06-28-2017, 06:23 | #106 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia C2-05 Download Firmware & Flash Done Code: SSChannel : Create SC SSChannel : SC Created! ProductID HWCode : RM-724 Selected Variant : RM-724 MEA M_A DGRAY URDU PK Firmware Version : 08.87 Platform Version : Series 40 SSChannel : DC Ok with code 0x04 Switch to IDM now ... IDM initializing, wait... Checking access to Products folder... Folder for RM-724 not exist. Attempt to create Prepare done, collect info [Query] : rm724__08.87.image_m_a_dgray_059G0C3 , 15.59 MiB [Query] : rm724__08.87.mcusw , 25.72 MiB [Query] : rm724__08.87.ppm_m_a , 4.46 MiB [Query] : RM724_059G0C3_08.87_038.vpl , 3.37 KiB Files to download : 4 Total size to download : 45.78 MiB Downloading now, please, wait... [Download] : rm724__08.87.image_m_a_dgray_059G0C3 [Download] : rm724__08.87.mcusw [Download] : rm724__08.87.ppm_m_a [Download] : RM724_059G0C3_08.87_038.vpl Verify files now ... [Verify Ok] : rm724__08.87.mcusw [Verify Ok] : rm724__08.87.ppm_m_a [Verify Ok] : rm724__08.87.image_m_a_dgray_059G0C3 All done, all files were downloaded! Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm724__08.87.mcusw PPM : rm724__08.87.ppm_m_a CNT : rm724__08.87.image_m_a_dgray_059G0C3 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 353285055557821 PCcode : 059G0C3 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\353285055557821_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm724__08.87.mcusw Image : rm724__08.87.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x018C0000 Erasing, wait ... Erase done, time : 00:00:50 Write , Start : 0x40280000 , Len : 0x01840000 Flashing , wait ... Region flash done, time : 00:00:34 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xB866 ===Flashing [PPM]=== File : rm724__08.87.ppm_m_a Image : package_m_a.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41B40000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:09 Write , Start : 0x41B40000 , Len : 0x0043EE54 Flashing , wait ... Region flash done, time : 00:00:05 CRC check passed , 0x2FE6 ===Flashing [CNT]=== File : rm724__08.87.image_m_a_dgray_059G0C3 Image : package_m_a_dgray_059G0C3.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42240000 , Len : 0x01BE0000 Erasing, wait ... Erase done, time : 00:01:04 Write , Start : 0x42240000 , Len : 0x00F60000 Flashing , wait ... Region flash done, time : 00:00:19 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0x4044 Flashing done! Total flash time : 00:03:11 Reboot phone now... Reading Phone Info.... Connected phone - C2-05 Software Info: V 08.87 17-10-12 RM-724 (c) Nokia IMEI: 353285055557821 PPM version : V 08.87 17-10-12 RM-724 (c) Nokia M_A Product code: 059G0C3 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 42 certs Certificates found, skip upload ... ===== WARNING ===== Battery voltage is NOT enough for start ===== WARNING ===== AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:10 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 5 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
06-28-2017, 08:51 | #107 (permalink) |
Freak Poster Join Date: Nov 2015 Location: Pakistan Age: 24
Member: 2488001 Status: Offline Sonork: 100.1669288 Thanks Meter: 295 | Nokia 130 Firmware Downloading And Flashig Done Connect phone on selected interface... SSChannel : Create SC SSChannel : SC Created! ProductID HWCode : RM-1035 Selected Variant : RM-1035 NDT MEA IJ URDU PK Firmware Version : 11.00.11 Platform Version : S30+ SSChannel : DC Ok with code 0x06 Switch to IDM now ... IDM initializing, wait... Checking access to Products folder... Folder for RM-1035 exist Prepare done, collect info [Query] : RM1035_059W037_11.00.11_053.vpl , 4.35 KiB [Query] : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 , 51.54 KiB [Query] : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 , 1.15 KiB [Query] : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 , 279.16 KiB [Query] : RM-1035_ROM_eMP_11.00.11 , 295.57 KiB [Query] : RM-1035_VIVA_eMP_11.00.11 , 2.47 MiB Files to download : 6 Total size to download : 3.08 MiB Downloading now, please, wait... [Download] : RM1035_059W037_11.00.11_053.vpl [Download] : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 [Download] : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 [Download] : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 [Download] : RM-1035_ROM_eMP_11.00.11 [Download] : RM-1035_VIVA_eMP_11.00.11 Verify files now ... [Verify Ok] : RM-1035_ROM_eMP_11.00.11 [Verify Ok] : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 [Verify Ok] : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 [Verify Ok] : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 [Verify Ok] : RM-1035_VIVA_eMP_11.00.11 All done, all files were downloaded! Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1035_ROM_eMP_11.00.11 VIVA : RM-1035_VIVA_eMP_11.00.11 LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 JMPT : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 42 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 0958755F4826F92875EE0D4D733D2A49 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_11.00.11 SecureDecrypt : RM-1035_VIVA_eMP_11.00.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_11.00.11 Write : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 Write : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_VIVA_eMP_11.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_11.00.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_VIVA_eMP_11.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:03 Reboot phone Ok Connect phone on selected interface... |
The Following User Says Thank You to Salman725626 For This Useful Post: |
06-28-2017, 10:50 | #108 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 130 Flashing Done . Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1035_ROM_eMP_11.00.11 VIVA : RM-1035_VIVA_eMP_11.00.11 LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 JMPT : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 78 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : EB3F6006653E77F01A4C59435DF88A74 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_11.00.11 SecureDecrypt : RM-1035_VIVA_eMP_11.00.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_11.00.11 Write : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 Write : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_VIVA_eMP_11.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_11.00.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_VIVA_eMP_11.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:03 Reboot phone Ok |
06-28-2017, 15:34 | #109 (permalink) | |
No Life Poster Join Date: Feb 2006
Member: 237256 Status: Offline Thanks Meter: 91 | Quote:
Can you please tell me what version of Best Dongle software u used for this test and is there flash file for this new version of Nokia 3310 model Ta-1008 and 1030? | |
The Following 2 Users Say Thank You to pastor good For This Useful Post: |
06-29-2017, 06:19 | #110 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Microsoft Nokia 215 RM-1110 Flashing Done Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1110_ROM_eMP_12.03.11 VIVA : RM-1110_VIVA_eMP_12.03.11 LANG : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001 CUST : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001 JMPT : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 55 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : DAD0798D1AA6FF9DA15BD1B09DE8082A BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : JET.10.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Jet.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000 SecureDecrypt : RM-1110_ROM_eMP_12.03.11 SecureDecrypt : RM-1110_VIVA_eMP_12.03.11 SecureDecrypt : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001 SecureDecrypt : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001 SecureDecrypt : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001 OVRLP : 000069B900000001 PHPID : JET.10.01.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1110_ROM_eMP_12.03.11 Write : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001 Write : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001 Write : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001 Write : RM-1110_VIVA_eMP_12.03.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1110_ROM_eMP_12.03.11 [VERIFY] DONE : RM-1110_LANG_PACK_ROM_IJ_eMP_12.03.11_001 [VERIFY] DONE : RM-1110_CUSTPACK_ROM_IJ_MEA_PK_eMP_12.03.11_001 [VERIFY] DONE : RM-1110_JUMP_TABLE_IJ_MEA_PK_eMP_12.03.11_001 [VERIFY] DONE : RM-1110_VIVA_eMP_12.03.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:02:52 Reboot phone Ok |
