Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 04-26-2017, 15:40   #46 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 628
Nokia 110
Core : v2.28 , BB5XG FlashEngine : v10.5
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm827__03.51.mcusw
PPM : rm827__03.51.ppm_m2
CNT : rm827__03.51.image_m2_059N2R0
Flashing phone now...
[Gen] Rules accepted for : XGOLD Generation
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
-> If Windows say "Unrecognized device" / Operation not start
-> Or if Phone start charge - just reinsert battery
-> If flashing freeze - reinsert cable/battery and try again
--- Press phone's power button or insert usb cable! ---
Connection opened successfully
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
IF xCPUID    : XGOLD 213 [XMM2130 QUANTUM]
IF Resp Data  :  1FB300020303010100FF
Sending EBL Loader ...
EBL Loader Ok, 01
EBL Loader ready, AA
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.49_M1S1
Speed accepted, use 6.500.000
FLASHID : 89008289
FLIC conf set, RST set
Boot done!
Check keys...
Check done. Image can be flashed
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 359981058150580
IMEI 2 : 359981058150598
PCcode : 059N403
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\359981058150580_XG213_CRT.rpl
Settings : EDM [0x8] , Block Mode , Fast CRC , Verify
   ===Flashing [MCU]===
File : rm827__03.51.mcusw
Image : rm827__03.51.mcusw_ebl_psi.fls
Sec-pack found, sending ...
Sec-pack sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:01
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:05
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x01940000
Erasing, wait ...
Erase done, time : 00:02:16
Write , Start : 0x40280000 , Len : 0x018C0000
Flashing , wait ...
Region flash done, time : 00:00:34
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
CRC check passed , 0xA3D6
   ===Flashing [PPM]===
File : rm827__03.51.ppm_m2
Image : package_m2.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41BC0000 , Len : 0x00600000
Erasing, wait ...
Erase done, time : 00:00:16
Write , Start : 0x41BC0000 , Len : 0x0030F748
Flashing , wait ...
Region flash done, time : 00:00:05
CRC check passed , 0x4605
   ===Flashing [CNT]===
File : rm827__03.51.image_m2_059N2R0
Image : package_m2_059N2R0.image.fls
Sec-pack sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x421C0000 , Len : 0x01C60000
Erasing, wait ...
Erase done, time : 00:04:28
Write , Start : 0x421C0000 , Len : 0x00F20000
Flashing , wait ...
Region flash done, time : 00:00:24
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
Erase done, time : 00:00:08
No write data, skip
CRC check passed , 0x7408
Flashing done!
Total flash time : 00:08:24
Reboot phone now...
Reading Phone Info....
Connected phone -   Nokia 110
Software Info:     V 03.51 06-08-13 RM-827 (c) Nokia
IMEI:  359981058150580
PPM version :   V 03.51 06-08-13 RM-827 (c) Nokia             M2
Product code:  059N403
Wait, when phone will be ready ...
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Processing After Flash Defaults...
FullFactorySet... Ok!
UserDataDefaultsSet...OK!
ServiceDefaultsSet... Ok!
LeaveDefaultsSet... Ok!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Check and Upload User Certificates ...
Total - 58 certs
Certificates found, skip upload ...
AfterFlash operations done ;D
Done!
Connect phone on selected interface...
Elapsed: 00:09:28
The Following User Says Thank You to Luckey1 For This Useful Post:
Old 04-27-2017, 04:47   #47 (permalink)
Member: 61595
Sonork: 100.1610188
Thanks Meter: 81
lumia 650 rm1152 unlock don
[WP8x] : Init TesMode
[TSTM] : Use File : RM1152_1078.0021.10586.13053.207.331_enosw-wim-signed_516102.secwim
=== Base Phone Info
Sw Version : 01078.00037.16082.41002
IMEI : 35512607830xxx
ProductCode : M1012174-001
Device catched in BOOT mode!
Collect Info...
