Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 03-22-2019, 06:40   #781 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,379
Smile Nokia 130 RM-1035
Core : v2.29 , MTKx FlashEngine : v14.0
Verify files ...
MAUI : RM-1035_ROM_eMP_11.00.11
VIVA : RM-1035_VIVA_eMP_11.00.11
LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002
CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002
JMPT : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002
- > MODE : FullFlash
Dead Mode is Selected
Waiting for USB device...
1. Phone should be Off!
2. Battery must be charged and inserted! ( if not used external power )
- > If phone can't switch to BL - use battery or flash from Local mode!
--- Insert USB cable now! ---
Wait for phone...
Phone found! [ 27 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0001
BB_CPU_SN : 39826C3723D76E2279F09CC89E1A359B
BROM Protocol Version : 05
BROM Status : 0000
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
Setting done , result code 0x8000
Project ID : CRYSTAL.11.00.11.p1
BROM/BL stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_eMP_Crystal.fg
DA_VERIFY : 00
DA_JUMP : 00040000
DA_AUTH : Passed!
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV
[0] : FLASH_DIE : 00EF 0040 0016 0000
[0] : FLASH_LEN : 0x00400000
FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000
SecureDecrypt : RM-1035_ROM_eMP_11.00.11
SecureDecrypt : RM-1035_VIVA_eMP_11.00.11
SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002
SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002
SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002
OVRLP : 000069B900000001
PHPID : CRYSTAL.11.00.11.p1
OVRLP : 00004DF900000001
DA : FORMAT_BIN
Processing Flash Pre-format
FILES : 5
SAFE_BLOCK : 04
FORMAT_BIN : Ok
WRITE_STYLE : DEF : 0x01 (SEQ)
Write : RM-1035_ROM_eMP_11.00.11
Write : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002
Write : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002
Write : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002
Write : RM-1035_VIVA_eMP_11.00.11
CODE_DNLOAD : Ok
[VERIFY] DONE : RM-1035_ROM_eMP_11.00.11
[VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002
[VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002
[VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002
[VERIFY] DONE : RM-1035_VIVA_eMP_11.00.11
CODE_VERIFY : Ok
Executing FFS FORMAT now...
DA_RET : DA_IN_PROGRESS
DA_RET : FORMAT_DONE
Rebooting phone now
Flashing done!
Total flash time : 00:01:05
Reboot phone Ok
Connect phone on selected interface...
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post:
Old 03-22-2019, 10:32   #782 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Nokia 3310 3G TA-1006 Format FS Done
Operation : Reset Settings ( Format FS ) [ v1.10 ]
1. Power off device, remove battery
2. Insert cable, press and hold BootKey ( # )
3. Insert battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD SECURE BOOT Block version
BootVersion : BEST RETRO3G
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
Erase BLK #0
Erase BLK #1
Erase BLK #2
Erase BLK #3
Format Ok!
Done!
Elapsed: 00:01:08
The Following 4 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 03-23-2019, 06:01   #783 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Nokia 130 TA-1017 Format Done
Operation : Reset Settings [ v1.09 ]
1. Make sure device is powered off. Power off, if need. Wait 10 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM Port (COM27)
MODE : NOKIA USB SERIAL
PORT : 27
BROM : Init BROM
BROM init passed!
CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001
BROM : SECCFG : 0x00000007
BROM : NOKIA USB SERIAL
BROM : 0x05 BL : 0x00
BROM : MEID : AC9E9CA050C000E35EF7E5E486230FAC
BROM : Run BootLoader ...
BOOT : Run BL ver. 01
BOOT : 0x05 BL : 0x01
BOOT : WD : 0005
BOOT : RTC : Setup ...
BOOT : RTC : 000E
BOOT : PRJ : KESA61A.10.00.11.p2
BOOT : SWR : 10.00.11
AGENT : Look for suitable BootChain in DA ...
AGENT : DEFAULT AUTO
AGENT : Found MT6261
AGENT : KESA61A.10.00.11.p2
BOOT : Sending 1st DA ...
BOOT : DA sent
BOOT : Transfer control to DA ...
