09-12-2018, 13:51 | #601 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 206 Read User Code Done Series 40 Device detected! read info... - Ok Reading User code... User Code is: 46526254 Done! Phone disconected! |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
09-14-2018, 11:39 | #602 (permalink) |
Freak Poster Join Date: Aug 2015 Location: Choubara(Layyah Pakistan..)
Member: 2451856 Status: Offline Thanks Meter: 247 | Nokia 230 rm1172 user code remove done with infinty best... Nokia 230 rm1172 user code remove done with infinty best... Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 7 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : A1AB506096C4A792EA74660519B6629F BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DOHA.10.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Doha.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 Executing FFS FORMAT now... FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:31 Connect phone on selected interface... |
The Following User Says Thank You to sanwal malik For This Useful Post: |
09-15-2018, 07:25 | #603 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Nokia 500 flash done Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm934_14.0.6_059S9V4_m1.image.fls Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x16 IF xCPUID : XGOLD 221 [XMM2210 QIMING] IF uCHIPID : 194200021C030101CAB21A09926609EC2F450500FFFF IF Resp Data : 194200021C030101 Wait for user action : Insert battery Sending EBL Loader ... EBL Loader Ok EBL Loader ready Sending EBL ... EBL sent Ok EBL : 1_1345.300_MKEYSKEY QIMING EEP config Ok FLASHID : 52F00000 , [ NOR ] Boot conf set, Target Ready Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 351747063734223 IMEI 2 : 351747063734231 Phone Product Code : 059S9V4 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\351747063734223_XG 221_CRT.rpl ===Flashing [CNT]=== Processing file : rm934_14.0.6_059S9V4_m1.image.fls Region count : 1 00 : [ Cust ] : rm934_14.0.6_059S9V4_m1.image.fls.image.fls Parse done , flashing now Flash : 00 : rm934_14.0.6_059S9V4_m1.image.fls.image.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x43800000 , Len : 0x04600000 Erase done Erase area 0x01 , Start 0x47E40000 , Len : 0x000E0000 Erase done Region Start : 0x43800000 , Data Len : 0x02800000 Region Load done Wait for phone write all data ... Write done rm934_14.0.6_059S9V4_m1.image.fls.image.fls image flash done Flashing done! Total flash time : 00:01:12 Reboot phone now... Reading Phone Info.... Connected phone - 500 Software Info: V 14.0.4 07-03-14 RM-934 (c) Nokia IMEI: 351747063734223 PPM version : 9007ffcebcdcc3fb1af9ad968c02920115f301f4 Product code: 059S9V4 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 59 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:01:39 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following User Says Thank You to Nadeem Waris For This Useful Post: |
09-15-2018, 14:13 | #604 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | nokia 216 reset code done Card found: S/N : 76BE6862 , v0122 Registered to: Nadeem Waris Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 701 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : E4B06CD7896AF22DCACE1EAAF3EA6221 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
09-15-2018, 14:17 | #605 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | NOkia 130 logo hang done With Best Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 701 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : E4B06CD7896AF22DCACE1EAAF3EA6221 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1035_ROM_eMP_11.00.11 VIVA : RM-1035_VIVA_eMP_11.00.11 LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 JMPT : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 658 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 1F4E8A288679698F8890A409872200C1 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_11.00.11 SecureDecrypt : RM-1035_VIVA_eMP_11.00.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_11.00.11 Write : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 Write : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_VIVA_eMP_11.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_11.00.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_VIVA_eMP_11.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:06 Reboot phone Ok Connect phone on selected interface... |