=== Nokia Flash App info :
Protocol Version : 2.41
Protocol Implementation : 2.75
=== Phone Initial info :
Phone Model ID : Microsoft.MSM8909.P6237.2.0
=== eMMC info :
eMMC Vendor : Samsung
eMMC CID : 0015
eMMC Size : 14910 MiB
=== Security Initial info :
Security Status : 010100000101
Secure Boot : Enabled
Secure eFUSE : Enabled
JTAG : Disabled
RDC Key : Not Present (Retail)
UEFI SBoot : Enabled
SecHW Key : Exists
Device RootKey : B8219CA0F88F67C2EF5C16BE975B61705FA14D95
=== Other info :
SD present : False
SECWIM : RM1152_1078.0021.10586.13053.207.331_enosw-wim-signed_516102.secwim
Sending WIM ...
WIM Image sent! Trying init TestMode now...
Phone found!
WP10/WP8x Lumia Phone detected
Read info... Ok
Check SimLock info
Conf key : 8000000000000000
Provider key : 2280100000000000
Country : Switzerland
Operator : Swisscom
Counters : Key 0 [3] , Fbus 0 [10]
Blocks : 1
LOCK STATUS :
BLK : 1
Lock1:Close
LOCKS : Closed
Done!
WP8 Unlock Started
Connecting to server...
Connected
Authenticating...
Authenticated
Checking Client version...
Client version is valid
Processing Step #1
Processing Step #2
Processing Step #3
Processing Step #4
Disconnected
Need SDAuth to finish ...
Started
Connecting to SX4 server...
Connected
SX4 enter ..
SDAuth Ok!
SX4 Disconnected
Unlock Done!
Wait for phone reboot ...
Reboot Ok!
rm1152 eno file https://we.tl/VbCEVutwcK
The Following 2 Users Say Thank You to naje For This Useful Post:
Old 04-27-2017, 04:51   #48 (permalink)
Member: 61595
Sonork: 100.1610188
Thanks Meter: 81
lumia 650 RM-1152 unlock success
=== Base Phone Info
IMEI : 355126078300724
Collect Info...
=== eMMC info :
eMMC CID : 0015
JTAG : Disabled
SecHW Key : Exists
=== Other info :
SD present : False
Sending WIM ...
Phone found!
Read info... Ok
Check SimLock info
Operator : Swisscom
Blocks : 1
LOCK STATUS :
BLK : 1
Lock1:Close
LOCKS : Closed
Done!
WP8 Unlock Started
Connected
Authenticating...
Authenticated
Processing Step #1
Processing Step #2
Processing Step #3
Processing Step #4
Disconnected
Started
Connected
SX4 enter ..
SDAuth Ok!
SX4 Disconnected
Unlock Done!
Reboot Ok!
The Following User Says Thank You to naje For This Useful Post:
Old 04-27-2017, 09:58   #49 (permalink)
Nasir Mobiles's Avatar
Member: 355782
Thanks Meter: 1,248
Nokia 130 (RM-1035) Blinking Repaired.
Write Firmware:
Core : v2.28 , MTKx FlashEngine : v12.0
Verify files ...
MAUI : RM-1035_ROM_eMP_10.01.11
VIVA : RM-1035_VIVA_eMP_10.01.11
LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001
CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001
JMPT : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001
 - > MODE : FullFlash
1. Phone should be Off!
2. Battery must be charged and inserted! ( if not used external power )
 - > If phone can't switch to BL - use battery or flash from Local mode!
--- Insert USB cable now! ---
Wait for phone...
Phone found! [ 256 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0001
BB_CPU_SN : DD694703B9A9A599E9364BE1EFAE9197
BROM Protocol Version : 05
BROM Status : 0000
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
Setting done , result code 0x8000
Project ID : CRYSTAL.10.01.11.p2
BROM/BL stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_eMP_Crystal.fg
DA_VERIFY : 00
DA_JUMP   : 00040000
DA_AUTH   : Passed!