DA : Agent : v03.02 on BBID : 0x8E
NOR: 00EF : 0060 : 0017 : 0000
NOR: [WINBOND] W25Q64DW
NOR:
TSIZE : 0x00800000 [ 8.00 MB ]
PSIZE : 0x00800000 [ 8.00 MB ]
STYPE : 0x00000000
FLOTP : DA_NOR_OTP_EXIST
STATUS : OK
BSTYLE : SF_FLASH_BOOT
Boot done!
FFS Info exists in MAUI : 0x00580000 : 0x00278000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:52
Reconnect Power/Cable!
Old 03-26-2019, 12:00   #784 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 3,968
TA-1034 Format / Reset Done :)
Operation : Reset Settings [ v1.11 ]
PTFN : Nokia USB Serial Port (COM246)
PORT : 246
BROM : Init BROM
BROM init passed!
BROM : MEID : 400AAC7E14421E3F84B9270AB493BDC9
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : N103.10.02.11.p1
BOOT : SWR : 10.02.11
AGENT : N103.10.02.11.p1
BOOT : DA sent
DA : Sync Passed!
DA : Authentification pass!
        NOR: 00EF : 0070 : 0016 : 0000
        NOR: [Winbond] SF_W25Q32JV
        NOR:
              TSIZE  : 0x00400000 [ 4.00 MB ]
              PSIZE  : 0x00400000 [ 4.00 MB ]
              STYPE  : 0x00000000
 STATUS : OK
Boot done!
FFS Info exists in MAUI : 0x00370000  :  0x00088000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:26
The Following 2 Users Say Thank You to syed tuqeer For This Useful Post:
Old 03-31-2019, 12:58   #785 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 764
Nokia 150 reset password done by best2
Card found : 30C22462 , v0122
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.11
Operation : Identify [ v1.11 ]
PTFN : Nokia USB Serial Port (COM6)
PORT : 6
BROM : Init BROM
BROM init passed!
BROM : MEID : E8BF060F73FE2D6D916065AC2F1CB20C
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : DUBAI61D.10.02.11.p1
BOOT : BDDS : 30
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
SWVer : DUBAI61D.10.02.11.p1
FLASH : 00C2 : 0025 : 0036 : 0000
BBSN : E8BF060F73FE2D6D916065AC2F1CB20C
PRDC : 059X8W6
IMEI[1] :
IMEI[2] :
NCK : 20 digits
PROV : 24407000
Saved as : 35xxxxxxxxxxxxx.mtsec
Saved to : C:\InfinityBox\BEST2\Backup\
Done!
Elapsed: 00:00:59
PORT : 6
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
AGENT : DUBAI61D.10.02.11.p1
BOOT : DA sent
DA : Sync Passed!
NOR: 00C8 : 0060 : 0016 : 0000
NOR: [GigaDevice] GD25LQ32
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
FFS Info exists in MAUI : 0x003A0000 : 0x00058000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:32
The Following User Says Thank You to A.G.Shahid For This Useful Post:
Old 03-31-2019, 14:23   #786 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Nokia C2-03
Core : v2.29 , BB5XG FlashEngine : v10.5
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm702__07.65.mcusw
PPM : rm702__07.65.ppm_m_a
CNT : rm702__07.65.image_m_a_059D434
Flashing phone now...
[Gen] Rules accepted for : XGOLD Generation
Check files done...
-> SWversion check skipped : Dead mode selected
-> If Windows say "Unrecognized device" / Operation not start
-> Or if Phone start charge - just reinsert battery
-> If flashing freeze - reinsert cable/battery and try again
--- Press phone's power button or insert usb cable! ---
Connection opened successfully
IF Boot Init : 0xF0
IF Resp Len : 0x0A
IF xCPUID : XGOLD 213 [XMM2130 QUANTUM]
IF Resp Data : 1FB300020303010100FF
Sending EBL Loader ...
EBL Loader Ok, 01
EBL Loader ready, AA
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.46_M1S1
Speed accepted, use 6.500.000
FLASHID : 89008289
FLIC conf set, RST set
Boot done!
Check keys...
Check done. Image can be flashed
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 359328046833762
IMEI 2 : 359328046833770
PCcode : 059D434
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\359328046833762_XG 213_CRT.rpl
Settings : EDM [0x8] , Block Mode , Fast CRC , Verify
===Flashing [MCU]===
File : rm702__07.65.mcusw
Image : rm702__07.65.mcusw_ebl_psi.fls
Sec-pack found, sending ...
