01-04-2020, 17:59 | #991 (permalink) |
Freak Poster Join Date: Dec 2014 Location: NIGERIA
Member: 2312129 Status: Offline Thanks Meter: 139 | Nokia E61i network unlock done Registered to: ESEOGHENE UFS S/N DOLPHIN CLIP boot - Ok Connect phone on selected interface... Read and Check phone data... BB5 bus checking... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : FF971D2DBD16240E641D9FF6039C25B6896DE866 APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 1E40020AD1A94F5003A86999906E97A9C1FFD8DC CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F [1ST BOOT] : Boot Ok , A6 CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 22E800EC , CMT , NOR CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok [2ND BOOT] : CMT : Boot Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : F6AB1F68D2E4D7D0487762E37D74EA7D923C341FBD [ALGO BOOT] : CMT : Boot Ok Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 Payload message : 72 Payload message : D9 APE Loader sent, Boot Ok MCU Configuration ready [09100000] ready [00000000] MCU cfg fail!!! Error : 000000 [2ND BOOT] : APE : Error , boot not accepted Connect phone on selected interface... Connect phone on selected interface... UFS S/N 79119 boot - Ok Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Read Uniq key data started... Phone Imei: 351879013203999 Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : FF971D2DBD16240E641D9FF6039C25B6896DE866 APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 1E40020AD1A94F5003A86999906E97A9C1FFD8DC CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... CMT Loader sent, Boot Ok rap= 1E40020AD1A94F5003A86999906E97A9C1FFD8DC hash= BAF3A9C3DBFA8454937DB77F2B8852B1 key= 6CDD6456A64D154FFCDBCB33BFCAAB6B9968D0FE Init Service mode... Wait... Key file updated... Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Unlock procedure started... Phone Imei: 351879013203999 Checking locks... Conf key : 0100000000000000 Provider key : 2140700000000000 Country : Spain Operator : movistar Counters : Key 0 [3] , Fbus 0 [10] Blocks : 4 LOCK STATUS : ============================= BLK : 1 Lock1:Close BLK : 2 Lock1:Close BLK : 3 Lock1:Close BLK : 4 Lock1:Close ============================= LOCKS : Closed ============================= NCK unlock failed, will try direct RPL Phone Imei: 351879013203999 Key file exists, no need to read... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Writing SimLock Data... Ok Writing SimLock Key... Ok Unlock Done! Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! |
The Following 2 Users Say Thank You to Elasunuas For This Useful Post: |
01-07-2020, 12:40 | #992 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 130 format done Operation : Reset Settings [ v1.19 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM342) MODE : NOKIA USB SERIAL PORT : 342 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : C073DDFA861EDD632DD216F38F09BCAD BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : CRYSTAL.10.01.11.p2 BOOT : SWR : 10.01.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : CRYSTAL.10.01.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0040 : 0016 : 0000 NOR: [WINBOND] W25Q32BV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x003A4000 : 0x00050000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
The Following User Says Thank You to Luckey1 For This Useful Post: |
01-08-2020, 08:48 | #993 (permalink) |
No Life Poster Join Date: May 2008
Member: 775581 Status: Offline Thanks Meter: 186 | Nokia 1 plus TA-1130 FRP done very easy, just identify & reset settings : Operation : Reset Settings [ v1.19 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : Android Gadget VCOM Driver (COM41) MODE : PRELOADER PORT PORT : 41 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY BROM : PRELOADER PORT BROM : SOCID : 25027F1C7875BF9660DACC4C38464FE4D48760DCCF062B9465 5AAE766AC9D9E6 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6739 AGENT : BEST_Nokia_DA_v19_1711_06 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 150100464E36324D4203F3AB68B4A511 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 9A45F0E49F1C981B3B64822ECA8D89E DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
