06-03-2017, 10:16 | #91 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 105 Write Firmware Done :) Code: Connect phone on selected interface... Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm908_003.400 PPM : rm908_003.40ic CNT : rm9080_nai03.40ic Infineon flashing... Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 PBL : Dynamic Boot Ok , 01AB SBL : Dynamic Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH VEN : 000000EF FLASH DIE : 00006017 FLASH ID : UNKNOW [Not In Base] Boot Done! ===Flashing [MCU]=== File : rm908_003.400 Image : hw_f31_rm908_62_mcusw_03.40_Best.fls Cert block found, sending.... Cert sent Found 3 region(s) Processing Region 1/3 Erase , Start : 0x00800000 , Len : 0x00210000 Erasing, wait ... Erase done Write , Start : 0x00800000 , Len : 0x00210000 Flashing , wait ... Region flash done Processing Region 2/3 Erase , Start : 0x00C60000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00C60000 , Len : 0x00221240 Flashing , wait ... Region flash done Processing Region 3/3 Erase , Start : 0x00FFC000 , Len : 0x00004000 Erasing, wait ... Erase done Write , Start : 0x00FFC000 , Len : 0x00000040 Flashing , wait ... Region flash done Check : 5960 ===Flashing [PPM]=== File : rm908_003.40ic Image : hw_f31_rm908_62_ppm_03.40ic_Best.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00210000 , Len : 0x00250000 Erasing, wait ... Erase done Write , Start : 0x00210000 , Len : 0x001C5A00 Flashing , wait ... Region flash done Check : 06A7 ===Flashing [CNT]=== File : rm9080_nai03.40ic Image : hw_f31_rm908_62_image_03.40ic_Best.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00EB0000 , Len : 0x000D0000 Erasing, wait ... Erase done Write , Start : 0x00EB0000 , Len : 0x000661C0 Flashing , wait ... Region flash done Check : 919A Flashing done, rebooting... -> Infineon info : Do FullFactory Sets after flashing Flashing Done! Init Service mode... Wait... Afterflash settings... SW ver : V 03.40 08-08-13 RM-908 (c) Nokia IMEI : 358134054959718 PCode : 059R449 Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! All done! Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... SW ver : V 03.40 08-08-13 RM-908 (c) Nokia IMEI : 358134054959718 PPM : V 03.40 08-08-13 RM-908 (c) Nokia IC PCode : 059R449 BPCode : 059Q858 HWID : 1000 LCDVer : CMI:BEIHAIv01 ILI9163C IMEI : 358134054959718 Sl Conf : 001-01-00000000000 Sl Prof : 000000000004000-2 Sl Aux : 000B0000 Hw Sig : 070F24A80FEF6A2C Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Done! Connect phone on selected interface... Phone disconected! Connect phone on selected interface... |
The Following 2 Users Say Thank You to syed tuqeer For This Useful Post: |
06-04-2017, 09:05 | #92 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 206 Write Firmware Done Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm872__04.52.mcusw PPM : rm872__04.52.ppm_m2 CNT : rm872__04.52.image_m2_059Q8L5 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 353072061180925 IMEI 2 : 353072061180933 PCcode : 059Q4J7 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\353072061180925_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm872__04.52.mcusw Image : rm872__04.52.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:00:49 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:34 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xFA4D ===Flashing [PPM]=== File : rm872__04.52.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00680000 Erasing, wait ... Erase done, time : 00:00:08 Write , Start : 0x41A80000 , Len : 0x003C68F0 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xC9E6 ===Flashing [CNT]=== File : rm872__04.52.image_m2_059Q8L5 Image : package_m2_059Q8L5.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:01:09 Write , Start : 0x42100000 , Len : 0x01040000 Flashing , wait ... Region flash done, time : 00:00:21 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0xDE0E Flashing done! Total flash time : 00:03:15 Reboot phone now... Reading Phone Info.... Connected phone - 206 Software Info: V 04.52 30-06-13 RM-872 (c) Nokia IMEI: 353072061180925 PPM version : V 04.52 30-06-13 RM-872 (c) Nokia M2 Product code: 059Q4J7 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:08 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 6 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
06-06-2017, 11:22 | #93 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Esam Telecom Age: 43