Sec-pack sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:04
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x01B40000
Erasing, wait ...
Erase done, time : 00:01:56
Write , Start : 0x40280000 , Len : 0x01AC0000
Flashing , wait ...
Region flash done, time : 00:00:31
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
CRC check passed , 0x26E7
===Flashing [PPM]===
File : rm702__07.65.ppm_m_a
Image : package_m_a.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41DC0000 , Len : 0x00700000
Erasing, wait ...
Erase done, time : 00:00:17
Write , Start : 0x41DC0000 , Len : 0x004048E0
Flashing , wait ...
Region flash done, time : 00:00:04
CRC check passed , 0xB129
===Flashing [CNT]===
File : rm702__07.65.image_m_a_059D434
Image : package_m_a_059D434.image.fls
Sec-pack sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x424C0000 , Len : 0x01960000
Erasing, wait ...
Erase done, time : 00:03:19
Write , Start : 0x424C0000 , Len : 0x00D00000
Flashing , wait ...
Region flash done, time : 00:00:19
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
Erase done, time : 00:00:07
No write data, skip
CRC check passed , 0xF4B0
Flashing done!
Total flash time : 00:06:42
Reboot phone now...
Reading Phone Info....
Connected phone - C2-03
Software Info: V 07.65 19-09-12 RM-702 (c) Nokia
IMEI: 359328046833762
PPM version : V 07.65 19-09-12 RM-702 (c) Nokia M_A
Product code: 059D434
Wait, when phone will be ready ...
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Processing After Flash Defaults...
FullFactorySet... Ok!
UserDataDefaultsSet...OK!
ServiceDefaultsSet... Ok!
LeaveDefaultsSet... Ok!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Check and Upload User Certificates ...
Total - 42 certs
Certificates found, skip upload ...
Battery voltage is enough for start
AfterFlash operations done ;D
Done!
Elapsed: 00:07:57
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 03-31-2019, 15:21   #787 (permalink)
CYB3R GSM's Avatar
Member: 2469611
Thanks Meter: 317
Nokia 3310 TA-1030 Contact Service Done
PTFN : Care Suite USB Serial Port (COM382)
PORT : 382
BROM : Init BROM
BROM init passed!
     CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000
BROM : MEID : 7AEE428C59A9FF0FA814B7681327AD3B
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : RETRO.11.02.11.p1
BOOT : SWR : 11.02.11
BOOT : BDDS : 30
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
SWVer : RETRO.11.02.11.p1
FLASH : 00EF : 0060 : 0018 : 0000
BBSN : 7AEE428C59A9FF0FA814B7681327AD3B
PRDC : 059Z014
IMEI[1] : 3XXXXXXXXXXXX8
IMEI[2] : 3XXXXXXXXXXXX5
Done!
Elapsed: 00:00:30
Open VPLfile : TA1030_059X9S3_11.02.11.vpl
Description  : TA-1030 NDT MEA IJ GREY URDU PK
DeviceType   : TA-1030
ProductCode  : 059X9S3
SoftwareVer  : 11.02.11
PPM LangPack :
[1] : Urdu (Islamic Republic of Pakistan)
[2] : English (United Kingdom)
Load Ok!
Operation : Write FirmWare
Setting   : UserData erase : True
Setting   : LangPack Only : False
PORT : 382
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
AGENT : Found MT6260
AGENT : RETRO.11.02.11.p1
BOOT : DA sent
DA : Agent : v03.02 on BBID : 0x8B
        NOR: 00C2 : 0025 : 0038 : 0000
        NOR: [MXIC] MX25U12835FZNI_10G
        NOR:
              TSIZE  : 0x01000000 [ 16.00 MB ]
              PSIZE  : 0x01000000 [ 16.00 MB ]
              STYPE  : 0x00000000
 STATUS : OK
Boot done!
