11-25-2018, 12:08 | #676 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 130 Write Firmware with BEST 2 (1.09) Code: Open VPLfile : RM1035_059W2D6_10.01.11.vpl Description : RM-1035 NDT MEA IJ RED FARSI AF DeviceType : RM-1035 ProductCode : 059W2D6 SoftwareVer : 10.01.11 PPM LangPack : [1] : Urdu (Islamic Republic of Pakistan) [2] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.09 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM37) MODE : NOKIA USB SERIAL PORT : 37 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : D473B4C033B4339C8E6F573E594293CB BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : CRYSTAL.10.01.11.p2 BOOT : SWR : 10.01.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : CRYSTAL.10.01.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0040 : 0016 : 0000 NOR: [WINBOND] W25Q32BV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 10.01.11 [RM-1035] DEV SoftwareVersion : 10.01.11 SWInfo compare result : SAME Load FlashSet : MROM : RM-1035_ROM_eMP_10.01.11 LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_AF_eMP_10.01.11_001 JUMP : RM-1035_JUMP_TABLE_IJ_MEA_AF_eMP_10.01.11_001 VIVA : RM-1035_VIVA_eMP_10.01.11 Prepare FlashSet : DCR : RM-1035_ROM_eMP_10.01.11 DCR : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 DCR : RM-1035_CUSTPACK_ROM_IJ_MEA_AF_eMP_10.01.11_001 DCR : RM-1035_JUMP_TABLE_IJ_MEA_AF_eMP_10.01.11_001 DCR : RM-1035_VIVA_eMP_10.01.11 Prepare Target SDS : OK : 0x003F4000 : 0x0000C000 FFS Format Ok! CBR : 0x0000001A:0x00000001:0x00000000:0x00000000:0x00000010:0x00000002:0x00000000 Erase Target Flash Erase done! Write Target Flash Write : RM-1035_ROM_eMP_10.01.11 Write : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 Write : RM-1035_CUSTPACK_ROM_IJ_MEA_AF_eMP_10.01.11_001 Write : RM-1035_JUMP_TABLE_IJ_MEA_AF_eMP_10.01.11_001 Write : RM-1035_VIVA_eMP_10.01.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : RM-1035_ROM_eMP_10.01.11 Verify : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 Verify : RM-1035_CUSTPACK_ROM_IJ_MEA_AF_eMP_10.01.11_001 Verify : RM-1035_JUMP_TABLE_IJ_MEA_AF_eMP_10.01.11_001 Verify : RM-1035_VIVA_eMP_10.01.11 Done! Elapsed: 00:01:21 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to syed tuqeer For This Useful Post: |
11-25-2018, 14:45 | #677 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 130 hang on logo done by best Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1035_ROM_eMP_10.01.11 VIVA : RM-1035_VIVA_eMP_10.01.11 LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 JMPT : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : D7152BEBABDD586E67FE056C1E74A419 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_10.01.11 SecureDecrypt : RM-1035_VIVA_eMP_10.01.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_10.01.11 Write : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 Write : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 Write : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 Write : RM-1035_VIVA_eMP_10.01.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_10.01.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 [VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 [VERIFY] DONE : RM-1035_VIVA_eMP_10.01.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:08 Reboot phone Ok |
The Following 2 Users Say Thank You to A.G.Shahid For This Useful Post: |
11-25-2018, 14:47 | #678 (permalink) |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | Ta-1017 flash done Code: Operation : Write FirmWare [ v1.09 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM23) MODE : NOKIA USB SERIAL PORT : 23 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : D2F65234A49B40D31C9435CFED607A90 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : KESA61A.11.02.11.p1 BOOT : SWR : 11.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : KESA61A.11.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0060 : 0017 : 0000 NOR: [WINBOND] W25Q64DW NOR: TSIZE : 0x00800000 [ 8,00 MB ] PSIZE : 0x00800000 [ 8,00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 11.02.11 [TA-1017] DEV SoftwareVersion : 11.02.11 SWInfo compare result : SAME Load FlashSet : MROM : TA-1017_ROM_eMP_11.02.11 LANG : TA-1017_LANG_PACK_ROM_IC_eMP_11.02.11_001 CUST : TA-1017_CUSTPACK_ROM_IC_MEA_MA_eMP_11.02.11_001 JUMP : TA-1017_JUMP_TABLE_IC_MEA_MA_eMP_11.02.11_001 VIVA : TA-1017_VIVA_eMP_11.02.11 Prepare FlashSet : DCR : TA-1017_ROM_eMP_11.02.11 DCR : TA-1017_LANG_PACK_ROM_IC_eMP_11.02.11_001 DCR : TA-1017_CUSTPACK_ROM_IC_MEA_MA_eMP_11.02.11_001 DCR : TA-1017_JUMP_TABLE_IC_MEA_MA_eMP_11.02.11_001 DCR : TA-1017_VIVA_eMP_11.02.11 Prepare Target SDS : OK : 0x007F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : TA-1017_ROM_eMP_11.02.11 Write : TA-1017_LANG_PACK_ROM_IC_eMP_11.02.11_001 Write : TA-1017_CUSTPACK_ROM_IC_MEA_MA_eMP_11.02.11_001 Write : TA-1017_JUMP_TABLE_IC_MEA_MA_eMP_11.02.11_001 Write : TA-1017_VIVA_eMP_11.02.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1017_ROM_eMP_11.02.11 Verify : TA-1017_LANG_PACK_ROM_IC_eMP_11.02.11_001 Verify : TA-1017_CUSTPACK_ROM_IC_MEA_MA_eMP_11.02.11_001 Verify : TA-1017_JUMP_TABLE_IC_MEA_MA_eMP_11.02.11_001 Verify : TA-1017_VIVA_eMP_11.02.11 Done! Elapsed: 00:01:34 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to rai14 For This Useful Post: |
