04-24-2013, 11:33 | #1 (permalink) |
Freak Poster Join Date: May 2012 Location: Beirut Age: 39
Member: 1759307 Status: Offline Sonork: 100.1636995 Thanks Meter: 56 | unable to create file for lbf nokia c2-01 i am trying to create file for lbf but i am getting error i tried in another pc but same problem i changed cables , installed latest nokia connectivity cable driver but same problem i am using best donlge easy service tool v1.62 here is the log __________________________________________________ ___ Phone found! Series 40 Device detected! read info... - Ok Phone Imei: 35xxxxxxxxxx Checking locks... Conf key : 8000000000000000 Provider key : 2280100000000000 Country : Switzerland Operator : Swisscom Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= PA_SL3 (15 digit) phone detected... - > Power Off phone, dissconnect it and connect Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... ASIC ID: 000000010000022600000001020C192102044100 CPU ID : RAP3Gv4 , Features : Dead-Test , USBRPL , FullUSB PUBLIC ID: 2E60010D028214491B911015E3666D5CF4F05482 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D Fetching data, wait... Boot error #2, break - > Reinsert cable and battery, press powerOn button again - > For X7, E7 - just waiting, near 1 minute - > When BEST start Search Phone - Press PowerOn if needed Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Phone disconected! Connect phone on selected interface... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600000001020C192102044100 CPU ID : RAP3Gv4 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 2E60010D028214491B911015E3666D5CF4F05482 ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 Use RAP3Gv40_2nd.fg , Rev : 3.0 Ver : 12.8.0 Processing RAWLOADER... Phone disconected! Connect phone on selected interface... MCU configuration response not received, 2nd boot fail - > Critical Error : NO FLASH DEVICE DETECTED (DAMAGED FLIC ???) - > Charge battery, Check USB port, Cable. Try again Boot error... Minor error, phone reboot not done #2 (Phone was not BootUp) rap= hash= key= - > Keys was readed sucefully! - > You can ignore it, power up phone manually - > Or repeat procedure again __________________________________________________ _________ i hope someone can help |
04-24-2013, 12:01 | #4 (permalink) |
Member: 1759307 Status: Offline Sonork: 100.1636995 Thanks Meter: 56 | i am unable to flash it __________________________________________________ ___ Connect phone on selected interface... Core : v1.62 , BB5XG FlashEngine : v4.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm721__11.10.mcusw PPM : rm721__11.10.ppm_meaa CNT : rm721__11.10.image_meaa_059D5D6_006 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600000001020C192102044100 CPU ID : RAP3Gv4 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 3160010D028214492D32062371D93DA08BB6EA81 ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 Use RAP3Gv40_2nd.fg , Rev : 3.0 Ver : 12.8.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAP3Gv40_XSR17_alg.fg , Rev : 3.0 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 ADL: Check mode ADL: phone is in flash mode === SW Version Check === - > Can not collect initial info, continue flashing... - > Hope, this version will be ok === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm721__11.10.mcusw Partitioning.... Partitioning error! Phone Not respond! Connect phone on selected interface... Elapsed: 00:00:47 Connect phone on selected interface... _________________________________________________ |
