05-12-2017, 12:42 | #61 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 110 flashing done Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm827__03.51.mcusw PPM : rm827__03.51.ppm_m2 CNT : rm827__03.51.image_m2_059N2R0 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.49_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 351970052848008 IMEI 2 : 351970052848016 PCcode : 059N403 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\351970052848008_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm827__03.51.mcusw Image : rm827__03.51.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:04 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:02:04 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:33 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xA3D6 ===Flashing [PPM]=== File : rm827__03.51.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:16 Write , Start : 0x41BC0000 , Len : 0x0030F748 Flashing , wait ... Region flash done, time : 00:00:03 CRC check passed , 0x4605 ===Flashing [CNT]=== File : rm827__03.51.image_m2_059N2R0 Image : package_m2_059N2R0.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:04:34 Write , Start : 0x421C0000 , Len : 0x00F20000 Flashing , wait ... Region flash done, time : 00:00:25 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:08 No write data, skip CRC check passed , 0x2091 Flashing done! Total flash time : 00:08:15 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 110 Software Info: V 03.51 06-08-13 RM-827 (c) Nokia IMEI: 351970052848008 PPM version : V 03.51 06-08-13 RM-827 (c) Nokia M2 Product code: 059N403 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:09:01 |
The Following User Says Thank You to Luckey1 For This Useful Post: |
05-14-2017, 08:35 | #62 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 130 format done Code: --- Insert USB cable now! --- Wait for phone... Phone found! [ 23 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 0FB43CDE7FD20EBC1BDD65A713D85382 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:25 Connect phone on selected interface... |
05-16-2017, 16:06 | #64 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 225 write Factory Firmware Done :) Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1011_ROM_eMP_30.06.11 VIVA : RM-1011_VIVA_eMP_30.06.11 LANG : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001 CUST : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001 JMPT : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001 - > MODE : FullFlash Software Info: 30.06.11 00-00-00 RM-1011 IMEI: 359770062267880 PPM version : IJ Product code: 059V6J5 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 273 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 5ACCB3DD33ED25FC323FA7E3946F75E5 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.30.06.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 SecureDecrypt : RM-1011_ROM_eMP_30.06.11 SecureDecrypt : RM-1011_VIVA_eMP_30.06.11 SecureDecrypt : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001 SecureDecrypt : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001 SecureDecrypt : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001 OVRLP : 000069B900000001 PHPID : PEARL.30.06.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1011_ROM_eMP_30.06.11 Write : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001 Write : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001 Write : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001 Write : RM-1011_VIVA_eMP_30.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1011_ROM_eMP_30.06.11 [VERIFY] DONE : RM-1011_LANG_PACK_ROM_IJ_eMP_30.06.11_001 [VERIFY] DONE : RM-1011_CUSTPACK_ROM_IJ_MEA_PK_eMP_30.06.11_001 [VERIFY] DONE : RM-1011_JUMP_TABLE_IJ_MEA_PK_eMP_30.06.11_001 [VERIFY] DONE : RM-1011_VIVA_eMP_30.06.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:03:24 Reboot phone Ok - > Hint : If phone shows Battery charge icon - press and hold PowerOn button 10 seconds Wait, when phone will be ready ... Reading Phone Info.... Software Info: 30.06.11 00-00-00 RM-1011 IMEI: 359770062267880 Ape Version: NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM version : IJ Product code: 059V6J5 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Phone disconected! Connect phone on selected interface... |
The Following 2 Users Say Thank You to syed tuqeer For This Useful Post: |