09-17-2018, 06:22 | #606 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Nokia 130 bilinking done With best Connect phone on selected interface... Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1035_ROM_eMP_11.00.11 VIVA : RM-1035_VIVA_eMP_11.00.11 LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 JMPT : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Device boot not done Check Drivers Try again Boot Error Flashing failed! Connect phone on selected interface... Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1035_ROM_eMP_11.00.11 VIVA : RM-1035_VIVA_eMP_11.00.11 LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 JMPT : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 701 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : AB7066CB70D3442972992301D23824F5 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_11.00.11 SecureDecrypt : RM-1035_VIVA_eMP_11.00.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_11.00.11 Write : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 Write : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_VIVA_eMP_11.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_11.00.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_VIVA_eMP_11.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:02 Reboot phone Ok Connect phone on selected interface... |
09-17-2018, 07:16 | #607 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 200 Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm761__11.95.mcusw PPM : rm761__11.95.ppm_ma2 CNT : rm761__11.95.image_ma2_059J4K9 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> Check SW version... FlashFile version : 11.95 Phone version : 11.95 19-12-12 RM-761 (c) Nokia -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... SL3 Simlock read (XGOLD) ... Ok WMDRM Key read ... Ok CMLA Key read ... Ok Reboot.... -> If Phone start charge - just reinsert battery fast Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 359345041436920 IMEI 2 : 359345041436938 PCcode : 059J4L0 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\359345041436920_XG 213.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm761__11.95.mcusw Image : rm761__11.95.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:08 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:02:54 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:45 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x495E ===Flashing [PPM]=== File : rm761__11.95.ppm_ma2 Image : package_ma2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00740000 Erasing, wait ... Erase done, time : 00:00:34 Write , Start : 0x41A80000 , Len : 0x0051B9FC Flashing , wait ... Region flash done, time : 00:00:07 CRC check passed , 0xA3D2 ===Flashing [CNT]=== File : rm761__11.95.image_ma2_059J4K9 Image : package_ma2_059J4K9.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:03:45 Write , Start : 0x421C0000 , Len : 0x00FA0000 Flashing , wait ... Region flash done, time : 00:00:20 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:07 No write data, skip CRC check passed , 0xFF7A Flashing done! Total flash time : 00:08:47 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 200 Software Info: V 11.95 19-12-12 RM-761 (c) Nokia IMEI: 359345041436920 PPM version : V 11.95 19-12-12 RM-761 (c) Nokia MA2 Product code: 059J4L0 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 43 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:09:36 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 3 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
09-17-2018, 07:27 | #608 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | nasaki b9 read code done Operation : Read UserCode [ v1.03 ] MODE : From Device 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Reading data ... Sorting data ... STATE : NOT ACTIVE : CODE : 0305300 Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
09-20-2018, 09:19 | #610 (permalink) | |
Banned Join Date: Jan 2017 Location: Algeria DZ
Member: 2669781 Status: Offline Thanks Meter: 1,839 | Nokia 900 Stuck at white screen, solved ... Full log of the operation/ Quote:
The Following User Says Thank You to lyes_albert For This Useful Post: |
09-20-2018, 14:00 | #611 (permalink) |
Freak Poster Join Date: Dec 2013 Location: India