VPL SoftwareVersion   : 11.02.11 [TA-1030]
DEV SoftwareVersion   : 11.02.11
SWInfo compare result : SAME
Load FlashSet :
MROM : TA-1030_ROM_eMP_11.02.11
LANG : TA-1030_LANG_PACK_ROM_IJ_eMP_11.02.11_001
CUST : TA-1030_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.02.11_001
JUMP : TA-1030_JUMP_TABLE_IJ_MEA_PK_eMP_11.02.11_001
VIVA : TA-1030_VIVA_eMP_11.02.11
Prepare FlashSet :
DCR : TA-1030_ROM_eMP_11.02.11
DCR : TA-1030_LANG_PACK_ROM_IJ_eMP_11.02.11_001
DCR : TA-1030_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.02.11_001
DCR : TA-1030_JUMP_TABLE_IJ_MEA_PK_eMP_11.02.11_001
DCR : TA-1030_VIVA_eMP_11.02.11
Prepare Target
SDS : OK : 0x00FF4000 : 0x0000C000
FFS Format Ok!
Erase Target Flash
Erase done!
Write Target Flash
Write : TA-1030_ROM_eMP_11.02.11
Write : TA-1030_LANG_PACK_ROM_IJ_eMP_11.02.11_001
Write : TA-1030_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.02.11_001
Write : TA-1030_JUMP_TABLE_IJ_MEA_PK_eMP_11.02.11_001
Write : TA-1030_VIVA_eMP_11.02.11
Write done, waiting target response ...
Write flash done!
Verify Target FlashContent
Verify : TA-1030_ROM_eMP_11.02.11
Verify : TA-1030_LANG_PACK_ROM_IJ_eMP_11.02.11_001
Verify : TA-1030_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.02.11_001
Verify : TA-1030_JUMP_TABLE_IJ_MEA_PK_eMP_11.02.11_001
Verify : TA-1030_VIVA_eMP_11.02.11
Done!
Elapsed: 00:03:14
The Following 3 Users Say Thank You to CYB3R GSM For This Useful Post:
Old 03-31-2019, 16:25   #788 (permalink)
aonemobile's Avatar
Member: 914059
Sonork: 121212
Thanks Meter: 34
ta-1118 frp done
Card found : 618EA76A , v0122
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
- > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage!
PTFN : MediaTek USB Port (COM7)
MODE : BOOTROM
PORT : 7
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : MODERN RAPHAEL
BROM : DSLevel : DEV_KEY+DEV_ARB
BROM : BOOTROM
AGENT : Found MT6765
AGENT : Nokia_All_InOne_DA_v03.2019.1303
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00040000 [ 256.00 KB ]
DRAM: 0xC0000000 [ 3.00 GB ]
EMMC: 90014A68423861503E0163E92EAF759F
EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP>
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x01000000 [ 16.00 MB ]
USER : 0x747C00000 [ 29.12 GB ]
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : FD156F39C7F926102FCEE65D274FFFCF
DA : USB : HIGH-SPEED
Boot done!
Format Ok : USERDATA
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:24
The Following 2 Users Say Thank You to aonemobile For This Useful Post:
Old 03-31-2019, 19:23   #789 (permalink)
CYB3R GSM's Avatar
Member: 2469611
Thanks Meter: 317
Nokia RM-1090 Contact Service Done
Verify files ...
MAUI : RM-1190_ROM_eMP_10.02.11
VIVA : RM-1190_VIVA_eMP_10.02.11
LANG : RM-1190_LANG_PACK_ROM_IC_eMP_10.02.11_001
CUST : RM-1190_CUSTPACK_ROM_IC_MEA_IQ_eMP_10.02.11_001
JMPT : RM-1190_JUMP_TABLE_IC_MEA_IQ_eMP_10.02.11_001
Wait for phone...
Phone found! [ 382 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0001
BB_CPU_SN : 98E153F9069B541F56EE8FCA2F2EB546
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
Project ID : DUBAI61D.11.00.11.p1
BROM/BL stage done
DA_eMP_Dubai.fg
DA_VERIFY : 00
DA_JUMP   : 00100000
DA_AUTH   : Passed!
