08-22-2014, 13:47 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: pakistan
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | what is difference between nokia sl3 15 and 20 digits info: Reading Phone Info.... Connected phone - 059N2G2 Software ver : IMEI : XappVer : 0000079E Ape Ver : V 03.60 17-11-11 RH-130(c) Nokia APE Var : 354585054429016 APE ADSP: V 03.60 17-11-11 RH-130(c) Nokia DSP Ver : 9N2G2 PPM : CNT : 354585054429016 Product SN : V 03.60 17-11-11 RH-130 (c) Nokia Product code : Base Prd.code: 059N2G2 Hardware info======= HWID : 354585054429016 Retu : V 03.60 17-11-11 RH-130 (c) Nokia Tahvo : 059N2G2 Batery: 6218 mV Lock info =========== IMEI : IMEI spNet : IMEI svNet : Conf key : 31310A52482D3133 Provider key : 300A286329204E6F Country : Unknown Operator : Unknown Counters : Key 0 [3] , Fbus 0 [10] Blocks : 97 LOCK STATUS : ============================= Error collect lock info, try again User code : Crypted MMC pwd : no any record found Done! |
08-22-2014, 13:55 | #2 (permalink) |
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | sorry this is correct info... info: Reading Phone Info.... SW ver : V 03.60 17-11-11 RH-130 (c) Nokia IMEI : 354585054429016 PPM : V 03.60 17-11-11 RH-130 (c) Nokia AE PCode : 059N2G2 BPCode : 059N126 HWID : 3051 LCDVer : TPO:BARACOAv92 HX5081 IMEI : 354585054429016 Sl Conf : 234-00-00300000000 Sl Prof : 800000000004000-2 Sl Aux : 000B0000 Hw Sig : 5FF06A7FF40714BE Country : United Kingdom Operator : Unknown Lock info: Block 1 L1:Close; L2:Close; Done! |
08-22-2014, 13:58 | #3 (permalink) |
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | i got answer....thanks Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 Boot Ok , 01 PBL : SE0_091125 F11 Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader FlashIc Size : 0x00800000 Trying dump eeprom.... Hash found 20 digits code length detected, LBF not supported... Error...! Connect phone on selected interface... |
