04-24-2019, 15:08 | #811 (permalink) |
No Life Poster Join Date: Sep 2009 Location: Hello Online Service
Member: 1126941 Status: Offline Sonork: 100.1672154 Thanks Meter: 2,488 | nokia 3.1 plus (ta-1118) frp one click by best TA-1118 VERSION 8.1 FRP ONE CLICK TESTED (boot key - both volume ) Card found : 19FEBXXX, v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.15 Operation : Identify [ v1.15 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM34) MODE : BOOTROM PORT : 34 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_ARB BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6765 AGENT : Nokia_All_InOne_DA_v04.2019.0804 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100474436424D4201882D90D4755B EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GD6BMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 83EC276055E5F474774E27F6FAFB93B5 DA : USB : HIGH-SPEED Boot done! --- SysInfoSub [PART A]: Sec. Patch : 2019-03-05 Patch Level : PPR1.180610.011 Display ID : 0001_2_23A Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-03-05 Build Time : 1552317343 Product Model : FIH-ROO Product Brand : alps Product Name : fih_mt6762_64_0001 Product Device : ROO_sprout Product Manfct : alps Product Info : fih_mt6762_64 Product Board : fih_mt6762_64 Board Platform : mt6765 --- SysInfoSub [PART B]: Sec. Patch : 2019-02-05 Patch Level : PPR1.180610.011 Display ID : 0001_2_230 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-02-05 Build Time : 1548958676 Product Model : FIH-ROO Product Brand : alps Product Name : fih_mt6762_64_0001 Product Device : ROO_sprout Product Manfct : alps Product Info : fih_mt6762_64 Product Board : fih_mt6762_64 Board Platform : mt6765 --- SecuritySub : NVRAM check : Passed! Done! Elapsed: 00:00:22 Reconnect Power/Cable! Operation : Reset Settings [ v1.15 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM34) MODE : BOOTROM PORT : 34 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_ARB BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6765 AGENT : Nokia_All_InOne_DA_v04.2019.0804 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100474436424D4201882D90D4755B EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GD6BMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 83EC276055E5F474774E27F6FAFB93B5 DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : RESET PROTECTION Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
The Following User Says Thank You to mobi_soft For This Useful Post: |
04-24-2019, 16:44 | #812 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Poland
Member: 1846735 Status: Offline Sonork: 100.1657479 Thanks Meter: 190 | Nokia 3310 2017 DUAL SIM TA1006 firmware update + phone code reset DONE Firmware update (from infinity sever) and reset phone code from TA-1006 sw ver. 13.0.0.17.01 to ver. 20.0.0.17.00 WARNING!! If you connect phone to usb and BEST not read phone, update SCI driver from here CM2SPD_Drivers_v1.02 install it and update manually from folder 2015-xx , need to detect in device manager "SPRD U2S Diag" and try again connect phone BOOT key is "#" or "0 and #" both Operation : Write FirmWare [ v1.15 ] Setting : False : Full Factory Reset Setting : True : NVRAM Update/Swap 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : SPRD SECURE BOOT Block version BootVersion : BEST RETRO3G Port speed : 921600 FDL Flash : Control transfered! Boot Done! [NVM] : Initialize SRC [NVM] : Initialize DST [NVM] : Prepare [NVM] : SWP : 0x000B : 0x000A [NVM] : Update [NVM] : Update Ok! Flash : KERNELIMG Flash : BOOTLOADER Flash : USERIMG Flash : MMIRES Flash : DSPCODE Flash : DSPCODE2 Erase : ERASE AUTOSMS Erase : ERASE PRELOAD Flash : PRELOAD Erase : FLASH Flashing finished! Done! Elapsed: 00:01:19 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to rudy178 For This Useful Post: |
04-25-2019, 13:01 | #813 (permalink) |
No Life Poster Join Date: Jan 2015 Location: STATE OF JAMMU & KASHMIR
Member: 2327602 Status: Offline Sonork: 100.1620953 Thanks Meter: 276 | NOKIA 3310 3G TA-1006 USER CODE FORMAT IN ONE CLICK WITH InfinityBox BEST2 NOKIA 3310 3G TA-1006 USER CODE FORMAT IN ONE CLICK WITH InfinityBox BEST2 Operation : Reset Settings ( Format FS ) [ v1.15 ] 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : SPRD SECURE BOOT Block version BootVersion : BEST RETRO3G Port speed : 921600 FDL Flash : Control transfered! Boot Done! Erase BLK #0 Erase BLK #1 Erase BLK #2 Erase BLK #3 Format Ok! Done! Elapsed: 00:00:47 Reconnect Power/Cable! |