The Following User Says Thank You to wong edan For This Useful Post: |
01-09-2020, 10:52 | #994 (permalink) |
No Life Poster Join Date: Nov 2014 Location: (pakistan)(chichawatni) Age: 38
Member: 2293727 Status: Offline Sonork: 100.1660528 Thanks Meter: 450 | Nokia 2.2 frp reset done by nokia best NOKIA 2.2 FRP RESET DONE BY NOKIA BEST TOOL |
The Following 3 Users Say Thank You to shabirahmad22 For This Useful Post: |
01-09-2020, 16:10 | #995 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Nokia 2.2 format all done Operation : Identify [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_ARB BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : CC6D3659963A22B1C20075B9634BB2C4E32BC6727D06BE814C 606734C805B250 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6761 AGENT : BEST_Nokia_DA_v19_1711_06 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00038000 [ 224.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 700100544232383136201E1811E85619 EMMC: VEN : KINGSTON | OEM : 01 | DEV : TB2816 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A8000000 [ 14.63 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E1A7C59436546899EDCBAB815C0DE6B DA : USB : HIGH-SPEED Boot done! --- SysInfoSub [PART A]: Patch Level : PPR1.180610.011 Display ID : 00WW_1_280_SP02 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-07-05 Build Time : 1561563965 Product Model : Nokia 2.2 Product Brand : Nokia Product Name : Wasp_00WW Product Device : WSP_sprout Product Manfct : HMD Global Product Info : WSP_sprout Product Model : Nokia 2.2 Product Model : 00WW Product Board : MT6761 Board Platform : mt6761 --- SysInfoSub [PART B]: Patch Level : PPR1.180610.011 Display ID : 00WW_1_280_SP01 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-06-05 Build Time : 1559735086 Product Model : Nokia 2.2 Product Brand : Nokia Product Name : Wasp_00WW Product Device : WSP_sprout Product Manfct : HMD Global Product Info : WSP_sprout Product Model : Nokia 2.2 Product Model : 00WW Product Board : MT6761 Board Platform : mt6761 --- SecuritySub : NVRAM check : Passed! Backup sensetive data [ 11 ] Backup path : Backup\MT6761__E1A7C594365468990EDCBAB815C0DE6B\ [16] Read : PROINFO [17] Read : NVRAM [15] Read : SEC1 Backup done! Done! Elapsed: 00:00:25 Reconnect Power/Cable! Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_ARB BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : CC6D3659963A22B1C20075B9634BB2C4E32BC6727D06BE814C 606734C805B250 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6761 AGENT : BEST_Nokia_DA_v19_1711_06 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00038000 [ 224.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 700100544232383136201E1811E85619 EMMC: VEN : KINGSTON | OEM : 01 | DEV : TB2816 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A8000000 [ 14.63 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E1A7C59436546899EDCBAB815C0DE6B DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : RESET PROTECTION Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
01-10-2020, 04:39 | #996 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | Nokia rm-1034 hang on logo done by flashing Code: Operation : Write FirmWare [ v1.19 ] Setting : UserData erase : False Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek DA USB VCOM Port (COM39) MODE : NOKIA USB SERIAL PORT : 39 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 6D85F20D97C897FD149CE30F505A81F7 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.30.04.11.p1 BOOT : SWR : 30.04.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.30.04.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 10.02.11 [TA-1034] DEV SoftwareVersion : 30.04.11 SWInfo compare result : VPL SW ( Major version ) is LOWER, than in DEVICE! Load FlashSet : MROM : TA-1034_ROM_eMP_10.02.11 LANG : TA-1034_LANG_PACK_ROM_MS_eMP_10.02.11_001 CUST : TA-1034_CUSTPACK_ROM_MS_eMP_10.02.11_001 JUMP : TA-1034_JUMP_TABLE_MS_eMP_10.02.11_001 VIVA : TA-1034_VIVA_eMP_10.02.11 Prepare FlashSet : DCR : TA-1034_ROM_eMP_10.02.11 DCR : TA-1034_LANG_PACK_ROM_MS_eMP_10.02.11_001 DCR : TA-1034_CUSTPACK_ROM_MS_eMP_10.02.11_001 DCR : TA-1034_JUMP_TABLE_MS_eMP_10.02.11_001 DCR : TA-1034_VIVA_eMP_10.02.