10-07-2021, 12:34 | #1 (permalink) |
Junior Member Join Date: Sep 2015 Location: hyderabad
Member: 2464278 Status: Offline Thanks Meter: 3 | nokia 150 contact service CODE 059X9F6 FLASH FILE NOT AVAILABLE IN SUPPORT AREA.... PLEASE PROVIDE LINK..... I FALSHED WITH OTHER FILE NOW HANG ON CONTACT SERVICE.... PLS HELP. |
10-07-2021, 14:49 | #3 (permalink) | |
Member: 2464278 Status: Offline Thanks Meter: 3 | Already checked.... Quote: CBR IS OK Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1190_DUBAI_ROM_eMP_11.00.11 VIVA : RM-1190_DUBAI_VIVA_eMP_11.00.11 LANG : RM-1190_DUBAI_LANG_PACK_ROM_IC_eMP_11.00.11 CUST : RM-1190_DUBAI_CUSTPACK_ROM_IC_eMP_11.00.11 JMPT : RM-1190_DUBAI_JUMP_TABLE_IC_eMP_11.00.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 18 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 8163738E5D89CF71A127F14B68CA2A30 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DUBAI61D.40.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Dubai.fg DA_VERIFY : 00 DA_JUMP : 00100000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A0000-0x003F7FFF , LEN : 0x00058000 SecureDecrypt : RM-1190_DUBAI_ROM_eMP_11.00.11 SecureDecrypt : RM-1190_DUBAI_VIVA_eMP_11.00.11 SecureDecrypt : RM-1190_DUBAI_LANG_PACK_ROM_IC_eMP_11.00.11 SecureDecrypt : RM-1190_DUBAI_CUSTPACK_ROM_IC_eMP_11.00.11 SecureDecrypt : RM-1190_DUBAI_JUMP_TABLE_IC_eMP_11.00.11 Executing FFS FORMAT now... FAT_RANGE : 0x003A0000-0x003F7FFF , LEN : 0x00058000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE OVRLP : 000069B900000001 PHPID : DUBAI61D.40.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1190_DUBAI_ROM_eMP_11.00.11 Write : RM-1190_DUBAI_LANG_PACK_ROM_IC_eMP_11.00.11 Write : RM-1190_DUBAI_CUSTPACK_ROM_IC_eMP_11.00.11 Write : RM-1190_DUBAI_JUMP_TABLE_IC_eMP_11.00.11 Write : RM-1190_DUBAI_VIVA_eMP_11.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1190_DUBAI_ROM_eMP_11.00.11 [VERIFY] DONE : RM-1190_DUBAI_LANG_PACK_ROM_IC_eMP_11.00.11 [VERIFY] DONE : RM-1190_DUBAI_CUSTPACK_ROM_IC_eMP_11.00.11 [VERIFY] DONE : RM-1190_DUBAI_JUMP_TABLE_IC_eMP_11.00.11 [VERIFY] DONE : RM-1190_DUBAI_VIVA_eMP_11.00.11 CODE_VERIFY : Ok Flashing done! Total flash time : 00:00:59 Reboot phone Ok ReadInfo can't be done! Re-insert battery and power up phone manually Connect phone on selected interface... ALSO --- Insert USB cable now! --- Wait for phone... Phone found! [ 18 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 8163738E5D89CF71A127F14B68CA2A30 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DUBAI61D.11.00.11.p1 BROM/BL stage done Configure RAMINIT Ok Reading flash now ... Done! Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive Mobile Info IMEI : 356009081475445 BBUID : 8163738E5D89CF71A127F14B68CA2A30 PCCode: 059X9F6 SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 356009081475445_MTKx_2nd.mtsec Read Done! Connect phone on selected interface... | |
10-07-2021, 15:39 | #5 (permalink) | |
Member: 2464278 Status: Offline Thanks Meter: 3 | Tried but same.. Quote: Verify files ... MAUI : RM-1190_DUBAI_ROM_eMP_40.00.11 VIVA : RM-1190_DUBAI_VIVA_eMP_40.00.11 LANG : RM-1190_DUBAI_LANG_PACK_ROM_IC_eMP_40.00.11 CUST : RM-1190_DUBAI_CUSTPACK_ROM_IC_eMP_40.00.11 JMPT : RM-1190_DUBAI_JUMP_TABLE_IC_eMP_40.00.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 18 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 8163738E5D89CF71A127F14B68CA2A30 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DUBAI61D.11.