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x8E
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32
[0] : FLASH_DIE : 00C8 0060 0016 0000
FAT_RANGE : 0x003A0000-0x003F7FFF , LEN : 0x00058000
SecureDecrypt : RM-1190_ROM_eMP_10.02.11
SecureDecrypt : RM-1190_VIVA_eMP_10.02.11
SecureDecrypt : RM-1190_LANG_PACK_ROM_IC_eMP_10.02.11_001
SecureDecrypt : RM-1190_CUSTPACK_ROM_IC_MEA_IQ_eMP_10.02.11_001
SecureDecrypt : RM-1190_JUMP_TABLE_IC_MEA_IQ_eMP_10.02.11_001
PHPID : DUBAI61D.11.00.11.p1
DA : FORMAT_BIN
FILES : 5
SAFE_BLOCK : 04
FORMAT_BIN : Ok
Write : RM-1190_ROM_eMP_10.02.11
Write : RM-1190_LANG_PACK_ROM_IC_eMP_10.02.11_001
Write : RM-1190_CUSTPACK_ROM_IC_MEA_IQ_eMP_10.02.11_001
Write : RM-1190_JUMP_TABLE_IC_MEA_IQ_eMP_10.02.11_001
Write : RM-1190_VIVA_eMP_10.02.11
CODE_DNLOAD : Ok
[VERIFY] DONE : RM-1190_ROM_eMP_10.02.11
[VERIFY] DONE : RM-1190_LANG_PACK_ROM_IC_eMP_10.02.11_001
[VERIFY] DONE : RM-1190_CUSTPACK_ROM_IC_MEA_IQ_eMP_10.02.11_001
[VERIFY] DONE : RM-1190_JUMP_TABLE_IC_MEA_IQ_eMP_10.02.11_001
[VERIFY] DONE : RM-1190_VIVA_eMP_10.02.11
CODE_VERIFY : Ok
Rebooting phone now
Flashing done!
Total flash time : 00:01:07
Reboot phone Ok
https://mega.nz/#!H3xnSKJL!Rgl5BxBcM...EtE0wK_P-LojFQ
The Following 2 Users Say Thank You to CYB3R GSM For This Useful Post:
Old 04-06-2019, 09:36   #790 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 764
Nokia 150 hang on logo done by best2
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.12
Open VPLfile : RM-1190_059X975_11.00.11.vpl
Description : RM-1190 059X975 IJ 11.00.11
DeviceType : RM-1190
ProductCode : 059X975
SoftwareVer : 11.00.11
PPM LangPack :
Load Ok!
Operation : Write FirmWare [ v1.12 ]
PTFN : Nokia USB Serial Port (COM8)
PORT : 8
BROM : Init BROM
BROM init passed!
BROM : MEID : 9D2781546402CE3464A7F68EEA23EE45
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : DA sent
DA : Sync Passed!
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
VPL SoftwareVersion : 11.00.11 [RM-1190]
DEV SoftwareVersion : 10.02.11
SWInfo compare result : DEVICE SW ( Minor version ) is LOWER, than in VPL!
Load FlashSet :
MROM : RM-1190_DUBAI_ROM_eMP_11.00.11
LANG : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11
CUST : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11
JUMP : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11
VIVA : RM-1190_DUBAI_VIVA_eMP_11.00.11
Prepare FlashSet :
DCR : RM-1190_DUBAI_ROM_eMP_11.00.11
DCR : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11
DCR : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11
DCR : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11
DCR : RM-1190_DUBAI_VIVA_eMP_11.00.11
Prepare Target
SDS : OK : 0x003F8000 : 0x00008000
FFS Format Ok!
Erase Target Flash
Erase done!
Write Target Flash
Write : RM-1190_DUBAI_ROM_eMP_11.00.11
Write : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11
Write : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11
Write : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11
Write : RM-1190_DUBAI_VIVA_eMP_11.00.11
Write flash done!
Verify : RM-1190_DUBAI_ROM_eMP_11.00.11
Verify : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11
Verify : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11
Verify : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11
Verify : RM-1190_DUBAI_VIVA_eMP_11.00.11
Done!
Elapsed: 00:01:23
Old 04-06-2019, 09:58   #791 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 764
Nokia 3310 3g reset password done by best2
Operation : Reset Settings ( Format FS ) [ v1.12 ]
Wait for device ...
Device Connected!
Port speed : 921600
Boot Done!
Erase BLK #0
Erase BLK #1
Erase BLK #2
Erase BLK #3
Format Ok!
