05-02-2019, 18:01 | #1 (permalink) |
No Life Poster Join Date: Mar 2016 Location: Ukraine
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Nokia 105 2017 TA-1034 Flashing Done with BEST2 Code: Operation : Identify [ v1.15 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM144) MODE : NOKIA USB SERIAL PORT : 144 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : B46D9F8126F758A65D7A4C9A2B72AAC4 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.30.04.11.p1 BOOT : SWR : 30.04.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : N103.30.04.11.p1 FLASH : 00C2 : 0025 : 0036 : 0000 BBSN : B46D9F8126F758A65D7A4C9A2B72AAC4 PRDC : 059Z1D1 IMEI[1] : 354193108459558 IMEI[2] : 354193109459557 NCK : 20 digits PROV : 24407000 Saved as : 354193108459558.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:00:59 Code: Open VPLfile : TA-1034_059Z0Z5_30.04.11.vpl Description : TA-1034 EI DeviceType : TA-1034 ProductCode : 059Z0Z5 SoftwareVer : 30.04.11 PPM LangPack : [1] : Georgian (Georgia) [2] : Armenian (Armenia) [3] : Romanian (Romania) [4] : Ukrainian (Ukraine) [5] : Belarusian (Belarus) [6] : Russian (Russia) [7] : Kazakh (Kazakhstan) [8] : Azeri (Azerbaijan) [9] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.15 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM144) MODE : NOKIA USB SERIAL PORT : 144 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : B46D9F8126F758A65D7A4C9A2B72AAC4 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.30.04.11.p1 BOOT : SWR : 30.04.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.30.04.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4,00 MB ] PSIZE : 0x00400000 [ 4,00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 30.04.11 [TA-1034] DEV SoftwareVersion : 30.04.11 SWInfo compare result : SAME Load FlashSet : MROM : TA-1034_ROM_eMP_30.04.11 LANG : TA-1034_LANG_PACK_ROM_EI_eMP_30.04.11_001 CUST : TA-1034_CUSTPACK_ROM_EI_eMP_30.04.11_001 JUMP : TA-1034_JUMP_TABLE_EI_eMP_30.04.11_001 VIVA : TA-1034_VIVA_eMP_30.04.11 Prepare FlashSet : DCR : TA-1034_ROM_eMP_30.04.11 DCR : TA-1034_LANG_PACK_ROM_EI_eMP_30.04.11_001 DCR : TA-1034_CUSTPACK_ROM_EI_eMP_30.04.11_001 DCR : TA-1034_JUMP_TABLE_EI_eMP_30.04.11_001 DCR : TA-1034_VIVA_eMP_30.04.11 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : TA-1034_ROM_eMP_30.04.11 Write : TA-1034_LANG_PACK_ROM_EI_eMP_30.04.11_001 Write : TA-1034_CUSTPACK_ROM_EI_eMP_30.04.11_001 Write : TA-1034_JUMP_TABLE_EI_eMP_30.04.11_001 Write : TA-1034_VIVA_eMP_30.04.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1034_ROM_eMP_30.04.11 Verify : TA-1034_LANG_PACK_ROM_EI_eMP_30.04.11_001 Verify : TA-1034_CUSTPACK_ROM_EI_eMP_30.04.11_001 Verify : TA-1034_JUMP_TABLE_EI_eMP_30.04.11_001 Verify : TA-1034_VIVA_eMP_30.04.11 Done! Elapsed: 00:01:18 |
