11-27-2010, 12:29 | #46 (permalink) | |||
Freak Poster Join Date: Jan 2008
Member: 671970 Status: Offline Sonork: 100.1578946 Thanks Meter: 40 | Quote:
MCU 59.60 ................ SL3 Quote:
Are you sure?? | |||
11-27-2010, 12:42 | #47 (permalink) |
Product Supporter Join Date: Jun 2010 Location: Infinity Team support
Member: 1330296 Status: Offline Thanks Meter: 1,137 | tested and working well : 2700c, 2730c, 2690c, 3600s, 5130, 5310, 6300, 6303, 6500s, N97, N97mini. |
The Following 33 Users Say Thank You to Infinity-BEST For This Useful Post: |
11-27-2010, 12:47 | #48 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: 95.0.206.212 Age: 35
Member: 1095116 Status: Offline Sonork: none Thanks Meter: 17 | Quote:
work is very very good and very nice but i have one question ? is support simlock for ? 2700c, 2730c, 2690c, 3600s, 5130, 5310, 6300, 6303, 6500s, N97, N97mini | |
11-27-2010, 12:49 | #49 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | Quote:
Code: BB5 HASH Supported based : 38F312750F686F9FC9B1B3778774A195 9A28E119033B91D14D22838C86D0D53C 9DDBFCFE6E73CED7D8C6268C8EB85723 A5404AE83A594ECADEE532F0C236BFA6 BAF3A9C3DBFA8454937DB77F2B8852B1 CAEEBB65D3C48E6DC73B49DC5063A2EE E9EFF4BFAA5393217CA6B17755FC3E14 F2D76DFAFD66C7F195F278417DF05888 F682624FFB08F6D955DBE7D9C0485084 FCB5C510AF7F09F313D9BDE85A707CC0 | |
The Following 3 Users Say Thank You to Mohsin-* For This Useful Post: |
11-27-2010, 13:18 | #52 (permalink) |
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | Nokia 6500s-1 V 59.60 Code: card found: S/N xxxx:xxxx registered to: Almoudamer DLL not found... Connect phone on selected interface... UFS S/N 74650 boot - Ok Connect phone on selected interface... Read and Check phone data... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 1FD000121A5B7D56565E83B2FDF83FA67A30FF8B CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 003F0001 < UNKNOW FLASHID : 003F0001 , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo.fg CMT Algo sent CMT PAPUB : 2A191B54288A818699B64E68916FE1E6A8562D3200 Transmission mode : Dual (Ddr, TX2) Boot Done! Init Service mode... Wait... SimLock status : SimLock is Ok Security status : Security is Ok Done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 6500s-1 Software ver : V 59.60 21-11-08 RM-240 (c) Nokia IMEI : 356854026796888 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR71_08w30 APE Test: PPM : V 59.60 21-11-08 RM-240 (c) Nokia CTM CNT : Content: c_uk_tmo_uk2_silver_v4 V 59.60 21-11-08 RM-240 (c) Nokia Product SN : 0 Product code : Base Prd.code: Module code : Long Prod.SN : 0 Hardware info======= HWID : Retu : 15 Tahvo : 22 Batery: 4795 mV Camera: CMT BT: Error APE BT: Error APE HW: Error LCDVer: Error RF ic : Error Lock info =========== IMEI : 356854026796888 IMEI spNet : IMEI svNet : Conf key : 8000000000000000 Provider key : 2343300000000000 Provider : Orange;United Kingdom Counters : Key 0 [3] , Fbus 0 [10] Blocks : 2 LOCK STATUS : ============================= BLK : 1 Lock1:Close BLK : 2 Lock1:Close ============================= LOCKS : Closed ============================= User Code : 567890 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Using F-bus count... Sending code 502315774118208 Level : 7 to SimLock Server... Simlock Server Answer: Unlock code Accepted! :) Done! Reading Phone Info.... Connected phone - Nokia 6500s-1 Software ver : V 59.60 21-11-08 RM-240 (c) Nokia IMEI : 356854026796888 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR71_08w30 APE Test: PPM : V 59.60 21-11-08 RM-240 (c) Nokia CTM CNT : Content: c_uk_tmo_uk2_silver_v4 V 59.60 21-11-08 RM-240 (c) Nokia Product SN : 0 Product code : Base Prd.code: Module code : Long Prod.SN : 0 Hardware info======= HWID : Retu : 15 Tahvo : 22 Batery: 4795 mV Camera: CMT BT: 2222-143 APE BT: APE HW: LCDVer: SEIKO RF ic : 17141715 Lock info =========== IMEI : 356854026796888 IMEI spNet : IMEI svNet : Conf key : 8000000000000000 Provider key : 2343300000000000 Provider : Orange;United Kingdom Counters : Key 0 [3] , Fbus 0 [10] Blocks : 2 LOCK STATUS : ============================= BLK : 1 Lock1:Open BLK : 2 Lock1:Open ============================= LOCKS : All Open ============================= User Code : 567890 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