05-17-2017, 08:09 | #65 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 206 Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm872__04.52.mcusw PPM : rm872__04.52.ppm_m2 CNT : rm872__04.52.image_m2_059Q8L5 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 358371057536842 IMEI 2 : 358371057536859 PCcode : 059S8K5 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\358371057536842_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm872__04.52.mcusw Image : rm872__04.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:00:51 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:35 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xFA4D ===Flashing [PPM]=== File : rm872__04.52.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00680000 Erasing, wait ... Erase done, time : 00:00:10 Write , Start : 0x41A80000 , Len : 0x003C68F0 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xC9E6 ===Flashing [CNT]=== File : rm872__04.52.image_m2_059Q8L5 Image : package_m2_059Q8L5.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:01:21 Write , Start : 0x42100000 , Len : 0x01040000 Flashing , wait ... Region flash done, time : 00:00:22 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0xDE0E Flashing done! Total flash time : 00:03:33 Reboot phone now... Reading Phone Info.... Connected phone - 206 Software Info: V 04.52 30-06-13 RM-872 (c) Nokia IMEI: 358371057536842 PPM version : V 04.52 30-06-13 RM-872 (c) Nokia M2 Product code: 059S8K5 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:32 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
05-18-2017, 14:46 | #66 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Lumia 535 Write Factory Firmware Done :) Downgrade win 10 to win 8.1 Code: Core : v2.29 , WP10x FlashEngine : v3.2 FFU : RM1090_02074.00000.15234.28008_RETAIL_prod_signed_1029_02E5F3_000-PK.ffu Checking FFU file, wait... FFU Revision ID : 2.0 FFU Model ID : Nokia.MSM8212.P6214 FFU RootKeyHash : 0000000000000000000000000000000000000000 FFU Languages : Portuguese(Brazil) , Russian , Belorusian , fr-ca , Indonesian , Korean , Polish , Ukrainian , Uzbekistan(Latin) , Catalan , Swedish , Bulgarian , Japanese , Spanish , English (UK) , Czech , Latvian , Slovak , Chinese , sr-latn-rs , af-za , Hindi (India) , gl-es , Turkish , Thai , Italian , Danish (Denmark) , ha-latn-ng , Slovenian , Malay (Malaysia) , Lithuanian , Persian (Iran) , Kazakh , Romanian , English , eu-es , Estonian , Filipino (Philippines) , Greek , Norwegian (Bokmal , Norway) , Finnish , Vietnamese , Arabic , Croatian , Portuguese(Portugal) , Chinese(Taiwan) , Macedonian , Hungarian , Spanish(Mexico) , Azerbaijan(Latin) , German , Albanian , Dutch (Netherlands) , French , Hwbre (Israel) , FFU ChipSectors : 15155200 FFU Header : 0x000E0000 FFU Payload : 0x69BE0000 FFU FastVerify : Ok Waiting for phone... Dead mode is selected , no phone in normal mode found 1. Press and hold "Volume Down" 2. Insert USB cable 3. Hold button until phone will be detected Device catched in BOOT mode! Boot Mode confirmed! Setting Preloder Collect Info... Setting Application Setting Secure Collect Info... === Nokia Flash App info : Protocol Version : 2.34 Protocol Implementation : 2.59 === Phone Initial info : Phone RMxxx ID : RM-1090 Phone Model ID : Nokia.MSM8212.P6214.1.1 Phone Model PC : 059W7L1 Phone IMEI : 359730066558xxx === eMMC info : eMMC Vendor : Hynix eMMC CID : 0090 eMMC Size : 7456 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : BC2353ACA62C327ECCD582A281CA4A5672F35001 === Other info : SD present : False Full Check skipped , will be checked by ImageSignature Battery Level : 54% RPMB Provision Status Code : 0x0101 Device RAM size : 1024 MiB Device not have ATRP Backup to RAM Ok! FFU : RM1090_02074.00000.15234.28008_RETAIL_prod_signed_1029_02E5F3_000-PK.ffu Flashing FFU Sending FFU Header CertData Header sent , accepted :) Perform Data Partition Erase Error : 06 : Data Partition Not Found! Seems as damaged Will Fix partitions by flash whole image Sending FFU Header CertData Header sent , accepted :) Skip Data Partition Erase Sending FFU Payload Data... Finishing flashing Flashing done! Green Light :) Image Sent, processing PostFlash FinalConfig : Ok , Status : Normal Make Factory Set : Ok Restore RAMBkp : Ok Update NVI from Image Ok , NVI will be updated on first boot! PostFlash Finished Total flash time : 00:07:34 Rebooting Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Phone disconected! Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok |
05-18-2017, 15:39 | #67 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | Nokia 230 (RM-1172) Flashing. Download Firmware Code: SSChannel : Create SC SSChannel : SC Created! ProductID HWCode : RM-1172 Selected Variant : RM-1172 NDT MEA IC D_SILVER ARABIC KW Firmware Version : 10.01.11 Platform Version : S30+ SSChannel : DC Ok with code 0x06 Switch to IDM now ... IDM initializing, wait... Checking access to Products folder... Folder for RM-1172 exist Prepare done, collect info [Query] : RM1172_059X5R6_10.01.11_017.vpl , 4.46 KiB [Query] : RM-1172_CUSTPACK_ROM_IC_MEA_KW_eMP_10.01.11_001 , 125.89 KiB [Query] : RM-1172_JUMP_TABLE_IC_MEA_KW_eMP_10.01.11_001 , 1.15 KiB [Query] : RM-1172_LANG_PACK_ROM_IC_eMP_10.01.11_001 , 3.62 MiB [Query] : RM-1172_ROM_eMP_10.01.11 , 1011.43 KiB [Query] : RM-1172_VIVA_eMP_10.01.11 , 6.06 MiB Files to download : 6 Total size to download : 10.80 MiB Downloading now, please, wait... [Download] : RM1172_059X5R6_10.01.11_017.vpl [Download] : RM-1172_CUSTPACK_ROM_IC_MEA_KW_eMP_10.01.11_001 [Download] : RM-1172_JUMP_TABLE_IC_MEA_KW_eMP_10.01.11_001 [Download] : RM-1172_LANG_PACK_ROM_IC_eMP_10.01.11_001 [Skip,Exist] : RM-1172_ROM_eMP_10.01.11 [Skip,Exist] : RM-1172_VIVA_eMP_10.01.11 Verify files now ... [Verify Ok] : RM-1172_ROM_eMP_10.01.11 [Verify Ok] : RM-1172_LANG_PACK_ROM_IC_eMP_10.01.11_001 [Verify Ok] : RM-1172_CUSTPACK_ROM_IC_MEA_KW_eMP_10.01.11_001 [Verify Ok] : RM-1172_JUMP_TABLE_IC_MEA_KW_eMP_10.01.11_001 [Verify Ok] : RM-1172_VIVA_eMP_10.01.11 All done, all files were downloaded! Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1172_ROM_eMP_10.01.11 VIVA : RM-1172_VIVA_eMP_10.01.11 LANG : RM-1172_LANG_PACK_ROM_IC_eMP_10.01.11_001 CUST : RM-1172_CUSTPACK_ROM_IC_MEA_KW_eMP_10.01.11_001 JMPT : RM-1172_JUMP_TABLE_IC_MEA_KW_eMP_10.01.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 256 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : BB907D739688F48C2FA9A6521E7F6B97 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DOHA.10.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Doha.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 SecureDecrypt : RM-1172_ROM_eMP_10.01.11 SecureDecrypt : RM-1172_VIVA_eMP_10.01.11 SecureDecrypt : RM-1172_LANG_PACK_ROM_IC_eMP_10.01.11_001 SecureDecrypt : RM-1172_CUSTPACK_ROM_IC_MEA_KW_eMP_10.01.11_001 SecureDecrypt : RM-1172_JUMP_TABLE_IC_MEA_KW_eMP_10.01.11_001 OVRLP : 000069B900000001 PHPID : DOHA.10.01.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1172_ROM_eMP_10.01.11 Write : RM-1172_LANG_PACK_ROM_IC_eMP_10.01.11_001 Write : RM-1172_CUSTPACK_ROM_IC_MEA_KW_eMP_10.01.11_001 Write : RM-1172_JUMP_TABLE_IC_MEA_KW_eMP_10.01.11_001 Write : RM-1172_VIVA_eMP_10.01.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1172_ROM_eMP_10.01.11 [VERIFY] DONE : RM-1172_LANG_PACK_ROM_IC_eMP_10.01.11_001 [VERIFY] DONE : RM-1172_CUSTPACK_ROM_IC_MEA_KW_eMP_10.01.11_001 [VERIFY] DONE : RM-1172_JUMP_TABLE_IC_MEA_KW_eMP_10.01.11_001 [VERIFY] DONE : RM-1172_VIVA_eMP_10.01.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:03:24 Reboot phone Ok |
The Following 2 Users Say Thank You to Nasir Mobiles For This Useful Post: |
05-19-2017, 06:01 | #68 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 230 RM-1172 Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1172_ROM_eMP_10.01.11 VIVA : RM-1172_VIVA_eMP_10.01.11 LANG : RM-1172_LANG_PACK_ROM_IJ_eMP_10.01.11_001 CUST : RM-1172_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 JMPT : RM-1172_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 000327E2C3BE079CD8EA4184F026FDAB BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DOHA.10.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Doha.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 SecureDecrypt : RM-1172_ROM_eMP_10.01.11 SecureDecrypt : RM-1172_VIVA_eMP_10.01.11 SecureDecrypt : RM-1172_LANG_PACK_ROM_IJ_eMP_10.01.11_001 SecureDecrypt : RM-1172_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 SecureDecrypt : RM-1172_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 OVRLP : 000069B900000001 PHPID : DOHA.10.01.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1172_ROM_eMP_10.01.11 Write : RM-1172_LANG_PACK_ROM_IJ_eMP_10.01.11_001 Write : RM-1172_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 Write : RM-1172_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 Write : RM-1172_VIVA_eMP_10.01.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1172_ROM_eMP_10.01.11 [VERIFY] DONE : RM-1172_LANG_PACK_ROM_IJ_eMP_10.01.11_001 [VERIFY] DONE : RM-1172_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 [VERIFY] DONE : RM-1172_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 [VERIFY] DONE : RM-1172_VIVA_eMP_10.01.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:03:14 Reboot phone Ok |