Done!
Elapsed: 00:00:32
Old 04-06-2019, 10:19   #792 (permalink)
Member: 654997
Thanks Meter: 3,968
TA-1017 Change Language Done :)
Open VPLfile : TA1017_059Z1Z6_11.02.11.vpl
Description  : TA-1017 NDT MEA IJ BLACK FARSI IR
DeviceType   : TA-1017
ProductCode  : 059Z1Z6
PPM LangPack :
Load Ok!
Setting   : UserData erase : False
Setting   : LangPack Only : True
PORT : 246
BROM : Init BROM
BROM init passed!
BROM : MEID : A65FC243B29638BE6BAFDAE0F86A24C3
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : KESA61A.11.02.11.p1
AGENT : KESA61A.11.02.11.p1
BOOT : DA sent
DA : Sync Passed!
        NOR:
              STYPE  : 0x00000000
 STATUS : OK
Boot done!
VPL SoftwareVersion   : 11.02.11 [TA-1017]
Load FlashSet :
LANG : TA-1017_LANG_PACK_ROM_IJ_eMP_11.02.11_001
CUST : TA-1017_CUSTPACK_ROM_IJ_MEA_IR_eMP_11.02.11_001
JUMP : TA-1017_JUMP_TABLE_IJ_MEA_IR_eMP_11.02.11_001
Prepare FlashSet :
DCR : TA-1017_LANG_PACK_ROM_IJ_eMP_11.02.11_001
DCR : TA-1017_CUSTPACK_ROM_IJ_MEA_IR_eMP_11.02.11_001
DCR : TA-1017_JUMP_TABLE_IJ_MEA_IR_eMP_11.02.11_001
Prepare Target
SDS : OK : 0x007F8000 : 0x00008000
Erase Target Flash
Erase done!
Write Target Flash
Write : TA-1017_LANG_PACK_ROM_IJ_eMP_11.02.11_001
Write : TA-1017_CUSTPACK_ROM_IJ_MEA_IR_eMP_11.02.11_001
Write : TA-1017_JUMP_TABLE_IJ_MEA_IR_eMP_11.02.11_001
Write flash done!
Verify : TA-1017_LANG_PACK_ROM_IJ_eMP_11.02.11_001
Verify : TA-1017_CUSTPACK_ROM_IJ_MEA_IR_eMP_11.02.11_001
Verify : TA-1017_JUMP_TABLE_IJ_MEA_IR_eMP_11.02.11_001
Done!
Elapsed: 00:00:43
The Following User Says Thank You to syed tuqeer For This Useful Post:
Old 04-07-2019, 14:04   #793 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Nokia 206 FullFlash Done
MCU : rm872__04.52.mcusw
PPM : rm872__04.52.ppm_m2
CNT : rm872__04.52.image_m2_059Q4J7
Check files done...
IF Boot Init : 0xF0
IF Resp Len : 0x0A
EBL Loader Ok, 01
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.53_M1S1
FLASHID : EC001230
Boot done!
Check keys...
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 351716063243600
IMEI 2 : 351716063243618
PCcode : 059Q4L3
RPL saved : C:\InfinityBox\BEST\Backup\Cert\351716063243600_XG 213_CRT.rpl
File : rm872__04.52.mcusw
Image : rm872__04.52.mcusw_ebl_psi.fls
Sec-pack sent
Found 5 region(s)
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Erase done, time : 00:00:02
Flashing , wait ...
Erase , Start : 0x40280000 , Len : 0x01800000
Erasing, wait ...
Erase done, time : 00:00:49
Write , Start : 0x40280000 , Len : 0x01800000
Flashing , wait ...
Region flash done, time : 00:00:29
Erasing, wait ...
No write data, skip
CRC check passed , 0xFA4D
File : rm872__04.52.ppm_m2
Image : package_m2.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Erase , Start : 0x41A80000 , Len : 0x00680000
Erasing, wait ...
Erase done, time : 00:00:11
Write , Start : 0x41A80000 , Len : 0x003C68F0
Flashing , wait ...
CRC check passed , 0xC9E6
File : rm872__04.52.image_m2_059Q4J7
Image : package_m2_059Q4J7.image.fls
Sec-pack sent
Found 2 region(s)
Erase , Start : 0x42100000 , Len : 0x01D20000
Erasing, wait ...