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Dubai.fg DA_VERIFY : 00 DA_JUMP : 00100000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A0000-0x003F7FFF , LEN : 0x00058000 SecureDecrypt : RM-1190_DUBAI_ROM_eMP_40.00.11 SecureDecrypt : RM-1190_DUBAI_VIVA_eMP_40.00.11 SecureDecrypt : RM-1190_DUBAI_LANG_PACK_ROM_IC_eMP_40.00.11 SecureDecrypt : RM-1190_DUBAI_CUSTPACK_ROM_IC_eMP_40.00.11 SecureDecrypt : RM-1190_DUBAI_JUMP_TABLE_IC_eMP_40.00.11 Executing FFS FORMAT now... FAT_RANGE : 0x003A0000-0x003F7FFF , LEN : 0x00058000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE OVRLP : 000069B900000001 PHPID : DUBAI61D.11.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1190_DUBAI_ROM_eMP_40.00.11 Write : RM-1190_DUBAI_LANG_PACK_ROM_IC_eMP_40.00.11 Write : RM-1190_DUBAI_CUSTPACK_ROM_IC_eMP_40.00.11 Write : RM-1190_DUBAI_JUMP_TABLE_IC_eMP_40.00.11 Write : RM-1190_DUBAI_VIVA_eMP_40.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1190_DUBAI_ROM_eMP_40.00.11 [VERIFY] DONE : RM-1190_DUBAI_LANG_PACK_ROM_IC_eMP_40.00.11 [VERIFY] DONE : RM-1190_DUBAI_CUSTPACK_ROM_IC_eMP_40.00.11 [VERIFY] DONE : RM-1190_DUBAI_JUMP_TABLE_IC_eMP_40.00.11 [VERIFY] DONE : RM-1190_DUBAI_VIVA_eMP_40.00.11 CODE_VERIFY : Ok Flashing done! Total flash time : 00:00:59 Reboot phone Ok ReadInfo can't be done! Re-insert battery and power up phone manually Connect phone on selected interface... | |
10-07-2021, 16:11 | #9 (permalink) | |
Member: 2464278 Status: Offline Thanks Meter: 3 | again failed.....BUT THNAKS FOR YOUR SUPPORT....... Quote: Verify files ... MAUI : RM-1190_ROM_eMP_60.04.11 VIVA : RM-1190_VIVA_eMP_60.04.11 LANG : RM-1190_LANG_PACK_ROM_IC_eMP_60.04.11_001 CUST : RM-1190_CUSTPACK_ROM_IC_eMP_60.04.11_001 JMPT : RM-1190_JUMP_TABLE_IC_eMP_60.04.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 18 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 8163738E5D89CF71A127F14B68CA2A30 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : DUBAI61D.40.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Dubai.fg DA_VERIFY : 00 DA_JUMP : 00100000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A0000-0x003F7FFF , LEN : 0x00058000 SecureDecrypt : RM-1190_ROM_eMP_60.04.11 SecureDecrypt : RM-1190_VIVA_eMP_60.04.11 SecureDecrypt : RM-1190_LANG_PACK_ROM_IC_eMP_60.04.11_001 SecureDecrypt : RM-1190_CUSTPACK_ROM_IC_eMP_60.04.11_001 SecureDecrypt : RM-1190_JUMP_TABLE_IC_eMP_60.04.11_001 OVRLP : 000069B900000001 PHPID : DUBAI61D.40.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1190_ROM_eMP_60.04.11 Write : RM-1190_LANG_PACK_ROM_IC_eMP_60.04.11_001 Write : RM-1190_CUSTPACK_ROM_IC_eMP_60.04.11_001 Write : RM-1190_JUMP_TABLE_IC_eMP_60.04.11_001 Write : RM-1190_VIVA_eMP_60.04.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1190_ROM_eMP_60.04.11 [VERIFY] DONE : RM-1190_LANG_PACK_ROM_IC_eMP_60.04.11_001 [VERIFY] DONE : RM-1190_CUSTPACK_ROM_IC_eMP_60.04.11_001 [VERIFY] DONE : RM-1190_JUMP_TABLE_IC_eMP_60.04.11_001 [VERIFY] DONE : RM-1190_VIVA_eMP_60.04.11 CODE_VERIFY : Ok Flashing done! Total flash time : 00:01:00 Reboot phone Ok ReadInfo can't be done! Re-insert battery and power up phone manually Connect phone on selected interface... | |
10-07-2021, 16:13 | #10 (permalink) | |
Member: 2464278 Status: Offline Thanks Meter: 3 | First only blinking problem.... Quote: only contact servie.... Do you have v10 flash file... Thanks..... | |
10-07-2021, 16:24 | #11 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,804 | YOUR PHONE IS HMD OR MICROSOFT TRY THIS https://forum.gsmhosting.com/vbb/f64...190-a-2196435/ AND THIS https://forum.gsmhosting.com/vbb/f64...-user-2239048/ |
10-08-2021, 07:32 | #12 (permalink) | |
Member: 2464278 Status: Offline Thanks Meter: 3 | unable to download Quote:
thanks..... | |