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x8B
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV
[0] : FLASH_DIE : 00EF 0040 0016 0000
[0] : FLASH_LEN : 0x00400000
FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000
SecureDecrypt : RM-1035_ROM_eMP_10.01.11
SecureDecrypt : RM-1035_VIVA_eMP_10.01.11
SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001
SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001
SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001
OVRLP : 000069B900000001
PHPID : CRYSTAL.10.01.11.p2
OVRLP : 00004DF900000001
DA : FORMAT_BIN
Processing Flash Pre-format
FILES : 5
SAFE_BLOCK : 04
FORMAT_BIN : Ok
WRITE_STYLE : DEF : 0x01 (SEQ)
Write : RM-1035_ROM_eMP_10.01.11
Write : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001
Write : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001
Write : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001
Write : RM-1035_VIVA_eMP_10.01.11
CODE_DNLOAD : Ok
[VERIFY] DONE : RM-1035_ROM_eMP_10.01.11
[VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001
[VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001
[VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001
[VERIFY] DONE : RM-1035_VIVA_eMP_10.01.11
CODE_VERIFY : Ok
Executing FFS FORMAT now...
DA_RET   : DA_IN_PROGRESS
DA_RET   : FORMAT_DONE
Rebooting phone now
Flashing done!
Total flash time : 00:00:52
Reboot phone Ok
The Following User Says Thank You to Nasir Mobiles For This Useful Post:
Old 04-29-2017, 07:09   #50 (permalink)
RAJAN BHAGORIYA's Avatar
Member: 2366206
Sonork: 100.1666898
Thanks Meter: 138
Nokia 225 hang to logo done with nokia best
The Following User Says Thank You to RAJAN BHAGORIYA For This Useful Post:
Old 05-01-2017, 08:59   #51 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 3,989
Nokia 501 Write Firmware Done :)
File [Ok] : rm902_14.0.6.mcusw.fpsx
File [Ok] : rm902_14.0.3_059R2T6_m1_245_03_452443.rofs.fpsx
File [Ok] : rm902_14.0.3_059R2T6_m1_245_03_452443.image.fpsx
If PC not detect phone - Insert Cable first, then Insert battery
If stuck on boot  - remove MicroSD card from phone!
--- Press phone's power button or insert cable & charger! ---
1st Boot Done, processing booting now
ASIC ID_F     : 00000C201610004049B22E099A69F14AEC469A00
ASIC ID_E     : 00000C2016100040
PUBLIC ID     : 358CC06FB31096C349B22E099A69F14AEC469A00
XGCHIP ID     : 358CC06FB31096C3
ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579
ROM ID        : 535882252F54C676
Prepare and send 2nd loader...
2nd boot Ok
Prepare and send Algo loader...
Algo boot Ok
IMEI [1] : 358139058311360
IMEI [2] : 358139058311378
RPL saved : F:\1+Flashing Software\1+Infinity Box\BEST\Backup\Cert\358139058311360_XG223_CRT.rpl
PAPUBkeys : 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E
 === SW Version Check ===
- > UPGRADE
  === Flashing MCU ===
Processing file : rm902_14.0.6.mcusw.fpsx
Erasing...
Writing...
Total blocks : 82
Writing RKH CRT [ISSW]
Writing RKH CRT [MEMSET]
Writing RKH CRT [PRIMAPP]
Writing RKH CRT [LOADER]
Writing RKH CRT [PASUBTOC]
Writing RKH CRT [PAPUBKEYS] [PAKeys : 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E]
Writing RKH CRT [UPDAPP]
Writing RKH CRT [MCUSW]
File processed Ok, 81 blocks were writen
  === Flashing PPM ===
Processing file : rm902_14.0.3_059R2T6_m1_245_03_452443.rofs.fpsx
Erasing...
Writing...
Total blocks : 13
Writing RKH CRT [PPM]
File processed Ok, 13 blocks were writen
  === Flashing CNT ===
Processing file : rm902_14.0.3_059R2T6_m1_245_03_452443.image.fpsx
Erasing...
