08-16-2017, 13:54 | #211 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 130 write firmware Done :) Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1035_ROM_eMP_11.00.11 VIVA : RM-1035_VIVA_eMP_11.00.11 LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 JMPT : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 140 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 24F0F7A9A62EA7AD7044832460E9DE7F BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_11.00.11 SecureDecrypt : RM-1035_VIVA_eMP_11.00.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_11.00.11 Write : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 Write : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_VIVA_eMP_11.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_11.00.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_VIVA_eMP_11.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:03 Reboot phone Ok - > Hint : If phone shows Battery charge icon - press and hold PowerOn button 10 seconds Wait, when phone will be ready ... Reading Phone Info.... Software Info: 11.00.11 00-00-00 RM-1035 IMEI: 357777066868185 Ape Version: NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM version : IJ Product code: 059W037 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 11.00.11 00-00-00 RM-1035 IMEI 1 : 357777066868185 IMEI 2 : 357777066868193 XappVer : 000008F2 Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : IJ CNT : CRYSTAL.11.00.11.p1 Product SN : 5C1B566AU Product code : 059W037 Base Prd.code: 059V7K4 Module code : 0206095 Hardware info======= HWID : 3200 LCDVer: TPO Lock info =========== IMEI : 357777066868185 IMEI spNet : 3A 75 77 07 66 68 18 58 Conf key : 800000000004000B Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; SimLock status : Ok Security status : Ok Done! |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
08-16-2017, 15:09 | #212 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 105 write full firmware Done :) Code: Connect phone on selected interface... UFS S/N 103896 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm908_003.400 PPM : rm908_003.40ic CNT : rm9080_nai03.40ic Infineon flashing... -> Infineon XG110 : IMEI Backup Created Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 PBL : Dynamic Boot Ok , 01AB SBL : Dynamic Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH VEN : 000000EF FLASH DIE : 00006017 FLASH ID : UNKNOW [Not In Base] Boot Done! ===Flashing [MCU]=== File : rm908_003.400 Image : hw_f31_rm908_62_mcusw_03.40_Best.fls Cert block found, sending.... Cert sent Found 3 region(s) Processing Region 1/3 Erase , Start : 0x00800000 , Len : 0x00210000 Erasing, wait ... Erase done Write , Start : 0x00800000 , Len : 0x00210000 Flashing , wait ... Region flash done Processing Region 2/3 Erase , Start : 0x00C60000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00C60000 , Len : 0x00221240 Flashing , wait ... Region flash done Processing Region 3/3 Erase , Start : 0x00FFC000 , Len : 0x00004000 Erasing, wait ... Erase done Write , Start : 0x00FFC000 , Len : 0x00000040 Flashing , wait ... Region flash done Check : 5960 ===Flashing [PPM]=== File : rm908_003.40ic Image : hw_f31_rm908_62_ppm_03.40ic_Best.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00210000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00210000 , Len : 0x001C5A00 Flashing , wait ... Region flash done Check : 06A7 ===Flashing [CNT]=== File : rm9080_nai03.40ic Image : hw_f31_rm908_62_image_03.40ic_Best.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00EB0000 , Len : 0x000D0000 Erasing, wait ... Erase done Write , Start : 0x00EB0000 , Len : 0x000661C0 Flashing , wait ... Region flash done Check : 919A Flashing done, rebooting... -> Infineon info : Do FullFactory Sets after flashing Flashing Done! Init Service mode... Wait... Afterflash settings... SW ver : V 03.40 08-08-13 RM-908 (c) Nokia IMEI : 358146058155655 PCode : 059R449 Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! All done! Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
08-20-2017, 09:13 | #213 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Burundi Bujumbura
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 169 | Microsoft 640 RM-1074 Direct unlock done Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok === Main info === NCSD Version : 5.1 Sw Version : 02177.00000.15184.36005 IMEI : 358606060905108 ProductCode : 059X248 ProductCodeB : 059W8Z4 ProductSN : 850DBE7AU Module Code : 0206637 === HW info === Public ID : 6D404B0D1B5C07BB7F58145E73DC0E7E3E662568 HW Version : 2162 BT Addr. : 0CE725BA4434 Wlan Mac : 0CE725BA6DD8 Battery Level : 34 % === Branding and security info === Operator : VOD-AU SimLock : Locked! SimLock : 5050300014981 Country : Australia Operator : vodafone AU Branding : RM-1074_1005 Sec. Mode : Restricted Done! Phone found! WP10/WP8x Lumia Phone detected Read info... Ok WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Need SDAuth to finish ... Started Connecting to SX4 server... Connected SX4 enter .. SDAuth Ok! SX4 Disconnected Unlock Done! Wait for phone reboot ... Reboot Ok! Phone disconected! Connect phone on selected interface... |
The Following 3 Users Say Thank You to Arafat Mashaka For This Useful Post: |
