10-15-2014, 05:54 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: P A K I S T A N Age: 16
Member: 190344 Status: Offline Thanks Meter: 280 | why sx4 icon disable in latest InfinityBox BEST sw. how can i use sx4 server as option is disabled. i have already restored rpl. set pm file except 1 and 308 could not be written using full pm write. can i restore it using usb or i have to use fbus cable? detailed log is [CODE]card found: S/N B0......... registered to: hamid ali Connect phone on selected interface... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-596_111.040.1511_79u_prd.core.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 22E00116B3A603440C17A59D096E84BFD4D73C9C ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... 2nd boot not accepted... Alive Request not done Boot error... -> Boot fail... Flashing failed... Phone disconected! Connect phone on selected interface... Connect phone on selected interface... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-596_111.040.1511_79u_prd.core.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- -> Phone not found.. -> Boot fail... Flashing failed... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-596_111.040.1511_79u_prd.core.fpsx PPM : RM-596_111.040.1511_13.01_MEA_A_79u_prd.rofs2.fpsx PPM2 : RM-596_111.040.1511_C04.01_MEA_1_79u_prd.rofs3.fpsx CNT : RM-596_111.040.1511_U07.01_79u.uda.fpsx APE : RM596_APE_ONLY_ENO_11w36_v0.162.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 22E00116B3A603440C17A59D096E84BFD4D73C9C ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : D172C32473AE199B213465ABB3853246F9631231 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 355361040875673 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\355361040875673_CR T_2nd.rpl === SW Version Check === - > DOWNGRADE DETECTED!!! - > Download latest Flash Files version and try again! - > Stop killing phone, break flashing! === SW Version Check === ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Elapsed: 00:00:10 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia N8-00 Software ver : V 79_sr1_12w18.6 14-06-13 RM-596 (c) Nokia IMEI : 355361040875673 XappVer : 000007B2 Ape Ver : 111.040.1514 APE Var : 111.040.1514 APE ADSP: 256 DSP Ver : 92_12w18 APE Test: 0.162 PPM : CNT : Product SN : CBM533892 Product code : 059C7Q4 Base Prd.code: 0596826 Long Prod.SN : 0 Hardware info======= HWID : 7300 Retu : 35 Tahvo : 00 Batery: 4044 mV APE BT: HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. APE HW: 256 Lock info =========== IMEI : 355361040875673 IMEI spNet : 3A 55 63 01 04 78 65 07 IMEI svNet : 33 55 63 01 04 78 65 47 F6 Conf key : 8000000000000000 Provider key : 5050300014981890 Country : Australia Operator : vodafone AU Counters : Key 0 [3] , Fbus 0 [10] Blocks : 2 LOCK STATUS : ============================= BLK : 1 Lock1:Open BLK : 2 Lock1:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Resetting selected items... Operating mode is OK, no need change... Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:01 Set phone in Normal mode... Restarting... Done! Connect phone on selected interface... card found: S/N B035:0122 registered to: hamid ali Connect phone on selected interface... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-596_111.040.1511_79u_prd.core.fpsx PPM : RM-596_111.040.1511_13.01_MEA_A_79u_prd.rofs2.fpsx PPM2 : RM-596_111.040.1511_C04.01_MEA_1_79u_prd.rofs3.fpsx CNT : RM-596_111.040.1511_U07.01_79u.uda.fpsx APE : RM596_APE_ONLY_ENO_11w36_v0.162.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 22E00116B3A603440C17A59D096E84BFD4D73C9C ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : D172C32473AE199B213465ABB3853246F9631231 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 355361040875673 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\355361040875673_CR T_2nd.rpl === SW Version Check === - > DOWNGRADE DETECTED!!! - > Download latest Flash Files version and try again! - > Stop killing phone, break flashing! === SW Version Check === ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Elapsed: 00:00:09 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Will Write CCC/HWC keys now... Using : RM-596.rpl CCC Data found! HWC Data found! Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 22E00116B3A603440C17A59D096E84BFD4D73C9C ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : D172C32473AE199B213465ABB3853246F9631231 ADL: Preparing for write certificates... Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot All done, disconneting... Done! Elapsed: 00:00:04 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Backup Certificates now... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok Check communication with phone.... Reboot.... Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 22E00116B3A603440C17A59D096E84BFD4D73C9C ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : D172C32473AE199B213465ABB3853246F9631231 ADL: Reading certificates... Reading NPC certificate... IMEI : 355361040875673 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... ADL: Reading certificates done! ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... Swap data collected to 059D5C3.pc RPL saved : C:\InfinityBox\BEST\Backup\Cert\355361040875673_2n d.rpl All done, Disconnecting Elapsed: 00:00:07 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Resetting selected items... Operating mode is OK, no need change... Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:01 Phone disconected! Connect phone on selected interface... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-596_111.040.1511_79u_prd.core.fpsx PPM : RM-596_111.040.1511_13.01_MEA_A_79u_prd.rofs2.fpsx PPM2 : RM-596_111.040.1511_C04.01_MEA_1_79u_prd.rofs3.fpsx CNT : RM-596_111.040.1511_U07.01_79u.uda.fpsx APE : RM596_APE_ONLY_ENO_11w36_v0.162.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 22E00116B3A603440C17A59D096E84BFD4D73C9C ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : D172C32473AE199B213465ABB3853246F9631231 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 355361040875673 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\355361040875673_CR T_2nd.rpl === SW Version Check === - > DOWNGRADE DETECTED!!! - > Download latest Flash Files version and try again! - > Stop killing phone, break flashing! === SW Version Check === ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Elapsed: 00:00:33 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading PM from field 0 to 400 Field [1] 31 Record(s) Record 0: 10 byte(s) readed - Ok Record 1: 94 byte(s) readed - Ok Record 2: 110 byte(s) readed - Ok Record 4: 10 byte(s) readed - Ok Record 6: 110 byte(s) readed - Ok Record 7: 450 byte(s) readed - Ok Record 8: 10 byte(s) readed - Ok Record 13: 110 byte(s) readed - Ok Record 15: 30 byte(s) readed - Ok Record 16: 30 byte(s) readed - Ok Record 17: 30 byte(s) readed - Ok Record 18: 30 byte(s) readed - Ok Record 19: 30 byte(s) readed - Ok Record 22: 24 byte(s) readed - Ok Record 26: 10 byte(s) readed - Ok Record 27: 36 byte(s) readed - Ok Record 28: 110 byte(s) readed - Ok Record 29: 10 byte(s) readed - Ok Record 30: 36 byte(s) readed - Ok Record 31: 24 byte(s) readed - Ok Record 32: 216 byte(s) readed - Ok Record 33: 36 byte(s) readed - Ok Record 35: 24 byte(s) readed - Ok Record 36: 24 byte(s) readed - Ok Record 38: 216 byte(s) readed - Ok Record 39: 36 byte(s) readed - Ok Record 40: 24 byte(s) readed - Ok Record 41: 216 byte(s) readed - Ok Record 43: 36 byte(s) readed - Ok Record 44: 216 byte(s) readed - Ok Record 45: 216 byte(s) readed - Ok Field [2] 1 Record(s) Record 0: 2808 byte(s) readed - Ok Field [4] 6 Record(s) Record 1: 200 byte(s) readed - Ok Record 3: 10 byte(s) readed - Ok Record 4: 8 byte(s) readed - Ok Record 5: 8 byte(s) readed - Ok Record 9: 5 byte(s) readed - Ok Record 28: 2 byte(s) readed - Ok Field [8] 6 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 16 byte(s) readed - Ok Record 2: 16 byte(s) readed - Ok Record 3: 128 byte(s) readed - Ok Record 4: 128 byte(s) readed - Ok Record 8: 8 byte(s) readed - Ok Field [11] 5 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 4 byte(s) readed - Ok Record 2: 4 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 1059 byte(s) readed - Ok Field [12] 1 Record(s) Record 0: 8 byte(s) readed - Ok Field [31] 1 Record(s) Record 4: 10 byte(s) readed - Ok Field [44] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [50] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [54] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 2: 24 byte(s) readed - Ok Field [96] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 20 byte(s) readed - Ok Field [107] 1 Record(s) Record 26: 12 byte(s) readed - Ok Field [117] 11 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 3 byte(s) readed - Ok Record 2: 6 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 4: 9 byte(s) readed - Ok Record 5: 10 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 8: 42 byte(s) readed - Ok Record 13: 3 byte(s) readed - Ok Record 14: 3 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [120] 4 Record(s) Record 0: 88 byte(s) readed - Ok Record 1: 160 byte(s) readed - Ok Record 2: 130 byte(s) readed - Ok Record 3: 112 byte(s) readed - Ok Field [122] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [153] 6 Record(s) Record 0: 68 byte(s) readed - Ok Record 1: 68 byte(s) readed - Ok Record 2: 68 byte(s) readed - Ok Record 3: 68 byte(s) readed - Ok Record 4: 68 byte(s) readed - Ok Record 5: 68 byte(s) readed - Ok Field [193] 4 Record(s) Record 2: 8 byte(s) readed - Ok Record 