Member: 2077370 Status: Offline Sonork: 100.1616788 Thanks Meter: 268 | Successful post by Sandeep Raxaul nokia rm-1011 format and flash by nk2 1.05 format Operation : Reset Settings [ v1.05 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM31) MODE : NOKIA USB SERIAL PORT : 31 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 7CC3C167FB23BD34D60CFA9C4FE48C33 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : PEARL.20.10.11.p1 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : PEARL.20.10.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00C80000 : 0x00374000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:01:18 Flash Reconnect Power/Cable! Open VPLfile : RM1011_059V6J3_20.10.11.vpl Description : RM-1011 NDT MEA IC WHITE ARABIC SA DeviceType : RM-1011 ProductCode : 059V6J3 SoftwareVer : 20.10.11 Load Ok! Operation : Write FirmWare [ v1.05 ] Setting : UserData erase : True 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM31) MODE : NOKIA USB SERIAL PORT : 31 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 7CC3C167FB23BD34D60CFA9C4FE48C33 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : PEARL.20.10.11.p1 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : PEARL.20.10.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! Load FlashSet : MROM : RM-1011_ROM_eMP_20.10.11 LANG : RM-1011_LANG_PACK_ROM_IC_eMP_20.10.11_002 CUST : RM-1011_CUSTPACK_ROM_IC_MEA_SY_eMP_20.10.11_002 JUMP : RM-1011_JUMP_TABLE_IC_MEA_SY_eMP_20.10.11_002 VIVA : RM-1011_VIVA_eMP_20.10.11 Prepare FlashSet : DCR : RM-1011_ROM_eMP_20.10.11 DCR : RM-1011_LANG_PACK_ROM_IC_eMP_20.10.11_002 DCR : RM-1011_CUSTPACK_ROM_IC_MEA_SY_eMP_20.10.11_002 DCR : RM-1011_JUMP_TABLE_IC_MEA_SY_eMP_20.10.11_002 DCR : RM-1011_VIVA_eMP_20.10.11 Prepare Target SDS : OK : 0x00FF4000 : 0x0000C000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : RM-1011_ROM_eMP_20.10.11 Write : RM-1011_LANG_PACK_ROM_IC_eMP_20.10.11_002 Write : RM-1011_CUSTPACK_ROM_IC_MEA_SY_eMP_20.10.11_002 Write : RM-1011_JUMP_TABLE_IC_MEA_SY_eMP_20.10.11_002 Write : RM-1011_VIVA_eMP_20.10.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : RM-1011_ROM_eMP_20.10.11 Verify : RM-1011_LANG_PACK_ROM_IC_eMP_20.10.11_002 Verify : RM-1011_CUSTPACK_ROM_IC_MEA_SY_eMP_20.10.11_002 Verify : RM-1011_JUMP_TABLE_IC_MEA_SY_eMP_20.10.11_002 Verify : RM-1011_VIVA_eMP_20.10.11 Done! Elapsed: 00:03:27 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to skgrxl For This Useful Post: |
09-21-2018, 07:18 | #612 (permalink) |
Product Manager Join Date: Mar 2014 Location: Bangladesh Age: 30
Member: 2142580 Status: Offline Thanks Meter: 1,214 | Nokia RM-1134 Bangle Flash Done BEST NK2 v1.05 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.05 Open VPLfile : RM1134_059X091_13.00.11.vpl Description : RM-1134 NDT MEA MS BENGALI BD DeviceType : RM-1134 ProductCode : 059X091 SoftwareVer : 13.00.11 Load Ok! Operation : Write FirmWare [ v1.05 ] Setting : UserData erase : True 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM47) MODE : NOKIA USB SERIAL PORT : 47 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 2D1A859EBF5DB601C94A6D47F36ECCFF BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : LAGOS61D.10.01.11.p2 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : LAGOS61D.10.01.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! Load FlashSet : MROM : RM-1134_ROM_eMP_13.00.11 LANG : RM-1134_LANG_PACK_ROM_MS_eMP_13.00.11_002 CUST : RM-1134_CUSTPACK_ROM_MS_MEA_BD_eMP_13.00.11_002 JUMP : RM-1134_JUMP_TABLE_MS_MEA_BD_eMP_13.00.11_002 VIVA : RM-1134_VIVA_eMP_13.00.11 Prepare FlashSet : DCR : RM-1134_ROM_eMP_13.00.11 DCR : RM-1134_LANG_PACK_ROM_MS_eMP_13.00.11_002 DCR : RM-1134_CUSTPACK_ROM_MS_MEA_BD_eMP_13.00.11_002 DCR : RM-1134_JUMP_TABLE_MS_MEA_BD_eMP_13.00.11_002 DCR : RM-1134_VIVA_eMP_13.00.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : RM-1134_ROM_eMP_13.00.11 Write : RM-1134_LANG_PACK_ROM_MS_eMP_13.00.11_002 Write : RM-1134_CUSTPACK_ROM_MS_MEA_BD_eMP_13.00.11_002 Write : RM-1134_JUMP_TABLE_MS_MEA_BD_eMP_13.00.11_002 Write : RM-1134_VIVA_eMP_13.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : RM-1134_ROM_eMP_13.00.11 Verify : RM-1134_LANG_PACK_ROM_MS_eMP_13.00.11_002 Verify : RM-1134_CUSTPACK_ROM_MS_MEA_BD_eMP_13.00.11_002 Verify : RM-1134_JUMP_TABLE_MS_MEA_BD_eMP_13.00.11_002 Verify : RM-1134_VIVA_eMP_13.00.11 Done! Elapsed: 00:01:20 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to >>Gsmmilon>> For This Useful Post: |
