01-22-2019, 17:13 | #721 (permalink) |
Freak Poster Join Date: Oct 2010 Location: Europe
Member: 1429766 Status: Offline Thanks Meter: 85 | Nokia TA-1057 FRP Successfully Removed BEST2 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.09 Operation : Reset Settings [ v1.09 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM30) MODE : BOOTROM PORT : 30 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6755 AGENT : Nokia_All_InOne_DA_v02.2018.1809 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: 150100514536334D42037B8672355BF EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3A3E00000 [ 14,56 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 49B7CE31FB05053111676AAFF1CC0795 DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM215) MODE : PRELOADER PORT PORT : 215 Boot done! Format Ok : USERDATA Format Ok : RESET PROTECTION Format Ok : PRIVACY Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to xukca For This Useful Post: |
01-24-2019, 13:15 | #722 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 503 Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm922_14.0.6.mcusw.fls PPM : rm922_14.0.1_059S8P4_m1_2022_01_452465.rofs.fls CNT : rm922_14.0.1_059S8P4_m1_2022_01_452465.image.fls Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x16 IF xCPUID : XGOLD 618 [XMM6180 QUARK] IF uCHIPID : 50A9070100030101E030101210108A8158846934FFFF IF Resp Data : 50A9070100030101 Wait for user action : Insert battery Sending EBL Loader ... EBL Loader Ok EBL Loader ready Sending EBL ... EBL sent Ok EBL : QUARK_1404.300_M1S1 QUARK EEP config Ok FLASHID : 20004000 , [ MuxOneNAND ] Boot conf set, Target Ready Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 351746064434296 IMEI 2 : 351746064434304 Phone Product Code : 059V531 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\351746064434296_XG 618_CRT.rpl ===Flashing [MCU]=== Processing file : rm922_14.0.6.mcusw.fls Region count : 7 00 : [ PSI ] : psi_flash_unsigned.fls 01 : [ BCore ] : slb_signed.fls 02 : [ Code ] : main_toc_signed.fls 03 : [ Code ] : rm922_14.0.6.mcusw.fls_signed_mcusw.fls 04 : [ Code ] : swap_signed.fls 05 : [ Code ] : aeneas_signed.fls 06 : [ Code ] : fota_signed.fls Parse done , flashing now Flash : 00 : psi_flash_unsigned.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x00090000 , Len : 0x00020000 Erase now... Erase done Region Start : 0x00090000 , Data Len : 0x00010FB0 Region Load done Write done psi_flash_unsigned.fls image flash done Flash : 01 : slb_signed.fls Sending Sec-Pack SecInfo Area : 0x0001 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x60000000 , Len : 0x00040000 Erase now... Erase done Region Start : 0x60000000 , Data Len : 0x00040000 Region Load done Write done slb_signed.fls image flash done Flash : 02 : main_toc_signed.fls Sending Sec-Pack SecInfo Area : 0x0002 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x60040000 , Len : 0x00000400 Erase now... Erase done Region Start : 0x60040000 , Data Len : 0x00000400 Region Load done Write done main_toc_signed.fls image flash done Flash : 03 : rm922_14.0.6.mcusw.fls_signed_mcusw.fls Sending Sec-Pack SecInfo Area : 0x0003 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x64800000 , Len : 0x02600000 Erase now... Erase done Erase area 0x01 , Start 0xFFF00000 , Len : 0x00080000 Erase now... Erase done Region Start : 0x64800000 , Data Len : 0x023218B4 Region Load done Write done rm922_14.0.6.mcusw.fls_signed_mcusw.fls image flash done Flash : 04 : swap_signed.fls Sending Sec-Pack SecInfo Area : 0x0004 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x80000000 , Len : 0x01100000 Erase now... Erase done Region Start : 0x80000000 , Data Len : 0x000053DC Region Load done Write done swap_signed.fls image flash done Flash : 05 : aeneas_signed.fls Sending Sec-Pack SecInfo Area : 0x0005 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x67F79C00 , Len : 0x00080000 Erase now... Erase done Region Start : 0x67F79C00 , Data Len : 0x00046870 Region Load done Write done aeneas_signed.fls image flash done Flash : 06 : fota_signed.fls Sending Sec-Pack SecInfo Area : 0x0006 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x61F00004 , Len : 0x0017FFFC Erase now... Erase done Region Start : 0x61F00004 , Data Len : 0x00164348 Region Load done Write done fota_signed.fls image flash done ===Flashing [PPM]=== Processing file : rm922_14.0.1_059S8P4_m1_2022_01_452465.rofs.fls Region count : 1 00 : [ Cust ] : rofs_ebl_psi.fls Parse done , flashing now Flash : 00 : rofs_ebl_psi.