Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 05-21-2020, 07:41   #1096 (permalink)
Member: 2608490
Thanks Meter: 273
TA-1017 Full Flash Done
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20
Open VPLfile : TA-1017_059Z1Z3_10.00.11.vpl
Description : TA-1017 IJ
DeviceType : TA-1017
ProductCode : 059Z1Z3
SoftwareVer : 10.00.11
PPM LangPack :
[1] : Urdu (Islamic Republic of Pakistan)
[2] : English (United Kingdom)
Load Ok!
Operation : Write FirmWare [ v1.20 ]
Setting : UserData erase : False
Setting : LangPack Only : False
1. Make sure device is powered off. Power off, if need. Wait 10 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : Care Suite USB Serial Port (COM47)
MODE : NOKIA USB SERIAL
PORT : 47
BROM : Init BROM
BROM init passed!
CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001
BROM : SECCFG : 0x00000007
BROM : NOKIA USB SERIAL
BROM : 0x05 BL : 0x00
BROM : MEID : 3B61A9A10E35510F2EC28DD415C6821D
BROM : Run BootLoader ...
BOOT : Run BL ver. 01
BOOT : 0x05 BL : 0x01
BOOT : WD : 0005
BOOT : RTC : Setup ...
BOOT : RTC : 000E
BOOT : PRJ : KESA61A.10.00.11.p2
BOOT : SWR : 10.00.11
AGENT : Look for suitable BootChain in DA ...
AGENT : DEFAULT AUTO
AGENT : Found MT6261
AGENT : KESA61A.10.00.11.p2
BOOT : Sending 1st DA ...
BOOT : DA sent
BOOT : Transfer control to DA ...
DA : Sync Passed!
DA : Authentification pass!
DA : Agent : v03.02 on BBID : 0x8E
NOR: 00EF : 0060 : 0017 : 0000
NOR: [WINBOND] W25Q64DW
NOR:
TSIZE : 0x00800000 [ 8.00 MB ]
PSIZE : 0x00800000 [ 8.00 MB ]
STYPE : 0x00000000
FLOTP : DA_NOR_OTP_EXIST
STATUS : OK
BSTYLE : SF_FLASH_BOOT
Boot done!
VPL SoftwareVersion : 10.00.11 [TA-1017]
DEV SoftwareVersion : 10.00.11
SWInfo compare result : SAME
Load FlashSet :
MROM : TA-1017_ROM_eMP_10.00.11
LANG : TA-1017_LANG_PACK_ROM_IJ_eMP_10.00.11_001
CUST : TA-1017_CUSTPACK_ROM_IJ_eMP_10.00.11_001
JUMP : TA-1017_JUMP_TABLE_IJ_eMP_10.00.11_001
VIVA : TA-1017_VIVA_eMP_10.00.11
Prepare FlashSet :
DCR : TA-1017_ROM_eMP_10.00.11
DCR : TA-1017_LANG_PACK_ROM_IJ_eMP_10.00.11_001
DCR : TA-1017_CUSTPACK_ROM_IJ_eMP_10.00.11_001
DCR : TA-1017_JUMP_TABLE_IJ_eMP_10.00.11_001
DCR : TA-1017_VIVA_eMP_10.00.11
Prepare Target
SDS : OK : 0x007F8000 : 0x00008000
Erase Target Flash
Erase done!
Write Target Flash
Write : TA-1017_ROM_eMP_10.00.11
Write : TA-1017_LANG_PACK_ROM_IJ_eMP_10.00.11_001
Write : TA-1017_CUSTPACK_ROM_IJ_eMP_10.00.11_001
Write : TA-1017_JUMP_TABLE_IJ_eMP_10.00.11_001
Write : TA-1017_VIVA_eMP_10.00.11
Write done, waiting target response ...
Write flash done!
Verify Target FlashContent
Verify : TA-1017_ROM_eMP_10.00.11
Verify : TA-1017_LANG_PACK_ROM_IJ_eMP_10.00.11_001
Verify : TA-1017_CUSTPACK_ROM_IJ_eMP_10.00.11_001
Verify : TA-1017_JUMP_TABLE_IJ_eMP_10.00.11_001
Verify : TA-1017_VIVA_eMP_10.00.11
Done!
Elapsed: 00:01:31
Reconnect Power/Cable!
The Following User Says Thank You to GSM AR For This Useful Post:
Old 05-21-2020, 10:52   #1097 (permalink)
Member: 2608490
Thanks Meter: 273
Noka 3310 3G TA-1006
Operation : Identify [ v1.20 ]
1. Power off device, remove battery
2. Insert cable, press and hold BootKey ( # )
3. Insert battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD SECURE BOOT Block version
BootVersion : BEST RETRO3G
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
SW_VERS : 13.0.0.17.01
PC_EXTR : IJ 059Z3S1
IMEI[1] : 357XXXXXXXXXXX
IMEI[2] : 357XXXXXXXXXXX
BT_ADDR : B74EDF28F104
Security saved : NKSPDv2_35730XXXXXXXXXXX.scnv
Done!
