08-29-2017, 14:22 | #1 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | World First ! Nokia 105 (2017) TA-1034 Read Info / Reset User Lock Done :) World First ! Nokia 105 (2017) TA-1034 Read Info / Reset User Lock Done Code: Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 10.02.11 00-00-00 TA-1034 IMEI 1 : 3573210842643xx IMEI 2 : 3573210842643xx XappVer : 000008F2 Ape Ver : NEMO G 4122fe8d/1 (00000000+0) T Thu Dec 29 01:31:09 2016 U d61db836 PPM : IJ CNT : N103.10.02.11.p1 Product SN : 15B9F7EBU Product code : 059Z0X8 Base Prd.code: 059X9M9 Module code : 0207195 Hardware info======= HWID : 1000 LCDVer: TPO Lock info =========== IMEI : 3573210842643xx IMEI spNet : 3A 75 23 01 48 62 34 32 Conf key : 800000000004000B Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; SimLock status : Ok Security status : Ok Done! Software Info: 10.02.11 00-00-00 TA-1034 IMEI: 3573210842643xx PPM version : IJ Product code: 059Z0X8 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 140 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 536F703817DF3C414EA92B0ED672742D BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
The Following 14 Users Say Thank You to syed tuqeer For This Useful Post: |
09-01-2017, 18:27 | #3 (permalink) |
Freak Poster Join Date: Jan 2004 Location: hong kong Age: 56
Member: 51463 Status: Offline Sonork: 100.1596671 Thanks Meter: 29 | hop get Firmware Reader/Maker for this model Nokia 105 single sim TA-1010 and Dual sim TA-1034 and nokia 3310 soon thank you very much ,,,,,,,,,,,,,,,,,,,,,,,,,,,Infinity-Box team ,,,,,,,,,,,,,,,,,,,,,,, |
The Following User Says Thank You to kin88 For This Useful Post: |
09-14-2017, 12:14 | #7 (permalink) | |
Freak Poster Join Date: Oct 2016 Location: PAKISTAN Age: 30
Member: 2641847 Status: Offline Sonork: 1678650 Thanks Meter: 135 | Quote:
The Following User Says Thank You to Faizan2147 For This Useful Post: |
10-21-2017, 08:46 | #9 (permalink) |
Freak Poster Join Date: Jan 2007 Location: karor lal-esan pakistan
Member: 427028 Status: Offline Sonork: 100.1639042 Thanks Meter: 63 | nokia TA-1034 user code don --- Insert USB cable now! --- Wait for phone... Phone found! [ 66 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : CFAD0E9EE586C0DE7FE1CFF349E5A72A BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
The Following User Says Thank You to haydernaz For This Useful Post: |
12-02-2017, 18:51 | #11 (permalink) |
Freak Poster Join Date: Jul 2011 Location: Portugal
Member: 1618416 Status: Offline Thanks Meter: 27 | how can i flash this phone i have 1000 phones in hand plzzz i need change language plz help sir |
The Following User Says Thank You to s4s_s4me For This Useful Post: |
12-06-2017, 09:05 | #13 (permalink) |
Freak Poster Join Date: Apr 2012 Location: pakisatan
Member: 1748563 Status: Offline Sonork: 1644958 Thanks Meter: 29 | Nokia 105 RT-1034 Reset Done Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : F6ED5112EF4693EE4D41AEBB BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... Last edited by imranazeem01; 12-06-2017 at 09:07. Reason: Nokia 105 AT-1034 Reaset |
The Following 2 Users Say Thank You to imranazeem01 For This Useful Post: |
12-09-2017, 13:35 | #14 (permalink) |
Junior Member Join Date: Jan 2015 Location: lalganj raebareli up
Member: 2336079 Status: Offline Thanks Meter: 8 | Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 15 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : F5F7EA323CF64EDB127CE19D6E09B056 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
The Following User Says Thank You to sanjay4llg2 For This Useful Post: |