05-21-2017, 08:17 | #69 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 105 Write Flash File Done :) Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm908_003.400 PPM : rm908_003.40ij CNT : rm9080_nai03.40ij Infineon flashing... -> Infineon XG110 : IMEI Backup Created Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 PBL : Dynamic Boot Ok , 01AB SBL : Dynamic Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH VEN : 0000002C FLASH DIE : 0000CB17 FLASH ID : SPI , 25W064A Boot Done! ===Flashing [MCU]=== File : rm908_003.400 Image : hw_f31_rm908_62_mcusw_03.40_Best.fls Cert block found, sending.... Cert sent Found 3 region(s) Processing Region 1/3 Erase , Start : 0x00800000 , Len : 0x00210000 Erasing, wait ... Erase done Write , Start : 0x00800000 , Len : 0x00210000 Flashing , wait ... Region flash done Processing Region 2/3 Erase , Start : 0x00C60000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00C60000 , Len : 0x00221240 Flashing , wait ... Region flash done Processing Region 3/3 Erase , Start : 0x00FFC000 , Len : 0x00004000 Erasing, wait ... Erase done Write , Start : 0x00FFC000 , Len : 0x00000040 Flashing , wait ... Region flash done Check : 5960 ===Flashing [PPM]=== File : rm908_003.40ij Image : hw_f31_rm908_62_ppm_03.40ij_Best.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00210000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00210000 , Len : 0x0018A340 Flashing , wait ... Region flash done Check : 3ED1 ===Flashing [CNT]=== File : rm9080_nai03.40ij Image : hw_f31_rm908_62_image_03.40ij_Best.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00EB0000 , Len : 0x000D0000 Erasing, wait ... Erase done Write , Start : 0x00EB0000 , Len : 0x000661C0 Flashing , wait ... Region flash done Check : 919A Flashing done, rebooting... -> Infineon info : Do FullFactory Sets after flashing Flashing Done! Init Service mode... Wait... Afterflash settings... SW ver : V 03.40 08-08-13 RM-908 (c) Nokia IMEI : 358986057633xxx PCode : 059R446 Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! All done! Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... SW ver : V 03.40 08-08-13 RM-908 (c) Nokia IMEI : 358986057633xxx PPM : V 03.40 08-08-13 RM-908 (c) Nokia IJ PCode : 059R446 BPCode : 059T865 HWID : 2000 LCDVer : CMI:BEIHAIv01 ILI9163C IMEI : 358986057633xxx Sl Conf : 001-01-00000000000 Sl Prof : 000000000004000-2 Sl Aux : 000B0000 Hw Sig : 934A9BDFC8A00860 Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Done! Phone disconected! Connect phone on selected interface... Connect phone on selected interface... |
05-21-2017, 10:26 | #70 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | flash nokia asha 202 Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm834__20.52.mcusw PPM : rm834__20.52.ppm_m_a CNT : rm834__20.52.image_m_a_059M6C0 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.47_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 353264053130246 IMEI 2 : 353264053130253 PCcode : 059M692 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\353264053130246_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm834__20.52.mcusw Image : rm834__20.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01B40000 Erasing, wait ... Erase done, time : 00:00:59 Write , Start : 0x40280000 , Len : 0x01AC0000 Flashing , wait ... Region flash done, time : 00:00:42 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xD2A9 ===Flashing [PPM]=== File : rm834__20.52.ppm_m_a Image : package_m_a.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41DC0000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:09 Write , Start : 0x41DC0000 , Len : 0x0041B6E4 Flashing , wait ... Region flash done, time : 00:00:05 CRC check passed , 0xBBFE ===Flashing [CNT]=== File : rm834__20.52.image_m_a_059M6C0 Image : package_m_a_059M6C0.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x424C0000 , Len : 0x01960000 Erasing, wait ... Erase done, time : 00:01:07 Write , Start : 0x424C0000 , Len : 0x00CC0000 Flashing , wait ... Region flash done, time : 00:00:17 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0xC996 Flashing done! Total flash time : 00:03:29 Reboot phone now... Reading Phone Info.... Connected phone - 202 Software Info: V 20.52 27-09-12 RM-834 (c) Nokia IMEI: 353264053130246 PPM version : V 20.52 27-09-12 RM-834 (c) Nokia M_A Product code: 059M692 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 42 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:18 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