11-26-2018, 15:31 | #679 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | NOkia 206 Read User Code Done :) Code: Backup Certificates now... Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF EBL Loader : Custom Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL : Custom EBL sent Ok EBL : Quantum_Bootloader_10.56_M1S1 Boot done! Read CRT block... Read EEPROM block... SL3 Simlock found (XGOLD) ... WMDRM Key found ... CMLA Key found ... ===== USER CODE ===== Executing Code extraction... - > Phone Lock Code : 6362532635 ===== USER CODE ===== ===== MMC PASSWORD ===== We have next Pass: 35815541 ===== MMC PASSWORD ===== NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : F:\1+Flashing Software\1+Infinity Box\BEST\Backup\Cert\358326051031349_XG213.rpl Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
11-28-2018, 09:35 | #680 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 105 (2017) Format / Reset Factory Done :) Code: Operation : Reset Settings [ v1.09 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM37) MODE : NOKIA USB SERIAL PORT : 37 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : FBC03B88CBE9E886EB9C9C9F219639E1 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.10.02.11.p1 BOOT : SWR : 10.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.10.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00370000 : 0x00088000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
12-03-2018, 11:11 | #681 (permalink) |
No Life Poster Join Date: Sep 2013 Location: KERALA, INDIA
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | Nokia 535 RM-1089 unlock via server done Code: WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Need SDAuth to finish ... Started Connecting to SX4 server... Connected SX4 enter .. SDAuth Ok! SX4 Disconnected Unlock Done! |
The Following 2 Users Say Thank You to technomak For This Useful Post: |
12-06-2018, 10:45 | #682 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,420 | Nokia X2-02 Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm694__11.84.mcusw PPM : rm694__11.84.ppm_m_a CNT : rm694__11.84.image_m_a_059D1B3 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> Check SW version... FlashFile version : 11.84 Phone version : 10.89 22-11-11 RM-694 (c) Nokia -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... Batery voltage : 3637 mV -> Batery voltage less, than 3,7V (3637mV). Continue at user risk SL3 Simlock read (XGOLD) ... Ok WMDRM Key read ... Ok Reboot.... -> If Phone start charge - just reinsert battery fast Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 357879045241821 IMEI 2 : 357879045241839 PCcode : 059D1B3 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\357879045241821_XG213.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm694__11.84.mcusw Image : rm694__11.84.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:06 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01980000 Erasing, wait ... Erase done, time : 00:02:38 Write , Start : 0x40280000 , Len : 0x01900000 Flashing , wait ... Region flash done, time : 00:00:35 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xB615 ===Flashing [PPM]=== File : rm694__11.84.ppm_m_a Image : package_m_a.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41C00000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:28 Write , Start : 0x41C00000 , Len : 0x00440340 Flashing , wait ... Region flash done, time : 00:00:06 CRC check passed , 0x40FC ===Flashing [CNT]=== File : rm694__11.84.image_m_a_059D1B3 Image : package_m_a_059D1B3.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42300000 , Len : 0x01B20000 Erasing, wait ... Erase done, time : 00:04:55 Write , Start : 0x42300000 , Len : 0x00DC0000 Flashing , wait ... Region flash done, time : 00:00:23 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:09 No write data, skip CRC check passed , 0x1F63 Flashing done! Total flash time : 00:09:27 |
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