06-30-2017, 10:33 | #112 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 130 Flashing Firmware Done Code: Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1035_ROM_eMP_11.00.11 VIVA : RM-1035_VIVA_eMP_11.00.11 LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 JMPT : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 55 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : C1ED3924E4FAE3853F36199601FC7488 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.13.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_11.00.11 SecureDecrypt : RM-1035_VIVA_eMP_11.00.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 OVRLP : 000069B900000001 PHPID : CRYSTAL.13.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_11.00.11 Write : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 Write : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 Write : RM-1035_VIVA_eMP_11.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_11.00.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_11.00.11_002 [VERIFY] DONE : RM-1035_VIVA_eMP_11.00.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:02 Reboot phone Ok |
06-30-2017, 18:37 | #113 (permalink) |
No Life Poster Join Date: Jan 2014 Location: gsmforum
Member: 2118052 Status: Offline Thanks Meter: 568 | ASHSA 200 RM 761 FLASH DONE.... Connect phone on selected interface... Core : v2.25 , BB5XG FlashEngine : v10.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : 8172CA6A_rm761__12.04.mcusw PPM : 7B97862C_rm761__12.04.ppm_mh1 CNT : 710B4427_rm761__12.04.image_mh1_059J515 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- -> Phone not found.. Elapsed: 00:00:43 Connect phone on selected interface... Core : v2.25 , BB5XG FlashEngine : v10.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : 8172CA6A_rm761__12.04.mcusw PPM : 7B97862C_rm761__12.04.ppm_mh1 CNT : 710B4427_rm761__12.04.image_mh1_059J515 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : 8172CA6A_rm761__12.04.mcusw Image : rm761__12.04.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:04 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:01:50 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:38 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x6D3B ===Flashing [PPM]=== File : 7B97862C_rm761__12.04.ppm_mh1 Image : package_mh1.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00740000 Erasing, wait ... Erase done, time : 00:00:28 Write , Start : 0x41A80000 , Len : 0x005E52FC Flashing , wait ... Region flash done, time : 00:00:08 CRC check passed , 0xDE94 ===Flashing [CNT]=== File : 710B4427_rm761__12.04.image_mh1_059J515 Image : package_mh1_059J515.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:03:29 Write , Start : 0x421C0000 , Len : 0x01120000 Flashing , wait ... Region flash done, time : 00:00:26 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:06 No write data, skip CRC check passed , 0x4050 Flashing done! Total flash time : 00:07:16 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 200 Software Info: V 12.04 20-05-13 RM-761 (c) Nokia IMEI: 354610056329970 PPM version : V 12.04 20-05-13 RM-761 (c) Nokia MH1 Product code: 059K959 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Check and Upload User Certificates ... FS damaged, or minor error AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:09:49 Connect phone on selected interface... |
The Following User Says Thank You to miftahulbari For This Useful Post: |
06-30-2017, 18:42 | #114 (permalink) |
Member: 2118052 Status: Offline Thanks Meter: 568 | RM 625 FLASHING DONE... Connect phone on selected interface... Core : v2.25 , BB5XG FlashEngine : v10.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-625_51.1.002_prd.core.C00 PPM : RM-625_51.1.002_prd.rofs2.V21 PPM2 : RM-625_51.1.002_C01_prd.rofs3.fpsx CNT : RM625_51.1.002_000_001_U001.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPIDO Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051105 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1E200114D3A40052F7847C735929EBB38FD73AEE ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 Waiting for response: 26 Waiting for response: 25 Waiting for response: 24 Waiting for response: 23 Waiting for response: 22 Waiting for response: 21 Waiting for response: 20 ADL -> [2nd] changing... ADL Server confirm flashmode! RHASH : B8C3ADECFC997FCD8081D3DEAF870B8C RPAKeys : 7DC72D3FDC552426A4479BC820097D304CFB6C15 Pr.Code : 059D6Q5 IMEI : 355932040050861 ADL : Auth done... === SW Version Check === - > REFLASHING or UPGRADE === SW Version Check === ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-625_51.1.002_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:01 Write : Processing RM-625_51.1.002_prd.core.C00 Total 418 [418/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:31 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-625_51.1.002_prd.rofs2.V21 Found 1 areas to erase Erasing area 0x06CE0000 - 0x0915FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-625_51.1.002_prd.rofs2.V21 Total 52 [52/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:04 