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 Erase Target Flash Erase done! Write Target Flash Write : TA-1034_ROM_eMP_10.02.11 Write : TA-1034_LANG_PACK_ROM_MS_eMP_10.02.11_001 Write : TA-1034_CUSTPACK_ROM_MS_eMP_10.02.11_001 Write : TA-1034_JUMP_TABLE_MS_eMP_10.02.11_001 Write : TA-1034_VIVA_eMP_10.02.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1034_ROM_eMP_10.02.11 Verify : TA-1034_LANG_PACK_ROM_MS_eMP_10.02.11_001 Verify : TA-1034_CUSTPACK_ROM_MS_eMP_10.02.11_001 Verify : TA-1034_JUMP_TABLE_MS_eMP_10.02.11_001 Verify : TA-1034_VIVA_eMP_10.02.11 Done! Elapsed: 00:01:18 Reconnect Power/Cable! |
The Following User Says Thank You to kothamamun For This Useful Post: |
01-10-2020, 07:48 | #997 (permalink) |
No Life Poster Join Date: Jan 2011 Location: Pakistan
Member: 1489718 Status: Offline Sonork: 100.1652829 QQ 3237590752 Thanks Meter: 1,495 | nokia 110 Hmd ta-1192 6531efm read password done big thanks best2 team Code: Operation : Read UserCode [ v1.20 ] 1. Power off device, remove battery 2. Not hold any key on device! 3. Insert battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SW_VER : 21.00.17.02 LP_VER : IJ 23NKL74PK00 UserCode : 45678 Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to YMS-RYK For This Useful Post: |
01-10-2020, 10:07 | #998 (permalink) |
Registered User Join Date: Mar 2008 Location: @ blacksheep digital
Member: 731353 Status: Offline Thanks Meter: 254 | VODAFONE smart kicka 5 NETWORK DONE Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM (Android) (COM235) MODE : PRELOADER PORT PORT : 235 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : blacksheep.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4500017041493848711F01347B46EBEB DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 700100454838494134011F71EBEB467B EMMC: VEN : KINGSTON | OEM : 01 | DEV : EH8IA4 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1C8000000 [ 7.13 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 308609D826B69118D0ECA755AFD97322 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Display ID : O11019 release-keys Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-08-05 Build Time : 1568171595 Product Model : Kicka 5 Product Brand : MobiWire Product Name : Kicka_5 Product Device : Kicka_5 Product Manfct : MobiWire Product Info : k80hd_bsp_fwv_512m Board Platform : mt6580 Product Board : VP506_Mobiwire_Kicka5 USERDATA : ENCRYPTED Card found : 6EF5F8E0 , v0138 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06 Load IDBase v124106 Ok! Update configuration ... Error connecting with SSL. EOF was observed that violates the protocol Update failed! Check settings and/or internet connection! Operation : SP Unlock [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM (Android) (COM235) MODE : PRELOADER PORT PORT : 235 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : blacksheep.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4500017041493848711F01347B46EBEB DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 700100454838494134011F71EBEB467B EMMC: VEN : KINGSTON | OEM : 01 | DEV : EH8IA4 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1C8000000 [ 7.13 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 308609D826B69118D0ECA755AFD97322 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! ID0 : Lock : Locked! | MNC : 512 | CNT : 214 | CODE : 12345678 ID1 : Lock : Not Locked! ID2 : Lock : Not Locked! ID3 : Lock : Not Locked! ID4 : Lock : Not Locked! ID5 : Lock : Not Locked! ID6 : Lock : Not Locked! Direct unlock done! Done! Elapsed: 00:00:55 |
The Following 2 Users Say Thank You to bigjef1 For This Useful Post: |