12-08-2018, 13:53 | #683 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,420 | Nokia 215 Format Done --- Insert USB cable now! --- Wait for phone... Phone found! [ 557 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 8C015A020DEFF52C285D9EE56F7E418D BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : JET.12.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Jet.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000 Executing FFS FORMAT now... FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:46 |
12-09-2018, 11:45 | #684 (permalink) |
Product Supporter Join Date: May 2010 Location: alwar, rajasthan (india)
Member: 1306196 Status: Offline Sonork: 100.1654602 Thanks Meter: 1,578 | nokia nxp rm 1013 hang logo easy solve ore : v2.29 , NXP FlashEngine : v6.0 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : rm1013_2.1.0.12_059V781_001_rawprogram_unsparse_ui .xml Ok, Set : rm1013_2.1.0.12_user_prog_emmc_firehose_8x10.mbn Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Handshake Ok Init[0] : 0x01000000 Init[1] : 0x30000000 Sending Loader ... Init Loader ... FireHose Initialized Device Init Ok Target VER : 1 Target CPU : 8x10 Target FLN : eMMC Target CNF : 1000/C000/1000 Target DBG : logbuf@0xF8021118 fh@0xF801DF80 Files in Chain : 67 Flashing now Flashing : rm1013_2.1.0.12_user_NON-HLOS.bin ProgInit : start 16384, num 75203 ProgDone : Finished sector address 91587 Flash Ok Flashing : rm1013_2.1.0.12_user_sbl1.mbn ProgInit : start 147456, num 492 ProgDone : Finished sector address 147948 Flash Ok Flashing : rm1013_2.1.0.12_user_sbl1.mbn ProgInit : start 148480, num 492 ProgDone : Finished sector address 148972 Flash Ok Flashing : rm1013_2.1.0.12_user_sdi.mbn ProgInit : start 149504, num 45 ProgDone : Finished sector address 149549 Flash Ok Flashing : rm1013_2.1.0.12_user_emmc_appsboot.mbn ProgInit : start 180224, num 938 ProgDone : Finished sector address 181162 Flash Ok Flashing : rm1013_2.1.0.12_user_emmc_appsboot.mbn ProgInit : start 181248, num 938 ProgDone : Finished sector address 182186 Flash Ok Flashing : rm1013_2.1.0.12_user_rpm.mbn ProgInit : start 182272, num 296 ProgDone : Finished sector address 182568 Flash Ok Flashing : rm1013_2.1.0.12_user_rpm.mbn ProgInit : start 183272, num 296 ProgDone : Finished sector address 183568 Flash Ok Flashing : rm1013_2.1.0.12_user_boot.img ProgInit : start 196608, num 14549 ProgDone : Finished sector address 211157 Flash Ok Flashing : rm1013_2.1.0.12_user_tz.mbn ProgInit : start 229376, num 663 ProgDone : Finished sector address 230039 Flash Ok Flashing : rm1013_2.1.0.12_user_tz.mbn ProgInit : start 230376, num 663 ProgDone : Finished sector address 231039 Flash Ok Flashing : rm1013_2.1.0.12_user_system_1.img ProgInit : start 344064, num 262160 ProgDone : Finished sector address 606224 Flash Ok Flashing : rm1013_2.1.0.12_user_system_2.img ProgInit : start 606600, num 16 ProgDone : Finished sector address 606616 Flash Ok Flashing : rm1013_2.1.0.12_user_system_3.img ProgInit : start 610352, num 257992 ProgDone : Finished sector address 868344 Flash Ok Flashing : rm1013_2.1.0.12_user_system_4.img ProgInit : start 868352, num 16 ProgDone : Finished sector address 868368 Flash Ok Flashing : rm1013_2.1.0.12_user_system_5.img ProgInit : start 872104, num 258384 ProgDone : Finished sector address 1130488 Flash Ok Flashing : rm1013_2.1.0.12_user_system_6.img ProgInit : start 1130496, num 16 ProgDone : Finished sector address 1130512 Flash Ok Flashing : rm1013_2.1.0.12_user_system_7.img ProgInit : start 1130888, num 16 ProgDone : Finished sector address 1130904 Flash Ok Flashing : rm1013_2.1.0.12_user_system_8.img ProgInit : start 1134640, num 95712 ProgDone : Finished sector address 1230352 Flash Ok Flashing : rm1013_2.1.0.12_user_system_9.img ProgInit : start 1392640, num 16 ProgDone : Finished sector address 1392656 Flash Ok Flashing : rm1013_2.1.0.12_user_system_10.img ProgInit : start 1654784, num 16 ProgDone : Finished sector address 1654800 Flash Ok Flashing : rm1013_2.1.0.12_user_system_11.img ProgInit : start 1655176, num 16 ProgDone : Finished sector address 1655192 Flash Ok Flashing : rm1013_2.1.0.12_user_cache_1.img ProgInit : start 1777664, num 11376 ProgDone : Finished sector address 1789040 Flash Ok Flashing : rm1013_2.1.0.12_user_recovery.img ProgInit : start 1974272, num 15529 ProgDone : Finished sector address 1989801 Flash Ok Flashing : rm1013_2.1.0.12_user_misc_erase.img ProgInit : start 1998848, num 1 ProgDone : Finished sector address 1998849 Flash Ok Flashing : rm1013_2.1.0.12_059V781_001.custom_1.img ProgInit : start 2015232, num 262136 ProgDone : Finished sector address 2277368 Flash Ok Flashing : rm1013_2.1.0.12_059V781_001.custom_2.img ProgInit : start 2277376, num 16 ProgDone : Finished sector address 2277392 Flash Ok Flashing : rm1013_2.1.0.12_059V781_001.custom_3.img ProgInit : start 2277640, num 16 ProgDone : Finished