Member: 696206 Status: Offline Sonork: 100.1597401 Thanks Meter: 262 | Nokia 3310 TA-1030 Nokia 3310 TA-1030 Reset User Code done Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 10.03.11_2 00-00-00 TA-1030 IMEI 1 : 356002080851666 IMEI 2 : 356002080851674 XappVer : 000008F2 Ape Ver : NEMO G 4122fe8d/1 (00000000+0) T Thu Dec 29 01:31:09 2016 U d61db836 PPM : MS CNT : RETRO.10.03.11_2.p1 Product SN : 08D5E8EBU Product code : 059Z008 Base Prd.code: 059X9P0 Module code : 0207217 Hardware info======= HWID : 1000 LCDVer: TPO Lock info =========== IMEI : 356002080851666 IMEI spNet : 3A 65 00 02 08 58 61 66 Conf key : 800000000004000B Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; SimLock status : Ok Security status : Ok Done! Software Info: 10.03.11_2 00-00-00 TA-1030 IMEI: 356002080851666 PPM version : MS Product code: 059Z008 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 160 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 5A1CC13DE7BF772B26767A38D809282F BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Read flash done Reading Phone Info.... Software ver : 10.03.11_2 00-00-00 TA-1030 IMEI 1 : 356002080851666 IMEI 2 : 356002080851674 XappVer : 000008F2 Ape Ver : NEMO G 4122fe8d/1 (00000000+0) T Thu Dec 29 01:31:09 2016 U d61db836 PPM : MS CNT : RETRO.10.03.11_2.p1 Product SN : 08D5E8EBU Product code : 059Z008 Base Prd.code: 059X9P0 Module code : 0207217 Hardware info======= HWID : 1000 LCDVer: TPO Lock info =========== IMEI : 356002080851666 IMEI spNet : 3A 65 00 02 08 58 61 66 Conf key : 800000000004000B Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; SimLock status : Ok Security status : Ok Done! Software Info: 10.03.11_2 00-00-00 TA-1030 IMEI: 356002080851666 PPM version : MS Product code: 059Z008 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 160 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 5A1CC13DE7BF772B26767A38D809282F BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : RETRO.10.03.11_2.p1 BROM/BL stage done Configure RAMINIT Ok Reading flash now ... Done! Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive Mobile Info IMEI : 356002080851666 BBUID : 5A1CC13DE7BF772B26767A38D809282F PCCode: 059Z008 SimLock Info : STATE : OPENED ( NOT LOCKED ) Dump Saved to : 356002080851666_MTKx.bin RPL Saved to : 356002080851666_MTKx.mtsec Read Done! Connect phone on selected interface... |
The Following 4 Users Say Thank You to mdmosheur For This Useful Post: |
06-06-2017, 14:58 | #94 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Old is Gold Nokia E5-00 Flashing Done With Best Code: SSChannel : Create SC SSChannel : SC Created! ProductID HWCode : RM-632 Selected Variant : RM-632 CTR BLACK MEA7 QW COM ENG PK Firmware Version : 101.003 Platform Version : Symbian SSChannel : DC Ok with code 0x06 Switch to IDM now ... IDM initializing, wait... Checking access to Products folder... Folder for RM-632 not exist. Attempt to create Prepare done, collect info [Query] : RM632_0595222_101.003_001.vpl , 4.25 KiB [Query] : rm632_101.003_27.01_MEA_A_prd.rofs2.fpsx , 54.76 MiB [Query] : rm632_101.003_C00.01_DEFAULT_prd.rofs3.fpsx , 8.43 MiB [Query] : rm632_101.003_prd.core.fpsx , 102.31 MiB [Query] : rm632_101.003_U010.000_prd.uda.fpsx , 24.20 MiB [Query] : RM-632_data_block , 4.02 KiB Files to download : 6 Total size to download : 189.71 MiB Downloading now, please, wait... [Download] : RM632_0595222_101.003_001.vpl [Download] : rm632_101.003_27.01_MEA_A_prd.rofs2.fpsx [Download] : rm632_101.003_C00.01_DEFAULT_prd.rofs3.fpsx [Download] : rm632_101.003_prd.core.fpsx [Download] : rm632_101.003_U010.000_prd.uda.fpsx [Download] : RM-632_data_block Verify files now ... [Verify Ok] : RM-632_data_block [Verify Ok] : rm632_101.003_prd.core.fpsx [Verify Ok] : rm632_101.003_27.01_MEA_A_prd.rofs2.fpsx [Verify Ok] : rm632_101.003_C00.01_DEFAULT_prd.rofs3.fpsx [Verify Ok] : rm632_101.003_U010.000_prd.uda.fpsx All done, all files were downloaded! Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm632_101.003_prd.core.fpsx PPM : rm632_101.003_27.01_MEA_A_prd.rofs2.fpsx PPM2 : rm632_101.003_C00.01_DEFAULT_prd.rofs3.fpsx CNT : rm632_101.003_U010.000_prd.