11-05-2012, 14:09 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Kumasi-Ghana
Member: 390204 Status: Offline Sonork: 100.1592805 Thanks Meter: 138 | Successfully generate Sim pm from full flash registered to: karikari Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 2B80011924865740B058D232CB6808E3FED5B28E ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : D172C32473AE199B213465ABB3853246F9631231 ADL: phone is in flash mode Reading NPC certificate... IMEI : 357398045209217 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\357398045209217_CR T_2nd.rpl Trying read spr block , wait ... Get phone data... Get flash data... SPR Read Ok! Spr saved to : 357398045209217.spr ADL: Close_Session Content: 0003000000000C0000000C00000000 ADL: Reboot Processing SimLock extraction.... Checking readed data, wait few seconds ID_INFO : 92PS1_10w46.9/01-03-11/RM-596 - > Initial check failed, SimLock seems FULLY dead - > You also can send it for check, but mostly chance is zero Elapsed: 00:00:45 Phone disconected! Connect phone on selected interface... Checking, wait ... Get phone info data from flash... IMEI : 357398045209217 NPC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\357398045209217_CR T_2nd.rpl Get secure data... ID_INFO : 79_sr1_11w42.7/03-04-12/RM-596 Initial data found, start fun... SimLock RPL saved : c:\InfinityBox\BEST\Backup\Cert\357398045209217_SI M.rpl SimLock PM saved : c:\InfinityBox\BEST\Backup\Cert\357398045209217_SI M.pm Done! Elapsed: 00:00:16 Thanks to best dongle team........................... |