sector address 2277656 Flash Ok Flashing : rm1013_2.1.0.12_059V781_001.custom_4.img ProgInit : start 2280856, num 258656 ProgDone : Finished sector address 2539512 Flash Ok Flashing : rm1013_2.1.0.12_059V781_001.custom_5.img ProgInit : start 2539520, num 16 ProgDone : Finished sector address 2539536 Flash Ok Flashing : rm1013_2.1.0.12_059V781_001.custom_6.img ProgInit : start 2542736, num 246224 ProgDone : Finished sector address 2788960 Flash Ok Flashing : rm1013_2.1.0.12_059V781_001.custom_7.img ProgInit : start 2801664, num 16 ProgDone : Finished sector address 2801680 Flash Ok Flashing : rm1013_2.1.0.12_059V781_001.custom_8.img ProgInit : start 2801928, num 16 ProgDone : Finished sector address 2801944 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_1.img ProgInit : start 2834432, num 80272 ProgDone : Finished sector address 2914704 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_2.img ProgInit : start 3096576, num 16 ProgDone : Finished sector address 3096592 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_3.img ProgInit : start 3097800, num 16 ProgDone : Finished sector address 3097816 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_4.img ProgInit : start 3358720, num 16 ProgDone : Finished sector address 3358736 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_5.img ProgInit : start 3620864, num 16 ProgDone : Finished sector address 3620880 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_6.img ProgInit : start 3622088, num 16 ProgDone : Finished sector address 3622104 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_7.img ProgInit : start 3883008, num 16 ProgDone : Finished sector address 3883024 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_8.img ProgInit : start 4145152, num 16 ProgDone : Finished sector address 4145168 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_9.img ProgInit : start 4146376, num 16 ProgDone : Finished sector address 4146392 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_10.img ProgInit : start 4407296, num 16 ProgDone : Finished sector address 4407312 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_11.img ProgInit : start 4669440, num 16 ProgDone : Finished sector address 4669456 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_12.img ProgInit : start 4670664, num 16 ProgDone : Finished sector address 4670680 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_13.img ProgInit : start 4931584, num 16 ProgDone : Finished sector address 4931600 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_14.img ProgInit : start 5193728, num 16 ProgDone : Finished sector address 5193744 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_15.img ProgInit : start 5194952, num 16 ProgDone : Finished sector address 5194968 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_16.img ProgInit : start 5455872, num 16 ProgDone : Finished sector address 5455888 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_17.img ProgInit : start 5718016, num 16 ProgDone : Finished sector address 5718032 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_18.img ProgInit : start 5980160, num 16 ProgDone : Finished sector address 5980176 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_19.img ProgInit : start 6242304, num 16 ProgDone : Finished sector address 6242320 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_20.img ProgInit : start 6504448, num 16 ProgDone : Finished sector address 6504464 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_21.img ProgInit : start 6766592, num 16 ProgDone : Finished sector address 6766608 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_22.img ProgInit : start 7028736, num 16 ProgDone : Finished sector address 7028752 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_23.img ProgInit : start 7290880, num 16 ProgDone : Finished sector address 7290896 Flash Ok Flashing : rm1013_2.1.0.12_user_userdata_24.img ProgInit : start 7553024, num 16 ProgDone : Finished sector address 7553040 Flash Ok Chain finished, All files flashed! Rebooting phone now Flashing done! Total flash time : 00:02:59 Connect phone on selected interface... Last edited by vishnudatt; 12-09-2018 at 11:47. Reason: some code left |
The Following 3 Users Say Thank You to vishnudatt For This Useful Post: |