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-625_51.1.002_C01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09160000 - 0x09E5FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-625_51.1.002_C01_prd.rofs3.fpsx Total 28 [28/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:02 PPM Write done ===Flashing [CNT]=== Erase : Processing RM625_51.1.002_000_001_U001.uda.fpsx Found 1 areas to erase Erasing area 0x09E60000 - 0x0F47FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM625_51.1.002_000_001_U001.uda.fpsx Total 69 [69/0/0] blocks to write, writing... TIME : Write time : 00:00:06 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:46 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5233 Software Info: V ICPR72_11w16.1 28-07-11 RM-625 (c) Nokia IMEI: 355932040050861 Ape Version: V 51.1.002 Product code: 059D6Q5 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:01:54 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading User code... User Code is: Error! Crypted user code! Done! Reading LifeTimer data... Looks like LifeTimer already reset... Done Resetting life Timer... Reset Done! Done Set phone in Normal mode... Restarting... Done! Phone disconected! Connect phone on selected interface... SSChannel : Create SC SSChannel : Failed to get info! Please, check ProductCode, which you enter. Probably it wrong ErroInfo : Unknown response received from SRV SSChannel : Create SC SSChannel : Failed to get info! Please, check ProductCode, which you enter. Probably it wrong ErroInfo : Unknown response received from SRV Core : v2.25 , BB5XG FlashEngine : v10.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-625_51.9.002_prd.core.C00 PPM : RM-625_51.9.002_prd.rofs2.V25 PPM2 : RM-625_51.9.002.548.04.rofs3.fpsx CNT : RM625_51.9.002_002_U549.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPIDO Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051105 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1E200114D3A40052F7847C735929EBB38FD73AEE ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! RHASH : B8C3ADECFC997FCD8081D3DEAF870B8C RPAKeys : 7DC72D3FDC552426A4479BC820097D304CFB6C15 Pr.Code : 059D6Q5 IMEI : 355932040050861 ADL : Auth done... === SW Version Check === - > DOWNGRADE DETECTED!!! - > Download latest Flash Files version and try again! - > Stop killing phone, break flashing! === SW Version Check === ================= ADL : End flashing ADL : Finalize... Elapsed: 00:00:15 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Read and Check phone data... ---------------------- RAP_BOOT: 1001010502010000 RAP_PUB: 1E200114D3A40052F7847C735929EBB38FD73AEE CMT_ROOT: B8C3ADECFC997FCD8081D3DEAF870B8C RAP_PAPUB: 7DC72D3FDC552426A4479BC820097D304CFB6C15 ---------------------- Live Test Ok! ---------------------- CMT Flash ID : 004000EC < SAMSUNG [SEC] => KAT00F00RA [NAND] ------------------------ SDD Key status : SDData is Ok CMLA Key status : CMLA key is Ok SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Elapsed: 00:00:06 Set phone in Normal mode... Restarting... Done! Phone disconected! Connect phone on selected interface... |
The Following 2 Users Say Thank You to miftahulbari For This Useful Post: |
06-30-2017, 18:45 | #115 (permalink) |
Member: 2118052 Status: Offline Thanks Meter: 568 | RM 1011 FLASHING DONE... Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 16 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 6AA372A3FF291BDF624BB0A3B561F442 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 Executing FFS FORMAT now... FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:01:02 Connect phone on selected interface... Core : v2.25 , MTKx FlashEngine : v10.5 Verify files ... MAUI : RM-1011_ROM_eMP_30.06.11 VIVA : RM-1011_VIVA_eMP_30.06.11 LANG : RM-1011_LANG_PACK_ROM_MH_eMP_30.06.11_001 CUST : RM-1011_CUSTPACK_ROM_MH_INDIA_IN_eMP_30.06.11_001 JMPT : RM-1011_JUMP_TABLE_MH_INDIA_IN_eMP_30.06.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 16 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 6AA372A3FF291BDF624BB0A3B561F442 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : PEARL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Pearl.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 SecureDecrypt : RM-1011_ROM_eMP_30.06.11 SecureDecrypt : RM-1011_VIVA_eMP_30.06.11 SecureDecrypt : RM-1011_LANG_PACK_ROM_MH_eMP_30.06.11_001 SecureDecrypt : RM-1011_CUSTPACK_ROM_MH_INDIA_IN_eMP_30.06.11_001 SecureDecrypt : RM-1011_JUMP_TABLE_MH_INDIA_IN_eMP_30.06.11_001 OVRLP : 000069B900000001 PHPID : PEARL.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1011_ROM_eMP_30.06.11 Write : RM-1011_LANG_PACK_ROM_MH_eMP_30.06.11_001 Write : RM-1011_CUSTPACK_ROM_MH_INDIA_IN_eMP_30.06.11_001 Write : RM-1011_JUMP_TABLE_MH_INDIA_IN_eMP_30.06.11_001 Write : RM-1011_VIVA_eMP_30.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1011_ROM_eMP_30.06.11 [VERIFY] DONE : RM-1011_LANG_PACK_ROM_MH_eMP_30.06.11_001 [VERIFY] DONE : RM-1011_CUSTPACK_ROM_MH_INDIA_IN_eMP_30.06.11_001 [VERIFY] DONE : RM-1011_JUMP_TABLE_MH_INDIA_IN_eMP_30.06.11_001 [VERIFY] DONE : RM-1011_VIVA_eMP_30.06.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:02:43 Reboot phone Ok - > Hint : If phone shows Battery charge icon - press and hold PowerOn button 10 seconds |