Writing...
Total blocks : 59
File processed Ok, 59 blocks were writen
Flashing done , total time : 00:00:58
Reboot phone to service mode...
Connected phone -   501
Software Info:     V 14.0.6 10-07-14 RM-902 (c) Nokia
IMEI:  358139058311360
PPM version :   ea6d94589d9f63b081391ac0aae46b014a8938b3
Product code:  059T1W3
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 59 certs
Battery voltage is enough for start
Set phone to Normal mode...
Phone found!
Series 40 Device detected!
read info...  - Ok
The Following User Says Thank You to syed tuqeer For This Useful Post:
Old 05-03-2017, 12:31   #52 (permalink)
Member: 355782
Thanks Meter: 1,248
Nokia 2700 Classic (RM-561) Flashing Done.
MCU : rm561__09.98.mcusw
PPM : rm561__09.98.ppm_t
CNT : rm561__09.98.image_t_ph_blac
[Gen] Rules accepted for : RAP3x Generation
Check files done...
-> SWversion check skipped : Manual mode selected
Backup CRT308 data...
CRT308 Backup Created
SLx Simlock Data read ... Ok
SL3 Simlock Sign read ... Ok
WMDRM read ... Ok
SimLock Data saved...
SimLock Key saved...
WMDRM_PD Data saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\357017045004143_SIM.rpl
Batery valtage : 3711 mV
-> Batery voltage less, than 3,8V (3711mV). Continue at user risk
Getting product info...
RAP_BOOT:     0803000302010000
RAP_PUBLIC:   1F300010BD710F569738948293B51EF2CDAFA9F5
CMT_ROOTKEY:  9DDBFCFE6E73CED7D8C6268C8EB85723
RAP_PAPUBKEY: 3EA22A1DDA660002E56108DB5072A10F8709443F
Checking CNT sector PN<>FL
PN CNT sector : 128 kb
ConvertImage: Processing rm561__09.98.image_t_ph_blac
ConvertImage: Page Size is 128K, no need convert
Loader len: 308032, CHK: 037B
ADL -> Sending loader...
Update Server code succesfully sent to phone!
TIME : Boot time : 00:00:06
Reopening the connection...
Waiting for response: 30
Waiting for response: 29
ADL -> [2nd] changing...
ADL Server confirm flashmode!
ADL : Check data
ADL : Data accepted
Erase : Processing rm561__09.98.mcusw
Found 6 areas to erase
Erasing area 0x00000000 - 0x000006BF, NOR, CMT
Result: 0000
Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT
Result: 0000
Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT
Result: 0000
Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT
Result: 0000
Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT
Result: 0000
Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:02:16
Write : Processing rm561__09.98.mcusw
Total 1256 [1256/0/0] blocks to write, writing...
CMT : Writing Hash CERT [NOLO]
CMT : Writing Hash CERT [KEYS]
CMT : Writing Hash CERT [PRIMAPP]
CMT : Writing Hash CERT [PASUBTOC]
CMT : Writing Hash CERT [PAPUBKEYS]
CMT : Writing Hash CERT [UPDAPP]
CMT : Writing Hash CERT [DSP0]
CMT : Writing Hash CERT [MCUSW]
TIME : Write time : 00:00:57
MCU Write done
Erase : Processing rm561__09.98.ppm_t
Found 1 areas to erase
Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:00:59
Write : Processing rm561__09.98.ppm_t
Total 353 [353/0/0] blocks to write, writing...
TIME : Write time : 00:00:16
PPM Write done
Erase : Processing rm561__09.98.image_t_ph_blac
Found 2 areas to erase
Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT
Result: 0000
Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:05:54
Write : Processing rm561__09.98.image_t_ph_blac
Total 696 [696/0/0] blocks to write, writing...
TIME : Write time : 00:00:32
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:10:56
Reboot phone now...
SwUpgradeSet...OK!