08-21-2017, 08:02 | #214 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 108 Flashing Done Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-944_ROM_eMP_20.06.11 VIVA : RM-944_VIVA_eMP_20.06.11 LANG : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 CUST : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 JMPT : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 34 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : B4CFBD0381D2955569A4139F38F0C299 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Bree.12.06.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 SecureDecrypt : RM-944_ROM_eMP_20.06.11 SecureDecrypt : RM-944_VIVA_eMP_20.06.11 SecureDecrypt : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 SecureDecrypt : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 SecureDecrypt : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 OVRLP : 000069B900000001 PHPID : Bree.12.06.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-944_ROM_eMP_20.06.11 Write : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 Write : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 Write : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 Write : RM-944_VIVA_eMP_20.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-944_ROM_eMP_20.06.11 [VERIFY] DONE : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 [VERIFY] DONE : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 [VERIFY] DONE : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 [VERIFY] DONE : RM-944_VIVA_eMP_20.06.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:25 |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
08-22-2017, 10:20 | #215 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 105 Format Done Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 33 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : E3E69EBEA0EAD6A6817DAC4F02DA02A7 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : LAGOS61D.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Lagos.fg DA_VERIFY : 00 DA_JUMP : 00100000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x00368000-0x003F7FFF , LEN : 0x00090000 Executing FFS FORMAT now... FAT_RANGE : 0x00368000-0x003F7FFF , LEN : 0x00090000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:24 |
08-23-2017, 13:55 | #216 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 130 write firmware Done :) Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1035_ROM_eMP_11.00.11 VIVA : RM-1035_VIVA_eMP_11.00.11 LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 JMPT : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 - > MODE : FullFlash Software Info: 10.01.11 00-00-00 RM-1035 IMEI: 353631063454560 PPM version : IJ Product code: 059W2D7 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 140 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : FEBD7E630292CBA66E1D4BECE09D2840 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_11.00.11 SecureDecrypt : RM-1035_VIVA_eMP_11.00.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_11.00.11 Write : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 Write : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_VIVA_eMP_11.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_11.00.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_VIVA_eMP_11.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:05 Reboot phone Ok - > Hint : If phone shows Battery charge icon - press and hold PowerOn button 10 seconds Wait, when phone will be ready ... Reading Phone Info.... Software Info: 11.00.11 00-00-00 RM-1035 IMEI: 353631063454560 Ape Version: NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM version : IJ Product code: 059W2D7 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok |
08-26-2017, 13:42 | #217 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 6120 Full flash done :) Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm243_07.20_prd_core.fpsx PPM : rm243_07.20_prd_vB15_01_apac2.fpsx CNT : rm243_ENO_A_2009wk15v0.100.fpsx APE : rm243_07.20_prd_UDA_Nokia_Noir.fpsx Flashing phone now... [Gen] Rules accepted for : RAPIDO Generation Check files done... -> Check SW version... FlashFile version : 07.20 Phone version : 06.51 -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL2 Simlock read ... Ok SimLock Data saved... SimLock Key saved... RPL saved : F:\1+Flashing Software\1+Infinity Box\BEST\Backup\Cert\354846025604826_SIM.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101021103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1F2001056A750052DB2CFB003873705736507C8D ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP ... Processing PASUBTOC ... Boot Done! :) TIME : Boot time : 00:00:30 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 ADL Server confirm flashmode! Get req info : empty ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm243_07.20_prd_core.fpsx Found 3 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x0087FFFF, NAND, CMT Result: 0000 Erasing area 0x00B80000 - 0x04DFFFFF, NAND, CMT Result: 0000 Partition erase not allowed by loader Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing rm243_07.20_prd_core.fpsx Total 404 [404/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS*CORE] CMT : Writing Hash CERT [SOS+ROFS] TIME : Write time : 00:01:09 MCU Write done ===Flashing [PPM]=== Erase : Processing rm243_07.20_prd_vB15_01_apac2.fpsx Found 1 areas to erase Erasing area 0x03300000 - 0x04DFFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm243_07.20_prd_vB15_01_apac2.fpsx Total 164 [164/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFX] TIME : Write time : 00:00:33 PPM Write done ===Flashing [CNT]=== Erase : Processing rm243_ENO_A_2009wk15v0.100.fpsx Found 1 areas to erase Erasing area 0x00880000 - 0x00B7FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm243_ENO_A_2009wk15v0.100.fpsx Total 18 [18/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS*ENO] TIME : Write time : 00:00:02 CNT Write done ===Flashing [APE]=== Erase : Processing rm243_07.20_prd_UDA_Nokia_Noir.fpsx Found 1 areas to erase Erasing area 0x04E00000 - 0x07B3FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm243_07.20_prd_UDA_Nokia_Noir.fpsx Total 1 [1/0/0] blocks to write, writing... TIME : Write time : 00:00:00 APE Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:01:46 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6120 Software Info: V 07.20 05-10-09 RM-243 (c) Nokia IMEI: 354846025604826 Ape Version: 07.20 Product code: 0550022 Wait, when phone will be ready ... Checking... SimLock status : Can't get status Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:02:49 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok CMLA Key status : CMLA key is Ok SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL2 phone detected Done! |
08-27-2017, 12:57 | #218 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia Asha 206 FlashingDone Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm872__04.52.mcusw PPM : rm872__04.52.ppm_m2 CNT : rm872__04.52.image_m2_059Q8L5 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 357255056085508 IMEI 2 : 357255056085516 PCcode : 059Q4J7 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\357255056085508_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm872__04.52.mcusw Image : rm872__04.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:02:19 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:31 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xFA4D ===Flashing [PPM]=== File : rm872__04.52.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00680000 Erasing, wait ... Erase done, time : 00:00:22 Write , Start : 0x41A80000 , Len : 0x003C68F0 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xC9E6 ===Flashing [CNT]=== File : rm872__04.52.image_m2_059Q8L5 Image : package_m2_059Q8L5.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:05:21 Write , Start : 0x42100000 , Len : 0x01040000 Flashing , wait ... Region flash done, time : 00:00:28 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:09 No write data, skip CRC check passed , 0xDE0E Flashing done! Total flash time : 00:09:27 Reboot phone now... Reading Phone Info.... Connected phone - 206 Software Info: V 04.52 30-06-13 RM-872 (c) Nokia IMEI: 357255056085508 PPM version : V 04.52 30-06-13 RM-872 (c) Nokia M2 Product code: 059Q8L5 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:10:17 |
08-27-2017, 12:58 | #219 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 220 Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-969_ROM_eMP_30.06.11 VIVA : RM-969_VIVA_eMP_30.06.11 LANG : RM-969_LANG_PACK_ROM_IJ_eMP_30.06.11_001 CUST : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001 JMPT : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 33 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 9969F34FD0ED07BB3580985C780C1D66 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Rivendell.10.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 SecureDecrypt : RM-969_ROM_eMP_30.06.11 SecureDecrypt : RM-969_VIVA_eMP_30.06.11 SecureDecrypt : RM-969_LANG_PACK_ROM_IJ_eMP_30.06.11_001 SecureDecrypt : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001 SecureDecrypt : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001 OVRLP : 000069B900000001 PHPID : Rivendell.10.03.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-969_ROM_eMP_30.06.11 Write : RM-969_LANG_PACK_ROM_IJ_eMP_30.06.11_001 Write : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001 Write : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001 Write : RM-969_VIVA_eMP_30.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-969_ROM_eMP_30.06.11 [VERIFY] DONE : RM-969_LANG_PACK_ROM_IJ_eMP_30.06.11_001 [VERIFY] DONE : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001 [VERIFY] DONE : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001 [VERIFY] DONE : RM-969_VIVA_eMP_30.06.11 CODE_VERIFY : Ok Will Upload FAT Image now Write : RM-969_FATIMAGE_IJ_30.06.11 FAT Image Flash done! FAT Verify Ok Rebooting phone now Flashing done! Total flash time : 00:04:28 |
