07-02-2013, 08:20 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: In My Shop, Bangladesh
Member: 733449 Status: Offline Sonork: 100.334100 Thanks Meter: 292 | Successfully flashed Nokia 206 Rm-872 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm872__03.58.mcusw PPM : rm872__03.58.ppm_a3 CNT : rm872__03.58.image_a3_059Q4B2 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 355922051726707 IMEI 2 : 355922051726715 PCcode : ض3¸قàH NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\355922051726707_XG 213_CRT.rpl ===Flashing [MCU]=== File : rm872__03.58.mcusw Image : rm872__03.58.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:02:12 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:33 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip ===Flashing [PPM]=== File : rm872__03.58.ppm_a3 Image : package_a3.ppm_ebl_psi.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00680000 Erasing, wait ... Erase done, time : 00:00:28 Write , Start : 0x41A80000 , Len : 0x0042D09C Flashing , wait ... Region flash done, time : 00:00:04 ===Flashing [CNT]=== File : rm872__03.58.image_a3_059Q4B2 Image : package_a3_059Q4B2.image.fls Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:03:15 Write , Start : 0x42100000 , Len : 0x00EE0000 Flashing , wait ... Region flash done, time : 00:00:18 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:05 No write data, skip Flashing done! Total flash time : 00:07:07 Reboot phone now... Reading Phone Info.... Connected phone - 206 Software Info: V 03.58 05-12-12 RM-872 (c) Nokia IMEI: 355922051726707 PPM version : V 03.58 05-12-12 RM-872 (c) Nokia A3 Product code: 059Q467 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 42 certs Data exist, skip certificate repair... ===== WARNING ===== Battery voltage is NOT enough for start ===== WARNING ===== AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:07:50 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
The Following 3 Users Say Thank You to somratjisan For This Useful Post: |