Total - 0 certs
Uploading User Certificates...
Uploaded 26 certs!
Done!
Elapsed: 00:11:57
Phone found!
read info...  - Ok
Set phone in Normal mode...
Restarting...
Done!
Phone disconected!
Old 05-03-2017, 17:16   #53 (permalink)
Member: 1297521
Thanks Meter: 28
Lumia 650 RM-1152 unlocked
Init TEST mode:
 === Base Phone Info
Sw Version   : 01078.00042.16352.50003
IMEI         : 355126078671454
Collect Info...
=== eMMC info :
eMMC CID : 0015
JTAG : Disabled
SecHW Key : Exists
=== Other info :
SD present        : False
Sending WIM ...
Phone found!
Read info... Ok
SD auth:
SD Authentification : not done
Local SX4 Card Not Found, wil use Server
Started
Connected
SX4 enter ..
SDAuth Ok!
SX4 Disconnected
SX4 Done!
Done!
Unlock:
WP8 Unlock Started
Connected
Authenticating...
Authenticated
Processing Step #1
Processing Step #2
Processing Step #3
Processing Step #4
Disconnected
Unlock Done!
Reboot Ok!
Done!
The Following User Says Thank You to servis.kompa For This Useful Post:
Old 05-05-2017, 12:32   #54 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 628
Nokia 206
MCU : rm872__04.52.mcusw
PPM : rm872__04.52.ppm_m2
CNT : rm872__04.52.image_m2_059Q8L5
Check files done...
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
EBL Loader Ok, 01
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.53_M1S1
FLASHID : EC001230
Boot done!
Check keys...
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 359991057334549
IMEI 2 : 359991057334556
PCcode : 059Q4L5
RPL saved : C:\InfinityBox\BEST\Backup\Cert\359991057334549_XG213_CRT.rpl
File : rm872__04.52.mcusw
Image : rm872__04.52.mcusw_ebl_psi.fls
Sec-pack sent
Found 5 region(s)
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Erase done, time : 00:00:02
Flashing , wait ...
Erase , Start : 0x40280000 , Len : 0x01800000
Erasing, wait ...
Erase done, time : 00:00:50
Write , Start : 0x40280000 , Len : 0x01800000
Flashing , wait ...
Erasing, wait ...
No write data, skip
CRC check passed , 0xFA4D
File : rm872__04.52.ppm_m2
Sec-pack sent
Found 1 region(s)
Erase , Start : 0x41A80000 , Len : 0x00680000
Erasing, wait ...
Write , Start : 0x41A80000 , Len : 0x003C68F0
Flashing , wait ...
Region flash done, time : 00:00:04
CRC check passed , 0xC9E6
File : rm872__04.52.image_m2_059Q8L5
Image : package_m2_059Q8L5.image.fls
Sec-pack sent
Found 2 region(s)
Erase , Start : 0x42100000 , Len : 0x01D20000
Erasing, wait ...
Erase done, time : 00:01:10
Write , Start : 0x42100000 , Len : 0x01040000
Flashing , wait ...
Region flash done, time : 00:00:21
Erasing, wait ...
No write data, skip
CRC check passed , 0xDE0E
Flashing done!
Total flash time : 00:03:17
Reboot phone now...
Connected phone -   206
Software Info:     V 04.52 30-06-13 RM-872 (c) Nokia
IMEI:  359991057334549
PPM version :   V 04.52 30-06-13 RM-872 (c) Nokia             M2
Product code:  059Q4L5
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 58 certs
Done!
Elapsed: 00:04:11
Old 05-06-2017, 07:05   #55 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,875
Smile Old Is Gold > Nokia 2690 Flashing Done
Core : v2.29 , BB5XG FlashEngine : v10.5
MCU : rm635__10.65.mcusw
PPM : rm635__10.65.ppm_ms
CNT : rm635__10.65.image_ms_black
Check files done...
->  Phone not found.. :(
->  Error while flashing... :(
Check files done...