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x66E00000 , Len : 0x01100000 Erase now... Erase done Region Start : 0x66E00000 , Data Len : 0x005EF04C Region Load done Write done rofs_ebl_psi.fls image flash done ===Flashing [CNT]=== Processing file : rm922_14.0.1_059S8P4_m1_2022_01_452465.image.fls Region count : 1 00 : [ Cust ] : rm922_14.0.1_059S8P4_m1_2022_01_452465.image.fls.i mage.fls Parse done , flashing now Flash : 00 : rm922_14.0.1_059S8P4_m1_2022_01_452465.image.fls.i mage.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0xA1000000 , Len : 0x0C680000 Erase now... Erase done Erase area 0x01 , Start 0xAE000000 , Len : 0x00300000 Erase now... Erase done Region Start : 0xA1000000 , Data Len : 0x031C4000 Region Load done Write done rm922_14.0.1_059S8P4_m1_2022_01_452465.image.fls.i mage.fls image flash done Flashing done! Total flash time : 00:00:19 Reboot phone now... |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
01-27-2019, 10:52 | #723 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Asha 301 Data Recovered Done :) Code: Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x16 IF xCPUID : XGOLD 618 [XMM6180 QUARK] IF uCHIPID : 50A9070100030101E0002409301CE1B1486EC636FFFF IF Resp Data : 50A9070100030101 Wait for user action : Insert battery Sending EBL Loader ... EBL Loader Ok EBL Loader ready Sending EBL ... EBL sent Ok EBL : QUARK_1337.500_M1S1 QUARK EEP config Ok FLASHID : EC004000 , [ MuxOneNAND ] Boot conf set, Target Ready Boot done! Reading CCC Reading HWC Reading NPC IMEI 1 : 357885050598583 IMEI 2 : 357885050598591 Phone Product Code : 059R214 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : F:\1+Flashing Software\1+Infinity Box\BEST\Backup\Cert\357885050598583_2nd_XG618_CRT.rpl Reading UserArea dump, please, wait ... Block count : 12640 Done, read time : 01:26:26 Connect phone on selected interface... Processing S40 [XG618/BB5] mode Scan image... Disc found, Size: 190M Search... Miriel detect phonebook type now ... Data proceed ok... CSV file saved to F:\1+Flashing Software\1+Infinity Box\BEST\Phones_Data\Readout\357885050598583_XG618.csv 5 records are found :) S40 PhoneBook saved to : 357885050598583_XG618.s4pb Done!!! Processing S40 [XG618/BB5] mode Scan image... Disc found, Size: 190M Calendar found! Saved as text Notes clear 191 files from Phone Gallery saved - Ok 688 sms files saved - Ok Search... Miriel detect phonebook type now ... Data proceed ok... CSV file saved to C:\Users\Syed Mobile\Desktop\301\357885050598583_XG618.csv 5 records are found :) S40 PhoneBook saved to : 357885050598583_XG618.s4pb Done!!! but data recover Done Thanks Team ..... |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
01-27-2019, 11:20 | #724 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Asha 301 Write Firmware Done :) Code: Connect phone on selected interface... Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm839__09.04.mcusw PPM : rm839__09.04.ppm_m2 CNT : rm839__09.04.image_m2_059T9L6 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x16 IF xCPUID : XGOLD 618 [XMM6180 QUARK] IF uCHIPID : 50A9070100030101E0002409301CE1B1486EC636FFFF IF Resp Data : 50A9070100030101 Wait for user action : Insert battery Sending EBL Loader ... EBL Loader Ok EBL Loader ready Sending EBL ... EBL sent Ok EBL : QUARK_1337.500_M1S1 QUARK EEP config Ok FLASHID : EC004000 , [ MuxOneNAND ] Boot conf set, Target Ready Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 357885050598583 IMEI 2 : 357885050598591 Phone Product Code : 059R214 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : F:\1+Flashing Software\1+Infinity Box\BEST\Backup\Cert\357885050598583_2nd_XG618_CRT.rpl ===Flashing [MCU]=== Processing file : rm839__09.04.mcusw Region count : 8 00 : [ PSI ] : psi_flash_unsigned.fls 01 : [ BCore ] : slb_signed.fls 02 : [ Code ] : main_toc_signed.fls 03 : [ Code ] : rm839__09.04.mcusw_signed_mcusw.fls 04 : [ Code ] : swap_signed.fls 05 : [ Cust ] : dynsw.fls 06 : [ Code ] : aeneas_signed.fls 07 : [ Code ] : fota_signed.fls Parse done , flashing now Flash : 00 : psi_flash_unsigned.