World First ! Nokia 105 (2017) TA-1034 Read Info / Reset User Lock Done :) World First ! Nokia 105 (2017) TA-1034 Read Info / Reset User Lock Done Code: Connect phone on selected interface... |
hop get Firmware Reader/Maker for this model and nokia 3310 soon |
hop get Firmware Reader/Maker for this model Nokia 105 single sim TA-1010 and Dual sim TA-1034 and nokia 3310 soon thank you very much ,,,,,,,,,,,,,,,,,,,,,,,,,,,Infinity-Box team ,,,,,,,,,,,,,,,,,,,,,,, |
We work on them. Soon you will get those device support. |
thanks JayDi reply good news ,, thank you very much ............brother |
can you add a function for repair imei ? i think that a repair imei even with credit will be successful even for this cheap phone can you do that ? |
Hi ALL I need firmware Nokia 105 TA-1034 have Thai language . pLs support me. |
nokia TA-1034 user code don --- Insert USB cable now! --- Wait for phone... Phone found! [ 66 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : CFAD0E9EE586C0DE7FE1CFF349E5A72A BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
Ta-1010 firnware needed? how to flash this mobile problem hang on logo?. |
how can i flash this phone i have 1000 phones in hand plzzz i need change language plz help sir |
Flashing not supported yet. Rest functions work. |
Nokia 105 RT-1034 Reset Done Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : F6ED5112EF4693EE4D41AEBB BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 15 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : F5F7EA323CF64EDB127CE19D6E09B056 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
wich exe u used .......... |