06-30-2017, 18:47 | #116 (permalink) |
Member: 2118052 Status: Offline Thanks Meter: 568 | NOKIA RM 827 FLASHING DONE... Connect phone on selected interface... Core : v2.25 , BB5XG FlashEngine : v10.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm837__03.26.mcusw PPM : rm837__03.26.ppm_mh2 CNT : rm837__03.26.image_mh2_059P2F4 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.50_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm837__03.26.mcusw Image : rm837__03.26.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:02:01 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:40 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xDC22 ===Flashing [PPM]=== File : rm837__03.26.ppm_mh2 Image : package_mh2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:17 Write , Start : 0x41BC0000 , Len : 0x00324548 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0x9FB8 ===Flashing [CNT]=== File : rm837__03.26.image_mh2_059P2F4 Image : package_mh2_059P2F4.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:04:18 Write , Start : 0x421C0000 , Len : 0x01060000 Flashing , wait ... Region flash done, time : 00:00:30 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:08 No write data, skip CRC check passed , 0x8EA9 Flashing done! Total flash time : 00:08:09 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 112 Software Info: V 03.26 27-06-12 RM-837 (c) Nokia IMEI: 359601057531024 PPM version : V 03.26 27-06-12 RM-837 (c) Nokia MH2 Product code: 059S611 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 42 certs Certificates found, skip upload ... AfterFlash operations done ;D Done! |
06-30-2017, 18:48 | #117 (permalink) |
Member: 2118052 Status: Offline Thanks Meter: 568 | RM 1035 FLASHING AND FORMAT DONE ... Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 16 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : CD7477612815C11BE360F09E4644FF3F BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Elapsed: 00:00:28 Connect phone on selected interface... Core : v2.25 , MTKx FlashEngine : v10.5 Verify files ... MAUI : RM-1035_ROM_eMP_10.02.11 VIVA : RM-1035_VIVA_eMP_10.02.11 LANG : RM-1035_LANG_PACK_ROM_MF_eMP_10.02.11_005 CUST : RM-1035_CUSTPACK_ROM_MF_MEA_LK_eMP_10.02.11_005 JMPT : RM-1035_JUMP_TABLE_MF_MEA_LK_eMP_10.02.11_005 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 16 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : CD7477612815C11BE360F09E4644FF3F BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_10.02.11 SecureDecrypt : RM-1035_VIVA_eMP_10.02.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_MF_eMP_10.02.11_005 SecureDecrypt : RM-1035_CUSTPACK_ROM_MF_MEA_LK_eMP_10.02.11_005 SecureDecrypt : RM-1035_JUMP_TABLE_MF_MEA_LK_eMP_10.02.11_005 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_10.02.11 Write : RM-1035_LANG_PACK_ROM_MF_eMP_10.02.11_005 Write : RM-1035_CUSTPACK_ROM_MF_MEA_LK_eMP_10.02.11_005 Write : RM-1035_JUMP_TABLE_MF_MEA_LK_eMP_10.02.11_005 Write : RM-1035_VIVA_eMP_10.02.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_10.02.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_MF_eMP_10.02.11_005 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_MF_MEA_LK_eMP_10.02.11_005 [VERIFY] DONE : RM-1035_JUMP_TABLE_MF_MEA_LK_eMP_10.02.11_005 [VERIFY] DONE : RM-1035_VIVA_eMP_10.02.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:00:53 Reboot phone Ok - > Hint : If phone shows Battery charge icon - press and hold PowerOn button 10 seconds |
06-30-2017, 18:50 | #118 (permalink) |