05-23-2017, 08:56 | #71 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 206 flashing done Code:
05-24-2017, 11:15 | #72 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Romania/Piatra Neamt
Member: 880649 Status: Offline Thanks Meter: 73 | nokia 501 reset user code by flashing Connect phone on selected interface... SSChannel : Create SC SSChannel : SC Created! ProductID HWCode : RM-902 Selected Variant : RM-902 VAR EURO-EU1 IT CV BLACK Firmware Version : 14.0.5 Platform Version : Nokia Asha SSChannel : DC Ok with code 0x05 Done! Generated Links : ------------------------------------------------------- https://sr.azureedge.net/softwarerep...FM2ODO261jA%3D https://sr.azureedge.net/softwarerep...tXUWUvt3aVI%3D https://sr.azureedge.net/softwarerep...IqJObP4sGKo%3D https://sr.azureedge.net/softwarerep...sILmNHS6NL8%3D https://sr.azureedge.net/softwarerep...L2jRXqB8CUA%3D ------------------------------------------------------- SSChannel : Create SC SSChannel : Failed to get info! Please, check ProductCode, which you enter. Probably it wrong ErroInfo : Unable connect to SRV Core : v2.28 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual File [Ok] : rm902_14.0.5.mcusw.fpsx File [Ok] : rm902_14.0.5_059R670_eu1_414_05_419436.rofs.fpsx File [Ok] : rm902_14.0.5_059R670_eu1_414_05_419436.image.fpsx Dead Mode is Selected Waiting for USB device... If PC not detect phone - Insert Cable first, then Insert battery If stuck on boot - remove MicroSD card from phone! --- Press phone's power button or insert cable & charger! --- 1st Boot Done, processing booting now ASIC ID_F : 00000C2016100040498A29899A46B9D285122233 ASIC ID_E : 00000C2016100040 PUBLIC ID : 0919FD0048A14B7B498A29899A46B9D285122233 XGCHIP ID : 0919FD0048A14B7B ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 35959405406XXX IMEI [2] : 35959405406XXX NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\35959405406xx_2nd_ XG223_CRT.rpl PAPUBkeys : 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E === SW Version Check === - > UPGRADE === SW Version Check === === Flashing MCU === Processing file : rm902_14.0.5.mcusw.fpsx Erasing... Writing... Total blocks : 82 Writing RKH CRT [ISSW] Writing RKH CRT [MEMSET] Writing RKH CRT [PRIMAPP] Writing RKH CRT [LOADER] Writing RKH CRT [PASUBTOC] Writing RKH CRT [PAPUBKEYS] [PAKeys : 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E] Writing RKH CRT [UPDAPP] Writing RKH CRT [MCUSW] File processed Ok, 81 blocks were writen === Flashing PPM === Processing file : rm902_14.0.5_059R670_eu1_414_05_419436.rofs.fpsx Erasing... Writing... Total blocks : 17 Writing RKH CRT [PPM] File processed Ok, 17 blocks were writen === Flashing CNT === Processing file : rm902_14.0.5_059R670_eu1_414_05_419436.image.fpsx Erasing... Writing... Total blocks : 56 File processed Ok, 56 blocks were writen Flashing done , total time : 00:00:57 Reboot phone to service mode... Reading Phone Info.... Connected phone - 501 Software Info: V 14.0.5 21-04-14 RM-902 (c) Nokia IMEI: 359594054064xx PPM version : 4627b38980fa70b4ae216bb7410c1d4403710416 Product code: 059T8B4 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 59 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - 501 Software ver : V 14.0.5 21-04-14 RM-902 (c) Nokia IMEI : 35959405406xx XappVer : 000008E8 APE Var : 0000000000000000000000000000000000000000 PPM : 4627b38980fa70b4ae216bb7410c1d4403710416 CNT : Product SN : 512DB5FBH Product code : 059T8B4 Base Prd.code: 059P9V6 Module code : 0205341 Long Prod.SN : 0 Hardware info======= HWID : 1000 Tahvo : RM-902-14.0.5-059T8B4-14.0.5-14.0.5 Battery: 3775 mV CMT BT: 0101-0.1.9 LCDVer: TPO Lock info =========== IMEI : 35959405406xx IMEI spNet : 3A 95 95 04 45 60 64 06 IMEI svNet : 33 95 95 04 45 60 64 36 F1 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= Error collect lock info, try again CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL30 (20 digit) phone detected... User code : Crypted MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Set phone in Normal mode... Restarting... Done! Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 2 Users Say Thank You to totmititelu For This Useful Post: |