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> Check SW version... FlashFile version : 101.003 Phone version : 101.003 -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 0250010457D6034462B5395F0B175F6BA9C027CF ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00500020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 355949046246202 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\355949046246202.rpl === SW Version Check === - > REFLASHING === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm632_101.003_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:03 Write : Processing rm632_101.003_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 433 blocks TIME : Write time : 00:00:16 MCU Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [PPM]=== Erase : Processing rm632_101.003_27.01_MEA_A_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm632_101.003_27.01_MEA_A_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 221 blocks TIME : Write time : 00:00:08 PPM Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [PPM2]=== Erase : Processing rm632_101.003_C00.01_DEFAULT_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm632_101.003_C00.01_DEFAULT_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 35 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [CNT]=== Erase : Processing rm632_101.003_U010.000_prd.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:03 Write : Processing rm632_101.003_U010.000_prd.uda.fpsx Total writen 97 blocks TIME : Write time : 00:00:05 CNT Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ADL: Close_Session Content: 000300000000030000000300000000 ADL: Reboot Flashing done! Total flash time : 00:00:40 Reboot phone now... Reading Phone Info.... Connected phone - Nokia E5-00 Software Info: V ICPR82_11w16.3.13 15-06-12 RM-632 (c) Nokia IMEI: 355949046246202 Ape Version: 101.003 Product code: 0595222 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:01:07 |
The Following 5 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
06-08-2017, 08:57 | #95 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 112 Flash File Download & Flashing Done Code: SSChannel : Create SC SSChannel : SC Created! ProductID HWCode : RM-837 Selected Variant : RM-837 MEA_M2_DGREY_URDU_PK Firmware Version : 03.51 Platform Version : Series 40 SSChannel : DC Ok with code 0x04 Switch to IDM now ... IDM initializing, wait... Checking access to Products folder... Folder for RM-837 not exist. Attempt to create Prepare done, collect info [Query] : rm837__03.51.image_m2_059P790 , 15.09 MiB [Query] : rm837__03.51.mcusw , 26.22 MiB [Query] : rm837__03.51.ppm_m2 , 3.28 MiB [Query] : RM837_059P790_03.51_027.vpl , 3.10 KiB Files to download : 4 Total size to download : 44.59 MiB Downloading now, please, wait... [Download] : rm837__03.51.image_m2_059P790 [Download] : rm837__03.51.mcusw [Download] : rm837__03.51.ppm_m2 [Download] : RM837_059P790_03.51_027.vpl Verify files now ... [Verify Ok] : rm837__03.51.mcusw [Verify Ok] : rm837__03.51.ppm_m2 [Verify Ok] : rm837__03.51.image_m2_059P790 All done, all files were downloaded! Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm837__03.51.mcusw PPM : rm837__03.51.ppm_m2 CNT : rm837__03.51.image_m2_059P790 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.50_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 356331053663125 IMEI 2 : 356331053663133 PCcode : 059P7C1 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\356331053663125_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm837__03.51.mcusw Image : rm837__03.51.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:02:08 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:32 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x87F4 ===Flashing [PPM]=== File : rm837__03.51.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:16 Write , Start : 0x41BC0000 , Len : 0x0030F7C0 Flashing , wait ... Region flash done, time : 00:00:03 CRC check passed , 0x46E6 ===Flashing [CNT]=== File : rm837__03.51.image_m2_059P790 Image : package_m2_059P790.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:04:21 Write , Start : 0x421C0000 , Len : 0x00EE0000 Flashing , wait ... Region flash done, time : 00:00:23 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:08 No write data, skip CRC check passed , 0x9EEB Flashing done! Total flash time : 00:08:04 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 112 Software Info: V 03.51 06-08-13 RM-837 (c) Nokia IMEI: 356331053663125 PPM version : V 03.51 06-08-13 RM-837 (c) Nokia M2 Product code: 059P7C1 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:08:52 |