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x00090000 , Len : 0x00020000 Erase now... Erase done Region Start : 0x00090000 , Data Len : 0x00010FB0 Region Load done Write done psi_flash_unsigned.fls image flash done Flash : 01 : slb_signed.fls Sending Sec-Pack SecInfo Area : 0x0001 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x60000000 , Len : 0x00040000 Erase now... Erase done Region Start : 0x60000000 , Data Len : 0x00040000 Region Load done Write done slb_signed.fls image flash done Flash : 02 : main_toc_signed.fls Sending Sec-Pack SecInfo Area : 0x0002 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x60040000 , Len : 0x00000400 Erase now... Erase done Region Start : 0x60040000 , Data Len : 0x00000400 Region Load done Write done main_toc_signed.fls image flash done Flash : 03 : rm839__09.04.mcusw_signed_mcusw.fls Sending Sec-Pack SecInfo Area : 0x0003 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x62E00000 , Len : 0x01100000 Erase now... Erase done Erase area 0x01 , Start 0xFFF00000 , Len : 0x00080000 Erase now... Erase done Region Start : 0x62E00000 , Data Len : 0x00F0D4CC Region Load done Write done rm839__09.04.mcusw_signed_mcusw.fls image flash done Flash : 04 : swap_signed.fls Sending Sec-Pack SecInfo Area : 0x0004 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x80000000 , Len : 0x00F00000 Erase now... Erase done Region Start : 0x80000000 , Data Len : 0x00C2BCD0 Region Load done Write done swap_signed.fls image flash done Flash : 05 : dynsw.fls Sending Sec-Pack SecInfo Area : 0x0005 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x62080000 , Len : 0x00100000 Erase now... Erase done Region Start : 0x62080000 , Data Len : 0x00044000 Region Load done Write done dynsw.fls image flash done Flash : 06 : aeneas_signed.fls Sending Sec-Pack SecInfo Area : 0x0006 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x63F79C00 , Len : 0x00080000 Erase now... Erase done Region Start : 0x63F79C00 , Data Len : 0x00046870 Region Load done Write done aeneas_signed.fls image flash done Flash : 07 : fota_signed.fls Sending Sec-Pack SecInfo Area : 0x0007 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x61F00004 , Len : 0x0017FFFC Erase now... Erase done Region Start : 0x61F00004 , Data Len : 0x00149890 Region Load done Write done fota_signed.fls image flash done ===Flashing [PPM]=== Processing file : rm839__09.04.ppm_m2 Region count : 1 00 : [ Cust ] : package_m2.ppm_ebl_psi.fls Parse done , flashing now Flash : 00 : package_m2.ppm_ebl_psi.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x80F00000 , Len : 0x00B00000 Erase now... Erase done Region Start : 0x80F00000 , Data Len : 0x0052A288 Region Load done Write done package_m2.ppm_ebl_psi.fls image flash done ===Flashing [CNT]=== Processing file : rm839__09.04.image_m2_059T9L6 Region count : 1 00 : [ Cust ] : package_m2_059T9L6.image.fls Parse done , flashing now Flash : 00 : package_m2_059T9L6.image.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0xA1000000 , Len : 0x0C580000 Erase now... Erase done Erase area 0x01 , Start 0xAE000000 , Len : 0x00300000 Erase now... Erase done Region Start : 0xA1000000 , Data Len : 0x01C35200 Region Load done Write done package_m2_059T9L6.image.fls image flash done Flashing done! Total flash time : 00:00:14 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 301 Dual SIM Software Info: V 09.04 03-12-13 RM-839 (c) Nokia IMEI: 357885050598583 PPM version : V 09.04 03-12-13 RM-839 (c) Nokia M2 Product code: 059Q9B5 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:00:48 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