The Following User Says Thank You to shazzmob For This Useful Post: |
04-28-2019, 14:50 | #814 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 216 Format done Operation : Reset Settings [ v1.15 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM20) MODE : NOKIA USB SERIAL PORT : 20 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : E19F90390D0ABC970A51DA7C587692D0 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : SUEZ.12.00.11.p1 BOOT : SWR : 12.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : SUEZ.12.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00CE0000 : 0x00314000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:39 Reconnect Power/Cable! |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
04-29-2019, 12:20 | #815 (permalink) |
Freak Poster Join Date: Jan 2012 Location: Sylhet Korim Ullah Market Age: 28
Member: 1714226 Status: Offline Sonork: 100.1683394 Thanks Meter: 243 | Ta-1022 3310 user lock reset done by Best nk2 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : SPRD SECURE BOOT Block version BootVersion : BEST RETRO3G Port speed : 921600 FDL Flash : Control transfered! Boot Done! Erase BLK #0 Erase BLK #1 Erase BLK #2 Erase BLK #3 Format Ok! Done! Elapsed: 00:00:37 Reconnect Power/Cable! Last edited by rubelgsm; 04-29-2019 at 12:24. Reason: Nokia-3310 Ta-1022 user lock reset done by Best nk2 |
The Following 2 Users Say Thank You to rubelgsm For This Useful Post: |
04-29-2019, 14:59 | #816 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Great India
Member: 1615596 Status: Offline Sonork: 100.160704? Thanks Meter: 760 | Microsoft 550-DS RM-1127 Flashing done. Code: Connect phone on selected interface... SSChannel : Create SC SSChannel : SC Created! ProductID HWCode : RM-1127 Selected Variant : RM-1127 VAR IMEA A7 CV WinPh OS Version : 10.0.10586.494 Firmware Version : 01078.00042.16352.50005 Platform Version : WP10 SSChannel : DC Ok with code 0x05 Switch to IDM now ... IDM initializing, wait... Checking access to Products folder... Folder for RM-1127 not exist. Attempt to create Prepare done, collect info [Query] : CustomerNvi_01078.00042.16352.50005_15316_3187d248c7e938099593932d7fba726b.nvi , 98.50 KiB [Query] : MS_MirrorLink_template_prod_v3.cer , 1.11 KiB [Query] : RetailModeNvi_1_01078.00042.16352.50005_15316_7fc7ba76d38d16fccb688eb9b4e59677.nvi , 1.22 KiB [Query] : RM1127_059X5V9_01078.00042.16352.50005_039.vpl , 4.84 KiB [Query] : RM1127_1078.0042.10586.13333.15316.03531B_retail_prod_signed.ffu , 1.81 GiB Files to download : 5 Total size to download : 1.81 GiB Downloading now, please, wait... [Download] : CustomerNvi_01078.00042.16352.50005_15316_3187d248c7e938099593932d7fba726b.nvi [Download] : MS_MirrorLink_template_prod_v3.cer [Download] : RetailModeNvi_1_01078.00042.16352.50005_15316_7fc7ba76d38d16fccb688eb9b4e59677.nvi [Download] : RM1127_059X5V9_01078.00042.16352.50005_039.vpl [Download] : RM1127_1078.0042.10586.13333.15316.03531B_retail_prod_signed.ffu Verify files now ... [Verify Ok] : RM1127_1078.0042.10586.13333.15316.03531B_retail_prod_signed.ffu [Verify Ok] : CustomerNvi_01078.00042.16352.50005_15316_3187d248c7e938099593932d7fba726b.nvi [Verify Ok] : RetailModeNvi_1_01078.00042.16352.50005_15316_7fc7ba76d38d16fccb688eb9b4e59677.nvi [Verify Ok] : MS_MirrorLink_template_prod_v3.cer All done, all files were downloaded! Core : v2.29 , WP10x FlashEngine : v3.2 FFU : RM1127_1078.0042.10586.13333.15316.03531B_retail_prod_signed.ffu Checking FFU file, wait... FFU Revision ID : 2.0 FFU Model ID : Microsoft.MSM8909.P6236 FFU RootKeyHash : 0000000000000000000000000000000000000000 FFU ChipSectors : 15154944 FFU Header : 0x000E0000 FFU Payload : 0x74100000 FFU FastVerify : Ok Waiting for phone... Dead mode is selected , no phone in normal mode found 1. Press and hold "Volume Down" 2. Insert USB cable 3. Hold button until phone will be detected Device catched in BOOT mode! Boot Mode confirmed! Setting Preloder Collect Info... Setting Application Setting Secure Collect Info... === Nokia Flash App info : Protocol Version : 2.41 Protocol Implementation : 2.75 === Phone Initial info : Phone RMxxx ID : RM-1127 Phone Model ID : Microsoft.MSM8909.P6236.2.0 Phone Model PC : 059X5V9 Phone IMEI : 353691078194767 === eMMC info : eMMC Vendor : Toshiba eMMC CID : 0011 eMMC Size : 7456 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : 56BDC3746226E080146D4D30C8C8432657A5282F === Other info : SD present : True , 002C7600 Full Check skipped , will be checked by ImageSignature Battery Level : 92% RPMB Provision Status Code : 0x0101 Device RAM size : 1024 MiB Device have ATRP (AntiTheft) system! Backup to RAM Ok! FFU : RM1127_1078.0042.10586.13333.15316.03531B_retail_prod_signed.ffu Flashing FFU Sending FFU Header CertData Header sent , accepted :) Perform Data Partition Erase Erase done Sending FFU Payload Data... Finishing flashing Flashing done! Green Light :) Image Sent, processing PostFlash FinalConfig : Ok , Status : Normal Make Factory Set : Ok Restore RAMBkp : Ok Update NVI from Image Ok , NVI will be updated on first boot! PostFlash Finished Total flash time : 00:05:06 |
The Following User Says Thank You to .::Gsm-Play::. For This Useful Post: |
04-29-2019, 17:17 | #817 (permalink) |
No Life Poster Join Date: Oct 2005 Location: pakistan
Member: 188374 Status: Offline Sonork: 1000.2 Thanks Meter: 203 | nokia 210 (2019) URDU Flash successfuly. Infinity Best NK2 VER 1.15 Success Report. PTFN : MediaTek PreLoader USB VCOM Port (COM8) MODE : NOKIA USB SERIAL PORT : 8 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 8EC2A48DF6EA4F18862814AB54590E92 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : OUTRUN.10.01.11.p1 BOOT : SWR : 10.01.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : OUTRUN.10.01.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 10.01.11 [TA-1139] DEV SoftwareVersion : 10.01.11 SWInfo compare result : SAME Load FlashSet : MROM : TA-1139_ROM_eMP_10.01.11 LANG : TA-1139_LANG_PACK_ROM_IJ_eMP_10.01.11_001 CUST : TA-1139_CUSTPACK_ROM_IJ_eMP_10.01.11_001 JUMP : TA-1139_JUMP_TABLE_IJ_eMP_10.01.11_001 VIVA : TA-1139_VIVA_eMP_10.01.11 Prepare FlashSet : DCR : TA-1139_ROM_eMP_10.01.11 DCR : TA-1139_LANG_PACK_ROM_IJ_eMP_10.01.11_001 DCR : TA-1139_CUSTPACK_ROM_IJ_eMP_10.01.11_001 DCR : TA-1139_JUMP_TABLE_IJ_eMP_10.01.11_001 DCR : TA-1139_VIVA_eMP_10.01.11 Prepare Target SDS : OK : 0x00FF4000 : 0x0000C000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : TA-1139_ROM_eMP_10.01.11 Write : TA-1139_LANG_PACK_ROM_IJ_eMP_10.01.11_001 Write : TA-1139_CUSTPACK_ROM_IJ_eMP_10.01.11_001 Write : TA-1139_JUMP_TABLE_IJ_eMP_10.01.11_001 Write : TA-1139_VIVA_eMP_10.01.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1139_ROM_eMP_10.01.11 Verify : TA-1139_LANG_PACK_ROM_IJ_eMP_10.01.11_001 Verify : TA-1139_CUSTPACK_ROM_IJ_eMP_10.01.11_001 Verify : TA-1139_JUMP_TABLE_IJ_eMP_10.01.11_001 Verify : TA-1139_VIVA_eMP_10.01.11 Done! Elapsed: 00:02:34 Reconnect Power/Cable! |
The Following User Says Thank You to papoo For This Useful Post: |
04-30-2019, 13:58 | #818 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 105 ta 1034 reset password & backup flash file done by best2 Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.15 Operation : Identify [ v1.15 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM14) MODE : NOKIA USB SERIAL PORT : 14 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCA02 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 7112801715EA6424614B0BB8252205E2 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.30.04.11.p1 BOOT : SWR : 30.04.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : N103.30.04.11.p1 FLASH : 00C2 : 0025 : 0036 : 0000 BBSN : 7112801715EA6424614B0BB8252205E2 PRDC : 059Z107 IMEI[1] : IMEI[2] : NCK : 20 digits PROV : 24407000 Saved as : 35898xxxxxxxxxx.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:01:03 Reconnect Power/Cable! Operation : Reset Settings [ v1.15 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM14) MODE : NOKIA USB SERIAL PORT : 14 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCA02 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 7112801715EA6424614B0BB8252205E2 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.30.04.11.p1 BOOT : SWR : 30.04.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.30.04.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C2 : 0020 : 0016 : 0000 NOR: [MXIC] MX25L3291FWJI_09 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00370000 : 0x00088000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:25 Reconnect Power/Cable! Operation : Read FirmWare [ v1.15 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM14) MODE : NOKIA USB SERIAL PORT : 14 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCA02 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 7112801715EA6424614B0BB8252205E2 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.30.04.11.p1 BOOT : SWR : 30.04.