06-08-2017, 12:45 | #96 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | lumia 520 blue lcd problem solved flash Code: Core : v2.29 , WP10x FlashEngine : v3.2 FFU : RM914_3058.50000.1425.0001_RETAIL_im_india_269_01_444377_prd_signed.ffu Checking FFU file, wait... FFU Revision ID : 2.0 FFU Model ID : Nokia.MSM8227.P6036 FFU RootKeyHash : F771E62AF89994064F77CD3BC16829503BDF9A3D FFU Languages : Albanian , Arabic , Azerbaijan(Latin) , Belorusian , Bulgarian , Catalan , Croatian , Czech , Danish (Denmark) , Dutch (Netherlands) , English (UK) , English , Estonian , Filipino (Philippines) , Finnish , French , German , Greek , Hwbre (Israel) , Hindi (India) , Hungarian , Indonesian , Italian , Japanese , Kazakh , Korean , Latvian , Lithuanian , Macedonian , Malay (Malaysia) , Norwegian (Bokmal , Norway) , Persian (Iran) , Polish , Portuguese(Brazil) , Portuguese(Portugal) , Romanian , Russian , sr-latn-rs , Chinese , Slovak , Slovenian , Spanish(Mexico) , Spanish , Swedish , Thai , Chinese(Taiwan) , Turkish , Ukrainian , Uzbekistan(Latin) , Vietnamese , FFU ChipSectors : 15155200 FFU Header : 0x000E0000 FFU Payload : 0x60020000 FFU FastVerify : Ok Waiting for phone... Dead mode is selected , no phone in normal mode found 1. Press and hold "Volume Down" 2. Insert USB cable 3. Hold button until phone will be detected Device boot not done Check Drivers, battery charge Try again in Dead mode Core : v2.29 , WP10x FlashEngine : v3.2 FFU : RM914_3058.50000.1425.0001_RETAIL_im_india_269_01_444377_prd_signed.ffu Checking FFU file, wait... FFU Revision ID : 2.0 FFU Model ID : Nokia.MSM8227.P6036 FFU RootKeyHash : F771E62AF89994064F77CD3BC16829503BDF9A3D FFU Languages : Albanian , Arabic , Azerbaijan(Latin) , Belorusian , Bulgarian , Catalan , Croatian , Czech , Danish (Denmark) , Dutch (Netherlands) , English (UK) , English , Estonian , Filipino (Philippines) , Finnish , French , German , Greek , Hwbre (Israel) , Hindi (India) , Hungarian , Indonesian , Italian , Japanese , Kazakh , Korean , Latvian , Lithuanian , Macedonian , Malay (Malaysia) , Norwegian (Bokmal , Norway) , Persian (Iran) , Polish , Portuguese(Brazil) , Portuguese(Portugal) , Romanian , Russian , sr-latn-rs , Chinese , Slovak , Slovenian , Spanish(Mexico) , Spanish , Swedish , Thai , Chinese(Taiwan) , Turkish , Ukrainian , Uzbekistan(Latin) , Vietnamese , FFU ChipSectors : 15155200 FFU Header : 0x000E0000 FFU Payload : 0x60020000 FFU FastVerify : Ok Waiting for phone... Dead mode is selected , no phone in normal mode found 1. Press and hold "Volume Down" 2. Insert USB cable 3. Hold button until phone will be detected Device catched in BOOT mode! Boot Mode confirmed! Setting Preloder Collect Info... Setting Application Setting Secure Collect Info... === Nokia Flash App info : Protocol Version : 1.15 Protocol Implementation : 1.28 === Phone Initial info : Phone RMxxx ID : RM-914 Phone Model ID : Nokia.MSM8227.P6036.1.2 Phone Model PC : 059S1N6 Phone IMEI : 359965053853926 === eMMC info : eMMC Vendor : Samsung eMMC CID : 0015 eMMC Size : 7456 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : F771E62AF89994064F77CD3BC16829503BDF9A3D === Other info : SD present : False Full Check skipped , will be checked by ImageSignature Battery Level : 27% RPMB Provision Status Code : 0x0101 Device RAM size : 512 MiB Device not have ATRP Backup to RAM Ok! FFU : RM914_3058.50000.1425.0001_RETAIL_im_india_269_01_444377_prd_signed.ffu Flashing FFU Sending FFU Header CertData Header sent , accepted :) Perform Data Partition Erase Erase done Sending FFU Payload Data... Finishing flashing Flashing done! Green Light :) Image Sent, processing PostFlash FinalConfig : abnormal status, error code : 0xFFFF0000 Make Factory Set : Ok Restore RAMBkp : Ok Update NVI from Image Ok , NVI will be updated on first boot! PostFlash Finished Total flash time : 00:05:08 Rebooting |
The Following 2 Users Say Thank You to Deepesh Sharma For This Useful Post: |
06-11-2017, 15:20 | #97 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 215 Write Firmware Done :) Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1110_ROM_eMP_12.03.11 VIVA : RM-1110_VIVA_eMP_12.03.11 LANG : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001 CUST : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001 JMPT : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001 - > MODE : FullFlash Software Info: 12.03.11 00-00-00 RM-1110 IMEI: 356867071929568 PPM version : IJ Product code: 059W6H5 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 94 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : C7AE34F8F1CC694FAB453754B9A9380D BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : JET.12.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Jet.