11-12-2018, 06:59 | #32 (permalink) |
Freak Poster Join Date: Dec 2007 Location: my dream
Member: 664744 Status: Offline Thanks Meter: 156 | Code: Reconnect Power/Cable! Operation : Reset Settings [ v1.08 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM29) MODE : NOKIA USB SERIAL PORT : 29 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : ECE93557BD84CA11158BF562BCE6700D BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.10.02.11.p1 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.10.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4,00 MB ] PSIZE : 0x00400000 [ 4,00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00370000 : 0x00088000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:23 Reconnect Power/Cable! done thx JayDi |
12-07-2018, 15:19 | #33 (permalink) | |
Junior Member Join Date: Jan 2010 Location: INDONESIA
Member: 1198667 Status: Offline Thanks Meter: 4 | Quote:
09-08-2019, 12:40 | #38 (permalink) |
Freak Poster Join Date: Jun 2008 Location: alex
Member: 793406 Status: Offline Sonork: 100.1647095 Thanks Meter: 68 | --- Insert USB cable now! --- Wait for phone... Phone found! [ 12 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 0F20F8FC6899CB64780DAD7175BDB934 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface... |
The Following User Says Thank You to medo_mshakel For This Useful Post: |
11-17-2020, 10:02 | #40 (permalink) |
Insane Poster Join Date: Jan 2008 Location: india,iran
Member: 685274 Status: Offline Thanks Meter: 19 | 3 diffrent ta-1034 same problem i cant reset code or read info on 2 different pc and 3 mobile... same error log: Wait for phone... Phone found! [ 152 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : FB4E63412E52CC56108024434D5782A1 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL failed! (CMD not accepted, 0x00) Check Power / Cable! BootLoader Init Failed (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:44 Reconnect Power/Cable! |
11-17-2020, 20:29 | #41 (permalink) | |
Result ? | |