Member: 2118052 Status: Offline Thanks Meter: 568 | RM 767 FLASHING DONE.... Connect phone on selected interface... Core : v2.25 , BB5XG FlashEngine : v10.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm767__03.63.mcusw PPM : rm767__03.63.ppm_ea2 CNT : rm767__03.63.image_ea2_059L939 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.49_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm767__03.63.mcusw Image : rm767__03.63.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x000C0000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40060000 , Len : 0x000C0000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40120000 , Len : 0x01C20000 Erasing, wait ... Erase done, time : 00:01:00 Write , Start : 0x40120000 , Len : 0x01C04000 Flashing , wait ... Region flash done, time : 00:00:48 Processing Region 5/5 Erase , Start : 0x43EE0000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xB6A3 ===Flashing [PPM]=== File : rm767__03.63.ppm_ea2 Image : package_ea2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41D40000 , Len : 0x00800000 Erasing, wait ... Erase done, time : 00:00:17 Write , Start : 0x41D40000 , Len : 0x006858C8 Flashing , wait ... Region flash done, time : 00:00:09 CRC check passed , 0x3B47 ===Flashing [CNT]=== File : rm767__03.63.image_ea2_059L939 Image : package_ea2_059L939.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42540000 , Len : 0x019A0000 Erasing, wait ... Erase done, time : 00:01:13 Write , Start : 0x42540000 , Len : 0x00C40000 Flashing , wait ... Region flash done, time : 00:00:18 Processing Region 2/2 Erase , Start : 0x43F00000 , Len : 0x00080000 Erasing, wait ... Erase done, time : 00:00:01 No write data, skip CRC check passed , 0xA4C0 Flashing done! Total flash time : 00:03:53 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 306 Software Info: V 03.63 14-06-12 RM-767 (c) Nokia IMEI: 351955053273785 PPM version : V 03.63 14-06-12 RM-767 (c) Nokia EA2 Product code: 059L902 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 42 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:04:53 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 306 Software ver : V 03.63 14-06-12 RM-767 (c) Nokia IMEI : 351955053273785 XappVer : 000008CA PPM : V 03.63 14-06-12 RM-767 (c) Nokia EA2 CNT : Content: ea2_059L939 V 03.63 14-06-12 RM-767 (c) Nokia Product SN : 45B58A8BI Product code : 059L902 Base Prd.code: 059L7D4 Module code : 0204887 Long Prod.SN : 0 Hardware info======= HWID : 2001 Battery: 4105 mV CMT BT: 19e2-4702D14 LCDVer: TPO Lock info =========== IMEI : 351955053273785 IMEI spNet : 3A 15 59 05 35 72 73 08 IMEI svNet : 33 15 59 05 35 72 73 18 F7 Sl Conf : 001-01-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : A5F4CC7D0921940C Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Error collect lock info, try again CRT308 Backup Created CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Reading User code... User Code is: 12345 Done! Reading LifeTimer data... LifeTime is: 174024 seconds Phone works: 48 Hours; 20 minutes; 24 seconds Last calls : Last call : 00:00:00 Total received calls : 00:00:00 Total sent calls : 00:00:00 Done Resetting life Timer... Reset Done! Done Set phone in Normal mode... Restarting... Done! Phone disconected! Connect phone on selected interface... |
06-30-2017, 18:51 | #119 (permalink) |
Member: 2118052 Status: Offline Thanks Meter: 568 | RM 632 FLASHING DONE.... Connect phone on selected interface... Core : v2.25 , BB5XG FlashEngine : v10.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm632_101.003_prd.core.fpsx PPM : rm632_101.003_47.01_India_prd.rofs2.fpsx PPM2 : rm632_101.003_C00.01_DEFAULT_prd.rofs3.fpsx CNT : rm632_101.003_U005.000_prd.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 2A100107E6705740546AE5D2591A7BEEB3ECE8E9 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00500020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C ADL: phone is in flash mode === SW Version Check === - > UPGRADE === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm632_101.003_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:03 Write : Processing rm632_101.003_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 433 blocks TIME : Write time : 00:00:17 MCU Write done ADL: Request programm status NAND status : 00000004 / 00000004 / 00000000 ===Flashing [PPM]=== Erase : Processing rm632_101.003_47.01_India_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm632_101.003_47.01_India_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 182 blocks TIME : Write time : 00:00:08 PPM Write done ADL: Request programm status NAND status : 00000004 / 00000004 / 00000000 ===Flashing [PPM2]=== Erase : Processing rm632_101.003_C00.01_DEFAULT_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm632_101.003_C00.01_DEFAULT_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 35 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000004 / 00000004 / 00000000 ===Flashing [CNT]=== Erase : Processing rm632_101.003_U005.000_prd.