01-27-2019, 15:38 | #725 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Nokia 3.1 TA-1070 Flashing Identify Code: Operation : Identify [ v1.09 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM12) MODE : BOOTROM PORT : 12 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6755 AGENT : Nokia_All_InOne_DA_v02.2018.1809 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100475836424D42030104D2E4155F EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GX6BMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 6AD432BBC647F16659E4E75F9CC49BCA DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM63) MODE : PRELOADER PORT PORT : 63 Boot done! --- SysInfoSub : Patch Level : O00623 Display ID : 00WW_0_46E Ver. CodeName : REL Ver. Release : 8.0.0 Sec. Patch : 2018-07-05 Build Time : 1530585060 Product Model : ES2 Product Brand : alps Product Name : ES2_00WW_FIH Product Device : ES2_sprout Product Manfct : alps Product Info : ES2 Board Platform : mt6750 --- SecuritySub : IMEI[0] : 3533820905----- IMEI[1] : 3533820910----- NVRAM check : Passed! Done! Elapsed: 00:00:28 Reconnect Power/Cable! Write FW Code: Load : F:\ES2-042E-0-00WW-B02.nb0 Load Ok! Operation : Write FW [ v1.09 ] Setting : UserData preserve : False Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM12) MODE : BOOTROM PORT : 12 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6755 AGENT : Nokia_All_InOne_DA_v02.2018.1809 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100475836424D42030104D2E4155F EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GX6BMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 6AD432BBC647F16659E4E75F9CC49BCA DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM63) MODE : PRELOADER PORT PORT : 63 Boot done! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : HW verification passed! Erase : 0x0000000000000000 : 0x0000000000BC8000 Erase : 0x0000000003BC8000 : 0x0000000004000000 Erase : 0x0000000009000000 : 0x0000000001000000 Erase : 0x000000000A300000 : 0x0000000000080000 Erase : 0x000000000A880000 : 0x0000000001E00000 Erase : 0x000000000C6A0000 : 0x0000000000100000 Erase : 0x000000000D4A0000 : 0x00000000C5360000 Erase : 0x00000000D3100000 : 0x0000000185700000 PMT Update : OK Flashing now ... PROCESS : PRELOADER Unpack : ES2-0-042E-00WW-1-2-preloader_ES2.bin Flash : ES2-0-042E-00WW-1-2-preloader_ES2.bin Update bootloader backup copy ... Update bootloader backup copy Ok! PROCESS : LOGO Unpack : ES2-0-042E-00WW-1-2-logo.bin Flash : ES2-0-042E-00WW-1-2-logo.bin PROCESS : SECRO Unpack : ES2-0-042E-00WW-1-2-secro.img Flash : ES2-0-042E-00WW-1-2-secro.img PROCESS : MD1IMG_A Unpack : ES2-0-042E-00WW-1-2-md1img.img Flash : ES2-0-042E-00WW-1-2-md1img.img PROCESS : MD1DSP_A Unpack : ES2-0-042E-00WW-1-2-md1dsp.img Flash : ES2-0-042E-00WW-1-2-md1dsp.img PROCESS : MD1ARM7_A Unpack : ES2-0-042E-00WW-1-2-md1arm7.img Flash : ES2-0-042E-00WW-1-2-md1arm7.img PROCESS : ODMDTBO_A Unpack : ES2-0-042E-00WW-1-2-odmdtbo.img Flash : ES2-0-042E-00WW-1-2-odmdtbo.img PROCESS : LK_A Unpack : ES2-0-042E-00WW-1-2-lk.img Flash : ES2-0-042E-00WW-1-2-lk.img PROCESS : BOOT_A Unpack : ES2-0-042E-00WW-1-2-boot.img Flash : ES2-0-042E-00WW-1-2-boot.img PROCESS : TEE_A Unpack : ES2-0-042E-00WW-1-2-tee.img Flash : ES2-0-042E-00WW-1-2-tee.img PROCESS : VENDOR_A Unpack : ES2-0-042E-00WW-1-2-vendor.img Flash : ES2-0-042E-00WW-1-2-vendor.img PROCESS : SYSTEM_A Unpack : ES2-0-042E-00WW-1-2-system.img Flash : ES2-0-042E-00WW-1-2-system.img PROCESS : SYSTEM_B Unpack : ES2-0-042E-00WW-1-2-system_other.img Flash : ES2-0-042E-00WW-1-2-system_other.img PROCESS : USERDATA Unpack : ES2-0-042E-00WW-1-2-userdata.img Flash : ES2-0-042E-00WW-1-2-userdata.img PMT Update : OK SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 Flashing finished! Done! Elapsed: 00:04:04 Reconnect Power/Cable! |
The Following User Says Thank You to VIJAY2U2 For This Useful Post: |
01-27-2019, 15:40 | #726 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Nokia 215 User Code Reset Code: Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 39 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 867E9CE511CA8191FD894541D8C3747C BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