Operation : Reset Settings ( Format FS ) [ v1.20 ]
Wait for device ...
Device Connected!
Port speed : 921600
Boot Done!
Erase BLK #0
Erase BLK #1
Erase BLK #2
Erase BLK #3
Format Ok!
Done!
Elapsed: 00:00:11
The Following 2 Users Say Thank You to GSM AR For This Useful Post:
Old 05-25-2020, 06:48   #1098 (permalink)
Member: 2608490
Thanks Meter: 273
Nokia 206 Full Flash Done
Core : v2.29 , BB5XG FlashEngine : v10.5
Selected FlashSettings : FullFlash
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm872__04.52.mcusw
PPM : rm872__04.52.ppm_m2
CNT : rm872__04.52.image_m2_059Q4J7_059S8K5_269_02
Flashing phone now...
[Gen] Rules accepted for : XGOLD Generation
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
-> If Windows say "Unrecognized device" / Operation not start
-> Or if Phone start charge - just reinsert battery
-> If flashing freeze - reinsert cable/battery and try again
--- Press phone's power button or insert usb cable! ---
Connection opened successfully
IF Boot Init : 0xF0
IF Resp Len : 0x0A
IF xCPUID : XGOLD 213 [XMM2130 QUANTUM]
IF Resp Data : 1FB300020303010100FF
Sending EBL Loader ...
EBL Loader Ok, 01
EBL Loader ready, AA
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.53_M1S1
Speed accepted, use 6.500.000
FLASHID : EC001230
FLIC conf set, RST set
Boot done!
Check keys...
Check done. Image can be flashed
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 3517xxxxxxxxxxxxx
IMEI 2 : 3517xxxxxxxxxxxxx
PCcode : 059Q4L3
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\3517xxxxxxxxx_XG21 3_CRT.rpl
Settings : EDM [0x8] , Block Mode , Fast CRC , Verify
===Flashing [MCU]===
File : rm872__04.52.mcusw
Image : rm872__04.52.mcusw_ebl_psi.fls
Sec-pack found, sending ...
Sec-pack sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:02
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x01800000
Erasing, wait ...
Erase done, time : 00:00:52
Write , Start : 0x40280000 , Len : 0x01800000
Flashing , wait ...
Region flash done, time : 00:00:32
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
CRC check passed , 0xFA4D
===Flashing [PPM]===
File : rm872__04.52.ppm_m2
Image : package_m2.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41A80000 , Len : 0x00680000
Erasing, wait ...
Erase done, time : 00:00:08
Write , Start : 0x41A80000 , Len : 0x003C68F0
Flashing , wait ...
Region flash done, time : 00:00:04
CRC check passed , 0xC9E6
===Flashing [CNT]===
File : rm872__04.52.image_m2_059Q4J7_059S8K5_269_02
Image : rm872__04.52.image_m2_059Q4J7_059S8K5_269_02.fls
Sec-pack sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x42100000 , Len : 0x01D20000
Erasing, wait ...
Erase done, time : 00:01:25
Write , Start : 0x42100000 , Len : 0x00FE0000
Flashing , wait ...
Region flash done, time : 00:00:19
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
No write data, skip
CRC check passed , 0xEE84
Flashing done!
Total flash time : 00:03:31
Reboot phone now...
Reading Phone Info....
Connected phone - 206
Software Info: V 04.52 30-06-13 RM-872 (c) Nokia
IMEI: 3517xxxxxxxxx
PPM version : V 04.52 30-06-13 RM-872 (c) Nokia M2
Product code: 059Q4L3
Wait, when phone will be ready ...
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Processing After Flash Defaults...
FullFactorySet... Ok!
UserDataDefaultsSet...OK!
ServiceDefaultsSet... Ok!
LeaveDefaultsSet... Ok!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Product code update...
Resetting LifeTimer
Reset Done!
Check and Upload User Certificates ...
Total - 58 certs
Certificates found, skip upload ...
===== WARNING =====
Battery voltage is NOT enough for start
===== WARNING =====
Set phone to Normal mode...
AfterFlash operations done ;D
Done!
Connect phone on selected interface...
Elapsed: 00:04:43
Old Today, 10:31   #1099 (permalink)
Member: 2608490
Thanks Meter: 273
Nokia 301 Full Flash Done
Selected FlashSettings : Manual
MCU : rm839__09.04.mcusw
PPM : rm839__09.04.ppm_s1
CNT : rm839__09.04.image_s1_059S172
Check files done...
IF Boot Init : 0xF0
IF Resp Len : 0x16
IF xCPUID : XGOLD 618 [XMM6180 QUARK]
IF uCHIPID : 50A9070100030101E03020120014A68358F87B35FFFF
IF Resp Data : 50A9070100030101
Wait for user action : Insert battery
EBL Loader Ok
EBL Loader ready
Sending EBL ...
EBL sent Ok
EBL : QUARK_1337.500_M1S1
QUARK EEP config Ok
FLASHID : EC004000 , [ MuxOneNAND ]
Boot conf set, Target Ready
Boot done!