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:03 Write : Processing rm632_101.003_U005.000_prd.uda.fpsx Total writen 97 blocks TIME : Write time : 00:00:06 CNT Write done ADL: Request programm status NAND status : 00000004 / 00000004 / 00000000 ADL: Close_Session Content: 000300000000040000000400000000 ADL: Reboot Flashing done! Total flash time : 00:00:42 Reboot phone now... Reading Phone Info.... Connected phone - Nokia E5-00 Software Info: V ICPR82_11w16.3.13 15-06-12 RM-632 (c) Nokia IMEI: 355949048927825 Ape Version: 101.003 Product code: 059B059 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:01:32 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia E5-00 Software ver : V ICPR82_11w16.3.13 15-06-12 RM-632 (c) Nokia IMEI : 355949048927825 XappVer : 000008CA Ape Ver : 101.003 APE Var : 101.003101.003.47.01101.003.C00.01 APE ADSP: 256 DSP Ver : 12w24 APE Test: v0.032 PPM : CNT : Product SN : 1C78DE4AA Product code : 059B059 Base Prd.code: 0590165 Module code : 0204475 Long Prod.SN : 0 Hardware info======= HWID : 3008 Retu : 35 Tahvo : 00 Battery: 3568 mV APE HW: 256 Lock info =========== IMEI : 355949048927825 IMEI spNet : 3A 55 49 09 84 29 87 02 IMEI svNet : 33 55 49 09 84 29 87 32 F0 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= Error collect lock info, try again CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Reading User code... User Code is: Error! Crypted user code! Done! Reading LifeTimer data... LifeTime is: 4204802 seconds Phone works: 1168 Hours; 0 minutes; 2 seconds Done Resetting life Timer... Reset Done! Done Set phone in Normal mode... Restarting... Done! Phone disconected! Connect phone on selected interface... |
07-01-2017, 13:22 | #120 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 3110c Flashing Done Code: Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm237__07.30.mcusw PPM : rm237__07.30.ppm_b CNT : rm237__07.30.image_ora_pl Flashing phone now... [Gen] Rules accepted for : RAP3x Generation Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- -> Phone not found.. :( -> Error while flashing... :( Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm237__07.30.mcusw PPM : rm237__07.30.ppm_b CNT : rm237__07.30.image_ora_pl Flashing phone now... [Gen] Rules accepted for : RAP3x Generation Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006010C192101001101 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 26A00102D97C7C5656FF92DE436BA6BCF1564C86 CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ===Flashing [MCU]=== Erase : Processing rm237__07.30.mcusw Found 9 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT Result: 0000 Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT Result: 0000 Erasing area 0x00200000 - 0x0031FFFF, NOR, CMT Result: 0000 Erasing area 0x00320000 - 0x0105FFFF, NOR, CMT Result: 0000 Erasing area 0x01060000 - 0x01067FFF, NOR, CMT Result: 0000 Erasing area 0x01068000 - 0x0107FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:05 Write : Processing rm237__07.30.mcusw Total 945 [945/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [PAPUBKEYS] CMT : PAPUBKEYS skip, already sent CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [PMM_CONF] CMT : Writing Hash CERT [SBIF_CONF] TIME : Write time : 00:00:45 MCU Write done ===Flashing [PPM]=== Erase : Processing rm237__07.30.ppm_b Found 1 areas to erase Erasing area 0x01080000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:35 Write : Processing rm237__07.30.ppm_b Total 179 [179/0/0] blocks to write, writing... TIME : Write time : 00:00:08 PPM Write done ===Flashing [CNT]=== Erase : Processing rm237__07.30.image_ora_pl Found 1 areas to erase Erasing area 0x01520000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:43 Checking content info... Resetting phone... Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm237__07.30.image_ora_pl ConvertImage: Page Size is 64K, converting... ConvertImage: File converted Loader len: 253888, CHK: 17DB ADL -> Sending loader... Reset connection... ADL : Check data ADL : Data accepted Write : Processing rm237__07.30.image_ora_pl_128 Total 296 [296/0/0] blocks to write, writing... TIME : Write time : 00:00:14 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:05:33 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 3110c Software Info: V 07.30 07-05-09 RM-237 (c) Nokia. IMEI: 359309029591429 PPM version : V 07.21 05-11-08 RM-237 (c) Nokia. MEA Product code: Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 0 certs Uploading User Certificates... Uploaded 26 certs! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:06:32 |