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : N103.30.04.11.p1 FLASH : 00C2 : 0025 : 0036 : 0000 CODE : 0x00370000 Reading Flash ... TDSN : TA-1034 PRDC : 059Z107 PPM : IJ LANG : [1] : Urdu (Islamic Republic of Pakistan) [2] : English (United Kingdom) BUILD : TA-1034_ROM_eMP_30.04.11 BUILD : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001 BUILD : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001 BUILD : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001 BUILD : TA-1034_VIVA_eMP_30.04.11 Make VPL definition Save Path : C:\TA-1034\ Save Name : TA-1034_059Z107_30.04.11.vpl Build Finished! Done! Elapsed: 00:06:08 Reconnect Power/Cable! |
The Following User Says Thank You to A.G.Shahid For This Useful Post: |
04-30-2019, 15:45 | #819 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 210 ta-1039 backup flash file done by best2 Card found : 30C22462 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.15 Operation : Identify [ v1.15 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM14) MODE : NOKIA USB SERIAL PORT : 14 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 6838BF73B4954A6B9624822994C36F82 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : OUTRUN.10.01.11.p1 BOOT : SWR : 10.01.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : OUTRUN.10.01.11.p1 FLASH : 00EF : 0060 : 0018 : 0000 PRDC : 059Z0X8 IMEI[1] : IMEI[2] : NCK : 20 digits PROV : 24407000 Saved as : 352xxxxxxxxxxxx.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:01:08 Reconnect Power/Cable! Operation : Read FirmWare [ v1.15 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM14) MODE : NOKIA USB SERIAL PORT : 14 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 6838BF73B4954A6B9624822994C36F82 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : OUTRUN.10.01.11.p1 BOOT : SWR : 10.01.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : OUTRUN.10.01.11.p1 FLASH : 00EF : 0060 : 0018 : 0000 CODE : 0x00C40000 Reading Flash ... TDSN : TA-1139 PRDC : 059Z0X8 PPM : IJ LANG : [1] : Urdu (Islamic Republic of Pakistan) [2] : English (United Kingdom) BUILD : TA-1139_ROM_eMP_10.01.11 BUILD : TA-1139_LANG_PACK_ROM_IJ_eMP_10.01.11_001 BUILD : TA-1139_CUSTPACK_ROM_IJ_eMP_10.01.11_001 BUILD : TA-1139_JUMP_TABLE_IJ_eMP_10.01.11_001 BUILD : TA-1139_VIVA_eMP_10.01.11 Make VPL definition Save Path : C:\TA-1139\ Save Name : TA-1139_059Z0X8_10.01.11.vpl Build Finished! Done! Elapsed: 00:19:34 Reconnect Power/Cable! |
05-02-2019, 08:13 | #820 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 105 TA-1034 Operation : Reset Settings [ v1.09 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM20) MODE : NOKIA USB SERIAL PORT : 20 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 0CB0F0A826D27722A644A2CD51423F92 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.10.02.11.p1 BOOT : SWR : 10.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.10.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00370000 : 0x00088000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
05-02-2019, 09:51 | #821 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Ta-1034 Operation : Reset Settings [ v1.09 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM20) MODE : NOKIA USB SERIAL PORT : 20 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 7607CF44B3CB70B99C4ED2195D5E50CF BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.30.04.11.p1 BOOT : SWR : 30.04.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.30.04.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8E NOR: 00C8 : 0060 : 0016 : 0000 NOR: [GigaDevice] GD25LQ32 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00370000 : 0x00088000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:52 Reconnect Power/Cable! |
05-02-2019, 13:15 | #822 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 225 Format Done With Best Operation : Reset Settings [ v1.09 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM20) MODE : NOKIA USB SERIAL PORT : 20 BROM : Init BROM BROM init passed! CHIP : MT625A , SBID : 0xCA01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 6DBEC826EB37FCD881DBEBDC1CC175EA BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : Rivendell.30.06.11.p1 BOOT : SWR : 30.06.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT625A AGENT : Rivendell.30.06.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x88 NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00A60000 : 0x00594000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:01:44 Reconnect Power/Cable! |