3: 32 byte(s) readed - Ok Record 4: 32 byte(s) readed - Ok Record 9: 64 byte(s) readed - Ok Field [212] 2 Record(s) Record 1: 4 byte(s) readed - Ok Record 2: 4 byte(s) readed - Ok Field [217] 1 Record(s) Record 0: 32 byte(s) readed - Ok Field [239] 7 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 3817 byte(s) readed - Ok Record 2: 3817 byte(s) readed - Ok Record 3: 3817 byte(s) readed - Ok Record 4: 3817 byte(s) readed - Ok Record 5: 3817 byte(s) readed - Ok Record 6: 218 byte(s) readed - Ok Field [291] 1 Record(s) Record 0: 92 byte(s) readed - Ok Field [308] 7 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 8192 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 6: 1 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Field [309] 7 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Record 2: 12 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 12 byte(s) readed - Ok Record 7: 12 byte(s) readed - Ok Record 17: 12 byte(s) readed - Ok Field [313] 1 Record(s) Record 0: 800 byte(s) readed - Ok Field [322] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [329] 1 Record(s) Record 0: 8392 byte(s) readed - Ok Field [334] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [341] 6 Record(s) Record 0: 1 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 4516 byte(s) readed - Ok Record 10: 4 byte(s) readed - Ok Record 11: 1972 byte(s) readed - Ok Record 12: 328 byte(s) readed - Ok Field [354] 1 Record(s) Record 0: 8 byte(s) readed - Ok Field [356] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 8 byte(s) readed - Ok Field [360] 2 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Field [369] 1 Record(s) Record 0: 40 byte(s) readed - Ok Field [382] 2 Record(s) Record 0: 64 byte(s) readed - Ok Record 1: 4 byte(s) readed - Ok Field [388] 1 Record(s) Record 0: 4 byte(s) readed - Ok Saved as C:\InfinityBox\BEST\Backup\RM-596 Nokia N8-00_355361040875673_0_400.pm Done! Elapsed: 00:00:01 Reading PM from field 0 to 512 Field [1] 31 Record(s) Record 0: 10 byte(s) readed - Ok Record 1: 94 byte(s) readed - Ok Record 2: 110 byte(s) readed - Ok Record 4: 10 byte(s) readed - Ok Record 6: 110 byte(s) readed - Ok Record 7: 450 byte(s) readed - Ok Record 8: 10 byte(s) readed - Ok Record 13: 110 byte(s) readed - Ok Record 15: 30 byte(s) readed - Ok Record 16: 30 byte(s) readed - Ok Record 17: 30 byte(s) readed - Ok Record 18: 30 byte(s) readed - Ok Record 19: 30 byte(s) readed - Ok Record 22: 24 byte(s) readed - Ok Record 26: 10 byte(s) readed - Ok Record 27: 36 byte(s) readed - Ok Record 28: 110 byte(s) readed - Ok Record 29: 10 byte(s) readed - Ok Record 30: 36 byte(s) readed - Ok Record 31: 24 byte(s) readed - Ok Record 32: 216 byte(s) readed - Ok Record 33: 36 byte(s) readed - Ok Record 35: 24 byte(s) readed - Ok Record 36: 24 byte(s) readed - Ok Record 38: 216 byte(s) readed - Ok Record 39: 36 byte(s) readed - Ok Record 40: 24 byte(s) readed - Ok Record 41: 216 byte(s) readed - Ok Record 43: 36 byte(s) readed - Ok Record 44: 216 byte(s) readed - Ok Record 45: 216 byte(s) readed - Ok Field [2] 1 Record(s) Record 0: 2808 byte(s) readed - Ok Field [4] 6 Record(s) Record 1: 200 byte(s) readed - Ok Record 3: 10 byte(s) readed - Ok Record 4: 8 byte(s) readed - Ok Record 5: 8 byte(s) readed - Ok Record 9: 5 byte(s) readed - Ok Record 28: 2 byte(s) readed - Ok Field [8] 6 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 16 byte(s) readed - Ok Record 2: 16 byte(s) readed - Ok Record 3: 128 byte(s) readed - Ok Record 4: 128 byte(s) readed - Ok Record 8: 8 byte(s) readed - Ok Field [11] 5 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 4 byte(s) readed - Ok Record 2: 4 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 1059 byte(s) readed - Ok Field [12] 1 Record(s) Record 0: 8 byte(s) readed - Ok Field [31] 1 Record(s) Record 4: 10 byte(s) readed - Ok Field [44] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [50] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [54] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 2: 24 byte(s) readed - Ok Field [96] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 20 byte(s) readed - Ok Field [107] 1 Record(s) Record 26: 12 byte(s) readed - Ok Field [117] 11 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 3 byte(s) readed - Ok Record 2: 6 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 4: 9 byte(s) readed - Ok Record 5: 10 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 8: 42 byte(s) readed - Ok Record 13: 3 byte(s) readed - Ok Record 14: 3 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [120] 4 Record(s) Record 0: 88 byte(s) readed - Ok Record 1: 160 byte(s) readed - Ok Record 2: 130 byte(s) readed - Ok Record 3: 112 byte(s) readed - Ok Field [122] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [153] 6 