Waiting for communication response.
ASIC ID:       000000010000022600010006030C192101033000
CPU ID :       RAP3Gv3 , Features : No any extended features
RAP_PUB:   1FE0000E6C9D7D5622A3EF87E4B7637699BD5E6B
CMT_ROOT:  9DDBFCFE6E73CED7D8C6268C8EB85723
PatchRAWLoader: Patched OK
Processing RAWLOADER...
Processing UPDAPP...
Processing PASUBTOC...
ADL : Check data
ADL : Data accepted
Erase : Processing rm635__10.65.mcusw
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
TIME : Erase time : 00:02:28
Write : Processing rm635__10.65.mcusw
Total 1165 [1165/0/0] blocks to write, writing...
TIME : Write time : 00:00:55
MCU Write done
Erase : Processing rm635__10.65.ppm_ms
Result: 0000
TIME : Erase time : 00:01:01
Write : Processing rm635__10.65.ppm_ms
Total 172 [172/0/0] blocks to write, writing...
TIME : Write time : 00:00:08
PPM Write done
Erase : Processing rm635__10.65.image_ms_black
Result: 0000
Result: 0000
TIME : Erase time : 00:07:19
Checking content info...
Check Image : Content size is 128k, use direct write mode
Write : Processing rm635__10.65.image_ms_black
Total 496 [496/0/0] blocks to write, writing...
TIME : Write time : 00:00:28
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:12:23
Reboot phone now...
Connected phone -   Nokia 2690
Software Info:     V 10.65 09-12-10 RM-635 (c) Nokia
IMEI:  353411041214323
PPM version :   V 10.65 09-12-10 RM-635 (c) Nokia             MS
Product code:  0592552
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 0 certs
Uploaded 26 certs!
Done!
Elapsed: 00:13:25
The Following 4 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 05-06-2017, 07:06   #56 (permalink)
Member: 953334
Sonork: 100.1614005
Nokia 215 Format Done
Wait for phone...
Phone found! [ 23 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_SN : E66FC4442AF4E79BEAC9822FB964B106
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
Project ID : JET.10.01.11.p1
BROM/BL stage done
DA_eMP_Jet.fg
DA_VERIFY : 00
DA_JUMP   : 00040000
DA_AUTH   : Passed!
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G
[0] : FLASH_DIE : 00C2 0025 0038 0000
[0] : FLASH_LEN : 0x01000000
FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000
Elapsed: 00:00:20
Old 05-12-2017, 12:25   #57 (permalink)
muzammal mudass's Avatar
Member: 1819120
Sonork: 100.1648344
Thanks Meter: 1,372
Nokia 105 New Full Flash Done
Verify files ...
MAUI : RM-1133_ROM_eMP_13.00.11
VIVA : RM-1133_VIVA_eMP_13.00.11
LANG : RM-1133_LANG_PACK_ROM_IJ_eMP_13.00.11_002
CUST : RM-1133_CUSTPACK_ROM_IJ_MEA_PK_eMP_13.00.11_002
JMPT : RM-1133_JUMP_TABLE_IJ_MEA_PK_eMP_13.00.11_002
Wait for phone...
Phone found! [ 46 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0001
BB_CPU_SN : E967416C4DB2F30326CA695BC8469147
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
Project ID : LAGOS61D.10.01.11.p2
BROM/BL stage done
DA_eMP_Lagos.fg
DA_VERIFY : 00
DA_JUMP   : 00100000
DA_AUTH   : Passed!