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000 SecureDecrypt : RM-1110_ROM_eMP_12.03.11 SecureDecrypt : RM-1110_VIVA_eMP_12.03.11 SecureDecrypt : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001 SecureDecrypt : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001 SecureDecrypt : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001 OVRLP : 000069B900000001 PHPID : JET.12.03.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1110_ROM_eMP_12.03.11 Write : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001 Write : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001 Write : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001 Write : RM-1110_VIVA_eMP_12.03.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1110_ROM_eMP_12.03.11 [VERIFY] DONE : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001 [VERIFY] DONE : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001 [VERIFY] DONE : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001 [VERIFY] DONE : RM-1110_VIVA_eMP_12.03.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:02:56 Reboot phone Ok - > Hint : If phone shows Battery charge icon - press and hold PowerOn button 10 seconds Wait, when phone will be ready ... Reading Phone Info.... Software Info: 12.03.11 00-00-00 RM-1110 IMEI: 356867071929568 Ape Version: NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM version : IJ Product code: 059W6H5 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
06-13-2017, 07:03 | #98 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Nokia 5130 Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm495__07.97.mcusw PPM : rm495__07.97.ppm_mena_a1 CNT : rm495__07.97.image_mena_a1_red Flashing phone now... [Gen] Rules accepted for : RAP3x Generation Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 2690000BEA9D7D56958ADA1114E81BF08742E606 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ===Flashing [MCU]=== Erase : Processing rm495__07.97.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:26 Write : Processing rm495__07.97.mcusw Total 1178 [1178/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:57 MCU Write done ===Flashing [PPM]=== Erase : Processing rm495__07.97.ppm_mena_a1 Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:01 Write : Processing rm495__07.97.ppm_mena_a1 Total 388 [388/0/0] blocks to write, writing... TIME : Write time : 00:00:19 PPM Write done ===Flashing [CNT]=== Erase : Processing rm495__07.97.image_mena_a1_red Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:40 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm495__07.97.image_mena_a1_red Total 656 [656/0/0] blocks to write, writing... TIME : Write time : 00:00:34 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:10:59 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5130 Software Info: V 07.97 13-09-10 RM-495 (c) Nokia IMEI: 354179030853406 PPM version : V 07.97 13-09-10 RM-495 (c) Nokia MEN Product code: 0576445 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 0 certs Uploading User Certificates... Uploaded 26 certs! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:12:01 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following User Says Thank You to Luckey1 For This Useful Post: |
06-15-2017, 15:59 | #99 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia Asha 305 Write Firmware Done :) Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm766__07.42.mcusw PPM : rm766__07.42.ppm_maa CNT : rm766__07.42.image_maa_059L1H0 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.49_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 354604056855183 IMEI 2 : 354604056855191 PCcode : 059P7W4 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : F:\1+Flashing Software\1+Infinity Box\BEST\Backup\Cert\354604056855183_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm766__07.42.mcusw Image : rm766__07.42.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x000C0000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40060000 , Len : 0x000C0000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40120000 , Len : 0x01AE0000 Erasing, wait ... Erase done, time : 00:00:54 Write , Start : 0x40120000 , Len : 0x01AC4000 Flashing , wait ... Region flash done, time : 00:00:44 Processing Region 5/5 Erase , Start : 0x43EE0000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x9E48 ===Flashing [PPM]=== File : rm766__07.42.ppm_maa Image : package_maa.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41C00000 , Len : 0x00800000 Erasing, wait ... Erase done, time : 00:00:12 Write , Start : 0x41C00000 , Len : 0x005C18A0 Flashing , wait ... Region flash done, time : 00:00:09 CRC check passed , 0xC270 ===Flashing [CNT]=== File : rm766__07.42.image_maa_059L1H0 Image : package_maa_059L1H0.