Record(s) Record 0: 68 byte(s) readed - Ok Record 1: 68 byte(s) readed - Ok Record 2: 68 byte(s) readed - Ok Record 3: 68 byte(s) readed - Ok Record 4: 68 byte(s) readed - Ok Record 5: 68 byte(s) readed - Ok Field [193] 4 Record(s) Record 2: 8 byte(s) readed - Ok Record 3: 32 byte(s) readed - Ok Record 4: 32 byte(s) readed - Ok Record 9: 64 byte(s) readed - Ok Field [212] 2 Record(s) Record 1: 4 byte(s) readed - Ok Record 2: 4 byte(s) readed - Ok Field [217] 1 Record(s) Record 0: 32 byte(s) readed - Ok Field [239] 7 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 3817 byte(s) readed - Ok Record 2: 3817 byte(s) readed - Ok Record 3: 3817 byte(s) readed - Ok Record 4: 3817 byte(s) readed - Ok Record 5: 3817 byte(s) readed - Ok Record 6: 218 byte(s) readed - Ok Field [291] 1 Record(s) Record 0: 92 byte(s) readed - Ok Field [308] 7 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 8192 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 6: 1 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Field [309] 7 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Record 2: 12 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 12 byte(s) readed - Ok Record 7: 12 byte(s) readed - Ok Record 17: 12 byte(s) readed - Ok Field [313] 1 Record(s) Record 0: 800 byte(s) readed - Ok Field [322] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [329] 1 Record(s) Record 0: 8392 byte(s) readed - Ok Field [334] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [341] 6 Record(s) Record 0: 1 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 4516 byte(s) readed - Ok Record 10: 4 byte(s) readed - Ok Record 11: 1972 byte(s) readed - Ok Record 12: 328 byte(s) readed - Ok Field [354] 1 Record(s) Record 0: 8 byte(s) readed - Ok Field [356] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 8 byte(s) readed - Ok Field [360] 2 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Field [369] 1 Record(s) Record 0: 40 byte(s) readed - Ok Field [382] 2 Record(s) Record 0: 64 byte(s) readed - Ok Record 1: 4 byte(s) readed - Ok Field [388] 1 Record(s) Record 0: 4 byte(s) readed - Ok Saved as C:\InfinityBox\BEST\Backup\RM-596 Nokia N8-00_355361040875673_0_512.pm Done! Elapsed: 00:00:01 Initializing Tests... IMEI : 355361040875673 , Phone : RM-596 Nokia N8-00 Get keys... PASSED | ST_SLEEP_X_LOOP_TEST PASSED | ST_UEM_CBUS_IF_TEST PASSED | ST_EAR_DATA_LOOP_TEST PASSED | ST_SIM_CLK_LOOP_TEST PASSED | ST_SIM_LOCK_TEST PASSED | ST_SECURITY_TEST PASSED | ST_PWR_KEY_TEST PASSED | ST_CURRENT_CONS_TEST PASSED | ST_HOOKINT_TEST PASSED | ST_BTEMP_TEST PASSED | ST_MBUS_RX_TX_LOOP_TEST PASSED | ST_KELVIN_BATVOLTAGE_TEST PASSED | ST_KELVIN_VIBRA_TEST PASSED | ST_KELVIN_CAPACITOR_TEST PASSED | ST_KELVIN_MISC_TEST PASSED | ST_KELVIN_AUDIO_TEST PASSED | ST_KELVIN_XEAR_TEST PASSED | ST_AMB_LIGHT_SENSOR_TEST PASSED | ST_USB_CHARGING_TEST PASSED | ST_DIGIMIC_TEST PASSED | ST_HEADSET_AMPLIFIER_TEST PASSED | ST_LED_CONTROLLER_TEST PASSED | ST_AUDIO_PLL_TEST PASSED | ST_RAM_IF_TEST PASSED | ST_CDSP_SLEEPCLOCK_FREQ_TEST NOT EXECUTED | ST_CDSP_RF_BB_IF_TEST NOT EXECUTED | ST_CDSP_STROBE_TEST NOT EXECUTED | ST_CDSP_DIGI_RXTX_IF_TEST NOT EXECUTED | ST_CDSP_RF_SUPPLY_TEST NOT EXECUTED | ST_CDSP_PA_ID_PIN_TEST NOT RUN | ST_CDSP_WCDMA_TX_POWER_TEST PASSED | ST_KEYBOARD_STUCK_TEST PASSED | ST_BT_IF_TEST PASSED | ST_CAMERA_IF_TEST PASSED | ST_CAMERA_ACCELERATOR_TEST PASSED | ST_SEC_CAMERA_IF_TEST PASSED | ST_LED_FLASH_TEST PASSED | ST_CAMERA_AUTOFOCUS_TEST PASSED | ST_BT_AUDIO_IF_TEST PASSED | ST_MAIN_LCD_IF_TEST PASSED | ST_TOUCH_TEST PASSED | ST_BT_WAKEUP_TEST PASSED | ST_WLAN_TEST PASSED | ST_MASS_MEMORY_IF_TEST PASSED | ST_ACCEL_IF_TEST PASSED | ST_VIBRA_TEST NOT RUN | ST_USB_LOOP_TEST PASSED | ST_MAGNETOMETER_TEST PASSED | ST_USB_CHARGER_IF_TEST PASSED | ST_MASS_MEMORY_TEST SelfTests end Done! Elapsed: 00:00:57 User ACCEPTED FULL ERASE Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 22E00116B3A603440C17A59D096E84BFD4D73C9C ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Seek file for this phone.... - > Backup for phone found and it is Ok Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : D172C32473AE199B213465ABB3853246F9631231 Reading NPC certificate... IMEI : 355361040875673 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\355361040875673_CR T_2nd.rpl ADL: Preparing for erase... Full Erase started... Asic : CMT , Sub : NAND Erase Area 0x00000000-0x1FFFFFFF Erasing Ok , [0F] Erase done , time : 00:00:02 ADL: Erase done ADL: Close_Session Content: 000205000000000000FFFF00000000 ADL: Reboot Phone disconected! Connect phone on selected interface... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-596_014.002_79.92_prd.core.fpsx PPM : RM-596_014.002_13.01_MEA_A_79.92_prd.rofs2.fpsx PPM2 : RM-596_014.002_C04.01_MEA_1_79.92_prd.rofs3.fpsx CNT : RM-596_014.002_U08.01_79.92_prd.