01-29-2019, 10:12 | #727 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 216 Format Done Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 38 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 0D9184DE62FDDA0AC7D9B4ADB5392946 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : SUEZ.30.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Suez.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00CE0000-0x00FF3FFF , LEN : 0x00314000 Executing FFS FORMAT now... FAT_RANGE : 0x00CE0000-0x00FF3FFF , LEN : 0x00314000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:56 Connect phone on selected interface... |
02-03-2019, 15:01 | #728 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 111 FullFlash Done Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm810__03.51.mcusw PPM : rm810__03.51.ppm_m2 CNT : rm810__03.51.image_m2_059N2S4 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.49_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 351972056848984 PCcode : 059N2S3 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\351972056848984_XG 213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm810__03.51.mcusw Image : rm810__03.51.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:04 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:02:04 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:29 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x97D7 ===Flashing [PPM]=== File : rm810__03.51.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:19 Write , Start : 0x41BC0000 , Len : 0x00310A80 Flashing , wait ... Region flash done, time : 00:00:03 CRC check passed , 0xC4FC ===Flashing [CNT]=== File : rm810__03.51.image_m2_059N2S4 Image : package_m2_059N2S4.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:04:30 Write , Start : 0x421C0000 , Len : 0x00F20000 Flashing , wait ... Region flash done, time : 00:00:25 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:07 No write data, skip CRC check passed , 0xB0E7 Flashing done! Total flash time : 00:08:09 Reboot phone now... |
02-05-2019, 09:38 | #729 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | nOKIA 206 Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 359991053372568 IMEI 2 : 359991053372576 PCcode : 059Q4J7 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\359991053372568_XG 213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm872__04.52.mcusw Image : rm872__04.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:00:48 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:30 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xFA4D ===Flashing [PPM]=== File : rm872__04.52.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00680000 Erasing, wait ... Erase done, time : 00:00:08 Write , Start : 0x41A80000 , Len : 0x003C68F0 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xC9E6 ===Flashing [CNT]=== File : rm872__04.52.image_m2_059Q4J7 Image : package_m2_059Q4J7.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:01:06 Write , Start : 0x42100000 , Len : 0x01040000 Flashing , wait ... Region flash done, time : 00:00:19 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0x5521 Flashing done! Total flash time : 00:03:04 Reboot phone now... Reading Phone Info.... Connected phone - 206 Software Info: V 04.52 30-06-13 RM-872 (c) Nokia IMEI: 359991053372568 PPM version : V 04.52 30-06-13 RM-872 (c) Nokia M2 Product code: 059Q4J7 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:03:52 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
02-05-2019, 10:23 | #730 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | Nokia 1 TA-1060 unlock done Card found : 07XXXXXX1 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.09 Operation : Identify [ v1.09 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v02.2018.1809 Fail to disable Dog! BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 90014A483847346132A55861DA5D97B1 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483847346132A55861DA5D34B1 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 10A003451CB9EF8919BFB4FA7BCD5F1D STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! --- SysInfoSub : Patch Level : O11019 Display ID : 00WW_1_40A Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-11-01 