12-26-2012, 07:00 | #1 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1015551 Status: Offline Thanks Meter: 59 | unable to write pm in nokia rm-774 phone has phone startup failed contact retailer problem Phone Imei: 358272041386247 Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" enabled, try again now - > If SDD original - "Use Server Sx4" Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358272041386247 Use custom key... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" disabled, try again now - > If SDD original - "Use Server Sx4" Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358272041386247 Use custom key... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" disabled, try again now - > If SDD original - "Use Server Sx4" Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358272041386247 Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" enabled, try again now - > If SDD original - "Use Server Sx4" SX4 still disabled till 1.6x/2.0 , sorry for delays Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358272041386247 Use custom key... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" disabled, try again now - > If SDD original - "Use Server Sx4" Uploading RF/Battery tune to phone... RM-774.pm not exist Select file, please No any file selected, break operation Upload failed Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358272041386247 Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" enabled, try again now - > If SDD original - "Use Server Sx4" SX4 still disabled till 1.6x/2.0 , sorry for delays Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358272041386247 Use custom key... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" disabled, try again now - > If SDD original - "Use Server Sx4" Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358272041386247 Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" enabled, try again now - > If SDD original - "Use Server Sx4" Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358272041386247 Use custom key... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" disabled, try again now - > If SDD original - "Use Server Sx4" Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358272041386247 Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" enabled, try again now - > If SDD original - "Use Server Sx4" |
01-26-2013, 13:16 | #5 (permalink) |
Insane Poster Join Date: Apr 2011 Location: East Java - Indonesia Age: 31
Member: 1560797 Status: Offline Thanks Meter: 6 | we have same problem Code: Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! :( - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! Check SD : Key is Ok Phone Imei: 354200036419495 Use custom key... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" disabled, try again now - > If SDD original - "Use Server Sx4" |
