11-24-2017, 07:28 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | WinUSB Driver issue with Lumia 640 LTE Today am trying to connect a Lumia 640 LTE RM1073 in normal m ode all I see in device manager is three unknoen devices with yellow circled exclamation mark named : Lumia 640 LTE (RM.1073) same name for the three. I installed the lumia 2016 drivers (all) from support Installed Zune, WMDC, Windows Device Recovery Tool, etc and there is no way to make the device to be catched by drivers. is there a way to forcely install de correct driver ? PS: Same issue in two different computers, both runing windows 7 64bit. PS2: I have worked othe rLumia phones in these computers before... |
11-24-2017, 08:19 | #2 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Hello I managed to forcedly install the WinUSB Drivers I found a folder in "program files" which had some drivers and I manually installed from there. I selected all as WinUSB and it worked, I entered Test mode using secwim file and after test mode is set I had to install same drivers to all devices and all went well. I uploaded the drivers here just in case anyone need to do the same. Code: ****************************/file/t9fn9d365i6tgnb/lumia%20drivers%20to%20force%20install%20use%20WinUSB.rar |
The Following User Says Thank You to yurais For This Useful Post: |
07-19-2018, 03:32 | #3 (permalink) | |
Freak Poster Join Date: Nov 2014 Location: venezuela
Member: 2299654 Status: Offline Thanks Meter: 25 | Quote:
hello .. I have the same problem I can not install the 3 drivers .. you can help me .. my email is hxc*****[email protected] .. regards | |
07-20-2018, 03:22 | #6 (permalink) | |
Unlock Done | |
07-20-2018, 04:09 | #7 (permalink) | |
Member: 220595 Status: Offline Thanks Meter: 355 | Quote:
Enviado desde mi SM-G930F mediante Tapatalk | |