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42400000 , Len : 0x01AE0000 Erasing, wait ... Erase done, time : 00:01:10 Write , Start : 0x42400000 , Len : 0x00E20000 Flashing , wait ... Region flash done, time : 00:00:19 Processing Region 2/2 Erase , Start : 0x43F00000 , Len : 0x00080000 Erasing, wait ... Erase done, time : 00:00:01 No write data, skip CRC check passed , 0x25FD Flashing done! Total flash time : 00:03:35 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 305 Software Info: V 07.42 07-05-13 RM-766 (c) Nokia IMEI: 354604056855183 PPM version : V 07.42 07-05-13 RM-766 (c) Nokia MAA Product code: 059P7W4 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:35 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
06-16-2017, 07:00 | #100 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 130 RM-1035 Flashing Done Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1035_ROM_eMP_11.00.11 VIVA : RM-1035_VIVA_eMP_11.00.11 LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 JMPT : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 55 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : C58FD674D07AF86562CC942705F5C8FD BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_11.00.11 SecureDecrypt : RM-1035_VIVA_eMP_11.00.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_11.00.11 Write : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 Write : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_VIVA_eMP_11.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_11.00.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_VIVA_eMP_11.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:07 |
06-19-2017, 07:43 | #101 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 130 Write Firmware Done :) Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1035_ROM_eMP_11.00.11 VIVA : RM-1035_VIVA_eMP_11.00.11 LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 JMPT : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 94 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 25C516B6EDF9CE3AB46F2741EB34787B BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.02.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_11.00.11 SecureDecrypt : RM-1035_VIVA_eMP_11.00.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.02.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_11.00.11 Write : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 Write : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_VIVA_eMP_11.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_11.00.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_VIVA_eMP_11.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:01 Reboot phone Ok - > Hint : If phone shows Battery charge icon - press and hold PowerOn button 10 seconds Wait, when phone will be ready ... Reading Phone Info.... Software Info: 11.00.11 00-00-00 RM-1035 IMEI: 355129073239905 Ape Version: NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM version : IJ Product code: 059W035 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 11.00.11 00-00-00 RM-1035 IMEI 1 : 355129073239905 IMEI 2 : 355129073239913 XappVer : 000008F2 Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : IJ CNT : CRYSTAL.11.00.11.p1 Product SN : C45E67EAU Product code : 059W035 Base Prd.code: 059V7K4 Module code : 0206095 Hardware info======= HWID : 3200 LCDVer: TPO Lock info =========== IMEI : 355129073239905 IMEI spNet : 3A 55 21 09 37 32 99 50 Conf key : 800000000004000B Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; SimLock status : Ok Security status : Ok Done! Phone disconected! Connect phone on selected interface... |
06-21-2017, 14:05 | #102 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 301 Flashing Done Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm840__08.02.mcusw PPM : rm840__08.02.ppm_m2 CNT : rm840__08.02.image_m2_059Q988 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> Check SW version... FlashFile version : 08.02 Phone version : 02.51 07-06-13 RM-840 (c) Nokia -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... SL3 Simlock read (XGOLD) ... Ok WMDRM Key read ... Ok CMLA Key read ... Ok Reboot.... -> If Phone start charge - just reinsert battery fast Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x16 IF xCPUID : XGOLD 618 [XMM6180 QUARK] IF uCHIPID : 50A9070100030101E0001809201CCD004A50ACB4FFFF IF Resp Data : 50A9070100030101 Wait for user action : Insert battery Sending EBL Loader ... EBL Loader Ok EBL Loader ready Sending EBL ... EBL sent Ok EBL : QUARK_1337.500_M1S1 QUARK EEP config Ok FLASHID : 20004000 , [ MuxOneNAND ] Boot conf set, Target Ready Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 355520058350743 Phone Product Code : 059R1M8 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\355520058350743_XG618.rpl ===Flashing [MCU]=== Processing file : rm840__08.02.mcusw Region count : 8 00 : [ PSI ] : psi_flash_unsigned.fls 01 : [ BCore ] : slb_signed.fls 02 : [ Code ] : main_toc_signed.fls 03 : [ Code ] : rm840__08.02.mcusw_signed_mcusw.fls 04 : [ Code ] : swap_signed.fls 05 : [ Cust ] : dynsw.fls 06 : [ Code ] : aeneas_signed.fls 07 : [ Code ] : fota_signed.fls Parse done , flashing now Flash : 00 : psi_flash_unsigned.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x00090000 , Len : 0x00020000 Erase now... Erase done Region Start : 0x00090000 , Data Len : 0x00010FB0 Region Load done Write done psi_flash_unsigned.fls image flash done Flash : 01 : slb_signed.fls Sending Sec-Pack SecInfo Area : 0x0001 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x60000000 , Len : 0x00040000 Erase now... Erase done Region Start : 0x60000000 , Data Len : 0x00040000 Region Load done Write done slb_signed.fls image flash done Flash : 02 : main_toc_signed.fls Sending Sec-Pack SecInfo Area : 0x0002 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x60040000 , Len : 0x00000400 Erase now... Erase done Region Start : 0x60040000 , Data Len : 0x00000400 Region Load done Write done main_toc_signed.fls image flash done Flash : 03 : rm840__08.02.mcusw_signed_mcusw.fls Sending Sec-Pack SecInfo Area : 0x0003 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x62E00000 , Len : 0x01100000 Erase now... Erase done Erase area 0x01 , Start 0xFFF00000 , Len : 0x00080000 Erase now... Erase done Region Start : 0x62E00000 , Data Len : 0x00F0BAF4 Region Load done Write done rm840__08.02.mcusw_signed_mcusw.fls image flash done Flash : 04 : swap_signed.fls Sending Sec-Pack SecInfo Area : 0x0004 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x80000000 , Len : 0x00F00000 Erase now... Erase done Region Start : 0x80000000 , Data Len : 0x00C254B4 Region Load done Write done swap_signed.fls image flash done Flash : 05 : dynsw.fls Sending Sec-Pack SecInfo Area : 0x0005 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x62080000 , Len : 0x00100000 Erase now... Erase done Region Start : 0x62080000 , Data Len : 0x00044000 Region Load done Write done dynsw.fls image flash done Flash : 06 : aeneas_signed.fls Sending Sec-Pack SecInfo Area : 0x0006 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x63F79C00 , Len : 0x00080000 Erase now... Erase done Region Start : 0x63F79C00 , Data Len : 0x00046870 Region Load done Write done aeneas_signed.fls image flash done Flash : 07 : fota_signed.fls Sending Sec-Pack SecInfo Area : 0x0007 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x61F00004 , Len : 0x0017FFFC Erase now... Erase done Region Start : 0x61F00004 , Data Len : 0x00149870 Region Load done Write done fota_signed.fls image flash done ===Flashing [PPM]=== Processing file : rm840__08.02.ppm_m2 Region count : 1 00 : [ Cust ] : package_m2.ppm_ebl_psi.fls Parse done , flashing now Flash : 00 : package_m2.ppm_ebl_psi.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x80F00000 , Len : 0x00B00000 Erase now... Erase done Region Start : 0x80F00000 , Data Len : 0x0052770C Region Load done Write done package_m2.ppm_ebl_psi.fls image flash done ===Flashing [CNT]=== Processing file : rm840__08.02.image_m2_059Q988 Region count : 1 00 : [ Cust ] : package_m2_059Q988.image.fls Parse done , flashing now Flash : 00 : package_m2_059Q988.image.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0xA1000000 , Len : 0x0C580000 Erase now... Erase done Erase area 0x01 , Start 0xAE000000 , Len : 0x00300000 Erase now... Erase done Region Start : 0xA1000000 , Data Len : 0x01C0F400 Region Load done Write done package_m2_059Q988.image.fls image flash done Flashing done! Total flash time : 00:00:13 Reboot phone now... |
