10-20-2013, 09:37 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: India Age: 37
Member: 145082 Status: Offline Thanks Meter: 798 | unable to unlock N95 on best ?? Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia N95 Software ver : V 06wk41v64.23 05-11-09 RM-159 (c) Nokia IMEI : 353094029002850 XappVer : 000006BE APE Var : 35.0.00219.01 APE ADSP: 256 DSP Ver : aalto.ICPR62_08w28p2 APE Test: rm159_eno_2007wk16v0.175 PPM : CNT : Product SN : SBK427830 Product code : 0546659 Base Prd.code: 0530865 Long Prod.SN : Error Hardware info======= HWID : Error Retu : 15 Tahvo : 22 Batery: 4464 mV APE BT: HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10. APE HW: 1 RF ic : 17141715 Lock info =========== IMEI : 353094029002850 IMEI spNet : IMEI svNet : Conf key : 0000000000000000 Provider key : 2343000000000000 Country : United Kingdom Operator : T-Mobile UK Counters : Key 0 [3] , Fbus 0 [10] Blocks : 2 LOCK STATUS : ============================= BLK : 1 Lock1:Close BLK : 2 Lock1:Close ============================= LOCKS : Closed ============================= User Code : 12345 UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Unlock procedure started... Phone Imei: 353094029002850 Checking locks... Conf key : 0000000000000000 Provider key : 2343000000000000 Country : United Kingdom Operator : T-Mobile UK Counters : Key 0 [3] , Fbus 0 [10] Blocks : 2 LOCK STATUS : ============================= BLK : 1 Lock1:Close BLK : 2 Lock1:Close ============================= LOCKS : Closed ============================= PA_SL phone detected... Key file exists, no need to read... NCK unlock failed, will try direct RPL Phone Imei: 353094029002850 Key file exists, no need to read... Operating mode is OK, no need change... Writing SimLock Data... Ok Writing SimLock Key... Error Direct RPL Unlock Error! [SL3 phone?] what can be done here working since 10 yr never seen N95 SL3 phone whats the problem here.... |
10-20-2013, 09:40 | #2 (permalink) |
Member: 145082 Status: Offline Thanks Meter: 798 | Checking BUS... Switch jaf to FlashMode... FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... Switch jaf to FlashMode... FlashMode set Ok Booting phone... BOOT 1ST : C0 APE part info : APE ASICID : 24200705 APE MODE ID : 00 APE PUB ID : 857F37B3592DE2FC3401E95997CE3AE70B6872F2 APE R_HASH : BA8710A7E1CD5A2909B9A875DB27AA24 CMT part info : CMT ASICID : 000000010000022600010006400C192101021103 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 052001142D63005242AC02C6955DADEB7EA32086 CMT MODE ID : 00 CMT R_HASH : CAEEBB65D3C48E6DC73B49DC5063A2EE CMT ROM ID : A8C1D6713E691FF8 CMT : Sending 2nd loader... Use : RAPIDOv11_2nd.fg , Rev : 0.0 Ver : 1.37.1 CMT Loader sent, Boot Ok MCU configuration CMT Flash ID : 00350001 < SPANSION => 72NS128N FLASHID : 00350001 , CMT , NOR FLCNT : 00000000000000000000000000000000000000 CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok FLASHID : 0000FFFF , CMT , MMC , EXT TransmissionReq : 16 bit, Single TransmissionReq : Accepted, 16 bit, Single Sending ALGO.... Use : RAPIDOv11_algo.fg , Rev : 0.0 Ver : 1.40.0 CMT Algo sent! TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual PAPUBKeys : 25129A39D9A3B031CA0124E1E90F5A17ED3EFC896F APE : Sending 2nd loader... Use : omap2420_m1_2nd.fg , Rev : 0.0 Ver : 1.39.0 APE Loader sent, Boot Ok MCU configuration APE Flash ID : 004000EC < SAMSUNG [SEC] => KAT00F00RA [NAND] FLASHID : 004000EC , APE , NAND ReqAlgo : APE , OMAP2420 UNISTORE-II-1.5.1 ALG APE Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok FLASHID : 0000FFFF , APE , MMC , EXT Sending ALGO.... Use : teflon_sam_nand_xsr151_m1.fg , Rev : 0.0 Ver : 1.52.0 APE Algo sent! TransmissionReq : 32 bit, Dual TransmissionReq : Accepted, 32 bit, Dual PAPUBKeys : 25129A39D9A3B031CA0124E1E90F5A17ED3EFC896F Boot done! CMT : Read PASUBTOC certificate... PA_INFO : DETECTED SL : PA_SL |