Build Time : 1541266231 Product Model : FRT Product Brand : alps Product Name : FRT_00WW_FIH Product Manfct : alps Product Info : FRT Board Platform : mt6737m --- SecuritySub : IMEI[0] : 35341XXXXXXXXXXX NVRAM check : Passed! Done! Elapsed: 00:02:13 Reconnect Power/Cable! ------------------------------------------------------ Operation : SP Unlock [ v1.09 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v02.2018.1809 Fail to disable Dog! BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 90014A483847346132A55861DA5D97B1 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483847346132A55861DA5D34B1 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 10A003451CB9EF8919BFB4FA7BCD5F1D STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! ID0 : Lock : Locked! | MNC : 256 | CNT : 5 | CODE : 57859XXXXXXXXX ID1 : Lock : Not Locked! ID2 : Lock : Not Locked! ID3 : Lock : Not Locked! ID4 : Lock : Not Locked! ID5 : Lock : Not Locked! ID6 : Lock : Not Locked! Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to gile@gile For This Useful Post: |
02-05-2019, 13:24 | #731 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | NOKIA 311 Flashing DONE Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm714__07.37.mcusw PPM : rm714__07.37.ppm_c CNT : rm714__07.37.image_c_059F7G9_059Q385_459_01 Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- -> Phone not found.. :( -> Boot fail... Flashing failed... Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm714__07.37.mcusw PPM : rm714__07.37.ppm_c CNT : rm714__07.37.image_c_059F7G9_059Q385_459_01 Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007400C192103042108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: B8250080FFFB3C40D2EFB09DFB61B539D12C77F0 ASIC MODE ID: 00 ROOT KEY HASH: 6D956B2D26FEC3C784E216492B7CC90A ROM ID: 2CAC45E21CB478AF Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : A3E0AA6F2F86410BA6D666BACF6186EEFBC82D28 ADL: phone is in flash mode === SW Version Check === - > UPGRADE === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm714__07.37.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm714__07.37.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [ISA+EXTDRV] Total writen 287 blocks TIME : Write time : 00:00:05 MCU Write done ADL: Request programm status NAND status : 00000006 / 00000006 / 00000000 ===Flashing [PPM]=== Erase : Processing rm714__07.37.ppm_c Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm714__07.37.ppm_c Total writen 97 blocks TIME : Write time : 00:00:02 PPM Write done ADL: Request programm status NAND status : 00000006 / 00000006 / 00000000 ===Flashing [CNT]=== Erase : Processing rm714__07.37.image_c_059F7G9_059Q385_459_01 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:02 Write : Processing rm714__07.37.image_c_059F7G9_059Q385_459_01 Total writen 763 blocks TIME : Write time : 00:00:11 CNT Write done ADL: Request programm status NAND status : 00000006 / 00000006 / 00000000 ADL: Close_Session Content: 000300000000060000000600000000 ADL: Reboot Flashing done! Total flash time : 00:00:23 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 311 Software Info: V 07.37 05-06-13 RM-714 (c) Nokia IMEI: 35933004864 PPM version : V 07.37 05-06-13 RM-714 (c) Nokia C Product code: 059Q1N3 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 62 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:18 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 2 Users Say Thank You to VIJAY2U2 For This Useful Post: |
02-05-2019, 16:04 | #732 (permalink) |
Freak Poster Join Date: Mar 2017 Location: Tanzania