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 22E00116B3A603440C17A59D096E84BFD4D73C9C ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : blank (Erased or HW failure) ADL: phone is in flash mode === SW Version Check === - > Can not collect initial info, continue flashing... - > Hope, this version will be ok === SW Version Check === ===Flashing [MCU]=== Erase : Processing RM-596_014.002_79.92_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-596_014.002_79.92_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 549 blocks TIME : Write time : 00:00:22 MCU Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM]=== Erase : Processing RM-596_014.002_13.01_MEA_A_79.92_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-596_014.002_13.01_MEA_A_79.92_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 139 blocks TIME : Write time : 00:00:06 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM2]=== Erase : Processing RM-596_014.002_C04.01_MEA_1_79.92_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-596_014.002_C04.01_MEA_1_79.92_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 2 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [CNT]=== Erase : Processing RM-596_014.002_U08.01_79.92_prd.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-596_014.002_U08.01_79.92_prd.uda.fpsx Total writen 211 blocks TIME : Write time : 00:00:08 CNT Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Flashing done! Total flash time : 00:00:41 Reboot phone now... -------AFTER FLASH BREAKED BY USER------- - > AfterFlash Failed! Reason : Downgrade try or HW Error Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Elapsed: 00:02:41 Connect phone on selected interface... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : APE : RM596_APE_ONLY_ENO_11w36_v0.162.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 22E00116B3A603440C17A59D096E84BFD4D73C9C ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : D172C32473AE199B213465ABB3853246F9631231 ADL: phone is in flash mode === SW Version Check === - > REFLASHING === SW Version Check === ===Flashing [APE]=== Erase : Processing RM596_APE_ONLY_ENO_11w36_v0.162.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM596_APE_ONLY_ENO_11w36_v0.162.fpsx CMT: Writing Hash CERT [SOS*ENO] Total writen 19 blocks TIME : Write time : 00:00:00 APE Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Flashing done! Total flash time : 00:00:00 Reboot phone now... - > AfterFlash Failed! Reason : Downgrade try or HW Error Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Elapsed: 00:02:19 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Will Write CCC/HWC keys now... No any file selected, break operation Connect phone on selected interface... Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SIMLOCK Data found! SIMLOCK KEY found! WMDRM KEY found! Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- -> Phone not found.. Looks like ASIC not supported, or HW failure Supported : RapuYama, RAP3Gv4, BroadComm, RAPIDO, XG213, XG223 UFS S/N 38442 boot - Ok Connect phone on selected interface... Read and Check phone data... BB5 bus checking... Setting FlashMode FlashMode set Ok No answer from phone... - > 1. Check cable/connection, try again - > 2. Maybe HW fault or bad cable Read and Check phone data... BB5 bus checking... Setting FlashMode FlashMode set Ok No answer from phone... - > 1. Check cable/connection, try again - > 2. Maybe HW fault or bad cable Read and Check phone data... BB5 bus checking... Setting FlashMode FlashMode set Ok No answer from phone... - > 1. Check cable/connection, try again - > 2. Maybe HW fault or bad cable Read and Check phone data... BB5 bus checking... Setting FlashMode FlashMode set Ok No answer from phone... - > 1. Check cable/connection, try again - > 2. Maybe HW fault or bad cable Read and Check phone data... BB5 bus checking... Setting FlashMode FlashMode set Ok No answer from phone... - > 1. Check cable/connection, try again - > 2. Maybe HW fault or bad cable Error open UFS #38442 Error open UFS #38442 Error open UFS #38442 Error open UFS #38442 Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Files Set for Flashing : MCU : RM-596_111.040.1511_79u_prd.core.fpsx PPM : RM-596_111.040.1511_13.01_MEA_A_79u_prd.rofs2.fpsx PPM2 : RM-596_111.040.1511_C04.01_MEA_1_79u_prd.rofs3.fpsx CNT : RM-596_111.040.1511_U07.01_79u.uda.fpsx APE : RM596_APE_ONLY_ENO_11w36_v0.162.fpsx Check FlashFiles, Please, wait... -> SWversion check skipped : Dead mode selected Setting FlashMode Error open UFS #38442 - > UFSx : FlashMode init fail! Reconnect box Error open UFS #38442 Connect phone on selected interface... Connect phone on selected interface... Connect phone on selected interface... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-596_111.040.1511_79u_prd.core.fpsx PPM : RM-596_111.040.1511_13.01_MEA_A_79u_prd.rofs2.fpsx PPM2 : RM-596_111.040.1511_C04.01_MEA_1_79u_prd.rofs3.fpsx CNT : RM-596_111.040.1511_U07.01_79u.uda.fpsx APE : RM596_APE_ONLY_ENO_11w36_v0.162.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- -> Phone not found.. -> Boot fail... Flashing failed... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-596_111.040.1511_79u_prd.core.fpsx PPM : RM-596_111.040.1511_13.01_MEA_A_79u_prd.rofs2.fpsx PPM2 : RM-596_111.040.1511_C04.01_MEA_1_79u_prd.rofs3.fpsx CNT : RM-596_111.040.1511_U07.01_79u.uda.fpsx APE : RM596_APE_ONLY_ENO_11w36_v0.162.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 22E00116B3A603440C17A59D096E84BFD4D73C9C ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Transmission type request fail [000000] -> Boot error... -> Boot fail... Flashing failed... Phone disconected! Connect phone on selected interface... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-596_111.040.1511_79u_prd.core.fpsx PPM : RM-596_111.040.1511_13.01_MEA_A_79u_prd.rofs2.fpsx PPM2 : RM-596_111.040.1511_C04.01_MEA_1_79u_prd.rofs3.fpsx CNT : RM-596_111.040.1511_U07.01_79u.uda.fpsx APE : RM596_APE_ONLY_ENO_11w36_v0.162.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- -> Phone not found.. -> Boot fail... Flashing failed... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-596_111.040.1511_79u_prd.core.fpsx PPM : RM-596_111.040.1511_13.01_MEA_A_79u_prd.rofs2.fpsx PPM2 : RM-596_111.040.1511_C04.01_MEA_1_79u_prd.rofs3.fpsx CNT : RM-596_111.040.1511_U07.01_79u.uda.fpsx APE : RM596_APE_ONLY_ENO_11w36_v0.162.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 22E00116B3A603440C17A59D096E84BFD4D73C9C ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : D172C32473AE199B213465ABB3853246F9631231 ADL: phone is in flash mode === SW Version Check === - > UPGRADE === SW Version Check === ===Flashing [MCU]=== Erase : Processing RM-596_111.040.1511_79u_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-596_111.040.1511_79u_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [SOS+DECOMP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS+IVE3A] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 526 blocks TIME : Write time : 00:00:21 MCU Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM]=== Erase : Processing RM-596_111.040.1511_13.01_MEA_A_79u_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-596_111.040.1511_13.01_MEA_A_79u_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 203 blocks TIME : Write time : 00:00:09 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM2]=== Erase : Processing RM-596_111.040.1511_C04.01_MEA_1_79u_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-596_111.040.1511_C04.01_MEA_1_79u_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] CMT: Writing Hash CERT [SOS+IVE3B] Total writen 4 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [CNT]=== Erase : Processing RM-596_111.040.1511_U07.01_79u.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-596_111.040.1511_U07.01_79u.uda.fpsx Total writen 477 blocks TIME : Write time : 00:00:15 CNT Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [APE]=== Erase : Processing RM596_APE_ONLY_ENO_11w36_v0.162.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM596_APE_ONLY_ENO_11w36_v0.162.fpsx CMT: Writing Hash CERT [SOS*ENO] Total writen 19 blocks TIME : Write time : 00:00:00 APE Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Flashing done! Total flash time : 00:00:50 Reboot phone now... Reading Phone Info.... Connected phone - Nokia N8-00 Software Info: V 79_sr1_12w18.5 27-07-12 RM-596 (c) Nokia IMEI: 12345610654321? Ape Version: 111.040.1511 Product code: Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:25 Connect phone on selected interface... Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SIMLOCK Data found! SIMLOCK KEY found! WMDRM KEY found! Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 22E00116B3A603440C17A59D096E84BFD4D73C9C ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : D172C32473AE199B213465ABB3853246F9631231 ADL: Preparing for write certificates... Erase NPC... Ok Writing NPC... Ok Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Wait, reconneting... Writing SimLock Key... Ok! Writing SimLock Data... Ok! Product Code Update : 059C7Q4 SDD Key status : SDData Damaged!!!!! SimLock status : SimLock is Ok Security status : Security is Ok WMDRM_PD key sent... Ok Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Operating mode is OK, no need change... Field 1 Record 0 write - Error Record 1 write - Error Record 2 write - Error Record 4 write - Error Record 6 write - Error Record 7 write - Error Record 8 write - Error Record 13 write - Error Record 15 write - Error Record 16 write - Error Record 17 write - Error Record 18 write - Error Record 19 write - Error Record 22 write - Error Record 26 write - Error Record 27 write - Error Record 28 write - Error Record 29 write - Error Record 30 write - Error Record 31 write - Error Record 32 write - Error Record 33 write - Error Record 35 write - Error Record 36 write - Error Record 38 write - Error Record 39 write - Error Record 40 write - Error Record 41 write - Error Record 43 write - Error Record 44 write - Error Record 45 write - Error Field 2 Record 0 write - Ok Field 4 Record 1 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 9 write - Ok Record 28 write - Ok Field 8 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 8 write - Ok Field 11 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Field 12 Record 0 write - Ok Field 31 Record 4 write - Ok Field 44 Record 0 write - Ok Field 50 Record 0 write - Ok Field 54 Record 0 write - Ok Record 2 write - Ok Field 96 Record 0 write - Ok Record 1 write - Ok Field 107 Record 26 write - Ok Field 117 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Record 8 write - Ok Record 13 write - Ok Record 14 write - Ok Record 16 write - Ok Field 120 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Field 122 Record 0 write - Ok Field 153 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Field 193 Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 9 write - Ok Field 212 Record 1 write - Ok Record 2 write - Ok Field 217 Record 0 write - Ok Field 239 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Record 4 write - Ok Record 5 write - Ok Record 6 write - Ok Field 291 Record 0 write - Ok Field 308 Record 0 write - Error Record 1 write - Error Record 3 write - Error Record 4 write - Error Record 6 write - Error Record 7 write - Error Record 9 write - Error Field 309 Record 0 write - Error Record 1 write - Error Record 2 write - Error Record 3 write - Error Record 4 write - Error Record 7 write - Error Record 17 write - Error Field 313 Record 0 write - Ok Field 322 Record 0 write - Ok Field 329 Record 0 write - Ok Field 334 Record 0 write - Ok Field 341 Record 0 write - Ok Record 3 write - Ok Record 4 write - Ok Record 10 write - Ok Record 11 write - Ok Record 12 write - Ok Field 354 Record 0 write - Ok Field 356 Record 0 write - Ok Record 1 write - Ok Field 360 Record 0 write - Ok Record 1 write - Ok Field 369 Record 0 write - Ok Field 382 Record 0 write - Ok Record 1 write - Ok Field 388 Record 0 write - Ok Done! Elapsed: 00:00:01 Checking Camera Configuration... Operating mode is OK, no need change... Primary Camera #1 configuration info not exist Secondary Camera #2 configuration info not exist Done! Phone disconected! Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 22E00116B3A603440C17A59D096E84BFD4D73C9C ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : D172C32473AE199B213465ABB3853246F9631231 ADL: phone is in flash mode Reading NPC certificate... IMEI : 355361040875673 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\355361040875673_CR T_2nd.rpl Trying read spr block , wait ... Get phone data... Get flash data... Spr read failed on #2 step [Absent data] ADL: Close_Session ADL: Reboot Error on SPR reading Connect phone on selected interface... Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SIMLOCK Data found! SIMLOCK KEY found! WMDRM KEY found! Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 22E00116B3A603440C17A59D096E84BFD4D73C9C ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : D172C32473AE199B213465ABB3853246F9631231 ADL: Preparing for write certificates... Erase NPC... Ok Writing NPC... Ok Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Wait, reconneting... Writing SimLock Key... Ok! Writing SimLock Data... Ok! Product Code Update : 059C7Q4 SDD Key status : SDData Damaged!!!!! SimLock status : SimLock is Ok Security status : Security is Ok WMDRM_PD key sent... Ok Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Will Write CCC/HWC keys now... Using : RM-596.rpl CCC Data found! HWC Data found! Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- -> Phone not found.. Looks like ASIC not supported, or HW failure Supported : RapuYama, RAP3Gv4, BroadComm - > If phone is RAPIDO - Use Dead mode for it ;D Connect phone on selected interface... Phone not connected... Connect phone and try again... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-596_111.040.1511_79u_prd.core.fpsx PPM : RM-596_111.040.1511_13.01_MEA_A_79u_prd.rofs2.fpsx PPM2 : RM-596_111.040.1511_C04.01_MEA_1_79u_prd.rofs3.fpsx CNT : RM-596_111.040.1511_U07.01_79u.uda.fpsx APE : RM596_APE_ONLY_ENO_11w36_v0.162.