12-23-2012, 11:29 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: ctg ,bangladesh Age: 42
Member: 538272 Status: Offline Sonork: 100.1589159 Thanks Meter: 71 | successfully flash nokia 110 with BB5 Easy Service Tool (BEST) Nokia Dongle screen short Core : v1.55 , FlashEngine : v3.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : 3998CC21_rm827__03.04.mcusw PPM : E3E09E22_rm827__03.04.ppm_m1 CNT : 3A4647A9_rm827__03.04.image_m1_059N416 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_10.49_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 353259051678964 IMEI 2 : 353259051678972 PCcode : Ù'¢V*ß NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\353259051678964_35 3259051678972_XG213_CRT.rpl ===Flashing [MCU]=== File : 3998CC21_rm827__03.04.mcusw Image : rm827__03.04.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:00:49 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:38 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip ===Flashing [PPM]=== File : E3E09E22_rm827__03.04.ppm_m1 Image : package_m1.ppm_ebl_psi.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:08 Write , Start : 0x41BC0000 , Len : 0x003DF0A4 Flashing , wait ... Region flash done, time : 00:00:05 ===Flashing [CNT]=== File : 3A4647A9_rm827__03.04.image_m1_059N416 Image : package_m1_059N416.image.fls Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:00:57 Write , Start : 0x421C0000 , Len : 0x00E40000 Flashing , wait ... Region flash done, time : 00:00:20 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip Flashing done! Total flash time : 00:03:06 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 110 Software Info: V 03.04 20-04-12 RM-827 (c) Nokia IMEI: 353259051678964 PPM version : V 03.04 20-04-12 RM-827 (c) Nokia M1 Product code: 059P7V6 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 42 certs Data exist, skip certificate repair... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:03:50 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 110 Software ver : V 03.04 20-04-12 RM-827 (c) Nokia IMEI 1 : 353259051678964 IMEI 2 : 353259051678972 PPM : V 03.04 20-04-12 RM-827 (c) Nokia M1 CNT : Content: m1_059N416 V 03.04 20-04-12 RM-827 (c) Nokia Product SN : A09290BAH Product code : 059P7V6 Base Prd.code: 059K3X3 Module code : 0205081 Long Prod.SN : 0 Hardware info======= HWID : 1100 Batery: 4270 mV CMT BT: 19b5-22012 LCDVer: TPO Lock info =========== IMEI : 353259051678964 IMEI spNet : 3A 35 52 09 15 76 98 06 IMEI svNet : 33 35 52 09 15 76 98 06 F2 Sl Conf : 001-01-00000000000 Sl Prof : 800000000004000-B Sl Aux : 000B0000 Hw Sig : 991D44DDE0C8C311 Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; CRT308 Backup Created INFINEON : SuperDongle not exist (It is Ok) CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL30 (20 digit) phone detected... |