01-10-2020, 10:41 | #999 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 210 read user code done Operation : Read UserCode [ v1.20 ] 1. Power off device, remove battery 2. Not hold any key on device! 3. Insert battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SW_VER : 21.00.17.02 LP_VER : IJ 23NKL74PK00 UserCode : 963214 Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Luckey1 For This Useful Post: |
01-11-2020, 12:18 | #1000 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 105 rm-1133 reset password done by best2 Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Operation : Identify [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM7) MODE : NOKIA USB SERIAL PORT : 7 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : BCD567AE8615D104DFB4ED28B388D6EB BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : LAGOS61D.15.00.11.p1 BOOT : SWR : 15.00.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : LAGOS61D.15.00.11.p1 FLASH : 00C2 : 0025 : 0036 : 0000 BBSN : BCD567AE8615D104DFB4ED28B388D6EB PRDC : 059W9Z8 IMEI[1] : 3572990xxxxxxxx IMEI[2] : 3572990xxxxxxxx NCK : 20 digits PROV : 24407000 Saved as : 3572990xxxxxxxx.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:00:59 Reconnect Power/Cable! Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM7) MODE : NOKIA USB SERIAL PORT : 7 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : BCD567AE8615D104DFB4ED28B388D6EB BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : LAGOS61D.15.00.11.p1 BOOT : SWR : 15.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : LAGOS61D.15.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00368000 : 0x00090000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to A.G.Shahid For This Useful Post: |
01-11-2020, 12:22 | #1001 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 150 hang on logo done by best2 Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Operation : Identify [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM7) MODE : NOKIA USB SERIAL PORT : 7 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 45BF3AAB276B63A9C9E0FE82CE17E970 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DUBAI61D.30.00.11.p1 BOOT : SWR : 30.00.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : DUBAI61D.30.00.11.p1 FLASH : 00C2 : 0025 : 0036 : 0000 BBSN : 45BF3AAB276B63A9C9E0FE82CE17E970 PRDC : 059X8W6 IMEI[1] : 357345081xxxxxx IMEI[2] : 357325086xxxxxx NCK : 20 digits PROV : 24407000 Saved as : 357345081xxxxxx.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:00:59 Reconnect Power/Cable! Open VPLfile : RM1190_059X8W6_30.00.11.vpl Description : RM-1190 NDT MEA IJ BLACK URDU PK DeviceType : RM-1190 ProductCode : 059X8W6 SoftwareVer : 30.00.11 PPM LangPack : [1] : Urdu (Islamic Republic of Pakistan) [2] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : False Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM7) MODE : NOKIA USB SERIAL PORT : 7 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 45BF3AAB276B63A9C9E0FE82CE17E970 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DUBAI61D.30.00.11.p1 BOOT : SWR : 30.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : DUBAI61D.30.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 30.00.11 [RM-1190] DEV SoftwareVersion : 30.00.11 SWInfo compare result : SAME Load FlashSet : MROM : RM-1190_ROM_eMP_30.00.11 LANG : RM-1190_LANG_PACK_ROM_IJ_eMP_30.00.11_001 CUST : RM-1190_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.00.11_001 JUMP : RM-1190_JUMP_TABLE_IJ_MEA_PK_eMP_30.00.11_001 VIVA : RM-1190_VIVA_eMP_30.00.11 Prepare FlashSet : DCR : RM-1190_ROM_eMP_30.00.11 DCR : RM-1190_LANG_PACK_ROM_IJ_eMP_30.00.11_001 DCR : RM-1190_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.00.11_001 DCR : RM-1190_JUMP_TABLE_IJ_MEA_PK_eMP_30.00.11_001 DCR : RM-1190_VIVA_eMP_30.00.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 Erase Target Flash Erase done! Write Target Flash Write : RM-1190_ROM_eMP_30.00.11 Write : RM-1190_LANG_PACK_ROM_IJ_eMP_30.00.11_001 Write : RM-1190_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.00.11_001 Write : RM-1190_JUMP_TABLE_IJ_MEA_PK_eMP_30.00.11_001 Write : RM-1190_VIVA_eMP_30.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : RM-1190_ROM_eMP_30.00.11 Verify : RM-1190_LANG_PACK_ROM_IJ_eMP_30.00.11_001 Verify : RM-1190_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.00.11_001 Verify : RM-1190_JUMP_TABLE_IJ_MEA_PK_eMP_30.00.11_001 Verify : RM-1190_VIVA_eMP_30.00.11 Done! Elapsed: 00:01:07 Reconnect Power/Cable! |