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 22E00116B3A603440C17A59D096E84BFD4D73C9C ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : D172C32473AE199B213465ABB3853246F9631231 ADL: phone is in flash mode === SW Version Check === - > REFLASHING === SW Version Check === ===Flashing [MCU]=== Erase : Processing RM-596_111.040.1511_79u_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-596_111.040.1511_79u_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [SOS+DECOMP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS+IVE3A] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 526 blocks TIME : Write time : 00:00:21 MCU Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM]=== Erase : Processing RM-596_111.040.1511_13.01_MEA_A_79u_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-596_111.040.1511_13.01_MEA_A_79u_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 203 blocks TIME : Write time : 00:00:09 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM2]=== Erase : Processing RM-596_111.040.1511_C04.01_MEA_1_79u_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-596_111.040.1511_C04.01_MEA_1_79u_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] CMT: Writing Hash CERT [SOS+IVE3B] Total writen 4 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [CNT]=== Erase : Processing RM-596_111.040.1511_U07.01_79u.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-596_111.040.1511_U07.01_79u.uda.fpsx Write error : Connection lost => HW error or Cable problem... Write CMT failed on block 452 Connect phone on selected interface... Elapsed: 00:01:17 Connect phone on selected interface... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-596_111.040.1511_79u_prd.core.fpsx PPM : RM-596_111.040.1511_13.01_MEA_A_79u_prd.rofs2.fpsx PPM2 : RM-596_111.040.1511_C04.01_MEA_1_79u_prd.rofs3.fpsx CNT : RM-596_111.040.1511_U07.01_79u.uda.fpsx APE : RM596_APE_ONLY_ENO_11w36_v0.162.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : Verify Error -> Error answer from BootRom -> Boot fail... Flashing failed... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-596_111.040.1511_79u_prd.core.fpsx PPM : RM-596_111.040.1511_13.01_MEA_A_79u_prd.rofs2.fpsx PPM2 : RM-596_111.040.1511_C04.01_MEA_1_79u_prd.rofs3.fpsx CNT : RM-596_111.040.1511_U07.01_79u.uda.fpsx APE : RM596_APE_ONLY_ENO_11w36_v0.162.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- -> Phone not found.. -> Boot fail... Flashing failed... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-596_111.040.1511_79u_prd.core.fpsx PPM : RM-596_111.040.1511_13.01_MEA_A_79u_prd.rofs2.fpsx PPM2 : RM-596_111.040.1511_C04.01_MEA_1_79u_prd.rofs3.fpsx CNT : RM-596_111.040.1511_U07.01_79u.uda.fpsx APE : RM596_APE_ONLY_ENO_11w36_v0.162.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 22E00116B3A603440C17A59D096E84BFD4D73C9C ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : D172C32473AE199B213465ABB3853246F9631231 ADL: phone is in flash mode === SW Version Check === - > REFLASHING === SW Version Check === ===Flashing [MCU]=== Erase : Processing RM-596_111.040.1511_79u_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-596_111.040.1511_79u_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [SOS+DECOMP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS+IVE3A] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] Write error : Connection lost => HW error or Cable problem... Write CMT failed on block 86 Connect phone on selected interface... Elapsed: 00:00:11 Connect phone on selected interface... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-596_111.040.1511_79u_prd.core.fpsx PPM : RM-596_111.040.1511_13.01_MEA_A_79u_prd.rofs2.fpsx PPM2 : RM-596_111.040.1511_C04.01_MEA_1_79u_prd.rofs3.fpsx CNT : RM-596_111.040.1511_U07.01_79u.uda.fpsx APE : RM596_APE_ONLY_ENO_11w36_v0.162.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : Verify Error -> Error answer from BootRom -> Boot fail... Flashing failed... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-596_111.040.1511_79u_prd.core.fpsx PPM : RM-596_111.040.1511_13.01_MEA_A_79u_prd.rofs2.fpsx PPM2 : RM-596_111.040.1511_C04.01_MEA_1_79u_prd.rofs3.fpsx CNT : RM-596_111.040.1511_U07.01_79u.uda.fpsx APE : RM596_APE_ONLY_ENO_11w36_v0.162.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- -> Phone not found.. -> Boot fail... Flashing failed... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-596_111.040.1511_79u_prd.core.fpsx PPM : RM-596_111.040.1511_13.01_MEA_A_79u_prd.rofs2.fpsx PPM2 : RM-596_111.040.1511_C04.01_MEA_1_79u_prd.rofs3.fpsx CNT : RM-596_111.040.1511_U07.01_79u.uda.fpsx APE : RM596_APE_ONLY_ENO_11w36_v0.162.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done |
10-15-2014, 07:57 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Please, not post miles of logs , Repair SDD, as SW ask and SX4 after will be enabled. |
The Following User Says Thank You to Dzirt For This Useful Post: |