09-22-2018, 14:33 | #613 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 2700 classic Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm561__09.98.mcusw PPM : rm561__09.98.ppm_t CNT : rm561__09.98.image_ctv_nz_gray Flashing phone now... [Gen] Rules accepted for : RAP3x Generation Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 0B300214CB146850CE12BC4F5B7BAEB77C373BE3 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ===Flashing [MCU]=== Erase : Processing rm561__09.98.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:31 Write : Processing rm561__09.98.mcusw Total 1256 [1256/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:01 MCU Write done ===Flashing [PPM]=== Erase : Processing rm561__09.98.ppm_t Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:04 Write : Processing rm561__09.98.ppm_t Total 353 [353/0/0] blocks to write, writing... TIME : Write time : 00:00:17 PPM Write done ===Flashing [CNT]=== Erase : Processing rm561__09.98.image_ctv_nz_gray Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:06:14 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm561__09.98.image_ctv_nz_gray Total 528 [528/0/0] blocks to write, writing... TIME : Write time : 00:00:25 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:11:34 Reboot phone now... |
The Following User Says Thank You to Luckey1 For This Useful Post: |
09-24-2018, 10:53 | #614 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 3310 (2G) write factory firmware /Blink Done :) Code: Infinity-Box BEST Nokia [HMD] Module [NK2] v1.05 Operation : Identify [ v1.05 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM25) MODE : NOKIA USB SERIAL PORT : 25 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 24CAA26A00AA06D6D418DC54ABD2B038 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.11.02.11.p1 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : RETRO.11.02.11.p1 FLASH : 00EF : 0060 : 0018 : 0000 BBSN : 24CAA26A00AA06D6D418DC54ABD2B038 PRDC : 059X9S3 IMEI[1] : 354494091753597 IMEI[2] : 354494096753592 Done! Elapsed: 00:01:00 Reconnect Power/Cable! Operation : Reset Settings [ v1.05 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM25) MODE : NOKIA USB SERIAL PORT : 25 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 24CAA26A00AA06D6D418DC54ABD2B038 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.11.02.11.p1 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : RETRO.11.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00CD0000 : 0x00324000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:43 Reconnect Power/Cable! Open VPLfile : TA1030_059X9S2_11.02.11.vpl Description : TA-1030 NDT MEA IC GREY ARABIC SA DeviceType : TA-1030 ProductCode : 059X9S2 SoftwareVer : 11.02.11 Load Ok! Operation : Write FirmWare [ v1.05 ] Setting : UserData erase : True 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM25) MODE : NOKIA USB SERIAL PORT : 25 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 24CAA26A00AA06D6D418DC54ABD2B038 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.11.02.11.p1 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : RETRO.11.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! Load FlashSet : MROM : TA-1030_ROM_eMP_11.02.11 LANG : TA-1030_LANG_PACK_ROM_IC_eMP_11.02.11_001 CUST : TA-1030_CUSTPACK_ROM_IC_MEA_SA_eMP_11.02.11_001 JUMP : TA-1030_JUMP_TABLE_IC_MEA_SA_eMP_11.02.11_001 VIVA : TA-1030_VIVA_eMP_11.02.11 Prepare FlashSet : DCR : TA-1030_ROM_eMP_11.02.11 DCR : TA-1030_LANG_PACK_ROM_IC_eMP_11.02.11_001 DCR : TA-1030_CUSTPACK_ROM_IC_MEA_SA_eMP_11.02.11_001 DCR : TA-1030_JUMP_TABLE_IC_MEA_SA_eMP_11.02.11_001 DCR : TA-1030_VIVA_eMP_11.02.11 Prepare Target SDS : OK : 0x00FF4000 : 0x0000C000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : TA-1030_ROM_eMP_11.02.11 Write : TA-1030_LANG_PACK_ROM_IC_eMP_11.02.11_001 Write : TA-1030_CUSTPACK_ROM_IC_MEA_SA_eMP_11.02.11_001 Write : TA-1030_JUMP_TABLE_IC_MEA_SA_eMP_11.02.11_001 Write : TA-1030_VIVA_eMP_11.02.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1030_ROM_eMP_11.02.11 Verify : TA-1030_LANG_PACK_ROM_IC_eMP_11.02.11_001 Verify : TA-1030_CUSTPACK_ROM_IC_MEA_SA_eMP_11.02.11_001 Verify : TA-1030_JUMP_TABLE_IC_MEA_SA_eMP_11.02.11_001 Verify : TA-1030_VIVA_eMP_11.02.11 Done! Elapsed: 00:02:40 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to syed tuqeer For This Useful Post: |
09-26-2018, 09:24 | #615 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 130 format done --- Insert USB cable now! --- Wait for phone... Phone found! [ 430 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : F20F941887B1F90DB45A26B1D5A75297 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:40 |
The Following 2 Users Say Thank You to Luckey1 For This Useful Post: |