12-11-2018, 12:31 | #685 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 108 blinking problem done by best Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-944_ROM_eMP_20.06.11 VIVA : RM-944_VIVA_eMP_20.06.11 LANG : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 CUST : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 JMPT : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 10 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 8E7095DC0EE52208D8E9611F63E4F54F BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Bree.20.06.11.p4 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 SecureDecrypt : RM-944_ROM_eMP_20.06.11 SecureDecrypt : RM-944_VIVA_eMP_20.06.11 SecureDecrypt : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 SecureDecrypt : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 SecureDecrypt : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 OVRLP : 000069B900000001 PHPID : Bree.20.06.11.p4 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-944_ROM_eMP_20.06.11 Write : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 Write : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 Write : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 Write : RM-944_VIVA_eMP_20.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-944_ROM_eMP_20.06.11 [VERIFY] DONE : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 [VERIFY] DONE : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 [VERIFY] DONE : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 [VERIFY] DONE : RM-944_VIVA_eMP_20.06.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:09 Reboot phone Ok |
12-13-2018, 16:39 | #686 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | NOKIA 3310 TA-1030 MT6260 BRUSH USER LOCK Done SUCCESSFULLY BRUSH USER LOCK(NOKIA 3310 TA-1030 MT6260)USB THANKS INFINITY-BOX TEAM |
The Following 3 Users Say Thank You to gracy_elec For This Useful Post: |
12-14-2018, 11:34 | #687 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,420 | Nokia 110 Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm827__03.51.mcusw PPM : rm827__03.51.ppm_m2 CNT : rm827__03.51.image_m2_059N2R0 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.49_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 353656057638886 IMEI 2 : 353656057638894 PCcode : 059N2R0 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\353656057638886_2nd_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm827__03.51.mcusw Image : rm827__03.51.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:06 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:02:30 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:32 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xA3D6 ===Flashing [PPM]=== File : rm827__03.51.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:18 Write , Start : 0x41BC0000 , Len : 0x0030F748 Flashing , wait ... Region flash done, time : 00:00:03 CRC check passed , 0x4605 ===Flashing [CNT]=== File : rm827__03.51.image_m2_059N2R0 Image : package_m2_059N2R0.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:02:47 Write , Start : 0x421C0000 , Len : 0x00F20000 Flashing , wait ... Region flash done, time : 00:00:22 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:08 No write data, skip CRC check passed , 0x2091 Flashing done! Total flash time : 00:06:54 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 110 Software Info: V 03.51 06-08-13 RM-827 (c) Nokia IMEI: 353656057638886 PPM version : V 03.51 06-08-13 RM-827 (c) Nokia M2 Product code: 059N2R0 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:07:43 |
12-14-2018, 12:33 | #688 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,420 | Nokia 105 TA-1034 Reset user Code done --- Insert USB cable now! --- Wait for phone... Phone found! [ 587 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : D126F61943C447E45BECF441DAEAAE01 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
12-14-2018, 14:47 | #689 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,420 | Nokia 108 Format Done --- Insert USB cable now! --- Wait for phone... Phone found! [ 587 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : F002F1EA3B92B524CD36D3CBA872047D BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Bree.20.06.11.p4 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:24 Connect phone on selected interface... |
12-15-2018, 08:12 | #690 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,420 | Nokia 216 Format Done Phone found! MTKx Nokia Phone detected Read info... Ok Software Info: 30.01.11 00-00-00 RM-1187 IMEI: 357343086115311 PPM version : IJ Product code: 059X817 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 589 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : E2D10078277A2CD194E7FF3D5B730769 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : SUEZ.30.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Suez.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00CE0000-0x00FF3FFF , LEN : 0x00314000 Executing FFS FORMAT now... FAT_RANGE : 0x00CE0000-0x00FF3FFF , LEN : 0x00314000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:55 Connect phone on selected interface... |