08-27-2017, 12:59 | #220 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 215 Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1110_ROM_eMP_12.03.11 VIVA : RM-1110_VIVA_eMP_12.03.11 LANG : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001 CUST : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001 JMPT : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 33 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 4F9C25389A0B2E57F932F47901BAA34C BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : JET.12.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Jet.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000 SecureDecrypt : RM-1110_ROM_eMP_12.03.11 SecureDecrypt : RM-1110_VIVA_eMP_12.03.11 SecureDecrypt : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001 SecureDecrypt : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001 SecureDecrypt : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001 OVRLP : 000069B900000001 PHPID : JET.12.03.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1110_ROM_eMP_12.03.11 Write : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001 Write : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001 Write : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001 Write : RM-1110_VIVA_eMP_12.03.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1110_ROM_eMP_12.03.11 [VERIFY] DONE : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001 [VERIFY] DONE : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001 [VERIFY] DONE : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001 [VERIFY] DONE : RM-1110_VIVA_eMP_12.03.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:03:05 |
08-27-2017, 13:01 | #221 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 130 Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1035_ROM_eMP_11.00.11 VIVA : RM-1035_VIVA_eMP_11.00.11 LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 JMPT : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 - > MODE : FullFlash Repair Mode is On Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 34 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 88CCFF866589904B4EC47F41D12DD0B0 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.11.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_11.00.11 SecureDecrypt : RM-1035_VIVA_eMP_11.00.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 OVRLP : 000069B900000001 PHPID : CRYSTAL.11.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_11.00.11 Write : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 Write : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_VIVA_eMP_11.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_11.00.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_VIVA_eMP_11.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:01 |
08-27-2017, 13:03 | #222 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 108 Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-944_ROM_eMP_20.06.11 VIVA : RM-944_VIVA_eMP_20.06.11 LANG : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 CUST : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 JMPT : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 33 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 7DDAF539B30448C1391537275947CAF5 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Bree.20.06.11.p4 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 SecureDecrypt : RM-944_ROM_eMP_20.06.11 SecureDecrypt : RM-944_VIVA_eMP_20.06.11 SecureDecrypt : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 SecureDecrypt : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 SecureDecrypt : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 OVRLP : 000069B900000001 PHPID : Bree.20.06.11.p4 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-944_ROM_eMP_20.06.11 Write : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 Write : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 Write : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 Write : RM-944_VIVA_eMP_20.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-944_ROM_eMP_20.06.11 [VERIFY] DONE : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 [VERIFY] DONE : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 [VERIFY] DONE : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 [VERIFY] DONE : RM-944_VIVA_eMP_20.06.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:16 |
08-27-2017, 13:26 | #223 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 130 reset user code Done :) Code: Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 140 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 464D2066290238A4393EDEEB7717E22E BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
08-30-2017, 15:26 | #224 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 108 read user code Done :) Code: Phone found! MTKx Nokia Phone detected Read info... Ok Software Info: 12.06.11 00-00-00 RM-944 IMEI: 359186057596383 PPM version : IJ Product code: 059S7R0 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : D15267F4053FC250F300C1D1FBB2E8CB BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Bree.12.06.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA0_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 MT625x : Read User Code User Code : 11111113 Done! Connect phone on selected interface... |
09-04-2017, 12:27 | #225 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 108 Format Done --- Insert USB cable now! --- Wait for phone... Phone found! [ 74 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 3F23244356C8B4AD08FF918AC39DE094 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Bree.20.06.11.p4 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E [0] : FLASH_DIE : 00C2 0025 0036 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:38 |
