08-02-2013, 19:20 | #1 (permalink) |
No Life Poster Join Date: Oct 2007
Member: 605126 Status: Offline Sonork: 100.1617907 Thanks Meter: 297 | Warning plz dont flash phone with BEST_v1.67 here is proof log, Reading Phone Info.... Connected phone - X2-01 Software ver : V 08.70 29-07-11 RM-709 (c) Nokia IMEI : 12345610654321? XappVer : 00000686 PPM : V 08.70 29-07-11 RM-709 (c) Nokia I2 CNT : Content: i2_059C3Q2 V 08.70 29-07-11 RM-709 (c) Nokia Product SN : CHN866847 Product code : 059K9B8 Base Prd.code: 059B859 Module code : 0204674 Long Prod.SN : 0 Hardware info======= HWID : 1001 Batery: 3669 mV CMT BT: 2.31-SP2.31 LCDVer: SEIKO Lock info =========== IMEI : 12345610654321? IMEI spNet : 1A 32 54 16 60 45 23 01 IMEI svNet : 13 32 54 16 60 45 23 41 F2 Unable to read Lock table... IMEI DAMAGED!!! CRT308 save skipped... SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Reading Phone Info.... Connected phone - Nokia C6-01 Software ver : V 92_11w37.1 21-11-11 RM-601 (c) Nokia IMEI : 12345610654321? XappVer : 00000686 Ape Ver : 025.008 APE Var : 025.008025.008.22.01025.008.00.01 APE ADSP: 256 DSP Ver : 92_11w36 APE Test: 0.063 PPM : CNT : Product SN : CYE855894 Product code : Base Prd.code: 0585850 Module code : 0204365 Long Prod.SN : 0 Hardware info======= HWID : 0600 Retu : 40 Tahvo : 00 Batery: 3833 mV APE BT: HCI Version 20 (rev. 64). LMP Version 44 (rev. 64). Manufacturer 2016. APE HW: 256 Lock info =========== IMEI : 12345610654321? IMEI spNet : 1A 32 54 16 60 45 23 01 IMEI svNet : 13 32 54 16 60 45 23 21 F2 Unable to read Lock table... IMEI DAMAGED!!! CRT308 save skipped... SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! |
08-02-2013, 19:39 | #3 (permalink) | |
No Life Poster Join Date: May 2007 Location: .::Rawalpindi::.
Member: 500844 Status: Offline Sonork: 100.1680109 Thanks Meter: 285 | Quote:
answer is in log you flashed with wrong files | |
08-03-2013, 03:34 | #5 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Please, proofs.Thread seems like a blaming. I not like blaming. Facts. EVERY update, before put on public - pass TESTs, where is just flashing tests on 20-25 DIFFERENT sets. Only IF ALL IS OK - update going to public. We never put untested things, which can HARM your phone, if you do all right. |
The Following User Says Thank You to Dzirt For This Useful Post: |
08-03-2013, 05:42 | #7 (permalink) |
No Life Poster Join Date: May 2007 Location: QC FAIRVIEW
Member: 504865 Status: Offline Thanks Meter: 213 | Flashing SL3 phone with different Firmware Will damage IMEI of course. don't blame Best because of your fault Back-up first before you do any operation especially flashing |
08-05-2013, 13:41 | #8 (permalink) |
Member: 605126 Status: Offline Sonork: 100.1617907 Thanks Meter: 297 | thx to nomi 42us problem sloved after flash with different firmware sorry for my blame to best dongle... logs.. Reading Phone Info.... Connected phone - Nokia C5-03 Software ver : V ICPR82_11w25.7 05-12-11 RM-697 (c) Nokia IMEI : 356992047914484 XappVer : 00000686 Ape Ver : V 22.0.007 APE Var : V 22.0.00722.0.007 APE ADSP: 256 DSP Ver : 11w48 APE Test: 10.0.022_v008 PPM : CNT : Product SN : CDJ870940 Product code : 059F910 Base Prd.code: 059B215 Module code : 0204650 Long Prod.SN : 0 Hardware info======= HWID : 3092 Retu : 35 Tahvo : 00 Batery: 3680 mV APE HW: 256 Lock info =========== IMEI : 356992047914484 IMEI spNet : 3A 65 99 02 74 19 44 08 IMEI svNet : 33 65 99 02 74 19 44 08 F7 Conf key : 8000000000000000 Provider key : 2343000000000000 Country : United Kingdom Operator : T-Mobile UK Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! |
08-05-2013, 14:03 | #9 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Sounds good... But check beofer you post any thing compliaing regarding a product... It is kind of abusive.... I think thread can be closed now.... |
08-06-2013, 03:28 | #10 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Normally - BEST not allow flash one phone with firmware from other. But only, if their platforms are differ - BCM/RAPU/RAP - in fact, if you flash same platform - mostly - after enough reflash back and nothing should be damaged in result. |
