03-21-2016, 21:32 | #1 (permalink) |
Freak Poster Join Date: Jun 2014 Location: ALL THINGS ARE POSIBLE WTH ***
Member: 2203712 Status: Offline Sonork: 100.1667064 Thanks Meter: 82 | Urgent help needed CONDITION:USER PASSWORD TRIED TO FLASH BUT THIS IS THE ERROR THAT I GET. ANY SOLUTIONS? Core : v2.19 , BB5XG FlashEngine : v10.0 Selected FlashSettings : FullFlash File [Ok] : rm899_14.0.5.mcusw.fpsx File [Ok] : rm899_14.0.5_059R6C0_m4.rofs.fpsx File [Ok] : rm899_14.0.5_059R6C0_m4.image.fpsx Dead Mode is Selected Waiting for USB device... If PC not detect phone - Insert Cable first, then Insert battery If stuck on boot - remove MicroSD card from phone! --- Press phone's power button or insert cable & charger! --- 1st Boot Done, processing booting now ASIC ID_F : 00000C2016100040498A21099A2278D20B27B133 ASIC ID_E : 00000C2016100040 PUBLIC ID : 739151337488F6D2498A21099A2278D20B27B133 XGCHIP ID : 739151337488F6D2 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 355523050120973 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\355523050120973_XG 223_CRT.rpl PAPUBkeys : B45D33F7E5B2F73BBBAFBCA173B06B46F1861C70 === PPM_ID Check === - > PPM_ID LOWER, THAN IN PHONE!!! - > Find other ID version and try again! - > Stop killing phone, break flashing! === PPM_ID Check === Error During flashing http://i.imgur.com/ltVoTMV.png |
03-21-2016, 22:49 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. You must select version with NEW region or atleast same. All can be found on search ( AAsha OS PPM info ) There is other trick - select CONTENT only. And flash it. |
03-22-2016, 07:35 | #3 (permalink) |
Member: 2203712 Status: Offline Sonork: 100.1667064 Thanks Meter: 82 | Hello. You must select version with NEW region or atleast same. All can be found on search ( AAsha OS PPM info ) There is other trick - select CONTENT only. And flash it.[/QUOTE] HOW TO SELECT CONTENT ONLY? |