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x8E
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32
[0] : FLASH_DIE : 00C8 0060 0016 0000
FAT_RANGE : 0x00368000-0x003F7FFF , LEN : 0x00090000
SecureDecrypt : RM-1133_ROM_eMP_13.00.11
SecureDecrypt : RM-1133_VIVA_eMP_13.00.11
SecureDecrypt : RM-1133_LANG_PACK_ROM_IJ_eMP_13.00.11_002
SecureDecrypt : RM-1133_CUSTPACK_ROM_IJ_MEA_PK_eMP_13.00.11_002
SecureDecrypt : RM-1133_JUMP_TABLE_IJ_MEA_PK_eMP_13.00.11_002
PHPID : LAGOS61D.10.01.11.p2
DA : FORMAT_BIN
FILES : 5
SAFE_BLOCK : 04
FORMAT_BIN : Ok
Write : RM-1133_ROM_eMP_13.00.11
Write : RM-1133_LANG_PACK_ROM_IJ_eMP_13.00.11_002
Write : RM-1133_CUSTPACK_ROM_IJ_MEA_PK_eMP_13.00.11_002
Write : RM-1133_JUMP_TABLE_IJ_MEA_PK_eMP_13.00.11_002
Write : RM-1133_VIVA_eMP_13.00.11
CODE_DNLOAD : Ok
[VERIFY] DONE : RM-1133_ROM_eMP_13.00.11
[VERIFY] DONE : RM-1133_LANG_PACK_ROM_IJ_eMP_13.00.11_002
[VERIFY] DONE : RM-1133_CUSTPACK_ROM_IJ_MEA_PK_eMP_13.00.11_002
[VERIFY] DONE : RM-1133_JUMP_TABLE_IJ_MEA_PK_eMP_13.00.11_002
[VERIFY] DONE : RM-1133_VIVA_eMP_13.00.11
CODE_VERIFY : Ok
Rebooting phone now
Flashing done!
Total flash time : 00:00:59
Reboot phone Ok
Phone found!
MTKx Nokia Phone detected
Read info... Ok
Muzammal Mudasser
The Following User Says Thank You to muzammal mudass For This Useful Post:
Old 05-12-2017, 12:40   #58 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 628
Nokia C1-01
MCU : rm607__04.40.mcusw
PPM : rm607__04.40.ppm_m_c
CNT : rm607__04.40.image_m_c_0595609
Check files done...
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
EBL Loader Ok, 01
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_2.3_M1S1
FLASHID : 89008289
Boot done!
Check keys...
Reading CCC
Reading HWC
Reading NPC
IMEI : 357913042838790
PCcode : 059G896
RPL saved : C:\InfinityBox\BEST\Backup\Cert\357913042838790_XG213_CRT.rpl
File : rm607__04.40.mcusw
Image : rm607__04.40.mcusw_ebl_psi.fls
Sec-pack sent
Found 5 region(s)
Erasing, wait ...
Flashing , wait ...
Erase , Start : 0x40040000 , Len : 0x00040000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00040000
Flashing , wait ...
Erase , Start : 0x40080000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40080000 , Len : 0x00020000
Flashing , wait ...
Erase , Start : 0x400A0000 , Len : 0x00100000
Erasing, wait ...
Write , Start : 0x400A0000 , Len : 0x00100000
Flashing , wait ...
Erase , Start : 0x40400000 , Len : 0x01800000
Erasing, wait ...
Erase done, time : 00:02:02
Write , Start : 0x40400000 , Len : 0x01780000
Flashing , wait ...
Region flash done, time : 00:00:31
CRC check passed , 0xD471
File : rm607__04.40.ppm_m_c
Image : package_m_c.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Erase , Start : 0x41C00000 , Len : 0x00600000
Erasing, wait ...
Write , Start : 0x41C00000 , Len : 0x0031A50C
Flashing , wait ...
Region flash done, time : 00:00:03
CRC check passed , 0x4A12
File : rm607__04.40.image_m_c_0595609
Image : package_m_c_0595609.image.fls
Sec-pack sent
Found 2 region(s)
Erase , Start : 0x42200000 , Len : 0x01C60000
Erasing, wait ...
Erase done, time : 00:05:26
Write , Start : 0x42200000 , Len : 0x00B60000
Flashing , wait ...
Erasing, wait ...
No write data, skip
CRC check passed , 0x17AA
Flashing done!
Total flash time : 00:09:01
Reboot phone now...