06-22-2017, 07:06 | #103 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 130 Write Firmware Done :) Code: Connect phone on selected interface... Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1035_ROM_eMP_11.00.11 VIVA : RM-1035_VIVA_eMP_11.00.11 LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 JMPT : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 94 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 8B7C2129C19EC0455FCD004ABC32B812 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_11.00.11 SecureDecrypt : RM-1035_VIVA_eMP_11.00.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_11.00.11 Write : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 Write : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_VIVA_eMP_11.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_11.00.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_VIVA_eMP_11.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:05 Reboot phone Ok - > Hint : If phone shows Battery charge icon - press and hold PowerOn button 10 seconds Wait, when phone will be ready ... Reading Phone Info.... Software Info: 11.00.11 00-00-00 RM-1035 IMEI: 351873076753602 Ape Version: NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM version : IJ Product code: 059W037 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 11.00.11 00-00-00 RM-1035 IMEI 1 : 351873076753602 IMEI 2 : 351873076753610 XappVer : 000008F2 Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : IJ CNT : CRYSTAL.11.00.11.p1 Product SN : A1AD9E6AU Product code : 059W037 Base Prd.code: 059V7K4 Module code : 0206095 Hardware info======= HWID : 3200 LCDVer: TPO Lock info =========== IMEI : 351873076753602 IMEI spNet : 3A 15 78 03 67 57 63 20 Conf key : 800000000004000B Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; SimLock status : Ok Security status : Ok Done! |
06-22-2017, 08:14 | #104 (permalink) |
Freak Poster Join Date: Nov 2015 Location: Pakistan Age: 24
Member: 2488001 Status: Offline Sonork: 100.1669288 Thanks Meter: 295 | Nokia E71-1 Hang On Logo Recover Done Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm346_510.21.009_prd.c00 PPM : rm346_510.21.009_prd.v17 CNT : rm346_510.21.009.07U APE : RM346_ENO_0741.10_08wk42.a36.fpsx CNT3 : leevi_erase_y_drive.fpsx Flashing phone now... [Gen] Rules accepted for : RAPIDO Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1F60010358A600524D76AC7571CD07A7B70C2CEA ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP ... Processing PASUBTOC ... Boot Done! TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 ADL Server confirm flashmode! ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm346_510.21.009_prd.c00 Found 3 areas to erase Erasing area 0x00040000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00A00000 - 0x0759FFFF, NAND, CMT Result: 0000 Erasing area 0x0F1C0000 - 0x0F8BFFFF, NAND, CMT Result: 0000 Partition erase not allowed by loader Partition erase not allowed by loader Partition erase not allowed by loader Partitioning : Ok [7] TIME : Erase time : 00:00:00 Write : Processing rm346_510.21.009_prd.c00 Total 588 [588/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS*CORE] CMT : Writing Hash CERT [SOS+ROFS] TIME : Write time : 00:02:02 MCU Write done ===Flashing [PPM]=== Erase : Processing rm346_510.21.009_prd.v17 Found 1 areas to erase Erasing area 0x05420000 - 0x0759FFFF, NAND, CMT Result: 0000 Partition erase not allowed by loader TIME : Erase time : 00:00:00 Write : Processing rm346_510.21.009_prd.v17 Total 186 [186/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFX] TIME : Write time : 00:00:42 PPM Write done ===Flashing [CNT]=== Erase : Processing rm346_510.21.009.07U Partition erase not allowed by loader TIME : Erase time : 00:00:00 Write : Processing rm346_510.21.009.07U Total 169 [169/0/0] blocks to write, writing... TIME : Write time : 00:00:39 CNT Write done ===Flashing [APE]=== Erase : Processing RM346_ENO_0741.10_08wk42.a36.fpsx TIME : Erase time : 00:00:00 Write : Processing RM346_ENO_0741.10_08wk42.a36.fpsx Total 18 [18/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS*ENO] TIME : Write time : 00:00:02 APE Write done ===Flashing [CNT3]=== Erase : Processing leevi_erase_y_drive.fpsx Found 1 areas to erase Erasing area 0x0F020000 - 0x0F1BFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing leevi_erase_y_drive.fpsx No any data for write, skip write CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:03:27 Reboot phone now... |
The Following 2 Users Say Thank You to Salman725626 For This Useful Post: |
06-22-2017, 12:11 | #105 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 108 Format Done Code: --- Insert USB cable now! --- Wait for phone... Phone found! [ 55 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 29EB96760BC9E052F715C96203A68DDF BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Bree.20.06.11.p4 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:23 Connect phone on selected interface... |