11-27-2010, 13:41 | #54 (permalink) |
Crazy Poster Join Date: Nov 2010
Member: 1453295 Status: Offline Sonork: 100.1582347 Thanks Meter: 18 | Hi to All, In my opnion its activaton of 300 Dollor permanent and 10 dollor per phone. But better can tell Best-Infinity Product supporter. And will release on 25 of next month. Thanks |
The Following User Says Thank You to Dr Phones For This Useful Post: |
11-27-2010, 15:05 | #57 (permalink) |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | DEAR BEST OF THE BEST TEAM JUST CHECK OUT HAVE I DONE GOOD OR NOT ? NOKIA_5230_UNLOCKED UFS S/N 88897 boot - Ok Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Using F-bus count... Sending code 044037172516238 Level : 1 to SimLock Server... Simlock Server Answer: Unlock code Accepted! Done! BR |
11-27-2010, 15:07 | #58 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 444805 Status: Offline Thanks Meter: 45 | Post all Successfylly SL3 unlock by BB5 easy Service Tool (NOKIA) Best Dongle Best dongle by Infinity card found: S/N xxxx:xxxx registered to: Infinity_bb5 Connect phone on selected interface... UFS S/N 90xxx boot - Ok Connect phone on selected interface... Read and Check phone data... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 2A40011034D58A564F0A7743B097C2D8CD0B2DE4 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 220C00EC < SAMSUNG [SEC] => K5G1257ATM FLASHID : 220C00EC , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo.fg CMT Algo sent CMT PAPUB : 9EB6E045546186CE2AD1CFB8ED40771C6FD8A71C00 Transmission mode : Dual (Ddr, TX2) Boot Done! Init Service mode... Wait... SimLock status : SimLock is Ok Security status : Security is Ok Done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 3600 slide Software ver : V 56.26 18-03-09 RM-352 (c) Nokia IMEI : 355222031231948 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR72_08w48 APE Test: PPM : V 56.26 18-03-09 RM-352 (c) Nokia C CNT : Content: c_uk_charcoal_sl2 V 56.26 18-03-09 RM-352 (c) Nokia Product SN : KDS827171 Product code : 0589682 Base Prd.code: 0590344 Module code : 0204465 Long Prod.SN : 0 Hardware info======= HWID : 2006 Retu : 15 Tahvo : 22 Batery: 4694 mV Camera: CMT BT: 2222-143C APE BT: APE HW: LCDVer: SEIKO RF ic : 06540601 Lock info =========== IMEI : 355222031231948 IMEI spNet : IMEI svNet : Conf key : 8000000000000000 Provider key : 2341500000000000 Provider : Vodafone;United Kingdom Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= User Code : not set MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Using F-bus count... Sending code 776414685321453 Level : 7 to SimLock Server... Simlock Server Answer: Unlock code Accepted! Done! Reading Phone Info.... Connected phone - Nokia 3600 slide Software ver : V 56.26 18-03-09 RM-352 (c) Nokia IMEI : 355222031231948 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR72_08w48 APE Test: PPM : V 56.26 18-03-09 RM-352 (c) Nokia C CNT : Content: c_uk_charcoal_sl2 V 56.26 18-03-09 RM-352 (c) Nokia Product SN : KDS827171 Product code : 0589682 Base Prd.code: 0590344 Module code : 0204465 Long Prod.SN : 0 Hardware info======= HWID : 2006 Retu : 15 Tahvo : 22 Batery: 4702 mV Camera: CMT BT: 2222-143C APE BT: APE HW: LCDVer: SEIKO RF ic : 06540601 Lock info =========== IMEI : 355222031231948 IMEI spNet : IMEI svNet : Conf key : 8000000000000000 Provider key : 5150300000000000 Provider : Vodafone;United Kingdom Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Open ============================= LOCKS : All Open ============================= User Code : not set MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
The Following 4 Users Say Thank You to SilentHawk For This Useful Post: |
11-27-2010, 15:09 | #59 (permalink) | |
