10-06-2018, 12:34 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: cameroon
Member: 260658 Status: Offline Thanks Meter: 184 | Sx4 server problem Card found: S/N : CC5B2A0C , v0137 Registered to: nyakam Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok SD Authentification : not done Local SX4 Card Not Found, wil use Server Started Connecting to SX4 server... Connection faled: Socket Error # 10060 Connection timed out. SX4 Disconnected Error while operation, check previous message for more info Here is best.ini: [srv] sx4=ext3.infinity-best.com port=1083 [auth] server=ext2.infinity-best.com port=1082 [verify] Flverify=1 cntverify=1 DieID=1 Mode=0 [stuff] WD2Force=0 FAsk=0 extchk=1 altway=0 JFN=1 JNR=1 XG1_BL=0 Hver=1 SoundEvent=1 LongDelay=0 checkid=1 checdeadksw=1 IfEs=1 SamAct=010101 [miriel] on=1 S40_all_on=1 S60_S1_on=1 S60_S3_on=1 [server] API=http://service.infinity-box.com/api/ OnlineService=http://user.infinity-box.com =# Set NaviFFLs option to 1 , if want download COMPLETE firmware package with all garbage NaviFFls=0 WP8Unlock=1 [Download] server-1=http://dl1.infinity-best.com/47 server-2=http://dl2.infinity-best.com/47 [Update] URL= [Configurator] Version=1 Date=2018-08-09 |
10-06-2018, 13:40 | #2 (permalink) |
Member: 260658 Status: Offline Thanks Meter: 184 | Card found: S/N : CC5B2A0C , v0137 Registered to: nyakam Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok === Main info === NCSD Version : 5.0 Sw Version : 02074.00000.15234.28004 IMEI : 353707072448445 ProductCode : 059W877 ProductCodeB : 059W248 ProductSN : 678A3E3AB Module Code : 0206285 === HW info === Public ID : 776C09218803E13F6EC4916CE3F1545EB2B50338 HW Version : 3000 BT Addr. : A4516FFE9A5C Wlan Mac : A4516FFFC844 Battery Level : 60 % === Branding and security info === Operator : SWI-CH SimLock : Locked! SimLock : 2280100000000 Country : Switzerland Operator : Swisscom Branding : RM-1089_1006 Sec. Mode : Restricted Done! [WP8x] : Init TesMode [TSTM] : Use File : RM1089_2074.0000.9651.14234.207.694_enosw-wim-signed_803881.secwim === Base Phone Info Sw Version : 02074.00000.15234.28004 IMEI : 353707072448445 ProductCode : 059W877 Device catched in BOOT mode! Collect Info... === Nokia Flash App info : Protocol Version : 2.34 Protocol Implementation : 2.59 === Phone Initial info : Phone Model ID : Nokia.MSM8212.P6214.1.1 === eMMC info : eMMC Vendor : Hynix eMMC CID : 0090 eMMC Size : 7456 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : BC2353ACA62C327ECCD582A281CA4A5672F35001 === Other info : SD present : False SECWIM : RM1089_2074.0000.9651.14234.207.694_enosw-wim-signed_803881.secwim Sending WIM ... WIM Image sent! Trying init TestMode now... Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Phone disconected! Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Phone disconected! Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Card found: S/N : CC5B2A0C , v0137 Registered to: nyakam Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok === Main info === SecLabel Version : Security LabelSW (wim) 18.2074.366.221 Sw Version : RM1089 2074.0000.9651.14234 803881 2015/04/27 //roll_engine/asset_integration_RG1\r\n IMEI : 353707072448445 ProductCode : 059W877 ProductSN : 678A3E3AB Module Code : 0206285 === HW info === Public ID : 776C09218803E13F6EC4916CE3F1545EB2B50338 BT Addr. : A4516FFE9A5C Wlan Mac : A4516FFFC844 === Branding and security info === Sec. Mode : Restricted Conf key : 8000000000000000 Provider key : 2280100000000000 Country : Switzerland Operator : Swisscom Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= Making RPL backup... NPC : Read Ok , [520] IMEI : 353707072448445 CCC : Certificate not available HWC : Certificate not available RDC : Certificate not available NPC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\353707072448445_CR T.rpl Done! Card serial: CC5B2A0C Card type: BEST Dongle Card password: SYFMtagn Link to my account: http://user.infinity-box.com Login: Lumiaunlocker Connecting to server... Error with message : HTTP/1.1 500 Access denied `Lumiaunlocker` Auth Card serial: CC5B2A0C Card type: BEST Dongle Card password: SYFMtagn Link to my account: http://user.infinity-box.com Login: Lumiaunlocker Connecting to server... Credits: 2502 SD Authentification : not done Local SX4 Card Not Found, wil use Server Started Connecting to SX4 server... Connection faled: Socket Error # 10060 Connection timed out. SX4 Disconnected Error while operation, check previous message for more info WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Need SDAuth to finish ... Started Connecting to SX4 server... Connection faled: Socket Error # 10060 Connection timed out. SX4 Disconnected SX4 Failed, will retry Auth again ... Started Connecting to SX4 server... Connection faled: Socket Error # 10060 Connection timed out. SX4 Disconnected SDAuth not done! Try make SX4 after 1-2 minute and make "Unlock" again! Error! Check previous error message for more info! please need help |
10-08-2018, 03:41 | #4 (permalink) |
Member: 260658 Status: Offline Thanks Meter: 184 | Still no unlock, hang on authenticating... Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok SD Authentification : not done Local SX4 Card Not Found, wil use Server Started Connecting to SX4 server... Connected SX4 enter .. SDAuth Ok! SX4 Disconnected SX4 Done! Done! WP8 Unlock Started Connecting to server... Connected Authenticating... |
10-08-2018, 09:54 | #5 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | WP8 Unlock Started Connecting to server... Connected Authenticating... same issue with me plz fix it as soon as possible |
10-08-2018, 10:43 | #7 (permalink) |
Member: 260658 Status: Offline Thanks Meter: 184 | thank's problem solved WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Unlock Done! Wait for phone reboot ... Reboot Ok! Phone disconected! Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok |
