0000-0x003F7FFF , LEN : 0x00058000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE OVRLP : 000069B900000001 PHPID : DUBAI61D.30.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1190_DUBAI_ROM_eMP_30.00.11 Write : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_30.00.11 Write : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_30.00.11 Write : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_30.00.11 Write : RM-1190_DUBAI_VIVA_eMP_30.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1190_DUBAI_ROM_eMP_30.00.11 [VERIFY] DONE : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_30.00.11 [VERIFY] DONE : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_30.00.11 [VERIFY] DONE : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_30.00.11 [VERIFY] DONE : RM-1190_DUBAI_VIVA_eMP_30.00.11 CODE_VERIFY : Ok Flashing done! Total flash time : 00:00:56 Reboot phone Ok |
10-20-2019, 06:21 | #928 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 12 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 342FECF464043F15EBA2BEE4023B20F2 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Bree.20.06.11.p4 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:27 |
10-20-2019, 06:22 | #929 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 31 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 7166459F6403C94884230F0F200E1F15 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 31 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 7166459F6403C94884230F0F200E1F15 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : JET.12.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Jet.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000 Executing FFS FORMAT now... FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:27 |
10-20-2019, 06:23 | #930 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1035_CRYSTAL_ROM_eMP_14.00.11 VIVA : RM-1035_CRYSTAL_VIVA_eMP_14.00.11 LANG : RM-1035_CRYSTAL_LANG_PACK_ROM_IJ_eMP_14.00.11 CUST : RM-1035_CRYSTAL_CUSTPACK_ROM_IJ_eMP_14.00.11 JMPT : RM-1035_CRYSTAL_JUMP_TABLE_IJ_eMP_14.00.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 12 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 62CD0E76D40092AB99591DBE62C315A1 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_CRYSTAL_ROM_eMP_14.00.11 SecureDecrypt : RM-1035_CRYSTAL_VIVA_eMP_14.00.11 SecureDecrypt : RM-1035_CRYSTAL_LANG_PACK_ROM_IJ_eMP_14.00.11 SecureDecrypt : RM-1035_CRYSTAL_CUSTPACK_ROM_IJ_eMP_14.00.11 SecureDecrypt : RM-1035_CRYSTAL_JUMP_TABLE_IJ_eMP_14.00.11 Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE OVRLP : 000069B900000001 PHPID : CRYSTAL.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_CRYSTAL_ROM_eMP_14.00.11 Write : RM-1035_CRYSTAL_LANG_PACK_ROM_IJ_eMP_14.00.11 Write : RM-1035_CRYSTAL_CUSTPACK_ROM_IJ_eMP_14.00.11 Write : RM-1035_CRYSTAL_JUMP_TABLE_IJ_eMP_14.00.11 Write : RM-1035_CRYSTAL_VIVA_eMP_14.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_CRYSTAL_ROM_eMP_14.00.11 [VERIFY] DONE : RM-1035_CRYSTAL_LANG_PACK_ROM_IJ_eMP_14.00.11 [VERIFY] DONE : RM-1035_CRYSTAL_CUSTPACK_ROM_IJ_eMP_14.00.11 [VERIFY] DONE : RM-1035_CRYSTAL_JUMP_TABLE_IJ_eMP_14.00.11 [VERIFY] DONE : RM-1035_CRYSTAL_VIVA_eMP_14.00.11 CODE_VERIFY : Ok Flashing done! Total flash time : 00:00:54 Reboot phone Ok |