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 3523xxxxxxxxxxxx
IMEI 2 : 3523xxxxxxxxxxxx
Phone Product Code : 059Q9B5
RPL saved : C:\InfinityBox\BEST\Backup\Cert\3523xxxxxxxxxxx_XG 618_CRT.rpl
Processing file : rm839__09.04.mcusw
Region count : 8
00 : [ PSI ] : psi_flash_unsigned.fls
01 : [ BCore ] : slb_signed.fls
02 : [ Code ] : main_toc_signed.fls
03 : [ Code ] : rm839__09.04.mcusw_signed_mcusw.fls
04 : [ Code ] : swap_signed.fls
05 : [ Cust ] : dynsw.fls
06 : [ Code ] : aeneas_signed.fls
07 : [ Code ] : fota_signed.fls
Parse done , flashing now
Flash : 00 : psi_flash_unsigned.fls
Sending Sec-Pack
SecInfo Area : 0x0000 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x00090000 , Len : 0x00020000
Erase now...
Erase done
Region Start : 0x00090000 , Data Len : 0x00010FB0
Region Load done
Write done
psi_flash_unsigned.fls image flash done
Flash : 01 : slb_signed.fls
Sending Sec-Pack
SecInfo Area : 0x0001 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x60000000 , Len : 0x00040000
Erase now...
Erase done
Region Start : 0x60000000 , Data Len : 0x00040000
Region Load done
Write done
slb_signed.fls image flash done
Flash : 02 : main_toc_signed.fls
Sending Sec-Pack
SecInfo Area : 0x0002 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x60040000 , Len : 0x00000400
Erase now...
Erase done
Region Start : 0x60040000 , Data Len : 0x00000400
Region Load done
Write done
main_toc_signed.fls image flash done
Flash : 03 : rm839__09.04.mcusw_signed_mcusw.fls
Sending Sec-Pack
SecInfo Area : 0x0003 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x62E00000 , Len : 0x01100000
Erase now...
Erase done
Erase area 0x01 , Start 0xFFF00000 , Len : 0x00080000
Erase now...
Erase done
Region Start : 0x62E00000 , Data Len : 0x00F0D4CC
Region Load done
Write done
rm839__09.04.mcusw_signed_mcusw.fls image flash done
Flash : 04 : swap_signed.fls
Sending Sec-Pack
SecInfo Area : 0x0004 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x80000000 , Len : 0x00F00000
Erase now...
Erase done
Region Start : 0x80000000 , Data Len : 0x00C2BCD0
Region Load done
Write done
swap_signed.fls image flash done
Flash : 05 : dynsw.fls
Sending Sec-Pack
SecInfo Area : 0x0005 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x62080000 , Len : 0x00100000
Erase now...
Erase done
Region Start : 0x62080000 , Data Len : 0x00044000
Region Load done
Write done
dynsw.fls image flash done
Flash : 06 : aeneas_signed.fls
Sending Sec-Pack
SecInfo Area : 0x0006 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x63F79C00 , Len : 0x00080000
Erase now...
Erase done
Region Start : 0x63F79C00 , Data Len : 0x00046870
Region Load done
Write done
aeneas_signed.fls image flash done
Flash : 07 : fota_signed.fls
Sending Sec-Pack
SecInfo Area : 0x0007 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x61F00004 , Len : 0x0017FFFC
Erase now...
Erase done
Region Start : 0x61F00004 , Data Len : 0x00149890
Region Load done
Write done
fota_signed.fls image flash done
Processing file : rm839__09.04.ppm_s1
Region count : 1
00 : [ Cust ] : package_s1.ppm_ebl_psi.fls
Flash : 00 : package_s1.ppm_ebl_psi.fls
Sending Sec-Pack
Erase area 0x00 , Start 0x80F00000 , Len : 0x00B00000
Erase now...
Erase done
Region Start : 0x80F00000 , Data Len : 0x00703478
Region Load done
Write done
package_s1.ppm_ebl_psi.fls image flash done
Processing file : rm839__09.04.image_s1_059S172
Region count : 1
00 : [ Cust ] : package_s1_059S172.image.fls
Flash : 00 : package_s1_059S172.image.fls
Sending Sec-Pack
Erase area 0x00 , Start 0xA1000000 , Len : 0x0C580000
Erase now...
Erase done
Erase area 0x01 , Start 0xAE000000 , Len : 0x00300000
Erase now...
Erase done
Region Start : 0xA1000000 , Data Len : 0x01AF5200
Region Load done
Write done
package_s1_059S172.image.fls image flash done
Flashing done!
Total flash time : 00:00:13
Reboot phone now...
Connected phone - Nokia 301 Dual SIM
Software Info: V 09.04 03-12-13 RM-839 (c) Nokia
IMEI: 3523xxxxxxxxxxxxx
PPM version : V 09.04 03-12-13 RM-839 (c) Nokia S1
Product code: 059Q9B5
Checking...
Read Info Done!
SwUpgradeSet...OK!
Resetting LifeTimer
Reset Done!
Total - 58 certs
Battery voltage is enough for start
Done!
Elapsed: 00:01:32
Page generated in 0.16241 seconds with 8 queries