05-25-2017, 13:39 | #73 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia Asha 206 Flashing Done Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm872__04.52.mcusw PPM : rm872__04.52.ppm_m2 CNT : rm872__04.52.image_m2_059Q8L5 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm872__04.52.mcusw Image : rm872__04.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:00:48 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:34 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xFA4D ===Flashing [PPM]=== File : rm872__04.52.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00680000 Erasing, wait ... Erase done, time : 00:00:08 Write , Start : 0x41A80000 , Len : 0x003C68F0 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xC9E6 ===Flashing [CNT]=== File : rm872__04.52.image_m2_059Q8L5 Image : package_m2_059Q8L5.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:01:09 Write , Start : 0x42100000 , Len : 0x01040000 Flashing , wait ... Region flash done, time : 00:00:21 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0xDE0E Flashing done! Total flash time : 00:03:14 Reboot phone now... |
The Following 5 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
05-25-2017, 13:41 | #74 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia Asha 202 Flashing Done Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm834__20.52.mcusw PPM : rm834__20.52.ppm_m_a CNT : rm834__20.52.image_m_a_059M6C0 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm834__20.52.mcusw Image : rm834__20.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01B40000 Erasing, wait ... Erase done, time : 00:00:59 Write , Start : 0x40280000 , Len : 0x01AC0000 Flashing , wait ... Region flash done, time : 00:00:42 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xD2A9 ===Flashing [PPM]=== File : rm834__20.52.ppm_m_a Image : package_m_a.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41DC0000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:09 Write , Start : 0x41DC0000 , Len : 0x0041B6E4 Flashing , wait ... Region flash done, time : 00:00:05 CRC check passed , 0xBBFE ===Flashing [CNT]=== File : rm834__20.52.image_m_a_059M6C0 Image : package_m_a_059M6C0.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x424C0000 , Len : 0x01960000 Erasing, wait ... Erase done, time : 00:01:07 Write , Start : 0x424C0000 , Len : 0x00CC0000 Flashing , wait ... Region flash done, time : 00:00:17 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0xC996 Flashing done! Total flash time : 00:03:29 |
05-25-2017, 13:44 | #75 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 230 Full Flashing Done Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1172_ROM_eMP_10.01.11 VIVA : RM-1172_VIVA_eMP_10.01.11 LANG : RM-1172_LANG_PACK_ROM_IJ_eMP_10.01.11_001 CUST : RM-1172_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 JMPT : RM-1172_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 000327E2C3BE079CD8EA4184F026FDAB BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DOHA.10.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Doha.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 SecureDecrypt : RM-1172_ROM_eMP_10.01.11 SecureDecrypt : RM-1172_VIVA_eMP_10.01.11 SecureDecrypt : RM-1172_LANG_PACK_ROM_IJ_eMP_10.01.11_001 SecureDecrypt : RM-1172_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 SecureDecrypt : RM-1172_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 OVRLP : 000069B900000001 PHPID : DOHA.10.01.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1172_ROM_eMP_10.01.11 Write : RM-1172_LANG_PACK_ROM_IJ_eMP_10.01.11_001 Write : RM-1172_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 Write : RM-1172_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 Write : RM-1172_VIVA_eMP_10.01.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1172_ROM_eMP_10.01.11 [VERIFY] DONE : RM-1172_LANG_PACK_ROM_IJ_eMP_10.01.11_001 [VERIFY] DONE : RM-1172_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 [VERIFY] DONE : RM-1172_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 [VERIFY] DONE : RM-1172_VIVA_eMP_10.01.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00DC0000-0x00FF3FFF , LEN : 0x00234000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:03:14 |