Connected phone -   C1-01
Software Info:     V 04.40 23-02-11 RM-607 (c) Nokia
IMEI:  357913042838790
PPM version :   V 04.40 23-02-11 RM-607 (c) Nokia             M_C
Product code:  059G896
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 39 certs
Done!
Elapsed: 00:09:59
Old 05-12-2017, 12:41   #59 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 628
Nokia 220 Rm-969
Core : v2.29 , MTKx FlashEngine : v14.0
Verify files ...
MAUI : RM-969_ROM_eMP_30.06.11
VIVA : RM-969_VIVA_eMP_30.06.11
LANG : RM-969_LANG_PACK_ROM_IJ_eMP_30.06.11_001
CUST : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001
JMPT : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001
Wait for phone...
Phone found! [ 38 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6250_S0001
BB_CPU_SN : E8E1F8BD6479163B9D3AD5EF0E84D725
BROM Status : 1012
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
Project ID : Rivendell.10.03.11.p1
BROM/BL stage done
DA_eMP_Rivendell.fg
DA_VERIFY : 00
DA_JUMP   : 00040000
DA_AUTH   : Passed!
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x88
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW
[0] : FLASH_DIE : 00EF 0060 0018 0000
FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000
SecureDecrypt : RM-969_ROM_eMP_30.06.11
SecureDecrypt : RM-969_VIVA_eMP_30.06.11
SecureDecrypt : RM-969_LANG_PACK_ROM_IJ_eMP_30.06.11_001
SecureDecrypt : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001
SecureDecrypt : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001
PHPID : Rivendell.10.03.11.p1
DA : FORMAT_BIN
FILES : 5
SAFE_BLOCK : 04
FORMAT_BIN : Ok
Write : RM-969_ROM_eMP_30.06.11
Write : RM-969_LANG_PACK_ROM_IJ_eMP_30.06.11_001
Write : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001
Write : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001
Write : RM-969_VIVA_eMP_30.06.11
CODE_DNLOAD : Ok
[VERIFY] DONE : RM-969_ROM_eMP_30.06.11
[VERIFY] DONE : RM-969_LANG_PACK_ROM_IJ_eMP_30.06.11_001
[VERIFY] DONE : RM-969_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001
[VERIFY] DONE : RM-969_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001
[VERIFY] DONE : RM-969_VIVA_eMP_30.06.11
CODE_VERIFY : Ok
Will Upload FAT Image now
Write : RM-969_FATIMAGE_IJ_30.06.11
FAT Image Flash done!
FAT Verify Ok
Rebooting phone now
Flashing done!
Total flash time : 00:05:04
Reboot phone Ok
Old 05-12-2017, 12:42   #60 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 628
Nokia 110 flashing done
Check files done...
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
EBL Loader Ok, 01
Sending EBL ...
EBL sent Ok
FLASHID : 89008289
Boot done!
Check keys...
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 351970052848008
IMEI 2 : 351970052848016
PCcode : 059N403
RPL saved : C:\InfinityBox\BEST\Backup\Cert\351970052848008_XG213_CRT.rpl
Sec-pack sent
Found 5 region(s)
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Erase done, time : 00:00:04
Flashing , wait ...
Erasing, wait ...
Erase done, time : 00:02:04
Flashing , wait ...
Region flash done, time : 00:00:33
Erasing, wait ...
No write data, skip
Sec-pack sent
Found 1 region(s)
Erasing, wait ...
Flashing , wait ...
Sec-pack sent
Found 2 region(s)
Erasing, wait ...
Erase done, time : 00:04:34
Flashing , wait ...
Region flash done, time : 00:00:25
Erasing, wait ...
No write data, skip
CRC check passed , 0x2091
Flashing done!
Total flash time : 00:08:15
Reboot phone now...
IMEI:  351970052848008
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 58 certs
Done!
Elapsed: 00:09:01
Page generated in 0.65252 seconds with 8 queries