Member: 2697846 Status: Offline Thanks Meter: 77 | Nokia 2 FRP RESET DONE BY NOKIA BEST2 Reconnect Power/Cable! Operation : Identify [ v1.04 ] 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 0CEEC200 ID_BLOCK_I : 009600E1 ID_BLOCK_L : BCBA5F637DFBD75059F64F49CFEE33C1 ID_BLOCK_L : FEC2A5272DCE6A25471AD04BE67283AC Use BEST Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Brand : Nokia ProdName : Dynamo_00WW ProdModel : Nokia 2 Device : E1M Manufact. : HMD Global NickName : Nokia 2 Dev Build : Dynamo_00WW-user 7.1.1 NMF26F 00WW_0_55B release-keys Dev CPU : MSM8909 Dev SKU : 600WW SKU Vendor: NOKIA SKU Locale: Worldwide SKU Carier: FIH Generic FXCN_SW : E1M-055B-0-00WW-B0 USERData : PLAIN ( NON-ENCRYPTED ) FRP State : ON ( ACTIVE ) Done! Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Reset Settings [ v1.04 ] 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 0CEEC200 ID_BLOCK_I : 009600E1 ID_BLOCK_L : BCBA5F637DFBD75059F64F49CFEE33C1 ID_BLOCK_L : FEC2A5272DCE6A25471AD04BE67283AC Use BEST Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to SkyCleaner For This Useful Post: |
02-06-2019, 09:16 | #733 (permalink) |
No Life Poster Join Date: Apr 2015 Location: LOOLCANO Taba Day.
Member: 2385819 Status: Offline Sonork: No More Used Thanks Meter: 827 | New Nokia 105 Urdo Language Done. Open VPLfile : TA-1034_059Z107_30.04.11.vpl Description : TA-1034 IJ DeviceType : TA-1034 ProductCode : 059Z107 SoftwareVer : 30.04.11 PPM LangPack : [1] : Urdu (Islamic Republic of Pakistan) [2] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.09 ] Setting : UserData erase : False Setting : LangPack Only : True 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : USB Serial Device (COM3) MODE : NOKIA USB SERIAL PORT : 3 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Write FirmWare [ v1.09 ] Setting : UserData erase : False Setting : LangPack Only : True 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM61) MODE : NOKIA USB SERIAL PORT : 61 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 2ED3AF0D79E7A9E26366BBFE84EB7643 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.30.04.11.p1 BOOT : SWR : 30.04.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.30.04.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 30.04.11 [TA-1034] DEV SoftwareVersion : 30.04.11 SWInfo compare result : SAME Load FlashSet : LANG : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001 CUST : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001 JUMP : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001 Prepare FlashSet : DCR : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001 DCR : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001 DCR : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 Erase Target Flash Erase done! Write Target Flash Write : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001 Write : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001 Write : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001 Verify : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001 Verify : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001 Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
The Following User Says Thank You to ahmer5050 For This Useful Post: |
02-06-2019, 12:29 | #734 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 108 Operation : Write FirmWare [ v1.08 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM20) MODE : NOKIA USB SERIAL PORT : 20 BROM : Init BROM BROM init passed! CHIP : MT625A , SBID : 0xCA01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : F21012B55241801E7DC81B3B010DA495 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : Bree.20.06.11.p4 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT625A AGENT : Bree.20.06.11.p4 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x88 NOR: 00C2 : 0025 : 0036 : 0000 NOR: [MX] MX25U3235E NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! Load FlashSet : MROM : RM-944_ROM_eMP_20.06.11 LANG : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 CUST : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 JUMP : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 VIVA : RM-944_VIVA_eMP_20.06.11 Prepare FlashSet : DCR : RM-944_ROM_eMP_20.06.11 DCR : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 DCR : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 DCR : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 DCR : RM-944_VIVA_eMP_20.06.11 Prepare Target SDS : OK : 0x003F4000 : 0x0000C000 FFS Format Ok! CBR : 0x00000019:0x00000001:0x00000000:0x00000000:0x0000 0010:0x00000002:0x00000000 Erase Target Flash Erase done! Write Target Flash Write : RM-944_ROM_eMP_20.06.11 Write : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 Write : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 Write : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 Write : RM-944_VIVA_eMP_20.06.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : RM-944_ROM_eMP_20.06.11 Verify : RM-944_LANG_PACK_ROM_IJ_eMP_20.06.11 Verify : RM-944_CUSTPACK_ROM_IJ_MEA_PK_eMP_20.06.11 Verify : RM-944_JUMP_TABLE_IJ_MEA_PK_eMP_20.06.11 Verify : RM-944_VIVA_eMP_20.06.11 Done! Elapsed: 00:01:04 Reconnect Power/Cable! |