Erase done, time : 00:01:03
Write , Start : 0x42100000 , Len : 0x01040000
Flashing , wait ...
Erasing, wait ...
No write data, skip
CRC check passed , 0x5521
Flashing done!
Total flash time : 00:03:05
Reboot phone now...
Connected phone - 206
Software Info: V 04.52 30-06-13 RM-872 (c) Nokia
IMEI: 351716063243600
PPM version : V 04.52 30-06-13 RM-872 (c) Nokia M2
Product code: 059Q4L3
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 58 certs
Done!
Elapsed: 00:04:01
Old 04-07-2019, 15:28   #794 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 764
Nokia 2 reset frp done by nokia best2
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.09
2. Use BOOT JIG or EDL cable!
3. Insert USB cable, press "POWER_ON" button few times, if need
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 210 [MSM8909]
BB_IDC_SWB : 00000000
ID_BLOCK_S : 12F9205A
ID_BLOCK_I : 009600E1
ID_BLOCK_L : 565CB9899B112DBAF328A9A33534E92B
ID_BLOCK_L : 8BB9AE5256BB65307A11A55CE97F96D1
Use BEST Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:19
The Following 2 Users Say Thank You to A.G.Shahid For This Useful Post:
Old 04-08-2019, 07:12   #795 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 578
Nokia 105 ta-1034
Open VPLfile : TA-1034_059Z0X8_10.02.11.vpl
Description : TA-1034 IJ
DeviceType : TA-1034
ProductCode : 059Z0X8
SoftwareVer : 10.02.11
PPM LangPack :
Load Ok!
PTFN : Nokia USB Serial Port (COM20)
PORT : 20
BROM : Init BROM
BROM init passed!
BROM : MEID : 17C3FC2A0DFCE56241394A849F160D41
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PRJ : N103.11.00.11.p1
BOOT : SWR : 11.00.11
AGENT : N103.11.00.11.p1
BOOT : DA sent
DA : Sync Passed!
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
VPL SoftwareVersion : 10.02.11 [TA-1034]
DEV SoftwareVersion : 11.00.11
SWInfo compare result : VPL SW ( Minor version ) is LOWER, than in DEVICE!
Load FlashSet :
MROM : TA-1034_ROM_eMP_10.02.11
LANG : TA-1034_LANG_PACK_ROM_IJ_eMP_10.02.11_001
CUST : TA-1034_CUSTPACK_ROM_IJ_eMP_10.02.11_001
JUMP : TA-1034_JUMP_TABLE_IJ_eMP_10.02.11_001
VIVA : TA-1034_VIVA_eMP_10.02.11
Prepare FlashSet :
DCR : TA-1034_ROM_eMP_10.02.11
DCR : TA-1034_LANG_PACK_ROM_IJ_eMP_10.02.11_001
DCR : TA-1034_CUSTPACK_ROM_IJ_eMP_10.02.11_001
DCR : TA-1034_JUMP_TABLE_IJ_eMP_10.02.11_001
DCR : TA-1034_VIVA_eMP_10.02.11
Prepare Target
FFS Format Ok!
Erase Target Flash
Erase done!
Write Target Flash
Write : TA-1034_ROM_eMP_10.02.11
Write : TA-1034_LANG_PACK_ROM_IJ_eMP_10.02.11_001
Write : TA-1034_CUSTPACK_ROM_IJ_eMP_10.02.11_001
Write : TA-1034_JUMP_TABLE_IJ_eMP_10.02.11_001
Write : TA-1034_VIVA_eMP_10.02.11
Write flash done!
Verify : TA-1034_ROM_eMP_10.02.11
Verify : TA-1034_LANG_PACK_ROM_IJ_eMP_10.02.11_001
Verify : TA-1034_CUSTPACK_ROM_IJ_eMP_10.02.11_001
Verify : TA-1034_JUMP_TABLE_IJ_eMP_10.02.11_001
Verify : TA-1034_VIVA_eMP_10.02.11
Done!
Elapsed: 00:01:15
The Following User Says Thank You to Luckey1 For This Useful Post:
Page generated in 0.33221 seconds with 8 queries