01-14-2020, 10:35 | #1002 (permalink) |
Member: 2556542 Status: Offline Thanks Meter: 1,790 | Nokia ta-1139 identify,password remove and firmware backup done Code: Operation : Identify [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek DA USB VCOM Port (COM39) MODE : NOKIA USB SERIAL PORT : 39 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 0D2C69BB3CE3E5DD4BB2E261A06A6840 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : OUTRUN.10.01.11.p1 BOOT : SWR : 10.01.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : OUTRUN.10.01.11.p1 FLASH : 00EF : 0060 : 0018 : 0000 PRDC : 059Z0X8 IMEI[1] : 357704109543435 IMEI[2] : 357704109983433 NCK : 20 digits PROV : 24407000 Saved as : 357704109543435.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:00:28 Reconnect Power/Cable! Code: Operation : Reset Settings [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek DA USB VCOM Port (COM39) MODE : NOKIA USB SERIAL PORT : 39 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 0D2C69BB3CE3E5DD4BB2E261A06A6840 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : OUTRUN.10.01.11.p1 BOOT : SWR : 10.01.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : OUTRUN.10.01.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00C8 : 0060 : 0018 : 0000 NOR: [GigaDevice] GD25LQ128 NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_NOT_SUPPORT STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00C40000 : 0x003B4000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! Code: Operation : Read FirmWare [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek DA USB VCOM Port (COM39) MODE : NOKIA USB SERIAL PORT : 39 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 0D2C69BB3CE3E5DD4BB2E261A06A6840 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : OUTRUN.10.01.11.p1 BOOT : SWR : 10.01.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : OUTRUN.10.01.11.p1 FLASH : 00EF : 0060 : 0018 : 0000 CODE : 0x00C40000 Reading Flash ... TDSN : TA-1139 PRDC : 059Z0X8 PPM : MD LANG : [1] : Malay (Malaysia) [2] : Indonesian (Indonesia) [3] : Chinese (S) [4] : English (United Kingdom) BUILD : TA-1139_ROM_eMP_10.01.11 BUILD : TA-1139_LANG_PACK_ROM_MD_eMP_10.01.11_001 BUILD : TA-1139_CUSTPACK_ROM_MD_eMP_10.01.11_001 BUILD : TA-1139_JUMP_TABLE_MD_eMP_10.01.11_001 BUILD : TA-1139_VIVA_eMP_10.01.11 Make VPL definition Save Path : D:\Nokia Flash file\TA-1139\ Save Name : TA-1139_059Z0X8_10.01.11.vpl Build Finished! Done! Elapsed: 00:05:58 Reconnect Power/Cable! |
01-16-2020, 07:53 | #1003 (permalink) |
Freak Poster Join Date: Nov 2019 Location: Narowal
Member: 2935044 Status: Offline Thanks Meter: 75 | Nokia 106 TA-1114 Pin Code Reset Done Infinity-Box [BEST] NK2 Nokia 106 TA-1114 Pin Code Reset Done Infinity-Box [BEST] NK2 Here are Logs Youtube Link https://www.youtube.com/watch?v=EPsIOuMygNo |
The Following User Says Thank You to AAdnan Mobile For This Useful Post: |
01-16-2020, 07:55 | #1004 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 210 HMD Global Read User Code Done Operation : Read UserCode [ v1.20 ] 1. Power off device, remove battery 2. Not hold any key on device! 3. Insert battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SW_VER : 21.00.17.02 LP_VER : IJ 23NKL74PK00 UserCode : 26795 Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
01-16-2020, 11:28 | #1005 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Pakistan
Member: 720264 Status: Offline Sonork: 100.1649278 Thanks Meter: 192 | Nokia 220 [ TA-1155 ] Format Done Operation : Reset Settings ( Format FS ) [ v1.20 ] Extra : FTM mode 1. Power off device, remove battery 2. Not hold any key on device! 3. Insert battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Erase BLK #0 Format Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! GSMdunya! |
The Following User Says Thank You to naveed ali For This Useful Post: |