02-06-2019, 12:36 | #735 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia E52 SDD Key Repair Done :) Code: Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia E52-1 Software ver : V ICPR82_11w16.3.11 29-03-12 RM-469 (c) Nokia IMEI : 357880043123755 XappVer : 000008F2 Ape Ver : 091.003 APE Var : 091.003091.003.10.01091.003.C00.01 APE ADSP: 256 DSP Ver : 11w52 APE Test: v0.a091 PPM : CNT : Product SN : MHL585834 Product code : 0591686 Base Prd.code: 0590828 Module code : 0203994 Long Prod.SN : 0 Hardware info======= HWID : 1100 Retu : 40 Tahvo : 00 Battery: 3929 mV APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652. APE HW: 256 Lock info =========== IMEI : 357880043123755 IMEI spNet : 3A 75 88 00 34 21 73 05 IMEI svNet : 33 75 88 00 34 21 73 55 F7 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= Error collect lock info, try again CRT308 Backup Created SDD key status : Damaged!!!!! CMLA Key status : Not Present SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Checking StartUp data ... ----------------------- SDD Key status : SDData Damaged!!!!! :( - > Do REPAIR SDD , Local SX4 if needed CMLA Key status : CMLA key Not exist SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Backup Certificates now... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok Check communication with phone.... Reboot.... Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 1EE0000240D90344A61BFBBBFDED95CBF6CA2740 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 85F252E351E225CAFC4DFBC8041EABD2823E3500 ADL: Reading certificates... Reading NPC certificate... IMEI : 357880043123755 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... ADL: Reading certificates done! :) ADL: Close_Session Content: 000300000000040000000300000000 ADL: Reboot NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : F:\1+Flashing Software\1+Infinity Box\BEST\Backup\Cert\357880043123755.rpl All done, Disconnecting Elapsed: 00:00:15 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Code: Repair SD procedure started... Phone Imei: 357880043123755 - > Power Off phone, dissconnect it and connect Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB PUBLIC ID: 1EE0000240D90344A61BFBBBFDED95CBF6CA2740 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 Fetching data, wait... - > Reinsert cable and battery, press powerOn button again - > For X7, E7 - just waiting, near 1 minute - > When BEST start Search Phone - Press PowerOn if needed Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 1EE0000240D90344A61BFBBBFDED95CBF6CA2740 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 85F252E351E225CAFC4DFBC8041EABD2823E3500 ADL: Close_Session Content: 000300000000040000000300000000 ADL: Reboot Wait, reconneting... rap= 1EE0000240D90344A61BFBBBFDED95CBF6CA2740 hash= 25B977A055BE9B5DEC0C38A2A279C695 key= 7CDAB4A72CB954516BE0E4429F8192509E6EBCB3 Key file updated... Operating mode is OK, no need change... Writing Super Dongle Key... Ok! Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Local SX4 procedure started... Phone Imei: 357880043123755 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Uploading RF/Battery tune to phone... Using : RM-469.pm Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => OK Done! Elapsed: 00:00:01 Upload done Done! Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok CMLA Key status : CMLA key Not exist SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! Code: Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:14 Set phone in Normal mode... Restarting... Done! Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