05-05-2019, 06:20 | #823 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 216 Format Done Operation : Reset Settings [ v1.09 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM44) MODE : NOKIA USB SERIAL PORT : 44 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : B450F138E1482929D5650343B070F814 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : SUEZ.40.00.11.p1 BOOT : SWR : 40.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : SUEZ.40.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0060 : 0018 : 0000 NOR: [WINBOND] W25Q128FW NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00CE0000 : 0x00314000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
05-06-2019, 07:08 | #824 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 110 FullFlash Done Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm827__03.51.mcusw PPM : rm827__03.51.ppm_m2 CNT : rm827__03.51.image_m2_059N2R0 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.49_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 351970053287800 IMEI 2 : 351970053287818 PCcode : 059N2R0 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\351970053287800_XG 213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm827__03.51.mcusw Image : rm827__03.51.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:02:20 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:30 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xA3D6 ===Flashing [PPM]=== File : rm827__03.51.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:17 Write , Start : 0x41BC0000 , Len : 0x0030F748 Flashing , wait ... Region flash done, time : 00:00:03 CRC check passed , 0x4605 ===Flashing [CNT]=== File : rm827__03.51.image_m2_059N2R0 Image : package_m2_059N2R0.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:04:33 Write , Start : 0x421C0000 , Len : 0x00F20000 Flashing , wait ... Region flash done, time : 00:00:23 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:08 No write data, skip CRC check passed , 0x2091 Flashing done! Total flash time : 00:08:28 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 110 Software Info: V 03.51 06-08-13 RM-827 (c) Nokia IMEI: 351970053287800 PPM version : V 03.51 06-08-13 RM-827 (c) Nokia M2 Product code: 059N2R0 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:09:13 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
05-06-2019, 07:31 | #825 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Rm-1133 Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1133_ROM_eMP_13.00.11 VIVA : RM-1133_VIVA_eMP_13.00.11 LANG : RM-1133_LANG_PACK_ROM_IJ_eMP_13.00.11_002 CUST : RM-1133_CUSTPACK_ROM_IJ_MEA_PK_eMP_13.00.11_002 JMPT : RM-1133_JUMP_TABLE_IJ_MEA_PK_eMP_13.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 44 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 51A71C53045C42D35C52588A2EAF1B3E BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : LAGOS61D.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Lagos.fg DA_VERIFY : 00 DA_JUMP : 00100000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x00368000-0x003F7FFF , LEN : 0x00090000 SecureDecrypt : RM-1133_ROM_eMP_13.00.11 SecureDecrypt : RM-1133_VIVA_eMP_13.00.11 SecureDecrypt : RM-1133_LANG_PACK_ROM_IJ_eMP_13.00.11_002 SecureDecrypt : RM-1133_CUSTPACK_ROM_IJ_MEA_PK_eMP_13.00.11_002 SecureDecrypt : RM-1133_JUMP_TABLE_IJ_MEA_PK_eMP_13.00.11_002 OVRLP : 000069B900000001 PHPID : LAGOS61D.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1133_ROM_eMP_13.00.11 Write : RM-1133_LANG_PACK_ROM_IJ_eMP_13.00.11_002 Write : RM-1133_CUSTPACK_ROM_IJ_MEA_PK_eMP_13.00.11_002 Write : RM-1133_JUMP_TABLE_IJ_MEA_PK_eMP_13.00.11_002 Write : RM-1133_VIVA_eMP_13.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1133_ROM_eMP_13.00.11 [VERIFY] DONE : RM-1133_LANG_PACK_ROM_IJ_eMP_13.00.11_002 [VERIFY] DONE : RM-1133_CUSTPACK_ROM_IJ_MEA_PK_eMP_13.00.11_002 [VERIFY] DONE : RM-1133_JUMP_TABLE_IJ_MEA_PK_eMP_13.00.11_002 [VERIFY] DONE : RM-1133_VIVA_eMP_13.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00368000-0x003F7FFF , LEN : 0x00090000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:00 Reboot phone Ok |
